GT25H-2024SCF
GT25H-2024SCF
    HRS(广濑)
    20 TO 22 AWG
GT25H-2024SCF 数据手册
GT5 Interface Connector GT13 GT19 GT21 Dec.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. PO5G — SMT Multi-contact Connectors — GT16 GT25 Series GT26 GT36 GT11 GT17 GT32 GT3 GT10 The width of tab is 025 size. GT25 ■ Product Specifications Insulation Resistance 100MΩ min Withstanding Voltage AC650V for one minute Contact Resistance Operating Temperature Range No more than 30mΩ (initially) −40℃ to +105℃(Note 2) Note 1 : When using different consitions, please consult with Hirose. Note 2 : Includes temperature rise caused by current flow. GT8E Rated Current 3A(Note 1) GT18W Metal holddowns to solder by reflow are used instead of screws for PCB mounting. GT9 GT15 In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 195 Interface Connector GT7 Features ■ F Terminal GT13 GT5 GT25 Series ● Interface Connector 1.9 15.3 11.8 GT19 GT21 GT26 HRS No. 775-0039-6 775-0070-6 Material Plating Copper palloy Tin plating Conductor Size (AWG) 20 to 22 AWG 24 to 28 AWG Outer Diameter φ1.0 to 1.7 φ0.5 to 1.0 Packaging RoHS 10,000 pcs/reel YES ■ F Connector ● Housing(Pre-assembled retainer) 18.5 GT17 GT11 GT36 Part No. GT25H-2024SCF GT25HB-2428SCF GT32 GZiV^cZgXdbeaZiZanVhhZbWaZYXdcY^i^dc GT3 A 7.4 13 2.8 GT7 9.5 2.7 GZiV^cZgiZbedgVg^anVhhZbWaZYXdcY^i^dc GT10 GZiV^cZg =djh^c\ GT18W GT25 GT8E GT9 GT15 Interface Connector Dec.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. PO5G GT16 1.4 196 Part No. HRS No. GT25-8DS-HU/R 775-0059-3 GT25-12DS-HU/R 775-0062-8 GT25-24DS-HU/R 775-0046-1 GT25-32DS-HU/R 775-0044-6 Color Housing:Black Retainer:Dark Gray Material No. of Contacts A Dimension Housing:PPE Retainer:PBT 8 11 PBT 12 15.4 24 28.6 32 37.4 Housing:PPE Retainer:PBT Note 1 : Pre-assembled retainer into housing body Note 2 : After insert assembled contact, retainer has to be pushed-in correct position Note 3 : Available to purchase housing and retainer separately for repair. Packaging RoHS 1 YES GT25 Series ● Interface Connector GT5 Improved prying force 3 BRecommended PCB pattern D 0.75±0.03 +0.1 7.4  0 8.9±0.05 4.3±0.05 .05 +00   PO5G (8) 9.65 A #' ¢& +0.1 E 0.8 4.3 8 0.4 C 1.4 0.64 0.1 2.2 GT19 4 3 13 0.64 2  0 2H GT21 GT26 (Under development) 775-0045-9 GT25H-32DP-2.2H (Under development) PPS Brass/ Tin plating 23.7 19.3 20.73 12.1±0.05 20.73±0.05 20 32.5 28.1 29.53 20.9±0.05 29.53±0.05 24 36.9 32.5 33.93 25.3±0.05 33.93±0.05 32 45.7 41.3 42.73 34.1±0.05 42.73±0.05 RoHS 200 pcs/reel YES GT17 GT25H-24DP-2.2H Black 12 Packaging Improved prying force 1.5 Ø1 BRecommended PCB pattern 1.2±0.05 .2 +   0.0 0 5 GT25H-*DP-2.2V +   0.0 0 5 6.48 -0.05  0 +0.1 2  0 E 推奨基板寸法図 4.4 18.8 GT10 9.65 4.3 3.3 0.8 GT18W 0.4 C 4.825 GT25 GT8E Part No. Material/ Plating Black PPS Brass/ Tin plating 775-0050-9 GT25H-24DP-2.2V (Under development) GT25H-32DP-2.2V 775-0053-7 No. of A B C D Contacts Dimension Dimension Dimension Dimension E Dimension 12 23.7 19.3 20.73 11±0.05 20.73±0.05 24 36.9 32.5 33.93 24.2±0.05 33.93±0.05 32 45.7 41.3 42.73 33±0.05 42.73±0.05 Packaging RoHS 1 YES GT15 Color GT9 GT25H-12DP-2.2V HRS No. 197 Interface Connector 9.65 GT7 4.3±0.05 7.4  0 + 2  B 1.2±0.05 .2 +0.1 4.3±0.05 Ø1  0 +0.1 7.4  0 13.25 3 6× 1.15 0.64 0.6 2.2±0.05 GT3 2.2 3.23 -0.05 D 0.64 GT32 2.2±0.05 6× A +0.05 GT25H-20DP-2.2H E Dimension 6.92 0 775-0038-3 No. of A B C D Contacts Dimension Dimension Dimension Dimension GT11 GT25H-12DP-2.2H Material/ Plating Color +0.05 HRS No. 10.17  0 Part No. GT36 Dec.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. GT16 16.9 +0.1 3.6  0 1.1±0.05 GT25H-*DP-2.2H B GT13 0.4 BRecommended PCB Pattern 8 GT16 PO5G 18±0.05 23.43±0.05 22 2.2 0.4 0.8 23.43 18 4.3 0.1 * 1.4 GT19 9.5 4.7 9.65 8 GT21 2 1. GT26 φ GT25-8P-2.2H(70) HRS No. Color Material/Plating Packaging RoHS 775-0001-3 70 Light Gray PPS Brass/ Tin plating 200pcs/reel YES BRecommended PCB Pattern 2 rows 3.6+0.1 0 D GT17 1.1±0.05 0.75±0.03 GT25-*DP-2.2H 2+0.1 0 9.65 φ E 0.64 0.4 0.8 4.3 8 GT8E GT25 GT18W GT10 C 1.4 2.2 0.1 3 * 4 GT7 12.7 GT3 A B .05 +00 1.2 7.4+0.1 0 (8) 8.9±0.05 4.3±0.05 8 17 GT32 3 0.4 0.64 GT11 GT36 Part No. Part No. GT9 198 HRS No. Color Material/ Plating No. of A B C D Contacts imension imension imension imension E imension GT25-8DP-2.2H 775-0004-1 8 17.65 13.2 14.63 7.7±0.05 14.63±0.05 GT25-12DP-2.2H 775-0005-4 12 22.05 17.6 19.03 12.1±0.05 19.03±0.05 GT25-16DP-2.2H 775-0006-7 16 26.45 22.0 23.43 16.5±0.05 23.43±0.05 24 35.25 30.8 32.23 25.3±0.05 32.23±0.05 GT25-28DP-2.2H(01) 775-0040-5 01 28 39.65 35.2 36.63 29.7±0.05 36.63±0.05 GT25-32DP-2.2H 775-0008-2 32 44.05 39.6 41.03 34.1±0.05 41.03±0.05 GT25-40DP-2.2H 775-0003-9 40 52.85 48.4 49.83 42.9±0.05 49.83±0.05 GT25-24DP-2.2H GT15 Interface Connector Dec.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. .1 +00 26.75 .3 Ø1 22 .1 +0 0 .2 Ø1 4±0.05 8 positions, 1 row 7.4±0.05 Right-angle Type 2.2±0.05 1.2±0.05 GT25-8P-2.2H 8±0.05 8.6±0.05 4 3±0 05 4.3±0.05 1.7 0.6 15.4±0.05 3.6 +0.1 0 ■ M connector (PCB type) 18 GT13 GT5 GT25 Series ● Interface Connector 775-0007-0 Note : (01) is tray package. Light Gray PPS Brass/ Tin plating Packaging RoHS 200 pcs/reel YES or 1/tray GT25 Series ● Interface Connector 6.48 3.23 10.17 7.4 +0.1 0 4.3±0.05 3 12.9 1.5 GT16 0.6 2.2 φ1 6.92 5 +0.0 0 .2 2 rows GT13 Straight Type GT25-*DP-2.2V E 2.2±0.05 1.2±0.05 1.5 A B GT5 BRecommended PCB pattern ■ M connector (PCB type) 0 2+0.1 F 18.8 4.3 0.2 0.8 4.3 4.825 1.4 0.4 C D GT21 GT26 Color GT25-16DP-2.2V(01) 775-0020-8 01 GT25-24DP-2.2V(01) 775-0021-0 01 GT25-32DP-2.2V(01) 775-0022-3 01 GT25-40DP-2.2V(01) 775-0014-5 01 Light Gray Material/ Plating No. of A B C D Contacts Dimension Dimension Dimension Dimension PPS Brass/ Tin plating E Dimension F Dimension 16 26.75 22.3 15.4 23.73 15.4±0.05 23.73±0.05 24 35.55 31.1 24.2 32.53 24.2±0.05 32.53±0.05 32 44.35 39.9 33.0 41.33 33±0.05 41.33±0.05 40 53.15 48.7 41.8 50.13 41.8±0.05 50.13±0.05 Packaging RoHS 1/tray YES GT17 HRS No. GT32 B Crimping tools User manuals are available. Please contact your Hirose Electric account representative. Item Picture reference only Specification Stroke Length 30mm Number of strokes 200spm (50Hz) Weight 75kg Remarks --------- 240spm (60Hz) ----- 0.2kw Crimping speed 2,000 to 4,000 pcs/hour AC100V ----- GT10 Motor GT18W Terminal Product No. Terminal HRS No. Tool Part No. GT25 Part No. CM-105C Tool HRS No. 775-0039-6 AP105-GT25H-2024S 901-5206-3 GT25HB-2428SCF 775-0070-6 AP105-GT25HB-2428S 901-5230-8 Note : Crimp height setting tables are available for each cable type. Pleace contact your nearest Hirose Electric account representative. Different cables will require different crimp height settings. tooling GT9 ● Hand GT8E GT25H-2024SCF HRS No. Part No. HT304/GT25H-2024S Applicable wire GT25H-2024SCF Note : HT304/GT25H-2024S is rated for 0.3SQ (22 AWG) or 0.5SQ (20 AWG) cable only. HT304/GT25H-2024S can not terminate 0.2SQ (24 AWG) cable. GT15 780-0044-1 00 199 Interface Connector 1.5tons GT7 Press capacity GT3 Specifications Automatic Crimping Machine GT11 Part No. GT36 Dec.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. GT19 Powered by TCPDF (www.tcpdf.org) PO5G 9.65 A
GT25H-2024SCF 价格&库存
很抱歉,暂时无法提供与“GT25H-2024SCF”相匹配的价格&库存,您可以联系我们找货
