30500109
30500109
    HERAEUS(贺利氏)
30500109 数据手册
Nexensos W-EYK, Insert Pt Temperature Sensor with Stainless-Steel Housing according to DIN EN 60751 Temperature range -40 °C to +500 °C Platinum sensor encapsulated in protective stainless steel housing Hi-temperature fiberglass insulated connection wires High maximum operating temperature +500 °C Housing resistant to oils, organic and inoranic bases and alkalis (medium concentration) The dimensionally stable stainless steel protective tube allows easy mounting in corresponding mating holes. Applications include temperature measurement in gas, including HVAC equipment at elevated temperatures. Measurement accuracy is optimized for tempertures between 0 °C and 100 °C. Nominal Resistance R₀ [Ω] Tolerance Class Order Number Pt100 F 0.10 / Class 1/3 B 30500109 Pt1000 F 0.10 / Class 1/3 B 31500989 Temperature and Tolerance Range Tolerance Class F 0.10 / 1/3 B 0 °C to +100 °C Temperature Coefficient TCR = 3850 ppm/K Connection Wire Fiberglass insulated twisted pair Ni wire 2 x 0.5 mm (24 AWG), 300 mm long Internal Conductor Resistance 0.04 Ω/ft.(0.48 Ω/m) for each conductor Housing Closed end tube,stainless steel 1.4571 (316 Ti) Applications HVAC Data Logging Laboratory instrumentation Oven temperature Hi-temp temperature sensing Image for illustration purposes only Heraeus Nexensos USA, a division of Heraeus Epurio LLC, USA Web: www.heraeus-nexensos.com Contact: nexensos.america@heraeus.com Document: 20003959423 | Part 001 | Version 00 | Status: 09/2021 Page 1 of 2 Nexensos W-EYK, Insert Pt Temperature Sensor with Stainless-Steel Housing according to DIN EN 60751 Temperature range -40 °C to +500 °C Features Corrosion resistant stainless steel protective housing High- temperature fiberglass-insulated connection wires Widely used for a variety of temperature sensing applications Available in Pt100 or Pt 1000 resistance values +500 °C maximum operating temperature Options Wire length Resistance Value Connectors Resistance vs Temperature Table Reference table @ www.herae.us/technical-information Image for illustration purposes only The information provided in this data sheet describes certain technical characteristics of the product, but shall not be qualified or construed as quality guarantees whatsoever. Furthermore, the information provided in this data sheet does not constitute a warranty, implied or express, whatsoever, including but not limited to warranties of merchantability, fitness for a particular purpose, or use. The information provided in this data sheet regarding measurement values (including, but not limited to, response time, long-term stability, vibration and shock resistance, insulation resistance and self-heating) are average values that have been obtained under laboratory conditions in tests of large numbers of the product. Product results or measurements achieved by customer or any other person in any production, test, or other environment may vary depending on the specific conditions of use. The customer is solely responsible to determine whether the product is suited for customer's intended use; in this respect Heraeus cannot assume any liability. The sale of any products of Heraeus is exclusively subject to the Terms and Conditions of Sale of Heraeus in their current version at the time of purchase, which is available under www.heraeus.com/gtc or may be furnished upon request. This data sheet is subject to changes without prior notice. Heraeus Nexensos USA, a division of Heraeus Epurio LLC, 770 Township Line Road, Suite 300, Yardley, Pennsylvania, USA 19067 Heraeus Nexensos USA, a division of Heraeus Epurio LLC, USA Web: www.heraeus-nexensos.com Contact: nexensos.america@heraeus.com Document: 20003959423 | Part 001 | Version 00 | Status: 09/2021 Page 2 of 2
30500109 价格&库存
很抱歉,暂时无法提供与“30500109”相匹配的价格&库存,您可以联系我们找货
