BV-SMAJ6CA
BV-SMAJ6CA
    BENCENT(槟城)
    SMA(DO-214AC)
    特性:IEC 61000-4-2(ESD) ±15KV (空气), ±8KV (接触)。 400Watts 峰值脉冲功率 (tp = 10 / 1000μS)。 对浪涌电压快速响应。 低钳位电压。 湿...
BV-SMAJ6CA 数据手册
SMA 400W series Version: A1 2016-9-9 Transient Voltage Suppressor Features Exterior IEC 61000-4-2(ESD)±15KV(air), ±8KV(contact) 400Watts peak pulse power (tp=10/1000μS) Quick response to surge voltage Low clamping voltage Moisture sensitivity level:Level 1 SMA Application Information Agency Approvals DC Port Icon RS485/232/422 Description Compliance with 2011/65/EU I/O Port Compliance withIEC61249-2-21:2003 Schematic Symbol cathode anode BI-directiona UNI-directional Part Number and Electrical Parameter Part Number Marking VR VBR VBR It Vc@IPP○ IPP○ IR@VR (V) min.(V) max.(V) (mA) (V) (A) (uA) 1 1 BI UNI BI UNI BV-SMAJ5CA BV-SMAJ5A A5C A5 5 6.4 7 10 9.2 43.5 800 BV-SMAJ6CA BV-SMAJ6A A6C A6 6 6.67 7.37 10 10.3 38.8 800 BV-SMAJ6.5CA BV-SMAJ6.5A A6.5C A6.5 6.5 7.22 7.98 10 11.2 35.7 500 BV-SMAJ7CA BV-SMAJ7A A7C A7 7 7.78 8.6 10 12 33.3 200 BV-SMAJ7.5CA BV-SMAJ7.5A A7.5C A7.5 7.5 8.33 9.21 1 12.9 31 100 BV-SMAJ8CA BV-SMAJ8A A8C A8 8 8.89 9.83 1 13.6 29.4 50 BV-SMAJ8.5CA BV-SMAJ8.5A A8.5C A8.5 8.5 9.44 10.4 1 14.4 27.8 20 BV-SMAJ9CA BV-SMAJ9A A9C A9 9 10 11.1 1 15.4 26 10 BV-SMAJ10CA BV-SMAJ10A A10C A10 10 11.1 12.3 1 17 23.5 5 BV-SMAJ11CA BV-SMAJ11A A11C A11 11 12.2 13.5 1 18.2 22 1 BV-SMAJ12CA BV-SMAJ12A A12C A12 12 13.3 14.7 1 19.9 20.1 1 BV-SMAJ13CA BV-SMAJ13A A13C A13 13 14.4 15.9 1 21.5 18.6 1 BV-SMAJ14CA BV-SMAJ14A A14C A14 14 15.6 17.2 1 23.2 17.2 1 BV-SMAJ15CA BV-SMAJ15A A15C A15 15 16.7 18.5 1 24.4 16.4 1 1/5 www.bencent.com.cn Specifications are subject to change without notice. Customers should verify actual device performance in their specific applications SMA 400W series Version: A1 2016-9-9 Transient Voltage Suppressor Part Number Marking VR VBR VBR It (V) min.(V) max.(V) (mA) Vc@IPP○ IPP○ IR@VR (V) (A) (uA) 1 1 BI UNI BI UNI BV-SMAJ16CA BV-SMAJ16A A16C A16 16 17.8 19.7 1 26 15.4 1 BV-SMAJ17CA BV-SMAJ17A A17C A17 17 18.9 20.9 1 27.6 14.5 1 BV-SMAJ18CA BV-SMAJ18A A18C A18 18 20 22.1 1 29.2 13.7 1 BV-SMAJ20CA BV-SMAJ20A A20C A20 20 22.2 24.5 1 32.4 12.3 1 BV-SMAJ22CA BV-SMAJ22A A22C A22 22 24.4 26.9 1 35.5 11.3 1 BV-SMAJ24CA BV-SMAJ24A A24C A24 24 26.7 29.5 1 38.9 10.3 1 BV-SMAJ26CA BV-SMAJ26A A26C A26 26 28.9 31.9 1 42.1 9.5 1 BV-SMAJ28CA BV-SMAJ28A A28C A28 28 31.1 34.4 1 45.4 8.8 1 BV-SMAJ30CA BV-SMAJ30A A30C A30 30 33.3 36.8 1 48.4 8.3 1 BV-SMAJ33CA BV-SMAJ33A A33C A33 33 36.7 40.6 1 53.3 7.5 1 BV-SMAJ36CA BV-SMAJ36A A36C A36 36 40 44.2 1 58.1 6.9 1 BV-SMAJ40CA BV-SMAJ40A A40C A40 40 44.4 49.1 1 64.5 6.2 1 BV-SMAJ43CA BV-SMAJ43A A43C A43 43 47.8 52.8 1 69.4 5.8 1 BV-SMAJ45CA BV-SMAJ45A A45C A45 45 50 55.3 1 72.7 5.5 1 BV-SMAJ48CA BV-SMAJ48A A48C A48 48 53.3 58.9 1 77.4 5.2 1 BV-SMAJ51CA BV-SMAJ51A A51C A51 51 56.7 62.7 1 82.4 4.9 1 BV-SMAJ54CA BV-SMAJ54A A54C A54 54 60 66.3 1 87.1 4.6 1 BV-SMAJ58CA BV-SMAJ58A A58C A58 58 64.4 71.2 1 93.6 4.3 1 BV-SMAJ60CA BV-SMAJ60A A60C A60 60 66.7 73.7 1 96.8 4.1 1 BV-SMAJ64CA BV-SMAJ64A A64C A64 64 71.1 78.6 1 103 3.9 1 BV-SMAJ70CA BV-SMAJ70A A70C A70 70 77.8 86 1 113 3.5 1 BV-SMAJ75CA BV-SMAJ75A A75C A75 75 83.3 92.1 1 121 3.3 1 BV-SMAJ78CA BV-SMAJ78A A78C A78 78 86.7 95.8 1 126 3.2 1 BV-SMAJ85CA BV-SMAJ85A A85C A85 85 94.4 104 1 137 2.9 1 BV-SMAJ90CA BV-SMAJ90A A90C A90 90 100 111 1 146 2.7 1 BV-SMAJ100CA BV-SMAJ100A A100C A100 100 111 123 1 162 2.5 1 BV-SMAJ110CA BV-SMAJ110A A110C A110 110 122 135 1 177 2.3 1 Note: Absolute maximum ratings measured at T= 25ºC RH = 45%-75% (unless otherwise noted). 1 Surge Waveform: 10/1000μS ○ Mark AXXC BI:AXXC 2/5 www.bencent.com.cn AXX UNI:AXX Specifications are subject to change without notice. Customers should verify actual device performance in their specific applications SMA 400W series Version: A1 2016-9-9 Transient Voltage Suppressor V-I Curve IPP VC VBR VR IR VC VBR VR It IR It VR V VBR VC IR It V VF Bi-directional Uni-directional IPP IPP Parameters Definition VF Forward Voltage drop for UNI-directional VC Clamping Voltage Ipp Surge Waveform 10/1000μs VR Stand-off Voltage VBR Breakdown Voltage IR Reverse Leakage Current It Test Current Ppp Peak Pulse Power Dissipation Thermal Considerations symbol Parameter Value Unit TJ Operating Junction Temperature Range -55 to +150 ℃ TS Storage Temperature Range -55 to +150 ℃ Environmental Characteristics Testing items High Temperature Reverse Bias Test High Temperature Life Test High-low Temperature Cycle Test High Temperature &High Humidity Test Pressure Cooker Test Resistance of Soldering Heat Technical standards Temperature: 150±3℃ Bias=80%VDRM Time:168H Temperature: 150℃ Time:168H Temperature: From -40℃ to125℃ Dwell time :30min,10cycles Temperature: 85℃ Humidity:85% Time:168H Temperature: 121℃,2atm. Humidity:100% Time:24H Temperature: 260±5℃ Time of dip soldering:10s,3times Note: The above testing items can be specified by customer’s special request 3/5 www.bencent.com.cn Specifications are subject to change without notice. Customers should verify actual device performance in their specific applications SMA 400W series Version: A1 2016-9-9 Transient Voltage Suppressor Product Dimensions REF. mm inch A 1.25--1.65 0.049--0.065 B 2.55--2.90 0.100--0.114 C 3.99--4.65 0.157--0.183 D 1.98--2.50 0.078--0.098 E 0.15--0.31 0.006--0.012 F 0.76--1.55 0.030--0.061 G 0.10--0.20 0.004--0.008 H 4.75--5.25 0.187--0.207 REF mm inch A 5.25 0.207 B 2.15 0.085 C 1.5 0.038 Recommended Soldering Pad Reflow Profile Reflow Condition Pre Heat Pb-Free assembly Temperature Min 150°C Temperature Max 200°C Time (min to max) 60 – 180 secs TP TP Average ramp up rate(Liquidus)Tamp(TL) 3°C/s max to peak Reflow 3°C/s max - Temperature (TL) (Liquidus) 217°C - Temperature (TL) 60 – 150 secs Peak Temperature (TP) 260+0/-5 °C Time within 5°C of actual peak Temperature (TP) 30secs Ramp-down Rate 6°C/s max Time 25°C to peak Temperature (TP) 8 min max. Do not exceed 260°C 4/5 www.bencent.com.cn TL Temperature TS(max) to TL - Ramp-up Rate Critical Zone TL to TP Ramp-up TL TS(max) Ramp-down Preheat TS(min) TS 25 time to peak temperature Time Specifications are subject to change without notice. Customers should verify actual device performance in their specific applications SMA 400W series Version: A1 2016-9-9 Transient Voltage Suppressor Package 5/5 Reel Information REF. mm inch A 2.79+/-0.3 0.110+/-0.012 B 5.33+/-0.3 0.210+/0-.012 d 1.5+/-0.1 0.059+/-0.004 D 330+/-10 13+/-0.394 D1 72+/-3 2.835+/-0.118 D2 13+/-0.3 0.512+/-0.012 E 1.5+/-0.3 0.059+/-0.012 F 5.5+/-0.4 0.217+/-0.016 P 4.0+/-0.2 0.157+/-0.008 P0 4.0+/-0.2 0.157+/-0.008 P1 2.0+/-0.2 0.079+/-0.008 W 12.0+/-0.2 0.472+/-0.008 W1 16.8+/-2.0 0.661+/-0.079 Outline Reel (pcs) Per Carton (pcs) Reel Diameters (mm) Taping 5,000 40,000 330 www.bencent.com.cn Carton Size(mm) L W H 360 360 380 Specifications are subject to change without notice. Customers should verify actual device performance in their specific applications
BV-SMAJ6CA 价格&库存
很抱歉,暂时无法提供与“BV-SMAJ6CA”相匹配的价格&库存,您可以联系我们找货
BV-SMAJ6CA
  • 1+0.33440
  • 500+0.22220
  • 2500+0.19360
  • 5000+0.17600
库存:4182
