HHXC160ARA151MF80G
HHXC160ARA151MF80G
    NCC(贵弥功)
    SMD,6.3x7.7mm
    HHXC160ARA151MF80G
HHXC160ARA151MF80G 数据手册
CONDUCTIVE POLYMER HYBRID ALUMINUM ELECTROLYTIC CAPACITORS Surface Mount HXC Series ・High reliability and high voltage are realized by hybrid electrolyte ・Endurance with ripple current : 4,000 hours at 125℃ ・Rated voltage range : 16 to 63Vdc, Capacitance range : 6.8 to 470μF ・For high temperature and high reliability applications. (Automotive equipment, Base station equipment, etc.) ・RoHS2 Compliant ・Halogen Free ・AEC-Q200 compliant : Please contact Chemi-Con for more details, test data, information. HXC Higher temperature HXD ◆SPECIFICATIONS Items Characteristics Category Temperature Range Rated Voltage Range Capacitance Tolerance Leakage Current -55 to +125℃ 16 to 63Vdc ±20% (M) I=0.01CV or 3μA, whichever is greater Where, I : Max. leakage current (μA) , C: Nominal capacitance(μF), V : Rated voltage(V) Rated voltage(Vdc) 16V 25V 35V 50V 63V tanδ 0.16 0.14 0.12 0.10 0.08 (Max.) Dissipation Factor (tanδ) Low Temperature Characteristics (Max. Impedance Ratio) Endurance (at 20℃, 120Hz) (at 20℃ after 2 minutes) (at 20℃, 120Hz) Z(-25℃)/Z(+20℃)≦1.5 Z(-55℃)/Z(+20℃)≦2.0 (at 100kHz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated ripple current is applied (the peak voltage shall not exceed the rated voltage) for 4,000 hours at 125℃. Capacitance change ≦±30% of the initial value D.F. (tanδ) ≦ 200% of the initial specified value ESR ≦ 200% of the initial specified value Leakage current ≦ The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 125℃ without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to item 4.1 of JIS C 5101-4. Capacitance change ≦±30% of the initial value D.F. (tanδ) ≦ 200% of the initial specified value ESR ≦ 200% of the initial specified value Leakage current ≦ The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjecting them to the DC rated voltage at 85℃, 85% RH for 2,000 hours. Appearance No significant damage Capacitance change ≦ ±30% of the initial value D.F.(tanδ) ≦ 200% of the initial specified value ESR ≦ 200% of the initial specified value Leakage current ≦ The initial specified value Shelf Life Bias Humidity Test ◆DIMENSIONS [mm] ● Terminal ● Terminal ● Size Code : A code : E61 to JA0 ● Size Code : G(Vibration resistant structure) code : HA0 and JA0 Vent for JA0 Vent for JA0 0.3max. W 0.3max. L±0.3 (Note) L±0.5 A±0.2 Note : L±0.5 for HA0 and JA0 2 3 4 H HXC 5 6 7 8 9 10 RA 11 12 Size Code E61 F61 F80 HA0 JA0 φD 5 6.3 6.3 8 10 L 5.8 5.8 7.7 10.0 10.0 A 5.3 6.6 6.6 8.3 10.3 B 5.3 6.6 6.6 8.3 10.3 C 5.9 7.2 7.2 9.0 11.0 W 0.5 to 0.8 0.5 to 0.8 0.5 to 0.8 0.7 to 1.1 0.7 to 1.1 P 1.4 1.9 1.9 3.1 4.5 A±0.2 : Dummy terminals ◆MARKING ◆PART NUMBERING SYSTEM 1 P C±0.2 B±0.2 φD±0.5 P C±0.2 B±0.2 φD±0.5 W 13 14 M 15 16 17 18 G Supplement code Size code Capacitance tolerance code Capacitance code (ex. 47µF:470, 100µF:101) Taping code Terminal code Voltage code (ex. 35V:350, 50V:500) Series code Category EX) 35V270µF 47E 270 V HC ●Rated voltage symbol Rated voltage (Vdc) 16 25 35 50 63 Symbol C E V H J Please refer to "Product code guide (conductive polymer hybrid type)" Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001U Ver.2 CONDUCTIVE POLYMER HYBRID ALUMINUM ELECTROLYTIC CAPACITORS Surface Mount HXCSeries ◆STANDARD RATINGS WV (Vdc) Cap (µF) 47 82 150 270 470 33 47 56 68 100 150 220 270 330 22 27 47 47 68 100 150 150 270 10 15 22 33 33 47 56 68 100 120 6.8 10 10 22 22 33 33 47 56 82 16 25 35 50 63 Size code ESR (mΩmax./20℃, 100kHz) Rated ripple current (mArms/125℃, 100kHz) Part No. E61 F61 F80 HA0 JA0 E61 F61 F61 F80 F80 HA0 HA0 JA0 JA0 E61 F61 F61 F80 F80 HA0 HA0 JA0 JA0 F61 F80 F61 F80 HA0 HA0 JA0 HA0 JA0 JA0 F61 F61 F80 F80 HA0 HA0 JA0 HA0 JA0 JA0 80 45 27 22 18 80 50 50 30 30 27 27 20 20 100 60 60 35 35 27 27 20 20 80 40 80 40 30 30 25 30 25 25 120 120 80 80 40 40 30 40 30 30 550 950 1,450 1,700 2,100 550 900 900 1,400 1,400 1,600 1,600 2,000 2,000 550 900 900 1,400 1,400 1,600 1,600 2,000 2,000 750 1,100 750 1,100 1,250 1,250 1,600 1,250 1,600 1,600 700 700 900 900 1,100 1,100 1,400 1,100 1,400 1,400 HHXC160ARA470ME61G HHXC160ARA820MF61G HHXC160ARA151MF80G HHXC160□RA271MHA0G HHXC160□RA471MJA0G HHXC250ARA330ME61G HHXC250ARA470MF61G HHXC250ARA560MF61G HHXC250ARA680MF80G HHXC250ARA101MF80G HHXC250□RA151MHA0G HHXC250□RA221MHA0G HHXC250□RA271MJA0G HHXC250□RA331MJA0G HHXC350ARA220ME61G HHXC350ARA270MF61G HHXC350ARA470MF61G HHXC350ARA470MF80G HHXC350ARA680MF80G HHXC350□RA101MHA0G HHXC350□RA151MHA0G HHXC350□RA151MJA0G HHXC350□RA271MJA0G HHXC500ARA100MF61G HHXC500ARA150MF80G HHXC500ARA220MF61G HHXC500ARA330MF80G HHXC500□RA330MHA0G HHXC500□RA470MHA0G HHXC500□RA560MJA0G HHXC500□RA680MHA0G HHXC500□RA101MJA0G HHXC500□RA121MJA0G HHXC630ARA6R8MF61G HHXC630ARA100MF61G HHXC630ARA100MF80G HHXC630ARA220MF80G HHXC630□RA220MHA0G HHXC630□RA330MHA0G HHXC630□RA330MJA0G HHXC630□RA470MHA0G HHXC630□RA560MJA0G HHXC630□RA820MJA0G □ : Enter the appropriate terminal code. ◆RATED RIPPLE CURRENT MULTIPLIERS ・Frequency Multipliers Capacitance(µF) to 15 to 47 to 220 to Frequency(Hz) 10 33 150 470 120 0.03 0.07 0.10 0.13 1k 0.30 0.30 0.40 0.45 5k 0.50 0.50 0.60 0.65 10k 0.60 0.60 0.70 0.75 20k 0.70 0.70 0.80 0.85 30k 0.75 0.75 0.80 0.85 100k to 500k 1.00 1.00 1.00 1.00 Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001U
HHXC160ARA151MF80G 价格&库存
很抱歉,暂时无法提供与“HHXC160ARA151MF80G”相匹配的价格&库存,您可以联系我们找货
HHXC160ARA151MF80G
  • 1+3.46680
  • 10+2.75400
  • 30+2.45160
库存:65
