79L09
SOT-89 Plastic-Encapsulate Voltage Regulators
79L09
SOT-89-3L
Three-terminal positive voltage regulator
FEATURES
z
z
z
1. GND
Maximum output current
IOM: 0.1A
Output voltage
V O: -9V
Continuous total dissipation
PD: 0.6 W (Ta= 25 ℃ )
2. IN
3. OUT
ABSOLUTE MAXIMUM RATINGS (Operating temperature range applies unless otherwise specified)
Symbol
Value
Unit
Vi
-30
V
Thermal Resistance from Junction to Ambient
RθJA
208.3
℃/W
Operating Junction Temperature Range
TOPR
0~+150
Storage Temperature Range
TSTG
-65 ~+150
Parameter
Input Voltage
ELECTRICAL CHARACTERISTICS AT SPECIFIED VIRTUAL JUNCTION TEMPERATURE (Vi=-16V,Io=40mA,Ci=0.33uF,,Co=0.1uF, unless otherwise specified )
Parameter
er
mbol
Test conditions
25℃
Output Voltage
-12V≤Vl≤-24V, Io=1mA~40mA
Vo
Io=1mA~70mA
Load Regulation
ΔVo
Line Regulation
ΔVo
Quiescent Current
Iq
Quiescent Current Change
ΔIq
I
T\S
MD[8QLW
-8.64
-9.0
-9.36
-8.55
-9.0
-9.45
V
-8.55
-9.0
-9.45
V
V
Io=1mA~100mA
25℃
19
90
mV
Io=1mA~40mA
25℃
11
40
mV
-12V≤V l≤-24V
25℃
45
175
mV
-13V≤V l≤-24V
25℃
40
125
mV
25℃
4.1
6
mA
1.5
mA
0.1
mA
-13V≤V l≤-24V
0-125℃
0-125℃
ΔIq
I
1mA ≤I O≤40mA
Output Noise Voltage
VN
10Hz≤f≤100KHz
Ripple Rejection
RR
-15V≤V l≤-24V,f=120Hz
Dropout Voltage
Vd
* Pulse test.
TYPICAL APPLICATION
0-125℃
MLQ
-Vi
58
μV/Vo
0-125℃
45
dB
25℃
1.7
V
25℃
2
3
-Vo
79L09
Ci
0.33μF
1
C0
0.1μF
Note: Bypass capacitors are recommended for optimum stability and transient response and should be located as close as
Possible to the regulators.
The above data are for reference only.
https://www.microdiode.com
Rev:2024A1
Page :1
79L09
Typical Characteristics
Dropout Characteristics
Output Characteristics
-12
-9.50
TJ=25℃
IO=0mA
-11
TJ=25℃
(V)
-9
(V)
OUTPUT VOLTAGE VO
-8
VO
-10
-9.25
OUTPUT VOLTAGE
-7
-6
-5
-4
-3
-2
IO=0mA
-8.75
IO=40mA,70mA,100mA
-8.50
-8.25
-8.00
-7.75
-1
-10
-15
INPUT VOLTAGE
-20
VIN
-25
-7.50
-9.0
-30
-9.5
Quiescent Current vs Input Voltage
-11.5
-12.0
(V)
Current Cut-off Grid Voltage
-2.5
VIN=-16V
-10
TJ=25℃
TJ=25℃
Pulsed
(V)
-9
VO
-2.0
OUTPUT VOLTAGE
(mA)
-11.0
VIN
-11
IO=0mA
IQ
-10.5
INPUT VOLTAGE
-3.0
QUIESCENT CURRENT
-10.0
(V)
-1.5
-1.0
-8
-7
-6
-5
-4
-3
-2
-0.5
-1
0.0
-6
-9
-12
-15
INPUT VOLTAGE
-18
VIN
-21
-24
-27
50
75
100
OUTPUT CURRENT
(V)
Output Voltage vs Junction Temperature
125
IO
150
175
200
(mA)
Power Derating Curve
-12
800
Vin=-16V
IO=5mA
700
-9
-8
-7
-6
-5
600
PD
-10
POWER DISSIPATION
OUTPUT VOLTAGE VO
(V)
(W)
-11
500
400
300
200
100
50
75
100
TJ
125
150
50
75
Rev:2024A1
100
TJ
125
150
Page :2
79L09
Outlitne Drawing
SOT-89-3L Package Outline Dimensions
Symbol
A
b
b1
c
D
D1
E
E1
e
e1
L
Dimensions In Millimeters
Max
Min
1.400
1.600
0.320
0.520
0.400
0.580
0.350
0.440
4.400
4.600
1.550 REF.
2.300
2.600
3.940
4.250
1.500 TYP.
3.000 TYP.
0.900
1.200
Dimensions In Inches
Min
Max
0.055
0.063
0.013
0.020
0.016
0.023
0.014
0.017
0.173
0.181
0.061 REF.
0.091
0.102
0.155
0.167
0.060 TYP.
0.118 TYP.
0.035
0.047
SOT-89-3L Suggested Pad Layout
Note:
1.Controlling dimension:in/millimeters.
2.General tolerance: ±0.05mm.
3.The pad layout is for reference purposes only.
PACKAGE SPECIFICATIONS
Package Reel Size
SOT-89-3L
Reel DIA.
(mm)
Q'TY/Reel
(pcs)
Box Size
(mm)
QTY/Box
(pcs)
Carton Size
(mm)
330
1000
203×203×195
40000
438×438×220
7'
Rev:2024A1
G.W.(Kg)
180000
Page :3
很抱歉,暂时无法提供与“79L09”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.59519
- 50+0.47078
- 150+0.40857
- 1000+0.36191
- 2000+0.32454
- 5000+0.30586
