1AS1T1B1M2QES-5
1AS1T1B1M2QES-5
    DAILYWELL(德利威)
    插件
1AS1T1B1M2QES-5 数据手册
1A Series 1A Toggle Switches Togg Sealed Miniature Toggle Switches SPECIFICATIONS CONTACT RATING: Dependent upon contact material, see page 17. MECHANICAL LIFE: 30,000 make-and-break cycles. CONTACT RESISTANCE: 10 mȟġmax. (initial value) @ 2-4VDC 100mA for both silver and gold plated contacts. INSULATION RESISTANCE: 1,000 Mȟġmin./1000VDC DIELECTRIC STRENGTH: 1,000 Vrms min.@sea level.(initial value) OPERATING TEMPERATURE: -40°C to 85°C. MATERIALS CASE & BUSHING: Glass filled nylon 6/6, flame retardant, heat stabilized (UL94v-0). ACTUATOR: Brass with chrome plated, internal o-ring sealed. SWITCH SUPPORT: Brass or steel, tin plated. SWITCH SUPPORT RETAINER: Stainless steel. CONTACT / TERMINALS: Copper with silver or gold plated. (See page 17) HOW TO ORDER MODEL NO. SP 1AS1 1AS2 1AS3 1AS4 1AS5 DP 1AD1 1AD2 1AD3 1AD4 1AD5 1AD6 1AD7 1AD8 3P 1A31 1A32 1A33 1A34 1A35 ACTUATOR ON-NONE-ON ON-NONE-(ON) ON-OFF-ON (ON)-OFF-(ON) ON-OFF-(ON) T1 T2 TA TB TC ON-NONE-ON ON-NONE-(ON) ON-OFF-ON (ON)-OFF-(ON) ON-OFF-(ON) ON-ON-ON (ON)-ON-(ON) Ÿ ON-ON-(ON) Ÿ ON-NONE-ON ON-NONE-(ON) ON-OFF-ON (ON)-OFF-(ON) ON-OFF-(ON) Ÿ BUSHING TERMINAL TYPE TERMINAL PLATING RoHS SOLDERING SEAL E EPOXY (std) 12.70 high 7.62 high Plastic,black 12.70 high Plastic,black 7.62 high Plastic,silver 12.70 high S RoHS & Lead Free Q Gold flash over silver R Gold C Gold over silver B1 8.80 high B4 6.10 high M1 M2 M51 M52 M53 M54 M6 M6N M7 Solder Lug PC thru-hole 18.70 high, wire wrap 24.20 high, wire wrap 10.55 high, wire wrap 26.97 high, wire wrap Right angle, PC thru-hole + Right angle, snap-in, PC thru-hole + Vertical right angle, PC thru-hole + V-bracket VS2 11.68 high + V2N 11.68 high, snap-in. + VS3 16.00 high + Ÿ Please confirm the availability before order. +!Only available for B4 bushing. EXAMPLE: 1AS1T1B1M1QES 012 Dimensions shown in inch(mm). Specifications and availability subject to change without notice. www.dailywell.com.tw 1A Series Sealed Miniature Toggle Switches 1A Toggle Switches SWITCH FUNCTION (ON) 2 (COMM) 2 (COMM) (ON) (ON) 1 1 3 3 (ON) (ON) 2 (COMM) (ON) (ON) 1 3 2 (COMM) 5 4 6 1 3 5 4 6 (ON) (ON) (ON) (ON) (ON) 2 (ON) (ON) 1 2 5 (COMM) 8 3 4 6 7 9 1 5 (COMM) 8 3 4 6 7 9 (ON) ( )= MOMENTARY Please confirm the availability before order. POLE OPTIONS .346 8.80 .409 10.40 EPOXY SEAL .030 0.76 .415 10.55 .185 4.70 Ø.115 Ø2.92 .500 12.70 .260 6.60 1/4-40 UNS-2A .156 3.96 .080 2.03 .030 0.76 SPDT Model name. 1AS1T1B1M1QES Dimensions shown in inch(mm). Specifications and availability subject to change without notice. www.dailywell.com.tw 013 1A Series 1A Toggle Switches Sealed Miniature Toggle Switches .240 6.10 .219 5.56 .409 10.40 EPOXY SEAL .185 4.70 .500 12.70 Ø.115 Ø2.92 .500 12.70 .450 11.43 DPDT .030 0.76 6 3 5 2 4 1 .050 1.27 .209 5.30 .190 4.83 Model name. 1AD1T1B4M2QES .500 12.70 .649 16.50 .240 6.10 EPOXY SEAL .185 4.70 .115 DIA Ø2.92 .500 12.70 9 .030 0.76 5 8 3 6 2 4 7 1 .030 0.76 .472 12.00 3PDT .209 5.30 .190 4.83 .050 1.27 Model name. 1A31T1B4M2QES ACTUATOR OPTIONS Actuator are shown with Bushing B4(standard) Note: For B1 Bushing: - .085inch(2.15mm) T2 T1 TA TB Ø.115 Ø2.92 Ø.115 Ø2.92 Ø.105 Ø2.67 Ø.105 Ø2.67 .500 12.70 .500 12.70 .300 7.62 .300 7.62 PLASTIC ACTUATOR (TC,Silver) BUSHING OPTIONS Ø.250 Ø6.35 B1 Note: Standard for terminal M1. Note: Standard for terminal M2, M6, M7, VS. .033 0.85 .022 0.55 Without locking ring (Keyway) 1/4-40UNS-2A .346 8.80 B4 .240 6.10 .240 6.10 Ø.250 Ø6.35 .030 0.76 Ø.094 Ø2.38 With standard locking ring. 014 Dimensions shown in inch(mm). Specifications and availability subject to change without notice. www.dailywell.com.tw 1A Series M1 Solder lug 1A TERMINAL OPTIONS M2 PC Thru-hole M3 Quick connect .078 1.98 Wire Wrap .075 1.91 EPOXY SEAL EPOXY SEAL .047 1.19 .080 2.03 M5 .209 5.30 .156 3.96 EPOXY SEAL .050 1.27 .030inch(0.76mm)THK Toggle Switches Sealed Miniature Toggle Switches EPOXY SEAL .209 5.30 .062 1.57 .030inch(0.76mm)THK .050 1.27 .030inch(0.76mm)THK .030inch(0.76mm)THK OTHER TERMINAL OPTIONS M6N M6 Right angle P.C. Mount M7 VS2 VS3 Vertical right angle P.C. Mount Vertical bracket P.C. Mount 'A' OPTION DIM. 'A' CODE M51 .736 ( 18.70 ) Right angle P.C. Mount with snap-in bracket Vertical bracket P.C. Mount V2N with snap-in bracket Vertical bracket P.C. Mount M6 A 2 1 .953 ( 24.20 ) M53 .415 ( 10.55 ) M54 1.062 ( 26.97 ) PCB MOUNTING .500 12.70 EPOXY SEAL (M6N - Snap-in) M52 .185 4.70 3 .137 3.48 .300 7.62 .232 5.90 .030 0.76 .016 0.40 .185 4.70 3 .260 6.60 A .500 12.7 2 1 .500 12.7 .048 1.22 .200 5.08 .050 1.27 Ø.073 Ø1.85 .200 5.08 Section drawing for A-A. SPDT Model name. 1AS1T2B4M6QES M6 .125 3.18 A .030 0.76 .300 7.62 .232 5.90 .185 4.70 1 PCB MOUNTING .500 12.70 EPOXY SEAL A 4 5 6 1 2 3 .450 11.43 4 .500 12.7 .050 1.27 .048 1.22 .200 5.08 .129 3.28 .150 3.81 Section drawing for A-A. DPDT M7 .185 4.70 5 4 2 1 .150 3.81 .500 12.7 Ø.073 Ø1.85 .200 5.08 Model name. 1AD1T2B4M6QES PCB MOUNTING .260 6.60 EPOXY SEAL A 3 3 .125 3.18 .300 7.62 .050 1.27 .232 5.90 .016 0.40 A .500 12.7 1 2 .500 12.70 2 2 1 .112 2.84 .150 3.81 .030 0.76 .150 3.81 1 .500 12.7 3 .200 5.08 .048 1.22 Section drawing for A-A. SPDT 6 3 .200 5.08 Ø.073 Ø1.85 Model name. 1AS1T2B4M7RES Dimensions shown in inch(mm). Specifications and availability subject to change without notice. www.dailywell.com.tw 015 1A Series 1A Toggle Switches Sealed Miniature Toggle Switches M7 .016 0.40 .190 4.83 6 3 .500 .125 12.70 5 3.18 2 4 .300 7.62 .050 1.27 .450 11.43 EPOXY SEAL A A 5 4 1 .030 0.76 .200 5.08 .048 1.22 .150 3.81 3 6 2 5 1 4 .150 3.81 Ø.073 Ø1.85 Section drawing for A-A. DPDT .190 4.83 6 .500 12.7 .232 5.90 .106 2.70 PCB MOUNTING .500 12.7 .200 5.08 Model name. 1AD1T2B4M7RES M7 Ø.240 Ø6.10 9 .125 3.18 A .300 7.62 .050 1.27 .233 5.92 .190 4.83 7 8 PCB MOUNTING .649 16.50 EPOXY SEAL A 6 8 7 4 5 3 2 .500 12.70 1 3 6 9 2 5 8 1 4 7 .150 3.81 9 .030 0.76 .565 14.35 .150 3.81 .048 1.22 .200 5.08 Section drawing for A-A. 3PDT .190 4.83 .565 14.35 Ø.073 Ø1.85 .200 5.08 Model name. 1A31T2B4M7QES VS2 / VS3 PCB MOUNTING .300 7.62 (V2N - Snap-in) .060 1.52 .320 8.13 .220 5.59 .185 4.70 Dim 'A' .125 3.18 EPOXY SEAL .020 0.51 .048 1.22 1 2 .460 11.68 VS3 .630 16.00 .125 3.18 .185 4.70 3 .620 2 15.75 .030 0.76 1 Ø.073 Ø1.85 .185 4.70 Model name. 1AS1T2B4VS2QES VS2 / VS3 .450 11.43 (V2N - Snap-in) PCB MOUNTING .320 8.13 .300 7.62 .060 1.52 .220 5.59 .185 4.70 Dim 'A' EPOXY SEAL .125 3.18 DPDT DIM. 'A' VS2 (V2N) 3 .620 15.75 SPDT OPTION CODE .048 1.22 4 5 6 .030 0.76 .020 0.51 .620 15.75 .185 4.70 OPTION CODE DIM. 'A' VS2 (V2N) .460 11.68 VS3 .630 16.00 .125 3.18 .620 15.75 3 6 2 5 1 4 .185 4.70 Ø.073 Ø1.85 .190 4.83 Model name. 1AD1T2B4VS2QES 016 Dimensions shown in inch(mm). Specifications and availability subject to change without notice. www.dailywell.com.tw 1A Series 1A Toggle Switches Sealed Miniature Toggle Switches VS2 / VS3 .649 16.50 .320 8.13 (V2N - Snap-in) PCB MOUNTING .300 7.62 .060 1.52 .185 4.70 DIM.'A' .052 1.32 EPOXY SEAL .020 0.51 .185 4.70 .125 3.18 .190 4.83 3PDT .240 6.10 7 8 9 .030 0.76 OPTION CODE DIM. 'A' VS2 (V2N) .460 11.68 VS3 .630 16.00 .125 3.18 .185 4.70 3 6 9 .620 2 15.75 5 8 1 4 7 Ø.073 Ø1.85 .190 4.83 .620 15.75 Model name. 1A31T2B4VS2QES SNAP-IN TERMINAL OPTIONS M6N V2N HARDWARE EXAMPLE: *Standard Hardware: 2 nut, 1 locking ring, 1 lockwasher 5 Standard hardware Model name. 1/4 NUT (Std.) LOCKING RING (Std.) LOCKWASHER (Std.) Model name. MNU-1M01A Model name. MNU-1M02 Model name. MNU-1M03 .362 9.19 Ø.468 Ø11.89 .029 0.74 Ø.425 Ø10.80 .312 7.92 1/4-40UNS-2A .065 1.65 .018inch(0.46mm) THK .062 1.57 CONTACT & TERMINAL PLATING OPTIONS CONTACT PLATING Q C R Silver Gold over Silver Gold TERMINAL PLATING RATINGS Gold flash over silver 5 Amps with resistant load @ 120VAC or 28VDC Gold over silver 2 Amps with resistant load @ 250VAC Gold 0.4 Volt - Amps ( VA ) max. @ 20V max. ( AC or DC ) SOLDERING PROCESS MANUAL SOLDERING: Use 30 watts soldering iron and controlled the temperature at 350°. Duration of solder immersion: Max. 5 sec. WAVE SOLDERING: Recommend soldering temperature: 260 ± 5°C Duration of solder immersion: Max. 5 sec. (PCB thickness is 1.6mm) Dimensions shown in inch(mm). Specifications and availability subject to change without notice. www.dailywell.com.tw 017
1AS1T1B1M2QES-5 价格&库存
很抱歉,暂时无法提供与“1AS1T1B1M2QES-5”相匹配的价格&库存,您可以联系我们找货
1AS1T1B1M2QES-5
    • 1+9.60120
    • 10+7.87320
    • 50+6.79320
    库存:501
