2020.0
2020.0
    CONTA-CLIP
2020.0 数据手册
Data sheet 2020.0 Q 3 Cross-connector, No. of poles: 3, Mounting type: Can be screwed on, Width: 17 mm, Rated cross-section: 4 mm², Colour: natural Business data Article number 2020.0 Article name Q3 GTIN (EAN) 4044211048235 Colour Natural Packaging unit 50 Quantity unit PC Weight per piece (not including packaging) 8.19 g Weight per piece (including packaging) 8.26 g Unit of weight G Customs number 85389099 Country of origin CZ Product description Cross-connector Creation date 01.10.2022 12:21:45 Subject to technical changes 1 Data sheet 2020.0 Q 3 Technical data Dimensions Length 6 mm Width 17 mm Hole diameter 3.4 mm Hole spacing (mid-point to mid-point) 6.1 mm Pitch size 6 mm Ratings Voltage with partition, max. 800 V Voltage without partition, max. 400 V Rated current 27 A Rated cross-section 4 mm² Contamination degree 3 Connection data No. of poles 3 Screw head Slotted Screw threading M3 Tightening torque, min. 0.5 Nm Tightening torque, max. 1 Nm Materials Material Copper Surface Nickel Surface screw Galvanized Further technical data Mounting type Screwable Number of bridged terminals 3 Creation date 01.10.2022 12:21:45 Subject to technical changes 2 Data sheet 2020.0 Q 3 Technical data Environmental Product Compliance REACH Conform No REACH Reference date 2022-06-10 REACH Candidate Substance Note No REACH CAS 1 Substance LEAD REACH CAS 1 Percent minimal 0.1 % REACH CAS 1 Percent maximum 4% REACH CAS 1 Number 7439-92-1 RoHS Conform yes RoHS Exception rule 6c Creation date 01.10.2022 12:21:45 Subject to technical changes 3 Data sheet 2020.0 Q 3 Media Creation date 01.10.2022 12:21:45 Subject to technical changes 4 Data sheet 2020.0 Q 3 Accessories Screwdriver Screwdriver with bare blade, Colour: Black-grey Article number Article name GTIN (EAN) Packaging unit 1086.0 SDB 0,6x3,5 4044211014797 1 ST ##INVERSE##CONTA-CONNECT Feed-through terminal, Faston Spade connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Width: 6 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1014.2 FF 2,5 BG 4044211003203 100 Feed-through terminal, Faston Spade connection / screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 2.5 mm², Width: 6 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1019.2 SF 2,5-4 BG 4044211004323 100 ST Feed-through terminal/block variant, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 4 mm², Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1003.2 KBL 2,5-4 beids. Bez-g (1-9) BG 4044211000721 10 ST Feed-through terminal for direct mount/block variant, Screw connection, Mounting type: Mounting surface, Rated cross-section: 4 mm², Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1385.2 KBL 2,5-4/10-D BG 4044211044268 10 Four-wire motor-connection block, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 4 mm², Colour: Multi-coloured Article number Article name GTIN (EAN) Packaging unit 1521.2 VMAB 2,5-4 4044211046682 10 ST Creation date 01.10.2022 12:21:45 Subject to technical changes 5 Data sheet 2020.0 Q 3 ##INVERSE##CONTA-CONNECT Five-wire mains-connection block, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 4 mm², Colour: Multi-coloured Article number Article name GTIN (EAN) Packaging unit 1524.2 FNAB 2,5-4 4044211046781 10 ST Feed-through terminal/block variant, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 4 mm², Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1002.2 KBL 2,5-4 BG 4044211000516 10 ST Feed-through terminal for direct mount/block variant, Screw connection, Mounting type: Mounting surface, Rated cross-section: 4 mm², Width: 6 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1388.2 KBL 2,5-4-D BG 4044211044299 100 Feed-through terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 4 mm², Width: 6 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1001.2 RK 2,5-4 BG 4044211000240 100 Feed-through terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 4 mm², Width: 6 mm, Colour: Black-yellow Article number Article name GTIN (EAN) Packaging unit 1563.2 RK 2,5-4/PE BKYE 4044211047344 100 ST Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6 mm, Colour: Black Article number Article name GTIN (EAN) Packaging unit 1748.4 RK 2,5-4 PA-G BK 4044211141134 100 ST Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1167.2 RK 2,5-4/35/SAS BG 4044211128623 100 Creation date 01.10.2022 12:21:45 Subject to technical changes 6 Data sheet 2020.0 Q 3 ##INVERSE##CONTA-CONNECT Feed-through terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 4 mm², Width: 6 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1211.2 RK 2,5-4/ZRL BG 4044211028558 100 Feed-through terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 4 mm², Width: 6 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1210.2 RK 2,5-4/ZR BG 4044211028459 100 Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1577.2 RK 2,5-4/35 BG 4044211047566 100 Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 10 mm², Width: 8 mm, Colour: Black Article number Article name GTIN (EAN) Packaging unit 1749.4 RK 6-10 PA-G BK 4044211141141 100 ST Creation date 01.10.2022 12:21:45 Subject to technical changes 7
2020.0 价格&库存
很抱歉,暂时无法提供与“2020.0”相匹配的价格&库存,您可以联系我们找货
