B5819W-SL
B5819W-SL
    ZRE(治润)
    SOD-123
    B5819W-SL
B5819W-SL 数据手册
B5819W 1.0A 40V Surface Mounted Schottky Barrier Rectifiers SOD123FL Features The plastic package carries Underwriters Laboratory Flammability Classification 94V-0 For surface mounted applications Built-in strain relief,ideal for automated placement Low reverse leakage High forward surge current capability High temperature soldering guaranteed 260 C/10 seconds at terminals Mechanical Data Case : Molded plastic body Terminals : Solder plated, solderable per MIL-STD-750,Method 2026 Polarity : Polarity symbol marking on body Mounting Position : Any Weight : 0.0007 ounce, 0.02 grams Dimensions in inches and (millimeters) Maximum Ratings And Electrical Characteristics Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load, for capacitive load current derate by 20%. Parameter SYMBOLS Marking Code B5819W UNITS SL Maximum repetitive peak reverse voltage VRRM 40 V Maximum RMS voltage VRMS 28 V Maximum DC blocking voltage VDC 40 V Maximum average forward rectified current at TL =100 C I(AV) 1.0 A Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load IFSM 30.0 A Maximum instantaneous forward voltage at 1.0A VF 0.55 V IR 0.5 50 mA RqJA 85.0 C/W TJ -55 to +125 C Storage temperature range TSTG -55 to +150 C http://www.zrediode.com Technology Innovation Future Maximum DC reverse current T A =25 C at rated DC blocking voltage TA=125 C Typical thermal resistance Operating junction temperature range Rev.2018 Page 1 B5819W 1.0A 40V Surface Mounted Schottky Barrier Rectifiers Ratings And Characteristic Curves FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD SURGE CURRENT PERLEG 35 Peak Forward Surage Current Amperes 1.0 0.9 0.8 Amperes Average Forward Rectified Current FIG. 1- DERATING CURVE OUTPUT RECTIFIED CURRENT 0.7 0.6 0.5 0.4 0.3 0.2 0 20 40 60 80 100 120 140 30 25 20 15 f=60Hz 10 5 1Cycle 0 160 1 10 100 Lead Temperature Number of cycles FIG. 3-TYPICAL FORWARD VOLTAGE CHARACTERISTICS FIG. 4-TYPICAL REVERSE LEAKAGE CHARACTERISTICS 50 100 10.0 1 0.1 0.01 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 INSTANTANEOUS REVERSE CURRENT, MICROAMPERES INSTANTANEOUS FORWARD CURRENT,AMPERES TJ=25 C INSTANTANEOUS FORWARD VOLTAGE, VOLTS 10 TJ=100 C 1 0.1 0.01 TJ=25 C 0.001 0 20 40 60 80 100 PERCENT OF PEAK REVERSE VOLTAGE,% Suggested Pad Layout http://www.zrediode.com Symbol Unit (mm) Unit (inch) A 1.2 0.048 B 1.15 0.045 C 3.10 0.122 D 1.95 0.077 E 4.25 0.167 Technology Innovation Future Rev.2018 Page 2 B5819W 1.0A 40V Surface Mounted Schottky Barrier Rectifiers Suggested Soldering Temperature Profile Note R ecom m ended reflow m ethods: IR , vap or phase ov en, hot air oven, w ave solder. Th e dev ice can b e exp osed to a m axim um tem p erature of 265 °C for 10 second s. D evices can b e cleaned using standa rd industry m ethods and solvents. If reflow tem peratures exceed the re c o m m e n d e d p ro file , d e v ic e s m a y n o t m e e t th e p e rfo rm a n c e re q u ire m e n ts . Package Information Carrier Dimension(mm) A0 B0 K0 D0 E F 2.15 3.95 1.35 1.55 1.75 3.50 P0 P1 P2 T W Tolerance 4.0 4.0 2.0 0.25 8 0.1 Package Specifications Package Reel Size SOD123FL 7' http://www.zrediode.com Reel DIA. (mm) Q'TY/Reel (Kpcs) Box Size (mm) QTY/Box (Kpcs) Carton Size (mm) Q'TY/Carton (Kpcs) 178 3 180 15 380*200*200 150 Technology Innovation Future Rev.2018 Page 3
B5819W-SL 价格&库存
很抱歉,暂时无法提供与“B5819W-SL”相匹配的价格&库存,您可以联系我们找货
