MMF-25FRE470R
MMF-25FRE470R
    YAGEO(国巨)
    MELF_D2.2X5.9MM_SM
    MMF-25FRE470R
MMF-25FRE470R 数据手册
無法顯示連結的圖像。檔案可能已移動、重新命名或刪除。請驗證連結指向正確的檔案及位置。 DATA SHEET MELF METAL FILM RESISTORS General Purpse MMF Series ±0.1%, ±0.25%, ±0.5%, ±1%, ±2%, ±5% 1/6W to 1W Product specification – August 13, 2021 V.0 RoHS compliant & Halogen Free Through Hole Resistors Melf Metal Film Resistors Product Specification ORDERING INFORMATION Part number of the MELF metal film resistor is identified by the series, power rating, tolerance, packing, temperature coefficient and resistance value. PART NUMBER APPLICATIONS MMF 25S F R E (1) (2) (3) (4) (5)  All general purpose applications (1) SERIES NAME  Power applications MMF Series 100R (6)  Energy meter (2) POWER RATING FEATURES  AEC-Q200 qualified  MELF, SMD package -12 = 1/6W 50S = 1/2W 25S = 1/4W 207 = 0.6W 204 = 0.4W -50 = 1/2W -25 = 1/4W 1WS = 1W (3) TOLERANCE  Excellent pulse withstanding capability B = ±0.1% G = ±2% C = ±0.25% J = ±5%  Wide resistance range D = ±0.5% - = Based on spec.  RoHS compliant and halogen free F = ±1% (4) PACKAGING R = Reel Pack (5) TEMPERATURE COEFFICIENT OF RESISTANCE E=±50ppm/°C G=±200ppm/°C F=±100ppm/°C - = Based on spec. (6) RESISTANCE VALUE 0.22Ω-1MΩ for E24 & E96 Series value,100Ω-100KΩ for E192 Series value Example: 1R = 1Ω, 10K = 10,000Ω, 1M = 1,000,000Ω www.yageo.com Aug. 13, 2021 V.0 2 8 MMF Through Hole Resistors Product Specification Melf Metal Film Resistors 8 MMF DIMENSIONS Unit: mm Normal Miniature L D C Min. MMF-12 MMF25S / MMF204 3.50 ± 0.2 1.40 ± 0.15 0.5 MMF-25 MMF50S / MMF207 5.90 ± 0.2 2.20 ± 0.1 0.5 MMF-50 MMF1WS 8.50 ± 0.2 3.20± 0.2 0.5 SUGGESTED PAD LAYOUT Unit: mm Normal Miniature MMF-12 MMF25S MMF204 MMF-25 MMF-50 MMF50S MMF207 Soldering L Min. Mode P W Min. Reflow 1.3 1.6 ± 0.1 1.6 Wave 1.5 1.5 ± 0.1 1.8 Reflow 2.0 3.0 ± 0.1 3.0 Wave 2.5 3.0 ± 0.1 3.0 Reflow 2.3 5.5 ± 0.2 4.0 Wave 2.8 5.5 ± 0.2 4.0 MMF1WS DERATING CURVE Rated Power (%) 100 80 60 40 20 20 40 70 100 155 Ambient Temperature (°C) www.yageo.com Aug. 13, 2021 V.0 3 Through Hole Resistors Melf Metal Film Resistors Product Specification 8 MMF ELECTRICAL CHARACTERISTICS CHARACTERISTICS MMF-12 MMF25S MMF204 MMF-25 MMF50S MMF207 MMF-50 MMF1WS Power Rating at 70 °C 1/6W 1/4W 0.4W 1/4W 1/2W 0.6W 1/2W 1W Maximum Working Voltage 150V 200V 200V 250V 250V 250V 350V 350V Maximum Overload Voltage 300V 400V 400V 500V 500V 500V 700V 700V Voltage Proof on Insulation 300V 300V 300V 500V 500V 500V 700V 700V Resistance Range 0.22Ω ~ 3.9Ω for tol ±5%,E96 series value, 4Ω ~ 1MΩ for tol ±1% E24 + E96 series value Operating Temp. Range - 55°C to +155°C Temperature Coefficient ±50ppm/°C for 4Ω ~ 1MΩ, ±100ppm/°C for 0.22Ω ~ 3.9Ω Note: For resistance value out of above range is by request. TEST AND REQUIRMENTS TEST TEST METHOD Short Time Overload IEC 60115-1 4.13 Voltage Proof on IEC 60115-1 4.7 Insulation PROCEDURE APPRAISE 2.5 times RCWV for 5 sec.(Not more ±0.25%+0.05Ω for≤332KΩ than maximum overload voltage) ±0.5%+0.05Ω for>332KΩ In V-Block for 60 sec. test voltage as No Breakdown above table Temperature Coefficient IEC 60115-1 4.8 Between -55°C to +155°C By Type Insulation Resistance IEC 60115-1 4.6 In V-Block for 60 sec. >10,000MΩ Solderability IEC 60115-1 4.17 245±5°C for 3±0.5 Sec. 95% Min. coverage Solvent Resistance of IEC 60115-1 4.30 IPA for 5±0.5 Min. with ultrasonic No deterioration of Marking coatings and markings Periodic-pulse Overload IEC 60115-1 4.39 4 times RCWV 10,000 cycles (1 Sec. on, ±1.0%+0.05Ω 25 Sec.off) Damp Heat Steady State Damp Heat Steady State IEC 60115-1 4.24 IEC 60115-1 4.37 (accelerated mode) Endurance at 70°C Temperature Cycling IEC 60115-1 4.25 IEC 60115-1 4.19 40±2°C,90-95% RH for 56 days, loaded ±1.5%+0.05Ω for≤332KΩ with 0.1 times RCWV ±2.5%+0.05Ω for>332KΩ 85±2°C,85% RH for 56 days, loaded ±3.0%+0.05Ω for≤332KΩ with 0.1 times RCWV(no over 100V) ±5.0%+0.05Ω for>332KΩ 70±2°C at RCWV(or Umax., whichever ±0.75%+0.05Ω for≤332KΩ less) for 1,000 Hr.(1.5 Hr.on,0.5 Hr. off) ±1.0%+0.05Ω for>332KΩ  -55°C  ±1.0%+0.05Ω Room Temp.  +155°C Room Temp.(5 cycles) Resistance to Soldering Heat IEC 60115-1 4.18 260±3°C for 10±1 Sec., immersed to a ±0.5%+0.05Ω point 3±0.5mm from the body www.yageo.com Aug. 13, 2021 V.0 4 Through Hole Resistors Melf Metal Film Resistors Endurance at upper Product Specification 8 MMF IEC 60115-1 4.25 125±2°C for 1,000 Hr. ±1.0%+0.05Ω IEC 60115-1 4.25 155±2°C for 1,000 Hr. ±2.0%+0.05Ω IEC 60115-1 4.23 Dry heat: 125°C for 16 Hr. ±1.0%+0.05Ω category temperature Endurance at upper category temperature Climatic test Damp heat: 55°C,95% RH for 24 Hr. Cold: -55°C for 2 Hr. Negative air pressure:8.5KPa at 25±10°C for 2 Hr. Damp heat cyclic: 55°C, 95% RH for 5 days. DC load: -55°C at RCWV for 1 Min. 125°C at RCWV for 1 Min. Note: RCWV (Rated Continuous Working Voltage): The DC or AC (rms) continuous working voltage corresponding to the rated power is determined by the following formula: V=√(P X R) or max. working voltage whichever is less Where V=Continuous rated DC or AC (rms) working voltage (V) P=Rated power (W) R=Resistance value (Ω) PACKING METHODS TYPE Unit: piece Normal Miniature Packaging Quantity Per Reel MMF-12 MMF25S MMF204 7” 3,000 MMF-25 MMF50S MMF207 7” 2,000 MMF-50 MMF1WS 13” 2,500 www.yageo.com Aug. 13, 2021 V.0 5 Through Hole Resistors Melf Metal Film Resistors Product Specification 8 MMF MARKING 3-BAND-CODE ±2%, ±5% COLOR BLACK BROWN RED ORANGE YELLOW GREEN BLUE VIOLET GREY WHITE GOLD SILVER 1st BAND 0 1 2 3 4 5 6 7 8 9 2nd BAND 0 1 2 3 4 5 6 7 8 9 3rd BAND 0 1 2 3 4 5 6 7 8 9 MULTIPLIER 1Ω 10Ω 100Ω 1KΩ 10KΩ 100K 1MΩ 10MΩ 0.001Ω 0.0001Ω 0.1Ω 0.01Ω ±0.1%, ±0.25%, ±0.5%, ±1% 4-BAND-CODE www.yageo.com Aug. 13, 2021 V.0 6 Through Hole Resistors Melf Metal Film Resistors Product Specification 8 MMF REVISION HISTORY REVISION DATE CHANGE NOTIFICATION DESCRIPTION Version 0 Aug.2, 2021 - - First issue of this specification “ Yageo reserves all the rights for revising the content of this datasheet without further notification, as long as the products itse lf are unchanged. Any product change will be announced by PCN.” www.yageo.com Aug. 13, 2021 V.0 7 Through Hole Resistors Melf Metal Film Resistors Product Specification 8 MMF LEGAL DISCLAIMER Yageo, its distributors and agents (collectively, “Yageo”), hereby disclaims any and all liabilities for any errors, inaccuracies or incompleteness contained in any product related information, including but not limited to product specifications, datasheets, pictures and/or graphics. Yageo may make changes, modifications and/or improvements to product related information at any time and without notice. Yageo makes no representation, warranty, and/or guarantee about the fitness of its products for any particular purpose or the continuing production of any of its products. To the maximum extent permitted by law, Yageo disclaims (i) any and all liability arising out of the application or use of any Yageo product, (ii) any and all liability, including without limitation special, consequential or incidental damages, and (iii) any and all implied warranties, including warranties of fitness for a particular purpose, non-infringement and merchantability. Yageo statements regarding the suitability of products for certain types of applications are based on Yageo’s knowledge of typical operating conditions for such types of applications in a generic nature. Such statements are neither binding statements of Yageo nor intended to constitute any warranty concerning the suitability for a specific customer application or use. They are intended for use only by customers with requisite knowledge and experience for determining whether Yageo products are the correct products for their application or use. In addition, unpredicatable and isolated cases of product failure may still occur, therefore, customer application or use of Yageo products which requires higher degree of reliability or safety, shall employ additional protective safeguard measures to ensure that product failure would not result in personal injury or property damage. Yageo products are not designed for application or use in medical, life-saving, or life-sustaining devices or for any other application or use in which the failure of Yageo products could result in personal injury or death. Customers using or selling Yageo products not expressly indicated for above-mentioned purposes shall do so at their own risk and agree to fully indemnify Yageo and hold Yageo harmless. Information provided here is intended to indicate product specifications only. Yageo reserves all the rights for revising this content without further notification, as long as products are unchanged. Any product change will be announced by PCN. www.yageo.com Aug. 13, 2021 V.0 8
MMF-25FRE470R
物料型号:MMF系列,包括不同尺寸和功率等级的型号,如MMF-12、MMF25S、MMF204、MMF-25、MMF50S、MMF207、MMF-50和MMF1WS。
器件简介:这是一系列通用目的的MELF金属膜电阻器,符合RoHS标准,无卤素,并通过AEC-Q200认证。
引脚分配:文档中没有提供具体的引脚分配图,但提到了SUGGESTED PAD LAYOUT,为焊接提供了推荐的焊盘布局尺寸。
参数特性:电阻器提供不同的公差等级(±0.1%, ±0.25%, ±0.5%, ±1%, ±2%, ±5%)和不同的功率等级(1/6W至1W)。电阻值范围从0.22Ω至1MΩ,有E24和E96系列值,以及E192系列值。
功能详解:电阻器具有优秀的脉冲承受能力,宽电阻范围,符合RoHS标准且无卤素,适用于各种通用目的应用和能源计量等特定应用。
应用信息:适用于所有通用目的应用和能源计量。
封装信息:提供MELF和SMD封装选项,具体尺寸在文档中有详细说明,例如MMF-12的尺寸为3.50mm x 1.40mm x 0.5mm。
MMF-25FRE470R 价格&库存
很抱歉,暂时无法提供与“MMF-25FRE470R”相匹配的价格&库存,您可以联系我们找货
