SHLVP-31V-S-1
SHLVP-31V-S-1
    JST
    P=0.5mm(交错脚)
    2X15P 1MM
SHLVP-31V-S-1 数据手册
SHLV CONNECTOR Emboss Emboss Tape Tape 1.0 mm pitch/Disconnectable Crimp style connectors SHLV CONNECTOR Specifications • Current rating: 1.0 A AC/DC (AWG #28) • Voltage rating: 30 V AC/DC • Temperature range: -25℃ to +85℃ (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 30 mΩ max. After environmental tests/ 50 mΩ max. • Insulation resistance: 100 MΩ min. • Withstanding voltage: 500 VAC/minute • Applicable wire: Conductor size/ AWG #32 to #28 Insulation O.D./ 0.4 to 0.8 mm This is the wire to board connector corresponding to the high frequency transmission (LVDS: Low Voltage Differential Signaling) with a lot of adoption for PDP, LCD - TV and so on. This connector was developed to have excellent workability, strength and cost performance. This connector is used not only for LVDS, but also for multi - circuits connector (small and space saving type) in normal circuit. ● Corresponding to LVDS (Low Voltage Differential Signaling) ● Secure locking structure ● Connector strength ● Contact locking structure * In using the products,refer to "Handling Precautions for Terminals and Connectors" described on our website (Technical documents of Product information page). * RoHS2 compliance * Dimensional unit: mm * Contact JST for details. Standards  ® ® ® PC board layout and Assembly layout ® Top entry type ® 1±0.05 A±0.05 0.5±0.05 0.3 A±0.05 5.15 6 ±0.05 2.6 ±0.05 (8.5) 4.4 ±0.05 Circuit No.1 0.3 ±0.05 6.65 ±0.05 (7.95) Connector outline 2.6 0.3 ±0.05 0.3±0.05 Circuit No.1 1.6 ±0.05 Side entry type 5 0.7 ±0.05 0.6±0.05 1.6±0.05 ±0.05 1.6 ±0.05 0.7±0.05 Recognized E60389 ±0.05 Connector outline 0.7±0.05 0.5±0.05 VHコネクタ表1 1.6±0.05 Note: 1 . The above figure is the figure viewed from the connector mounting side. 2. T  olerances are non-cumulative: ± 0.05 mm for all centers. 3. T  he dimensions above should serve as a guideline. Contact JST for details. Contact Applicable wire mm2 AWG # Model No. SSHL-003GA1-P0.2 0.032~0.08 4.75 0.8 2.35 41,000 Phosphor bronze, nickel-undercoated, Mating part; gold-plated, Crimping part; gold-plated 0.8 0.4 RoHS2 compliance Contact Crimping machine Crimp applicator SSHL-003GA1-P0.2 AP-K2N 1 0.4~0.8 32~28 Material and Finish 2 0.5 Insulation O.D. (mm) Q'ty/reel MKS-L-10-3 Applicator Dies Crimp applicator with dies MK/SSH/L-003-02 APLMK SSH/L003-02 Note: Contact JST for fully automatic crimping applicator. SHLV CONNECTOR Housing No. of circuits With secure lock 21 31 B Model No. SHLVP-21V-S-1 SHLVP-31V-S-1 Dimensions (mm) B C Q'ty/bag 10.0 16.7 17.7 3,000 15.0 21.7 22.7 2,000 SHLV CONNECTOR A Material and Finish 1 2.6 PBT, UL94V-0, natural (white) 5.7 6 N A 11 Circuit No.1 mark 4.6 RoHS2 compliance As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. C SHLVP-21V-S-1 S...natural (white) LE...light blue Shrouded header No. of circuits Top entry type 21 4.7 31 1.05 0.2 0.5 2 0.7 5 No. of circuits 21 31 A Model No. Top entry type BM21B-SHLVS-G-TBT BM31B-SHLVS-G-TBT Dimensions (mm) A B Model No. Side entry type SM21B-SHLVS-G-TB SM31B-SHLVS-G-TB Dimensions (mm) A B Q'ty/reel 10.0 15.0 1,500 15.0 20.0 1,500 Q'ty/reel 10.0 15.0 2,000 15.0 20.0 2,000 Material and Finish B Contact: Phosphor bronze, nickel-undercoated, gold-plated Wafer: Polyamide, UL94V-0, natural (ivory) Solder tab: Brass, copper-undercoated, tin-plated (reflow treatment) Side entry type 5 RoHS2 compliance This product displays (LF)(SN) on a label. The products listed above are supplied on embossed-tape. As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. A B ex. 2 4.7 0.7 BM21B-SHLVS-G-TBT S...natural (ivory) LE...light blue ex. SM21B-SHLVS-G-TB S...natural (ivory) LE...light blue 2
SHLVP-31V-S-1 价格&库存
很抱歉,暂时无法提供与“SHLVP-31V-S-1”相匹配的价格&库存,您可以联系我们找货
SHLVP-31V-S-1
    • 500+1.06250
    • 1000+1.05040
    库存:8753
    SHLVP-31V-S-1
      • 2000+0.90200
      库存:6000
