LAD52CXXL01 SERIES
Electrostatic Discharged Protection Devices (ESD) Data Sheet
Description
The LAD52CXXL01 Series of Transient Voltage Suppressors (TVS)
are designed to replace multilayer varistors (MLVs) in portable
applications such as cell phones, notebook computer, and PDAs.
They offer superior electrical characteristics such as lower clamping
voltage and no device degradation when compared to MLVs. They
are designed to protect sensitive semiconductor components from
damage or upset due to electrostatic discharge (ESD), lightning,
electrical fast transients (EFT), and cable discharge events (CDE).
Features
IEC61000-4-2 ESD 15KV Air, 8KV contact compliance
SOD523 surface mount package
Working voltage: 3.3V,5V
Low leakage current
Low operating and clamping voltages
Solid-state silicon avalanche technology
Lead Free/RoHS compliant
Solder reflow temperature: Pure Tin-Sn, 260~270℃
Flammability rating UL 94V-0
Meets MSL level 1, per J-STD-020
AEC-Q101 qualified
1
2
Pin Configuration
Maximum Ratings
Rating
Symbol
ESD voltage (Contact discharge)
Value
±8
VESD
ESD voltage (Air discharge)
Storage & operating temperature range
Unit
kV
±15
TSTG ,TJ
-55~+150
Electrical Characteristics (TJ=25℃)
LAD52C03L01(Marking:A3)
Parameter
Reverse stand-off voltage
Reverse breakdown voltage
Symbol
Condition
Min.
Typ.
VRWM
Max.
Unit
3.3
V
VBR
IBR=1mA
Reverse leakage current
IR
VR=3.3V
1
μA
Clamping voltage (tp=8/20μs)
VC
IPP=1A
7
V
Off state junction capacitance
CJ
0Vdc,f=1MHz
Revision:ESD-LAD52CXXL01 SERIES-001(A1)
1/4
4.0
V
10
pF
http://brightking.pulseelectronics.com
LAD52CXXL01 SERIES
LAD52C05L01(Marking:A5)
Parameter
Symbol
Condition
Min.
Typ.
VRWM
Max.
Unit
5
V
VBR
IBR=1mA
5.6
V
IR
VR=5V
1
μA
VC
IPP=1A
9.8
V
CJ
0Vdc,f=1MHz
12
pF
Typical Characteristics Curves
Figure 1. Pulse Waveforms
tr
25
Peak value Ipp
Waveform
Parameters:
tr=8µs
td=20µs
90
80
Clamping Voltage (V)
% of Peak Power Current
110
100
Figure 2. Clamping Voltage vs. Peak Pulse Current
70
60
50
40
30
td=t|IPP/2
10
Waveform
Parameters:
tr=8µs
tb=20µs
5
10
10
15
30
t-Time (μs)
2
3
4
5
6
IPP-Peak Pulse Current (A)
Figure 3. Capacitance vs. Reverse Voltage
Figure 4. ESD Clamping(8kV Contact IEC61000-4-2)
F=1MHz
Junction Capacitance (pF)
18
16
14
12
LAD52C05L01
10
8
LAD52C03L01
6
4
2
2
3
4
5
Reverse Voltage (V)
2/4
LAD52CXXL01 SERIES
Recommended Soldering Conditions
Reflow Soldering
Critical Zone
TL to TP
tP
TP
Ramp-up
TL
tL
Temperature
TS max
TS min
Ramp-down
tS
Preheat
25
t 25℃ to Peak
Time
Recommended Conditions
Profile Feature
Pb-Free Assembly
Average ramp-up rate (TL to TP)
3℃/second max.
Preheat
-Temperature Min (TS min)
-Temperature Max (TS max)
-Time (min to max) (ts)
150℃
200℃
60-180 seconds
TS max to TL
-Ramp-up Rate
3℃/second max.
Time maintained above:
-Temperature (TL)
-Time (tL)
217℃
60-150 seconds
Peak Temperature (TP)
260℃
Time within 5℃ of actual Peak Temperature (tP)
Ramp-down Rate
6℃/second max.
Time 25℃ to Peak Temperature
20-40 seconds
8 minutes max.
3/4
LAD52CXXL01 SERIES
Dimensions (SOD-523)
Dimension (mm)
Symbol
Millimeters
Min.
Max.
Min.
Max.
A
0.50
0.70
0.020
0.028
B
0.07
0.20
0.003
0.008
C
0.70
0.90
0.028
0.035
D
0.25
0.35
0.010
0.014
E
1.10
1.30
0.043
0.051
F
1.50
1.70
0.059
0.067
G
0.15
0.25
0.006
0.010
D C
0.55
(2X)
0.50
(2X)
E
F
0.80
1.90
A
B
Recommended Soldering Pad Layout
G
Inches
Packaging
Tape
P0
P1
P2
K
W
B0
B
F
E
øD0
A0
øD1
t
A
Symbol
Dimension (mm)
W
8.00±0.30
P0
4.00±0.10
P1
2.00±0.10
P2
2.00±0.10
D0
Φ1.55±0.10
D1
Φ0.50±0.05
E
1.75±0.10
F
3.50±0.10
A
1.00±0.10
A0
0.50±0.10
B
1.80±0.10
B0
1.30±0.10
K
0.65±0.10
t
0.20±0.05
D
Φ178.0±2.0
D2
Φ13.0
W1
9.5
Reel
D2
D
W1
Quantity: 3000PCS
4/4
很抱歉,暂时无法提供与“LAD52C05L01”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.63910
- 200+0.21230
- 1500+0.13310
- 3000+0.10571
- 国内价格
- 20+0.22000
- 200+0.17216
- 600+0.14559
- 3000+0.12528
