VHR-5N-BK
VHR-5N-BK
    JST
    P=3.96mm
    1X5P 3.96MM
VHR-5N-BK 数据手册
VH CONNECTOR CONNECTOR 3.96 mm mm pitch/Disconnectable pitch/DisconnectableCrimp Crimpstyle styleconnectors connectors 6 Specifications 4 5 • Current rating: 10 A AC/DC (AWG #16) • Voltage rating: 250 V AC/DC • Temperature range: -25℃ to +85℃ (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 10 mΩ max. After environmental tests/ 20 mΩ max. • Insulation resistance: 1,000 MΩ min. • Withstanding voltage: 1,500 VAC/minute • Applicable wire: AWG #22 to #16 • Applicable PC board thickness: 1.6 mm 2 1 T JS 6 3 VH CONNECTOR CONNECTOR VH Note: Do not branch in parallel current which exceeds the rated current. If branched in parallel, current imbalance or other problems may develop. If it is absolutely necessary to branch such a large current in parallel, be sure to use contacts made of phosphor bronze. Design the circuits without causing imbalance and provide an extra margin for each circuit. This small, field-proven connector for printed circuit boards is reliable and has a large current carrying capacity. It can be used with a wide variety of signal, power supply, and output circuits that appear in consumer electronic products. ● Proven box contact ● Compact connector with a large capacity ● Secure contact and mounting ® * In using the products,refer to "Handling Precautions for Terminals and Connectors" described on our website (Technical documents of Product information page). * RoHS2 compliance * Dimensional unit: mm * Contact JST for details. Standards ® Recognized E60389 Certified LR20812 R75122 ® ® ® PC board layout and Assembly layout Locking header Side entry type 3.96±0.05 (20.5) (16.5) 8 3.96±0.05 10.5 10.5 * 7.2 min. Locking header Top entry type +0.1 φ1.65 0 +0.1 φ1.65 0 * 7.2 min. *11.0 max. when used with the VR connector receptacle. Shrouded header Locking header Side entry type with PCB stabilizer 3.96 10.5 1.5 ±0.05 +0.1 (21) φ1.4 0 (16.5) 10.5 Circuit No.1 3.4 ±0.05 3.96±0.05 ±0.05 +0.1 φ1.65 0 +0.1 19 1 φ1.65 0 Note: 1 . The above figure is the figure viewed from soldering side. 2. Tolerances are non-cumulative: ± 0.05 mm for all centers. 3. Please consider the pattern layout design in case of applying the large current. 4. Hole dimensions differ according to the type of PC board and piercing method. The dimensions above should serve as a guideline. Contact JST for details. VH CONNECTOR Contact Applicable wire AWG # mm2 Model No. SVH-21T-P1.1 SVH-41T-P1.1 10.6 3 4 4.2 Insulation O.D. (mm) Q’ty/reel 0.33~0.83 22~18 1.7~3.0 4,500 0.5 ~1.25 20~16 1.7~3.0 3,500 VH CONNECTOR Material and Finish 3.8 Phosphor bronze, tin-plated (reflow treatment) RoHS2 compliance Note: When using retainer mountable type housing, applicable wire's insulation O. D. shall be 1.7 to 2.2 mm. Contact SVH-21T-P1.1 SVH-41T-P1.1 Crimping machine Crimp applicator AP-K2N MKS-L Applicator Dies Crimp applicator with dies MK/SVH-21-11 APLMK SVH21-11 MK/SVH-41-11 APLMK SVH41-11 Note: Contact JST for fully automatic crimping applicator. Housing M type Retainer mountable type B B A 6.2 Circuit No.1 No. of circuits 2 3 4 5 6 7 8 9 10 11 Model No. N type M type VHR-2N VHR-3N VHR-4N VHR-5N VHR-6N VHR-7N VHR-8N VHR-9N VHR-10N VHR-11N VHR-2M VHR-3M VHR-4M VHR-5M VHR-6M VHR-7M VHR-9M - Circuit No.1 Retaine mountable type Dimensions (mm) VHRR-2N VHRR-3N VHRR-5N VHRR-7N VHRR-8N VHRR-9N - A B Q’ty/ bag 3.96 7.86 1,000 7.92 11.82 11.88 15.78 (*) 1,000 15.84 19.74 19.80 23.70 (*) 23.76 27.66 500 27.72 31.62 500 31.68 35.58 500 35.64 39.54 500 39.60 43.50 500 500 15 13.3 13.3 Circuit No.1 10.5 5.7 A 5.7 A 10.5 B 10.6 N type Note: 1 . M  odels identified as VHR-( ) M incorporate measures to prevent electric shock and are thus safer in regard to high voltages. 2. The applicable housing for 2 circuits shrouded header is "VHR-2N" only. "VHRR-2N" is not applicable. 3. Contact JST for Glow Wire compliant connectors. (*) N / M type ; 1,000 Retainer mountable type ; 500 As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. VHR-2N-oo(blank)...natural (white) BK...black R...red BL...blue M...green D...orange Y...yellow PK...pink H...gray Material and Finish PA 6, UL94V-0, natural (white) RoHS2 compliance Retainer No. of circuits 2 circuits : 2.6 3 to 9 circuits : 4.2 2 3 5 7 8 A 9 Model No. VHS-2V VHS-3V VHS-5V VHS-7V VHS-8V VHS-9V A Q’ty/bag 3.70 1,000 7.52 1,000 15.44 1,000 23.36 1,000 27.32 1,000 31.28 1,000 Material and Finish Glass-filled PA 66, UL94V-0, natural (ivory) RoHS2 compliance 7.1 2 VH CONNECTOR Locking header Top entry type No. of circuits 1 H JST 8 □1.14 B2P-VH B3P-VH B4P-VH B5P-VH B6P-VH B7P-VH B8P-VH B9P-VH B10P-VH 2 3 4 5 2 Circuit No.1 8.5 (9.4) 6 3.2 7.7 A 7 14.6 B 8 9 10 A B Top entry Side entry type type 3.96 7.86 1,000 1,000 7.92 11.82 1,000 500 11.88 15.78 500 500 15.84 19.74 500 250 19.80 23.70 250 250 23.76 27.66 250 250 27.72 31.62 200 200 31.68 35.58 200 200 35.64 39.54 200 100 Post: Brass, copper-undercoated, tin-plated (reflow treatment) Wafer: PA 66, UL94V-0, natural (white) (9.4) RoHS2 compliance This product displays (LF)(SN) on a label. Note: 1 . Headers with a reduced number of posts are also available. Contact JST for details. 2. Contact JST for Glow Wire compliant connectors. 8.5 2 1 H JST 8 □1.14 7.7 3.96 A As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. 3.2 14.9 ex. B B2P(S)-VH-oo- (blank)...natural (white) BK...black R...red TR...tomato red BL...blue M...green O...orange Y...yellow PK...pink H...gray Model No. Top entry type of PBT No. of circuits (9.4) B 2 1.7 Circuit No.1 A 3 4 2 □1.14 6.8 8.5 (1.95) B2PS-VH B3PS-VH B4PS-VH B5PS-VH B6PS-VH B7PS-VH B8PS-VH B9PS-VH B10PS-VH Q’ty/box Dimensions (mm) Material and Finish Side entry type Circuit No.1 Model No. Top entry Side entry type type (1.95) 5 7.7 3.2 (14.6) 6 7 8 9 10 11 Q’ty/box Dimensions (mm) Top entry type of PBT Side entry type with PCB stabilizer B2P-VH-B B3P-VH-B B4P-VH-B B5P-VH-B B6P-VH-B B7P-VH-B B8P-VH-B B9P-VH-B B10P-VH-B B11P-VH-B S2P-VH S3P-VH S4P-VH S5P-VH S6P-VH S7P-VH - B Top entry type Side entry type 3.96 7.86 1,000 1,000 7.92 11.82 1,000 500 11.88 15.78 500 500 15.84 19.74 500 250 19.80 23.70 250 250 23.76 27.66 250 250 27.72 31.62 200 - 31.68 35.58 200 - 35.64 39.54 200 - 39.60 43.50 200 - A Material and Finish Post: Brass, copper-undercoated, tin-plated (reflow treatment) Wafer: Top entry type of PBT: Glass-filled PBT, UL94V-0, natural (white) Side entry type with PCB stabilizer: PA 66, UL94V-0, natural (white) Side entry type with PCB stabilizer 7.7 A RoHS2 compliance This product displays (LF)(SN) on a label. 4.5 As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. 2 □1.14 Circuit No.1 (9.4) 3.6 B ex. 13.4 B2P-VH-B-oo(blank)...natural (white) C...black R...red E...blue M...green Y...yellow ex. 3 S2P-VH-oo(blank)...natural (white) BK...black R...red BL...blue M...green Y...yellow VH CONNECTOR Shrouded header B No. of circuits 9.7 B2P-VH-FB-B B3P-VH-FB-B B4P-VH-FB-B B5P-VH-FB-B B6P-VH-FB-B B7P-VH-FB-B B8P-VH-FB-B B9P-VH-FB-B B10P-VH-FB-B 2 3 4 11 5 6 1.5 7 8 3.7 A Circuit No.1 9 10 □1.14 Dimensions (mm) A B Model No. Q’ty/ box 3.96 9.80 250 7.92 13.76 200 11.88 17.72 150 15.84 21.68 200 19.80 25.64 200 23.76 29.60 100 27.72 33.56 100 31.68 37.52 100 35.64 41.48 125 Material and Finish Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: Glass-filled PBT, UL94V-0, natural (white) 9.7 RoHS2 compliance This product displays (LF)(SN) on a label. Note:T  he applicable housing for 2 circuits shrouded header is "VHR-2N" only. "VHRR-2N" is not applicable. As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. 3.7 1.5 11 B 3.96 A Circuit No.1 ex. B2P-VH-FB-B-oo(blank)...natural (white) C...black R...red E...blue M...green O...orange Y...yellow PK...pink H...gray □1.14 Post-omitted Header 1) When giving the polarity to the product by removing the post (N-1)th circuit However, since the product that the 2nd post of 3-circuit connector is omitted doesn't have polarity, select 3). B *1 P *2 -VH e.g.) *1; No. of circuits (No. of posts) *2; Circuit No. of used original header Circuit No. 1 2 3 4 5 6 7 Circuit (post) Model No. B6P7-VH ; With circuit (post) ; Without circuit (post) 2) When giving the polarity to the product by removing the post in 2nd circuit However, since the product that the 2nd post of 3-circuit connector is omitted doesn't have polarity, select 3). B *1 P *2 -VH-L e.g.) Circuit No. 1 2 3 4 5 6 7 3 4 5 6 7 3 4 5 6 7 3 4 5 6 7 Circuit (post) Model No. B6P7-VH-L 3) When the pitch is set again 1. When setting two times of pitch with omitting every other one post However, posts shall be inserted in No.1-circuit and No. N-circuit. B *1 P *2 -VH e.g.) Circuit No. 1 2 Circuit (post) Model No. B4P7-VH 2. When setting three times of pitch with omitting every other two posts However, posts shall be inserted in No.1-circuit and No. N-circuit. B *1 P *2 -VH e.g.) Circuit No. 1 2 Circuit (post) Model No. B3P7-VH 3. When setting four times of pitch with omitting every other three posts However, posts shall be inserted in No.1-circuit and No. N-circuit. B *1 P *2 -VH e.g.) Circuit No. 1 2 8 9 Circuit (post) Model No. B3P9-VH 4
VHR-5N-BK 价格&库存
很抱歉,暂时无法提供与“VHR-5N-BK”相匹配的价格&库存,您可以联系我们找货
VHR-5N-BK
    • 1+1.199771+0.15594
    • 10+1.1128310+0.14464
    • 50+0.7476850+0.09718
    • 100+0.67813100+0.08814
    • 500+0.62597500+0.08136
    • 1000+0.599891000+0.07797
    • 2000+0.582502000+0.07571
    库存:137
    VHR-5N-BK
      • 1000+0.32740
      库存:1000
      VHR-5N-BK
        • 500+0.30180
        库存:982
        VHR-5N-BK
          库存:3000
