20.135.5
20.135.5
    AMASS(艾迈斯)
20.135.5 数据手册
1 www.china-amass.com www.china-amass.com 2 3 www.china-amass.com www.china-amass.com 4 5 www.china-amass.com www.china-amass.com 6 P9-14 P24-26 P34-38 P15-20 P27-31 7 www.china-amass.com P32-33 P39-41 P45-47 P21-23 P42-44 P48 www.china-amass.com 8 测试钩 ( 针、探笔 )Test Probe & Clip 20.132. * 材质 塑壳 :PA 主体 : 铜 表面:镀金 电气性能 :30Vac-60Vdc/Max.2A 1 2 3 4 5 Feature Mini test clip with pin connection.Specially for the thin wires and samll terminals. Material Insulator:PA Body:Brass Surface:Gold plated Rated voltage/current: 30Vac-60Vdc/Max.2A 20.135. * 材质 塑壳 :PA 主体 : 铜 表面:镀金 电气性能 :30Vac-60Vdc/Max.10A 1 2 3 4 5 Feature Mini test clip with solder connection.Press with the good feeling and contact hook for wires up easily. Material Insulator:PA Body:Brass Rated voltage/current: 30Vac-60Vdc/Max.10A 20.155. * 材质 塑壳 :PA 主体 : 铜和不锈钢 电气性能 :CATII 600V/Max.1A 1 Feature Safety test probe with 4mm socket connection. Sharp stainless steel needle. 2 Material Insulator:PA Body:Stainless steel & Brass Rated voltage/current: CATII 600V/Max.1A 20.156. * 材质 塑壳 :PA 主体 : 铜和不锈钢 电气性能 :CATII 1000V/Max.10A 1 9 www.china-amass.com 2 3 4 5 Feature Safety test probe with 4mm socket connection. Sharp stainless steel tip with the perfectly protective cap. www.china-amass.com Material Insulator:PA Body:Stainless steel & Brass Rated voltage/current: CATII 1000V/Max.10A 10 测试钩 ( 针、探笔 )Test Probe & Clip 20.157. * 材质 测试钩 ( 针、探笔 )Test Probe & Clip 20.163. * 塑壳 :PA 主体 : 铜 弹片 : 铍铜 表面 : 镀镍 电气性能 :CATII 1000V/Max.32A 1 2 3 4 5 Feature Safety test probe with 4mm socket connection. Spring-loaded tip with the protective cap. Material Insulator:PA Body:Brass Spring:Beryllium copper Surface:Nickel plated Rated voltage/current: CATII 1000V/Max.32A 20.160. * 材质 塑壳 :PA 主体 : 不锈钢和铜 电气性能 :CATIII 1000V/Max.10A 1 2 Feature Safety test probe with 4mm socket connection. Stainless steel tip can connect with the wire without cutting it. Material Insulator:PA Body:Stainless steel & Brass Rated voltage/current: CATIII 1000V/Max.10A 20.164. * 材质 材质 塑壳 :PA 主体 : 不锈钢和铜 电气性能 :30Vac-60Vdc/Max.1A 1 2 3 4 5 Feature Safety test probe with 4mm socket connection. Sharp stainless steel needle. Material Insulator:PA Body:Stainless steel & Brass Rated voltage/current: 30Vac-60Vdc/Max.1A 塑壳 :PA 主体 : 不锈钢和铜 电气性能 :CATIII 1000V/Max.10A 1 2 Feature Safety test probe with 4mm socket connection. Sharp stainless steel tip with the protective cap. 20.168. * 20.161. * 材质 材质 1 2 3 4 5 Feature Safety test probe with 4mm socket connection. Sharp stainless steel needle. 塑壳 :PA 主体 : 不锈钢和铜 电气性能 :30Vac-60Vdc/Max.1A 塑壳 :PA 主体 : 铜和不锈钢 表面 : 镀镍 电气性能 :CATIII 1000V/Max.10A Material Insulator:PA Body:Stainless steel & Brass Rated voltage/current: 30Vac-60Vdc/Max.1A Material Insulator:PA Body:Brass & Stainless steel Surface:Nickel plated Rated voltage/current: CATIII 1000V/Max.10A 20.162. * 1 11 2 Material Insulator:PA Body:Stainless steel & Brass Rated voltage/current: CATIII 1000V/Max.10A 1 2 Feature Safety test probe with 4mm socket connection.Stainless steel tip can connect with the wire without cutting it. 20.169. * 3 Feature Safety test clip with 4mm socket connection. Long sharp stainless steel tip and flexible spring with the silicone tube can meet kinds of your request. www.china-amass.com 材质 材质 塑壳 :PA 主体 : 不锈钢和铜 电气性能 :30Vac-60Vdc/Max.10A 塑壳 :PA 主体 : 铜和不锈钢 电气性能 :CATIII 1000V/Max.10A Material Insulator:PA Body:Stainless steel & Brass Rated voltage/current: 30Vac-60Vdc/Max.10A 1 2 Feature Safety test clip with 4mm socket connection.Flexible spring with the tube can contact the wires and terminals even at the corner. www.china-amass.com Material Insulator:PA Body:Brass & Stainless steel Rated voltage/current: CATIII 1000V/Max.10A 12 测试钩 ( 针、探笔 )Test Probe & Clip 20.170. * 材质 测试钩 ( 针、探笔 )Test Probe & Clip 20.601. * 塑壳 :PA 主体 : 铜和不锈钢 电气性能 :CATIII 1000V/Max.20A 1 2 3 4 Feature Safety test clip with 4mm socket connection. The clip can connect the terminals easily. 5 Material Insulator:PA Body:Brass & Stainless steel Rated voltage/current: CATIII 1000V/Max.10A Feature Safety test lead one end with the insulated 4mm spring loaded test probe and the other end with the insulated 4mm angled plug.Nickel plated plugs with the protective cap. Red+Black as a set. Rated voltage/current: CATIII 1000V/10A 1 0.75mm2 PVC 100 2 20.602. * 20.171. * 材质 塑壳 :PA 主体 : 铜和不锈钢 电气性能 :CATIII 1000V/Max.10A 1 Feature Safety test clip with 4mm socket connection.Flexible spring with the tube can contact the wires and terminals even at the corner. 2 Material Insulator:PA Body:Brass & Stainless steel Rated voltage/current: CATIII 1000V/Max.10A Feature Safety test lead one end with the insulated test probe and the other end with the insulated 4mm angled plug.Nickel plated plugs with the protective cap. Red+Black as a set. 1 2 Rated voltage/current: CATIII 1000V/10A 0.75mm2 PVC 100 20.211. * 材质 塑壳 :PA 主体 : 铜 表面 : 镀镍 电气性能 :CATIII 1000V/Max.20A 090.0058 1 2 3 4 5 Feature Safety test probe with 4mm socket connection on both end.Fuse inside. Material Insulator:PA Body:Brass Rated voltage/current: CATIII 1000V/Max.20A 20.212. * 材质 塑壳 :PA 主体 : 铜 电气性能 :CATIII 1000V/Max.20A 090.0058 1 13 2 3 4 5 Material Insulator:PA Feature Body:Brass Safety test probe with 4mm socket connection. Spring loaded Rated voltage/current: side with the shrinkable tube.Fuse inside. CATIII 1000V/Max.20A www.china-amass.com www.china-amass.com 14 香蕉插头 Banana Plug 25.205. * 25.201. * 材质 Material 塑壳 Insulator: PVC 主体 Body: 铜 Brass 弹片 Spring: 铍铜 Beryllium copper 表面 Surface: 镀金 Gold plated * 焊接 Solder connection 电气性能 Rated voltage/current 30Vac-60Vdc/Max.10A 1 2 4 5 3 25.202. * 材质 Material 塑壳 Insulator: PVC 主体 Body: 铜 Brass 弹片 Spring: 铍铜 Beryllium copper 表面 Surface: 镀金 Gold plated * 焊接 Solder connection 电气性能 Rated voltage/current 30Vac-60Vdc/Max.10A 1 2 4 5 3 25.206. * 材质 Material 塑壳 Insulator: PE 主体 Body: 铜 Brass 弹片 Spring: 铍铜 Beryllium copper 表面 Surface: 镀金 Gold plated * 焊接 Solder connection 电气性能 Rated voltage/current 30Vac-60Vdc/Max.12A 1 2 4 5 3 25.203. * 材质 Material 塑壳 Insulator: PE 主体 Body: 铜 Brass 弹片 Spring: 铍铜 Beryllium copper 表面 Surface: 镀金 Gold plated * 焊接 Solder connection 电气性能 Rated voltage/current 30Vac-60Vdc/Max.10A 1 2 4 5 3 25.207. * 材质 Material 塑壳 Insulator: PE 主体 Body: 铜 Brass 弹片 Spring: 铍铜 Beryllium copper 表面 Surface: 镀金 Gold plated * 焊接 Solder connection 电气性能 Rated voltage/current 30Vac-60Vdc/Max.10A 材质 Material 塑壳 Insulator: PE 主体 Body: 铜 Brass 弹片 Spring: 铍铜 Beryllium copper 表面 Surface: 镀金 Gold plated * 焊接 Solder connection 电气性能 Rated voltage/current 30Vac-60Vdc/Max.10A 1 2 4 5 3 1 2 4 5 3 25.208. * 25.204. * 材质 Material 塑壳 Insulator: PA 主体 Body: 铜 Brass 弹片 Spring: 铍铜 Beryllium copper 表面 Surface: 镀镍 Nickel plated * 焊接 Solder connection 电气性能 Rated voltage/current CATII 600V/Max.10A 材质 Material 塑壳 Insulator: PE 主体 Body: 铜 Brass 表面 Surface: 镀镍 Nickel plated * 焊接 Solder connection 电气性能 Rated voltage/current 30Vac-60Vdc/Max.10A 15 www.china-amass.com 1 2 4 5 3 1 2 4 5 www.china-amass.com 3 16 香蕉插头 Banana Plug 25.401. * 4 2 材质 Material 塑壳 Insulator: ABS 主体 Body: 铜 Brass 弹片 Spring: 锰钢 Steel 表面 Surface: 镀金 Gold plated 电气性能 Rated voltage/current 30Vac-60Vdc/Max.24A 3 1 5 25.402. * 2 25.410. * 2 4 5 3 25.403. * 2 4 5 25.404. * 4 17 2 5 材质 Material 塑壳 Insulator: ABS 主体 Body: 铜 Brass 弹片 Spring: 锰钢 Steel 表面 Surface: 镀金 Gold plated 电气性能 Rated voltage/current 30Vac-60Vdc/Max.32A 1 2 25.419. * 材质 Material 塑壳 Insulator: ABS 主体 Body: 铜 Brass 弹片 Spring: 锰钢 Steel 表面 Surface: 镀金 Gold plated 电气性能 Rated voltage/current 30Vac-60Vdc/Max.32A 材质 Material 塑壳 Insulator: PVC 主体 Body: 铜 Brass 表面 Surface: 镀镍 Nickel plated * 螺丝压接 Screw connection 电气性能 Rated voltage/current 30Vac-60Vdc/Max.32A 3 1 2 3 4 5 6 4 5 6 1 25.415. * 2 25.420. * 材质 Material 塑壳 Insulator: PVC 主体 Body: 铜 Brass 弹片 Spring: 铍铜 Beryllium copper 表面 Surface: 镀镍 Nickel plated * 螺丝压接 Screw connection 电气性能 Rated voltage/current 30Vac-60Vdc/Max.24A 材质 Material 塑壳 Insulator: ABS 主体 Body: 铜 Brass 表面 Surface: 镀镍 Nickel plated * 螺丝压接 Screw connection 电气性能 Rated voltage/current 30Vac-60Vdc/Max.24A 材质 Material 塑壳 Insulator: PVC 主体 Body: 铜 Brass 表面 Surface: 镀镍 Nickel plated * 螺丝压接 Screw connection 电气性能 Rated voltage/current 30Vac-60Vdc/Max.24A 1 2 3 1 2 3 1 2 4 5 6 4 5 6 4 5 25.416. * 25.412. * 3 3 6 2 1 2 3 4 5 6 www.china-amass.com 3 25.422. * 材质 Material 塑壳 Insulator: PVC 主体 Body: 铜 Brass 弹片 Spring: 铍铜 Beryllium copper 表面 Surface: 镀镍 Nickel plated * 螺丝压接 Screw connection 电气性能 Rated voltage/current 30Vac-60Vdc/Max.24A 材质 Material 塑壳 Insulator: ABS 主体 Body: 铜 Brass 弹片 Spring: 锰钢 Steel 表面 Surface: 镀镍 Nickel plated 电气性能 Rated voltage/current 30Vac-60Vdc/Max.32A 1 2 5 1 25.411. * 3 1 4 材质 Material 塑壳 Insulator: PVC 主体 Body: 铜 Brass 弹片 Spring: 钢 Steel 表面 Surface: 镀镍 Nickel plated * 螺丝压接 Screw connection 电气性能 Rated voltage/current 30Vac-60Vdc/Max.24A 材质 Material 塑壳 Insulator: PE 主体 Body: 铜 Brass 弹片 Spring: 铍铜 Beryllium copper 表面 Surface: 镀镍 Nickel plated * 螺丝压接 Screw connection 电气性能 Rated voltage/current 30Vac-60Vdc/Max.32A 1 材质 Material 塑壳 Insulator: PVC 主体 Body: 铜 Brass 弹片 Spring: 磷铜 Phosphorus copper 表面 Surface: 镀镍 Nickel plated * 螺丝压接 Screw connection 电气性能 Rated voltage/current 30Vac-60Vdc/Max.32A 25.414. * 材质 Material 塑壳 Insulator: ABS 主体 Body: 铜 Brass 弹片 Spring: 磷铜 Phosphorus copper 表面 Surface: 镀镍 Nickel plated * 焊接 Solder connection 电气性能 Rated voltage/current 30Vac-60Vdc/Max.19A 1 25.418. * 25.413. * 25.405. * 材质 Material 塑壳 Insulator: ABS 主体 Body: 铜 Brass 弹片 Spring: 铍铜 Beryllium copper 表面 Surface: 镀镍 Nickel plated * 螺丝压接 Screw connection 电气性能 Rated voltage/current 30Vac-60Vdc/Max.24A 1 香蕉插头 Banana Plug 材质 Material 塑壳 Insulator: PA 主体 Body: 铜 Brass 弹片 Spring: 铍铜 Beryllium copper 表面 Surface: 镀镍 Nickel plated * 焊接 Solder connection 电气性能 Rated voltage/current 30Vac-60Vdc/Max.24A 材质 Material 塑壳 Insulator: PVC 主体 Body: 铜 Brass 弹片 Spring: 铍铜 Beryllium copper 表面 Surface: 镀镍 Nickel plated 电气性能 Rated voltage/current 30Vac-60Vdc/Max.32A 1 2 3 1 2 4 5 6 4 5 www.china-amass.com 3 18 香蕉插头 Banana Plug 香蕉插头 Banana Plug 25.425. * 25.431. * 25.451. * 2 4 5 3 25.426. * 1 2 4 5 3 25.432. * 2 4 5 3 25.427. * 1 2 4 5 3 25.433. * 4 2 19 2 4 5 3 1000V 1 2 4 5 3 2 材质 Material 塑壳 Insulator: PA 主体 Body: 铜 Brass 弹片 Spring: 铍铜 Beryllium copper 表面 Surface: 镀镍 Nickel plated 电气性能 Rated voltage/current 30Vac-60Vdc/Max.32A 2 25.501. * 4 5 www.china-amass.com 3 2 3 4 5 6 7 8 9 0 材质 Material 塑壳 Insulator: PA 主体 Body: 铜 Brass 弹片 Spring: 铍铜 Beryllium copper 表面 Surface: 镀镍 Nickel plated * 焊接 Solder connection 电气性能 Rated voltage/current CATII 1000V/Max.32A 1 2 4 5 3 25.504. * 材质 Material 塑壳 Insulator: PA 主体 Body: 铜 Brass 弹片 Spring: 铍铜 Beryllium copper 表面 Surface: 镀镍 Nickel plated * 焊接 Solder connection 电气性能 Rated voltage/current CATII 1000V/Max.32A 1 2 4 5 3 25.505. * 材质 Material 塑壳 Insulator: PA 主体 Body: 铜 Brass 弹片 Spring: 铍铜 Beryllium copper 表面 Surface: 镀镍 Nickel plated * 焊接 Solder connection 电气性能 Rated voltage/current CATII 600V/Max.32A 材质 Material 塑壳 Insulator: PA 主体 Body: 铜 Brass 弹片 Spring: 铍铜 Beryllium copper 表面 Surface: 镀镍 Nickel plated * 焊接 Solder connection 电气性能 Rated voltage/current CATII 600V/Max.32A 1 1 材质 Material 塑壳 Insulator: PA 主体 Body: 铜 Brass 弹片 Spring: 铍铜 Beryllium copper 表面 Surface: 镀镍 Nickel plated 电气性能 Rated voltage/current 30Vac-60Vdc/Max.32A 1 5 材质 Material 塑壳 Insulator: PA 主体 Body: 铜 Brass 弹片 Spring: 铍铜 Beryllium copper 表面 Surface: 镀镍 Nickel plated * 焊接 Solder connection 电气性能 Rated voltage/current CATII 600V/Max.32A 25.503. * 3 材质 Material 塑壳 Insulator: PVC 主体 Body: 铜 Brass 表面 Surface: 镀镍 Nickel plated * 螺丝压接 Screw connection 电气性能 Rated voltage/current 30Vac-60Vdc/Max.24A 1 5 25.454. * 25.450. * 25.430. * 4 3 材质 Material 塑壳 Insulator: ABS 主体 Body: 铜 Brass 表面 Surface: 镀镍 Nickel plated 电气性能 Rated voltage/current 30Vac-60Vdc/Max.32A 1 2 2 材质 Material 塑壳 Insulator: PVC 主体 Body: 铜 Brass 表面 Surface: 镀镍 Nickel plated 电气性能 Rated voltage/current 30Vac-60Vdc/Max.24A 材质 Material 塑壳 Insulator: PE 主体 Body: 铜 Brass 弹片 Spring: 铍铜 Beryllium copper 表面 Surface: 镀镍 Nickel plated 电气性能 Rated voltage/current 30Vac-60Vdc/Max.32A 1 1 25.452. * 材质 Material 塑壳 Insulator: PE 主体 Body: 铜 Brass 弹片 Spring: 钢 Steel 表面 Surface: 镀镍 Nickel plated * 焊接 Solder connection 电气性能 Rated voltage/current 30Vac-60Vdc/Max.19A 1 材质 Material 塑壳 Insulator: PA 主体 Body: 铜 Brass 弹片 Spring: 铍铜 Beryllium copper 表面 Surface: 镀镍 Nickel plated * 按压 Press connection 电气性能 Rated voltage/current CATII 600V/Max.32A 材质 Material 塑壳 Insulator: PA 主体 Body: 铜 Brass 表面 Surface: 镀镍 Nickel plated * 焊接 Solder connection 电气性能 Rated voltage/current 30Vac-60Vdc/Max.24A 材质 Material 塑壳 Insulator: PE 主体 Body: 铍铜 Beryllium copper 弹片 Spring: 铍铜 Beryllium copper 表面 Surface: 镀金 Gold plated * 焊接 Solder connection 电气性能 Rated voltage/current 30Vac-60Vdc/Max.19A 1 25.502. * 材质 Material 塑壳 Insulator: PA 主体 Body: 铜 Brass 表面 Surface: 镀镍 Nickel plated * 焊接 Solder connection 电气性能 Rated voltage/current CATII 600V/Max.19A 1 2 3 1 2 4 5 0 4 5 www.china-amass.com 3 20 短路插及转换插 Connecting Plug 26.121. * 2 4 5 3 2 5 6 2 2 2 26.222. * 26.203. * 26.123. * 材质 Material 塑壳 Insulator: ABS 主体 Body: 铜 Brass 弹片 Spring: 铍铜 Beryllium copper 表面 Surface: 镀镍 Nickel plated 电气性能 Rated voltage/current 30Vac-60Vdc/Max.32A 材质 Material 塑壳 Insulator: PA 主体 Body: 铜 Brass 弹片 Spring: 铍铜 Beryllium copper 表面 Surface: 镀金 Gold plated 电气性能 Rated voltage/current 30Vac-60Vdc/Max.10A 1 7 2 2 4 5 3 材质 Material 塑壳 Insulator: PVC 主体 Body: 铜 Brass 表面 Surface: 镀镍 Nickel plated 电气性能 Rated voltage/current 30Vac-60Vdc/Max.24A 1 2 4 5 3 26.460. * 材质 Material 塑壳 Insulator: PA 主体 Body: 铜 Brass 弹片 Spring: 铍铜 Beryllium copper 表面 Surface: 镀镍 Nickel plated 电气性能 Rated voltage/current CAT II 1000V/Max.32A 材质 Material 主体 Body: 铜 Brass 弹片 Spring: 铍铜 Beryllium copper 表面 Surface: 镀镍 Nickel plated 电气性能 Rated voltage/current 30Vac-60Vdc/Max.32A 材质 Material 主体 Body: 铜 Brass 弹片 Spring: 铍铜 Beryllium copper 表面 Surface: 镀镍 Nickel plated 电气性能 Rated voltage/current 30Vac-60Vdc/Max.32A 材质 Material 主体 Body: 铜 Brass 表面 Surface: 镀金 Gold plated 电气性能 Rated voltage/current 30Vac-60Vdc/Max.32A 2 2 26.124. * 1 材质 Material 塑壳 Insulator: ABS 主体 Body: 铜 Brass 弹片 Spring: 铍铜 Beryllium copper 表面 Surface: 镀镍 Nickel plated 电气性能 Rated voltage/current CAT II 1000V/Max.32A 材质 Material 塑壳 Insulator: ABS 主体 Body: 铜 Brass 弹片 Spring: 铍铜 Beryllium copper 表面 Surface: 镀镍 Nickel plated 电气性能 Rated voltage/current 30Vac-60Vdc/Max.32A 1 材质 Material 塑壳 Insulator: PVC 主体 Body: 铜 Brass 表面 Surface: 镀镍 Nickel plated 电气性能 Rated voltage/current 30Vac-60Vdc/Max.19A 26.420. * 26.221. * 26.202. * 材质 Material 塑壳 Insulator: ABS 主体 Body: 铜 Brass 弹片 Spring: 铍铜 Beryllium copper 表面 Surface: 镀金 Gold plated 电气性能 Rated voltage/current 30Vac-60Vdc/Max.10A 1 材质 Material 主体 Body: 铜 Brass 弹片 Spring: 铍铜 Beryllium copper 表面 Surface: 镀镍 Nickel plated 电气性能 Rated voltage/current 30Vac-60Vdc/Max.32A 材质 Material 塑壳 Insulator: ABS 主体 Body: 铜 Brass 弹片 Spring: 铍铜 Beryllium copper 表面 Surface: 镀镍 Nickel plated 电气性能 Rated voltage/current 30Vac-60Vdc/Max.32A 1 26.122. * 26.410. * 26.220 26.201. * 材质 Material 塑壳 Insulator: ABS 主体 Body: 铜 Brass 弹片 Spring: 铍铜 Beryllium copper 表面 Surface: 镀金 Gold plated 电气性能 Rated voltage/current 30Vac-60Vdc/Max.10A 1 短路插及转换插 Connecting Plug 26.223. * 26.205. * 材质 Material 塑壳 Insulator: ABS 主体 Body: 铜 Brass 弹片 Spring: 铍铜 Beryllium copper 表面 Surface: 镀镍 Nickel plated 电气性能 Rated voltage/current 30Vac-60Vdc/Max.32A 材质 Material 塑壳 Insulator: PA 主体 Body: 铜 Brass 弹片 Spring: 铍铜 Beryllium copper 表面 Surface: 镀金 Gold plated 电气性能 Rated voltage/current 30Vac-60Vdc/Max.10A 26.480 1 21 2 2 www.china-amass.com 7 1 26.481 2 www.china-amass.com 22 短路插及转换插 Connecting Plug 28.110 26.456. * 26.450. * 材质 Material 塑壳 Insulator: PA 主体 Body: 铜 Brass 表面 Surface: 镀镍 Nickel plated 电气性能 Rated voltage/current 30Vac-60Vdc/Max.36A 1 2 4 5 3 非绝缘插头、插座 Uninsulated Banana plug & Socket 材质 Material 主体 Body: 铜 Brass 表面 Surface: 镀金 Gold plated 材质 Material 塑壳 Insulator: PA 主体 Body: 铜 Brass 弹片 Spring: 铍铜 Beryllium copper 表面 Surface: 镀镍 Nickel plated 电气性能 Rated voltage/current 30Vac-60Vdc/Max.10A 1 2 4 5 3 材质 Material 塑壳 Insulator: PA 主体 Body: 铜 Brass 表面 Surface: 镀镍 Nickel plated 电气性能 Rated voltage/current 30Vac-60Vdc/Max.36A 2 4 5 3 2 4 5 L M2.0 6.5 28.331 M2.5 6.5 Item No. 材质 Material 主体 Body: 铜 Brass 表面 Surface: 镀金 Gold plated 电气性能 Rated voltage/current 材质 Material 塑壳 Insulator: PA 主体 Body: 铜 Brass 表面 Surface: 镀镍 Nickel plated 电气性能 Rated voltage/current 30Vac-60Vdc/Max.10A 1 T 28.330 A-1.005 28.36* 28.111 T L 28.360 M2.0 6.5 28.361 M2.0 10.0 材质 Material 主体 Body: 铜 Brass 弹片 Spring: 铍铜 Beryllium copper 表面 Surface: 镀金 Gold plated 28.112 1 Item No. 材质 Material 主体 Body: 铜 Brass 弹片 Spring: 铍铜 Beryllium copper 表面 Surface: 镀金 Gold plated 26.470. * 26.451. * A-1.005 28.33* 28.370 材质 Material 主体 Body: 铜 Brass 弹片 Spring: 铍铜 Beryllium copper 表面 Surface: 镀镍 Nickel plated 材质 Material 主体 Body: 铜 Brass 表面 Surface: 镀金 Gold plated 电气性能 Rated voltage/current 3 26.452. * 材质 Material 塑壳 Insulator: PA 主体 Body: 铜 Brass 弹片 Spring: 铍铜 Beryllium copper 表面 Surface: 镀金 Gold plated 电气性能 Rated voltage/current 30Vac-60Vdc/Max.36A 1 2 4 5 28.41* 28.220 材质 Material 主体 Body: 铜 Brass 表面 Surface: 镀镍 Nickel plated 材质 Material 主体 Body: 铜 Brass 弹片 Spring: 铍铜 Beryllium copper 表面 Surface: 镀镍 Nickel plated 3 26.455. * 材质 Material 塑壳 Insulator: PA 主体 Body: 铜 Brass 弹片 Spring: 铍铜 Beryllium copper 表面 Surface: 镀镍 Nickel plated 电气性能 Rated voltage/current 30Vac-60Vdc/Max.10A 1 2 4 5 23 3 www.china-amass.com 28.230 材质 Material 主体 Body: 铜 Brass 表面 Surface: 镀镍 Nickel plated Item No. T L 28.410 M3.0 6.0 28.411 M3.0 10.0 28.412 M4.0 4.5 28.413 M4.0 6.0 28.414 M4.0 9.0 28.415 M4.0 18.0 www.china-amass.com 24 非绝缘插头、插座 Uninsulated Banana plug & Socket 28.420 28.461 非绝缘插头、插座 Uninsulated Banana plug & Socket 28.910 28.710 材质 Material 主体 Body: 铜 Brass 弹片 Spring: 铍铜 Beryllium copper 表面 Surface: 镀镍 Nickel plated 材质 Material 主体 Body: 铜 Brass 弹片 Spring: 铍铜 Beryllium copper 表面 Surface: 镀镍 Nickel plated 材质 Material 主体 Body: 铜 Brass 弹片 Spring: 铍铜 Beryllium copper 表面 Surface: 镀金 Gold plated 材质 Material 主体 Body: 铜 Brass 表面 Surface: 镀镍 Nickel plated T L 28.430 28.510 材质 Material 主体 Body: 铜 Brass 弹片 Spring: 铍铜 Beryllium copper 表面 Surface: 镀金 Gold plated 28.440 28.520 A-1.005 28.441 材质 Material 主体 Body: 铜 Brass 弹片 Spring: 锰钢 Steel 表面 Surface: 镀镍 Nickel plated 材质 Material 主体 Body: 铜 Brass 弹片 Spring: 锰钢 Steel 表面 Surface: 镀金 Gold plated 28.803 材质 Material 主体 Body: 铜 Brass 弹片 Spring: 铍铜 Beryllium copper 表面 Surface: 镀金 Gold plated 28.620 材质 Material 主体 Body: 铜 Brass 弹片 Spring: 铍铜 Beryllium copper 表面 Surface: 镀镍 Nickel plated www.china-amass.com A-1.005 28.712 28.610 28.450 材质 Material 主体 Body: 铜 Brass 弹片 Spring: 锰钢 Steel 表面 Surface: 镀镍 Nickel plated 材质 Material 主体 Body: 铜 Brass 弹片 Spring: 铍铜 Beryllium copper 表面 Surface: 镀镍 Nickel plated 材质 Material 主体 Body: 铜 Brass 弹片 Spring: 铍铜 Beryllium copper 表面 Surface: 镀镍 Nickel plated 25 28.711 材质 Material 主体 Body: 铜 Brass 弹片 Spring: 铍铜 Beryllium copper 表面 Surface: 镀镍 Nickel plated 材质 Material 主体 Body: 铜 Brass 弹片 Spring: 铍铜 Beryllium copper 表面 Surface: 镀银 Silver plated 材质 Material 主体 Body: 铜 Brass 弹片 Spring: 铍铜 Beryllium copper 表面 Surface: 镀金 Gold plated 28.804 材质 Material 主体 Body: 铜 Brass 表面 Surface: 镀金 Gold plated www.china-amass.com 26 面板插座 Panel Socket 24.101. * 24.106. * 材质 Material 塑壳 Insulator: ABS 主体 Body: 铜 Brass 表面 Surface: 镀镍 Nickel plated 电气性能 Rated voltage/current 30Vac-60Vdc/Max.10A 材质 Material 塑壳 Insulator: PA 主体 Body: 铜 Brass 表面 Surface: 镀金 Gold plated 电气性能 Rated voltage/current 30Vac-60Vdc/Max.10A 1 2 4 5 面板插座 Panel Socket 3 24.102. * 1 2 3 4 5 6 24.107. * 材质 Material 塑壳 Insulator: ABS 主体 Body: 铜 Brass 表面 Surface: 镀镍 Nickel plated 电气性能 Rated voltage/current 30Vac-60Vdc/Max.10A 材质 Material 塑壳 Insulator: ABS 主体 Body: 铜 Brass 表面 Surface: 镀镍 Nickel plated 电气性能 Rated voltage/current 30Vac-60Vdc/Max.6A 24.131. * 型号 Model. 24.131. * 24.132. * 1 2 4 5 24.133. * 3 1 2 3 4 5 6 24.110. * 24.103. * 2 4 5 3 2 4 5 3 24.111. * 24.104. * 1 2 4 5 27 3 2 2 4 5 www.china-amass.com CATIII 600V/Max.10A Nickel or Gold plated 3 1 4 5 1 2 2 4 5 3 4 5 4 5 3 24.244. * 材质 Material 塑壳 Insulator: PA 主体 Body: 铜 Brass 表面 Surface: 镀镍 Nickel plated 电气性能 Rated voltage/current 30Vac-60Vdc/Max.24A 1 2 材质 Material 塑壳 Insulator: PA 主体 Body: 铜 Brass 表面 Surface: 镀银 Silver plated 电气性能 Rated voltage/current 30Vac-60Vdc/Max.24A 3 材质 Material 塑壳 Insulator: PA 主体 Body: 铜 Brass 表面 Surface: 镀金 Gold plated 电气性能 Rated voltage/current 30Vac-60Vdc/Max.10A 1 塑壳 Insulator:PA 主体 Body: 铜 Brass 表面 Surface: 镀镍或镀金 材质 Material 塑壳 Insulator: PA 主体 Body: 铜 Brass 表面 Surface: 镀镍 Nickel plated 电气性能 Rated voltage/current 30Vac-60Vdc/Max.24A 1 24.134. * 电气性能 Rated voltage/current 24.242. * 材质 Material 塑壳 Insulator: PA 主体 Body: 铜 Brass 表面 Surface: 镀镍 Nickel plated 电气性能 Rated voltage/current 30Vac-60Vdc/Max.10A 24.133. * 24.243. * 材质 Material 塑壳 Insulator: PA 主体 Body: 铜 Brass 表面 Surface: 镀金 Gold plated 电气性能 Rated voltage/current 30Vac-60Vdc/Max.10A 1 材质 Material 24.241. * 材质 Material 塑壳 Insulator: PA 主体 Body: 铜 Brass 表面 Surface: 镀镍 Nickel plated 电气性能 Rated voltage/current 30Vac-60Vdc/Max.10A 1 24.134. * 24.132. * 3 材质 Material 塑壳 Insulator: ABS 主体 Body: 铜 Brass 表面 Surface: 镀锌 Zinc plated 电气性能 Rated voltage/current 30Vac-60Vdc/Max.24A 1 2 3 4 5 6 www.china-amass.com 28 面板插座 Panel Socket 面板插座 Panel Socket 24.331. * 24.332. * 24.333. * 24.334. * 24.335. * 24.341. * 24.342. * 24.343. * 24.344. * 24.345. * 24.321. * 型号 Model. 型号 Model. 24.341. * 24.332. * 24.342. * 24.333. * 24.343. * 24.334. * 24.344. * 24.335. * 24.345. * 电气性能 Rated voltage/current 24.322. * 24.323. * 24.324. * CATII 600V/Max.24A CATII 600V/Max.32A 1 2 6 0 3 4 5 24.324. * 24.325. * 24.326. * 电气性能 Rated voltage/current 24.321. * CATII 600V/Max.32A 塑壳 Insulator:ABS 主体 Body: 铜 Brass 表面 Surface: 镀镍 Nickel plated 材质 Material 24.323. * CATIII 1000V/Max.32A 塑壳 Insulator:PA 主体 Body: 铜 Brass 表面 Surface: 镀镍 Nickel plated CATIII 1000V/Max.24A CATIII 1000V/Max.32A 24.325. * 24.326. * 1 2 3 4 6 7 8 9 5 Ep:0.8 24.331. * 材质 Material 24.322. * 型号 Model. 24.301. * 24.311. * 24.302. * 24.312. * 24.303. * 24.313. * 24.304. * 24.314. * 24.305. * 24.315. * 24.306. * 24.316. * 29 24.301. * 24.302. * 24.303. * 24.304. * 24.305. * 24.306. * 24.311. * 24.312. * 24.313. * 24.314. * 24.315. * 24.316. * 材质 Material 24.381. * 24.382. * 24.383. * 24.384. * 24.391. * 24.392. * 24.393. * 24.394. * 电气性能 Rated voltage/current 塑壳 Insulator:PA 主体 Body: 铜 Brass 表面 Surface: 镀镍 Nickel plated CATIII 1000V/Max.24A CATIII 1000V/Max.32A www.china-amass.com 材质 Material 型号 Model. CATIII 1000V/Max.32A 1 2 3 4 5 6 7 8 9 0 24.381. * 24.391. * 24.382. * 24.392. * 24.383. * 24.393. * 24.384. * 24.394. * 塑壳 Insulator:PA 主体 Body: 铜 Brass 表面 Surface: 镀镍 Nickel plated www.china-amass.com 电气性能 Rated voltage/current CATIII 1000V/Max.32A CATIII 1000V/Max.24A CATIII 1000V/Max.32A 0 30 面板插座 Panel Socket 24.245. * 24.824. * 24.247. * 1 2 4 5 24.260. * 材质 Material 塑壳 Insulator: PA 主体 Body: 铜 Brass 表面 Surface: 镀镍 Nickel plated 电气性能 Rated voltage/current 24.825. * 2 4 5 3 1 2 4 5 3 1 2 4 5 3 24.829.* 材质 Material 塑壳 Insulator: PA 主体 Body: 铜 Brass 表面 Surface: 镀镍 Nickel plated 电气性能 Rated voltage/current 材质 Material 塑壳 Insulator: ABS 主体 Body: 铜 Brass 表面 Surface: 镀镍 Nickel plated 电气性能 Rated voltage/current CATIII 1000V/Max.32A 1 材质 Material 塑壳 Insulator: ABS 主体 Body: 铜 Brass 表面 Surface: 镀镍 Nickel plated 电气性能 Rated voltage/current 30Vac-60Vdc/Max.24A 3 材质 Material 塑壳 Insulator: ABS 主体 Body: 铜 Brass 表面 Surface: 镀镍 Nickel plated 电气性能 Rated voltage/current 30Vac-60Vdc/Max.19A 24.828. * 30Vac-60Vdc/Max.24A 30Vac-60Vdc/Max.24A 2 24.246. * 材质 Material 塑壳 Insulator: ABS 主体 Body: 铜 Brass 表面 Surface: 镀镍 Nickel plated 电气性能 Rated voltage/current 材质 Material 塑壳 Insulator: ABS 主体 Body: 铜 Brass 表面 Surface: 镀镍 Nickel plated 电气性能 Rated voltage/current 材质 Material 塑壳 Insulator: PA 主体 Body: 铜 Brass 表面 Surface: 镀金 Gold plated 电气性能 Rated voltage/current CATIII 1000V/Max.24A 1 接线柱 Binding Post 30Vac-60Vdc/Max.24A 30Vac-60Vdc/Max.24A 1 2 4 5 3 24.826. * 1 2 4 5 1 2 4 5 3 24.830.* 材质 Material 塑壳 Insulator: ABS 主体 Body: 铜 Brass 表面 Surface: 镀镍 Nickel plated 电气性能 Rated voltage/current 材质 Material 塑壳 Insulator: ABS 主体 Body: 铜 Brass 表面 Surface: 镀镍 Nickel plated 电气性能 Rated voltage/current 30Vac-60Vdc/Max.19A 30Vac-60Vdc/Max.24A 3 1 2 4 5 3 24.831.* 24.827. * 材质 Material 塑壳 Insulator: ABS 主体 Body: 铜 Brass 表面 Surface: 镀镍 Nickel plated 电气性能 Rated voltage/current 材质 Material 塑壳 Insulator: ABS 主体 Body: 铜 Brass 表面 Surface: 镀镍 Nickel plated 电气性能 Rated voltage/current 30Vac-60Vdc/Max.24A 31 www.china-amass.com 1 2 4 5 3 30Vac-60Vdc/Max.24A 1 2 4 5 www.china-amass.com 3 32 接线柱 Binding Post 线规 Cable Specification 24.935. * 24.832. * 材质 Material 塑壳 Insulator: ABS 主体 Body: 铜 Brass 表面 Surface: 镀镍 Nickel plated 电气性能 Rated voltage/current 1 2 3 4 5 30Vac-60Vdc/Max.24A 1 2 4 5 Material Insulator:ABS Body:Brass Surface:Nickel plated Rated voltage/current 30Vac-60Vdc/Max.80A 3 24.932. * 24.936. * 材质 Material 塑壳 Insulator: ABS 主体 Body: 铜 Brass 表面 Surface: 镀镍 Nickel plated 电气性能 Rated voltage/current 1 2 3 4 5 30Vac-60Vdc/Max.50A PVC Item No. ( 型号 ) 2 4 5 24.937. * 24.933. * 材质 Material 塑壳 Insulator: ABS 主体 Body: 铜 Brass 表面 Surface: 镀镍 Nickel plated 电气性能 Rated voltage/current 1 30Vac-60Vdc/Max.60A 1 2 4 5 2 3 4 5 Material Insulator:ABS Body:Brass Surface:Nickel plated Rated voltage/current 30Vac-60Vdc/Max.150A 额定电压、电流 (Rated Volatge&Current)V/A 0.5/20 2.3 1500/10 1 2 3 4 5 6 011.0137 0.75/18 2.8 1500/15 1 2 3 4 5 6 011.0026 0.75/18 3.5 1500/15 1 2 3 4 5 6 011.0044 1.00/17 3.9 1500/19 1 2 3 4 5 6 7 011.0043 2.50/13 3.9 1500/32 1 2 3 4 5 6 7 Material Insulator:ABS Body:Brass Surface:Nickel plated Rated voltage/current 30Vac-60Vdc/Max.100A 3 Outer diameter. 外径 mm 011.0046 SIL Item No. ( 型号 ) 1 Cross Section ( 线规 ) mm2/AWG Cross Section ( 线规 ) mm2/AWG 额定电压、电流 Outer diameter. 外径 mm (Rated Volatge&Current)V/A 011.0078 0.5/20 1.8 1500/10 1 2 3 4 5 6 011.0066 0.75/18 3.5 1500/15 1 2 3 4 5 6 011.0063 1.00/17 3.9 1500/19 1 2 3 4 5 6 7 011.0136 2.50/13 3.9 1500/32 1 2 3 4 5 6 7 3 24.934. * 1 33 2 3 4 5 Material Insulator:ABS Body:Brass Surface:Nickel plated Rated voltage/current 30Vac-60Vdc/Max.60A www.china-amass.com www.china-amass.com 34 测试导线 Test Lead 测试导线 Test Lead 4mm Test Lead 2mm Test Lead Test lead with the 2mm gold plated plug on both ends. 36 11 Test lead with the injected 4mm satckable nickel plated plug on both ends. φ4 1 2 3 4 5 L φ2 1 2 3 22.030. 22.040. 4 * * 22.162. 22.171. 22.172. 22.170. 5 Rated voltage/current: 30Vac-60Vdc/Max.10A Rated voltage/current: 30Vac-60Vdc/Max.10A 0.50mm2 PVC 025 050 0.50mm2 SIL 025 050 100 Test lead with the 2mm stackable gold plated plug on both ends. 11 26.5 3 22.050. 22.060. 4 * * 1 5 Rated voltage/current: 30Vac-60Vdc/Max.10A Rated voltage/current: 30Vac-60Vdc/Max.10A 18 59 18 025 050 100 L 2 3 4 5 22.190. 22.201. * * Rated voltage/current: 30Vac-60Vdc/Max.15A Rated voltage/current: 30Vac-60Vdc/Max.15A Safety test lead one end with the insulated 4mm straight plug and the other end with the insulated 4mm 30 angled plug.Nickel plated plugs with the protective cap. Injected type. L φ4 φ4 3 4 22.090. 22.091. * * Rated voltage/current: 30Vac-60Vdc/Max.15A Rated voltage/current: 30Vac-60Vdc/Max.15A 5 1 0.75mm2 PVC 0.75mm2 SIL 025 050 100 025 050 100 0.75mm2 PVC 0.75mm2 SIL 025 050 100 025 050 100 20 φ4 42 2 3 4 5 22.210. * Rated voltage/current: CATIII 1000V/15A L 70 0.75mm2 PVC 025 050 100 CE 4mm Safety Test Lead 4mm Test Lead Test lead with the 4mm stackable nickel plated plug on both ends. φ4 18 44.5 L Safety test lead with the insulated 4mm angled plug on both ends.Nickel plated plugs with the protective cap. Injected type. φ4 2 3 4 22.100. 22.111. 22.110. * * * Rated voltage/current: 30Vac-60Vdc/Max.15A Rated voltage/current: 30Vac-60Vdc/Max.15A Rated voltage/current: 30Vac-60Vdc/Max.19A 20 φ4 70 L 5 0.75mm2 PVC 0.75mm2 SIL 1.0mm2 JBF 1 025 050 100 025 050 100 025 050 100 2 22.241. 3 4 * 5 Rated voltage/current: CATIII 1000V/15A 0.75mm2 PVC 025 050 100 CE 4mm Safety Test Lead 4mm Test Lead Test lead with the 4mm stackable gold plated plug on both ends. 16 33 L φ4 φ4 Safety test lead with the insulated 4mm stackable plug on both ends. Nickel plated φ4 plugs with the red cap. 1 2 3 4 22.120. 22.121. * * Rated voltage/current: 30Vac-60Vdc/Max.15A Rated voltage/current: 30Vac-60Vdc/Max.19A 35 025 050 100 025 050 100 025 050 100 0.50mm2 PVC 025 050 100 0.50mm2 SIL 025 050 100 47.5 2 1 30Vac-60Vdc/Max.15A 30Vac-60Vdc/Max.19A 30Vac-60Vdc/Max.32A 4mm Safety Test Lead Test lead with the 4mm stackable nickel plated plug on both ends. 1 2.5mm2 SIL 0.75mm2 PVC 0.75mm2 PVC 2.5mm2 PVC 30Vac-60Vdc/Max.32A φ4 φ2 4mm Test Lead 1 L φ4 Test lead with the 4mm nickel plated plug on both ends. L φ2 2 Rated voltage/current: Rated voltage/current: Rated voltage/current: Rated voltage/current: 48.5 4mm Test Lead 2mm Test Lead 1 * * * * 18 5 0.75mm2 PVC 1.0mm2 JBF www.china-amass.com 025 050 100 025 050 100 2 22.390. 22.391. 22.401. 3 4 * * * 5 0 φ4 18.5 50 Rated voltage/current: CATIII 600V/19A Rated voltage/current: CATIII 600V/32A Rated voltage/current: CATIII 600V/32A L 1.0mm2 JBF 2.5mm2 JBF 2.5mm2 SIL www.china-amass.com 025 050 100 025 050 100 025 050 100 CE CE CE 36 测试导线 Test Lead 测试导线 Test Lead 4mm Test Lead 4mm Safety Test Lead Safety test lead one end with the insulated 4mm straight plug and the other end with the insulated 4mm angled plug.Nickel plated plugs 40 with the protective cap. Assembled type. Safety test lead with 4mm stackable plug on both ends. Nickel plated plugs with the shrinkable tube and red cap. 20 1 φ4 1 2 22.270. 22.280. 22.281. 22.291. 22.290. 3 4 * * * * * 5 41 Rated voltage/current: Rated voltage/current: Rated voltage/current: Rated voltage/current: Rated voltage/current: CATIII 1000V/15A CATIII 1000V/19A CATIII 1000V/32A CATIII 1000V/19A CATIII 1000V/32A L 0.75mm2 PVC 1.0mm2 PVC 2.5mm2 PVC 1.0mm2 SIL 2.5mm2 SIL 54 025 050 100 025 050 100 025 050 100 CE CE CE 025 050 100 025 050 100 CE CE 4 1 * * * * * 5 54 Rated voltage/current: Rated voltage/current: Rated voltage/current: Rated voltage/current: Rated voltage/current: L 0.75mm2 PVC 1.0mm2 PVC 2.5mm2 PVC 1.0mm2 SIL 2.5mm2 SIL CATIII 1000V/15A CATIII 1000V/19A CATIII 1000V/32A CATIII 1000V/19A CATIII 1000V/32A 025 025 025 025 025 050 050 050 050 050 100 100 100 100 100 20 5 68.5 Rated voltage/current: Rated voltage/current: Rated voltage/current: Rated voltage/current: L CATIII 1000V/19A 1.0mm2 CATIII 1000V/32A CATIII 1000V/19A CATIII 1000V/32A 2.5mm2 1.0mm2 2.5mm2 PVC PVC SIL SIL 025 050 100 025 050 100 025 050 100 CE CE CE 025 050 100 CE CE CE CE CE CE 2 3 22.480. 22.481. 22.282. 22.500. * * * 4 φ4 φ4 18 5 56 L Rated voltage/current: 30Vac-60Vdc/Max.15A Rated voltage/current: 30Vac-60Vdc/Max.15A Rated voltage/current: 30Vac-60Vdc/Max.32A 2 1.0mm PVC 2.5mm2 PVC 2.5mm2 SIL 025 050 100 025 050 100 025 050 100 4mm Test Lead Test lead one end with the 4mm stackable nickel plated plug and the other end with 55mm length nickel plated crocodile clip. 55 22.300. 22.310. 22.311. 22.321. 22.320. 3 * * * * 4 Test lead with the injected 4mm satckable nickel plated plug on both ends. Safety test lead with the insulated 4mm straight plug on both ends. Nickel plated plugs φ4 with the protective cap. Assembled type. 2 22.460. 22.461. 22.490. 22.491. 3 4mm Test Lead 4mm Safety Test Lead 1 2 φ4 4mm Safety Test Lead φ4 1 Safety test lead with the insulated 4mm stackable plug on both ends. Nickel plated φ4 plugs with the red cap. φ4 2 22.510. 22.520. 3 * * 4 18 5 59 L Rated voltage/current: 30Vac-60Vdc/Max.15A Rated voltage/current: 30Vac-60Vdc/Max.15A 0.75mm2 PVC 0.75mm2 SIL 025 050 100 025 050 100 20 54 1 2 3 22.420. 22.421. 22.440. 4 * * * 5 L 4mm Test Lead 0 Rated voltage/current: CATIII 600V-CATII 1000V/19A 1.0mm2 PVC 025 050 100 Rated voltage/current: CATIII 600V-CATII 1000V/32A 2.5mm2 PVC 025 050 100 Rated voltage/current: CATIII 600V-CATII 1000V/32A 2.5mm2 SIL 025 050 100 CE CE CE 1 4mm Test Lead Safety test lead with 4mm stackable plug on both ends. Nickel plated plugs with the shrinkable tube and red cap. φ4 20 56 1 2 22.450. 22.451. 22.470. 37 3 4 * * * 2 22.570. 22.580. φ4 L φ4 Test lead one end with the 4mm stackable nickel plated plug and the other end with 55mm length nickel plated crocodile clip. φ4 3 * * 4 18 5 44.5 L Rated voltage/current: 30Vac-60Vdc/Max.15A Rated voltage/current: 30Vac-60Vdc/Max.15A 2 0.75mm PVC 0.75mm2 SIL 39.7 025 050 100 025 050 100 4mm Safety Test Lead Safety test lead with the insulated 4mm stackable plug on both ends. Nickel plated plugs with the red cap. 5 φ4 φ4 18.5 Rated voltage/current: CATII 600V/19A Rated voltage/current: CATII 600V/32A Rated voltage/current: CATII 600V/32A 1.0mm2 PVC 025 050 100 2.5mm2 PVC 025 050 100 025 050 100 2.5mm2 SIL www.china-amass.com CE CE CE 22.900. 22.901. * * 50 Rated voltage/current: CATIII 1000V/15A Rated voltage/current: CATIII 1000V/15A L 0.75mm2 PVC 1.0mm2 PVC www.china-amass.com 100 100 CE CE 38 BNC 转接 BNC Adapter & Breakouts 21.010 BNC 转接 BNC Adapter & Breakouts 21.050 Feture:Insulated BNC Male to 2*4mm straight safety plugs,connected with the flexible RG58/50Ω wire.L:1.2M Rating:CATI 500V、CATII 150V/3A Feture:Insulated BNC Male to two crocodile clips,connected with the flexible RG58/50Ω wire.L:1.2M Rating:CATI 500V、CATII 150V/3A 21.060 Feture:Insulated BNC Male at the each end,connected with the flexible RG58/50Ω wire.L:1.0M Rating:CATI 500V、CATII 150V/3A 21.020 Feture:Insulated BNC Male to 2*4mm stackable safety plugs,connected with the flexible RG58/50Ω wire.L:1.2M Rating:CATI 500V、CATII 150V/3A 21.131 21.132 21.030 Feture:Insulated BNC Male to 2*4mm stackable plugs,connected with the flexible RG58/50Ω wire.L:1.2M Rating:CATI 500V、CATII 150V/3A Feture:BNC Male with 2*4mm Stackable Plug Material: Body:Brass; Spring:Beryllium copper; Surface:Nickel plated Rating:Maxium voltage for hands free use:500Vrms 21.133 21.040 Feture:Insulated BNC Male to 2*Mini test clips,connected with the flexible RG58/50Ω wire.L:1.2M Rating:CATI 500V、CATII 150V/3A Feture:BNC Male with 2*4mm Stackable Binding Post Material: Body:Brass; Surface:Nickel plated Rating:Maxium voltage for hands free use:500Vrms Feture:BNC Female with 2*4mm Stackable Plug Material: Body:Brass; Spring:Beryllium copper; Surface:Nickel plated Rating:Maxium voltage for hands free use:500Vrms 21.134 Feture:BNC Female with 2*4mm Stackable Binding Post Material: Body:Brass; Surface:Nickel plated Rating:Maxium voltage for hands free use:500Vrms 21.135 Feture:Feture:BNC Male with the Binding Post Rating:Maxium voltage for hands free use:500Vrms 39 www.china-amass.com www.china-amass.com 40 鳄鱼夹 Crocodile clip BNC 转接 BNC Adapter & Breakouts 21.151 27.187. * 27.260. * 材质 Material 塑壳 Insulator: PA 主体 Body: 铜 Brass 表面 Surface: 镀镍 Nickel plated 电气性能 Rated voltage/current 30Vac-60Vdc/Max.10A Feture: Safety BNC Male with 2x4mm Male Safety Socket Material: Body: Brass; Surface:Nickel plated Rating:CATI 500V、CATII 150V/3A 1 2 3 4 5 6 材质 Material 塑壳 Insulator: PA 主体 Body: 铜 Brass 表面 Surface: 镀镍 Nickel plated 电气性能 Rated voltage/current CATII 300V/Max.15A 1 27.257. * 2 27.262. * 材质 Material 塑壳 Insulator: PA 主体 Body: 铜 Brass 表面 Surface: 镀镍 Nickel plated 电气性能 Rated voltage/current CATII 300V/Max.15A 21.152 Feture: Safety BNC Male with 2x4mm Female Safety Socket Material: Body: Brass; Surface:Nickel plated Rating:CATI 500V、CATII 150V/3A 1 2 27.258. * 材质 Material 塑壳 Insulator: PA 主体 Body: 铜 Brass 表面 Surface: 镀镍 Nickel plated 电气性能 Rated voltage/current CATIII 1000V/Max.32A 1 2 3 4 5 6 27.263. * 材质 Material 塑壳 Insulator: PA 主体 Body: 铜 Brass 表面 Surface: 镀镍 Nickel plated 电气性能 Rated voltage/current CATIII 1000V/Max.32A 材质 Material 塑壳 Insulator: PA 主体 Body: 铜 Brass 表面 Surface: 镀镍 Nickel plated 电气性能 Rated voltage/current CATII 300V/Max.15A 1 2 4 5 3 27.259. * 1 2 4 5 27.264. * 材质 Material 塑壳 Insulator: ABS 主体 Body: 钢 Steel 表面 Surface: 镀镍 Nickel plated 电气性能 Rated voltage/current 30Vac-60Vdc/Max.19A 41 www.china-amass.com 1 2 4 5 3 材质 Material 塑壳 Insulator: PA 主体 Body: 铜 Brass 表面 Surface: 镀镍 Nickel plated 电气性能 Rated voltage/current CATIII 1000V/Max.32A 3 1 www.china-amass.com 2 42 鳄鱼夹 Crocodile clip 材质 Material 塑壳 Insulator: ABS 主体 Body: 钢 Steel 表面 Surface: 镀镍 Nickel plated 材质 Material 塑壳 Insulator: ABS 主体 Body: 铜 Brass 表面 Surface: 镀金 Gold plated 2 7 1 27.330. * 2 1 2 材质 Material 塑壳 Insulator: PVC 主体 Body: 钢 Steel 表面 Surface: 镀镍 Nickel plated 材质 Material 主体 Body: 钢 Steel 表面 Surface: 镀镍 Nickel plated 电气性能 Rated voltage/current 3Max.10A 1 27.710 1 2 27.720. * 2 27.710/711/712. * 材质 Material 塑壳 Insulator: PVC 主体 Body: 钢 Steel 表面 Surface: 镀镍 Nickel plated 电气性能 Rated voltage/current Max.50A 材质 Material 塑壳 Insulator: ABS 主体 Body: 钢 Steel 表面 Surface: 镀镍 Nickel plated 1 27.716. * 材质 Material 塑壳 Insulator: PVC 主体 Body: 铜 Brass 表面 Surface: 镀镍 Nickel plated 27.211. * 27.719. * 27.715. * 27.320. * 1 鳄鱼夹 Crocodile clip 27.722. * 27.717. * 材质 Material 塑壳 Insulator: PVC 主体 Body: 钢 Steel 表面 Surface: 镀镍 Nickel plated 2 材质 Material 塑壳 Insulator: PVC 主体 Body: 钢 Steel 表面 Surface: 镀镍 Nickel plated 电气性能 Rated voltage/current Max.30A 材质 Material 塑壳 Insulator: ABS 主体 Body: 钢 Steel 表面 Surface: 镀镍 Nickel plated 27.711 27.712 1 27.714. * 43 2 2 27.723. * 27.718. * 材质 Material 塑壳 Insulator: PVC 主体 Body: 钢 Steel 表面 Surface: 镀镍 Nickel plated 1 1 2 材质 Material 塑壳 Insulator: PVC 主体 Body: 钢 Steel 表面 Surface: 镀镍 Nickel plated 1 www.china-amass.com 2 材质 Material 塑壳 Insulator: PVC 主体 Body: 钢 Steel 表面 Surface: 镀镍 Nickel plated 电气性能 Rated voltage/current Max.30A 1 2 www.china-amass.com 44 测试组套 Test Kits 33.110 测试组套 Test Kits 33.150 2 x 4mm safety test lead:22.420(1mm2 JBF wire,L:100cm) 2 x test probe:20.164 2 x safety crocodile clips:27.262 2 x test clip:20.169 2 x 4mm safety test lead:22.280(1mm2 JBF wire,L:100cm) 2 x 4mm test lead:22.530(0.75mm2 PVC wire,L:25cm) 2 x test probe:20.157 2 x safety crocodile clips:27.262 33.120 2 x 4mm safety test lead:22.420(1mm2 JBF wire,L:100cm) 2 x test probe:20.164 2 x safety crocodile clips:27.262 2 x test probe:20.168 33.310 2 x 4mm safety test lead:22.280(1mm2 JBF wire,L:100cm) 2 x 4mm test lead:22.370(1mm2 JBF wire,L:100cm) 2 x test probe:20.157 2 x safety crocodile clips:27.262 2 x test clip:20.169 33.130 2 x 4mm safety test lead:22.310(1mm2 JBF wire,L:100cm) 2 x test probe:20.164 2 x safety crocodile clips:27.262 2 x test clip:20.169 Packed in the tool bag 33.320 33.140 2 x 4mm safety test lead:22.280(1mm2 JBF wire,L:100cm) 2 x test probe:20.157 2 x safety crocodile clips:27.262 2 x test clip:20.169 2 x 4mm safety test lead:22.280(1mm2 JBF wire,L:100cm) 2 x test probe:20.157 2 x test probe:20.164 2 x safety crocodile clips:27.262 2 x test clip:20.169 2 x connecting plug:26.451 2 x connecting plug:26.456 Packed in the tool bag 45 www.china-amass.com www.china-amass.com 46 测试组套 -DIY 区 Test kits-DIY Zone 35.900 配件 Accessories 六角螺母 Hex nut 圆螺母 Round nut Choose the products from our catalogue and we will pack them into the tool bag as you want.Suitable for the small test kits with the test lead within 100CM. Feature:1.Five independent space of each bag 2.Tool bag can hang on the wall or your belt 3.Free logo space 35.910 Choose the products from our catalogue and we will pack them into the magic tool box as you want.Suitable for the medium test kits with the test lead within 200CM. Feature:1.Tool box can be devided into the different space with the plastic insert 2.Tool bag can hang on the wall 3.Free logo space Item No. T e sw 035.0005 M4 3 6 035.0010 M6 2 8 035.0014 M8 3 10 035.0023 M12 2.5 14 Item No. T e 035.0039 M6 2.5 8 035.0029 M8 3 10 035.0030 M12 5 14 φ 端子 Terminals 35.911 Choose the products from our catalogue and we will pack them into the magic tool box as you want.Suitable for the big test kits with the test lead within 500CM. Feature:1.Tool box can be devided into the different space with the plastic insert 2.Tool bag can hang on the wall 3.Free logo space Item No. W L 023.0083 2.8 14 023.0084 4.8 15 023.0085 3.8 19 六角管 Hex spacers 35.920 33.140 Choose the products from our catalogue and we will pack them into the tool box as you want.Suitable for the professional test kits. Feature:1.Special material to make the box that insure it can save in different working enviroment 2.Foam-rubber cushion protect the inside products 3.Free logo space 47 www.china-amass.com Item No. φ sw L 023.0086 3 6 8 023.0087 3 6 20 www.china-amass.com 48
20.135.5
PDF文档中包含以下信息: 1. 物料型号:型号为XXXX,是XXXX公司生产的。
2. 器件简介:该器件是用于XXXX的集成电路,具有XXXX功能。
3. 引脚分配:共有引脚数为XX,各引脚功能如下:引脚1-功能,引脚2-功能,...。
4. 参数特性:工作电压范围为XXV至XXV,工作频率为XXMHz,功耗为XXmW。
5. 功能详解:器件的主要功能包括XXXX,XXXX,XXXX。
6. 应用信息:适用于XXXX领域,如XXXX,XXXX等。
7. 封装信息:采用XXXX封装,尺寸为XXmm x XXmm x XXmm。
