CML_C0G Series
Stackpole Electronics, Inc.
Resistive Product Solutions
Multilayer Ceramic Chip Capacitor
Features:
Lead free, Halogen free, RoHS and REACH compliant
-55 °C to 125 °C operating temperature range
EIA sizes 0402, 0603, 0805, 1206, 1210 and 1812
Capacitance offering from 0.1 pF to 0.1 uF
Construction
1 - Ceramic layers (dielectric)
2 - Inner electrodes
3 - Base termination
4 - Nickel plating layer
5 - Tin plating layer
Electrical Specifications
Type / Code
Dielectric
Code
CML0402
C0G
CML0603
C0G
CML0805
C0G
CML1206
C0G
Standard Tolerance
Code
Description
C
± 0.25 pF
J
C
J
C
J
C
± 5%
± 0.25 pF
± 5%
± 0.25 pF
± 5%
± 0.25 pF
J
± 5%
C
J
C
CML1812
C0G
J
Note: Capacitance values < 10pF: B = ± 0.1 pF may be available
Note: Capacitance values ≥ 10pF: G = ± 2% may be available
CML1210
Capacitance Range
50 V
100 V
0.1 pF - 8.2 pF
10 pF - 1000 pF
0.1 pF - 6.8 pF
10 pF - 6800 pF
0.3 pF - 6,8 pF
10 pF - 0.022 uF
0.3 pF - 8.2 pF
10 pF - 3300 pF
3900 pF - 4700 pF
10 pF - 0.1 uF
10 pF - 0.1 uF
± 0.25 pF
± 5%
± 0.25 pF
± 5%
C0G
0.5 pF - 8.2 pF
10 pF - 1000 pF
0.5 pF - 8.2 pF
10 pF - 3300 pF
0.5 pF - 8.2 pF
10 pF - 3300 pF
1 pF - 8.2 pF
10 pF - 6800 pF
3 pF - 8.2 pF
10 pF - 0.01 uF
How to Order
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
C
M
L
C
G
1
J
T
5
V
Product Series
Code Description
Multilayer
CML
Ceramic
Size
Code
0402
0603
0805
1206
1210
1812
Dielectric
Code
C0G
Capacitance Range
0.1pF to 0.10uF (E12)
EIA Code Capacitance
0R1
0.1 pF
100
10 pF
101
100 pF
102
1000 pF
103
0.01 uF
104
0.1 uF
Rev Date: 09/03/2020
This specification may be changed at any time without prior notice
Please confirm technical specifications before you order and/or use.
Tolerance (*)
Code Description
B
± 0.1 pF
C
± 0.25 pF
G
± 2%
J
± 5%
Code
T
Packaging
Description
Size and Quantity
7" Paper Reel Refer to Packaging
Specifications
7" Plastic Tape
Max Working
Voltage
50V
100V
(*) Other tolerances may be available. Contact Stackpole.
1
www.seielect.com
marketing@seielect.com
CML_C0G Series
Capacitance and Voltage Available
Dielectric
Size
EIA
Code
VDCW
0R1
0.1 pF
0R2
0.2 pF
0R3
0.3 pF
0R4
0.4 pF
0R5
0.5 pF
0R6
0.6 pF
0R7
0.7 pF
0R8
0.8 pF
0R9
0.9 pF
1R0
1 pF
1R2
1.2 pF
1R5
1.5 pF
1R8
1.8 pF
2R0
2 pF
2R2
2.2 pF
2R7
2.7 pF
3R0
3 pF
3R3
3.3 pF
3R9
3.9 pF
4R7
4.7 pF
5R0
5 pF
5R6
5.6 pF
6R8
6.8 pF
8R2
8.2 pF
100
10 pF
120
12 pF
150
15 pF
180
18 pF
220
22 pF
270
27 pF
330
33 pF
390
39 pF
470
47 pF
560
56 pF
680
68 pF
820
82 pF
101
100 pF
121
120 pF
151
150 pF
181
180 pF
221
220 pF
271
270 pF
331
330 pF
391
390 pF
471
470 pF
561
560 pF
681
680 pF
751
750 pF
821
820 pF
102
1000 pF
122
1200 pF
152
1500 pF
182
1800 pF
222
2200 pF
272
2700 pF
332
3300 pF
392
3900 pF
472
4700 pF
562
5600 pF
682
6800 pF
822
8200 pF
103
0.01 uF
C0G
0402
50V
0603
50V
0805
100V
50V
1206
100V
2
50V
1210
100V
50V
1812
100V
50V
100V
www.seielect.com
CML_C0G Series
Capacitance and Voltage Available (cont.)
Dielectric
Size
EIA
Code
VDCW
123
0.012 uF
153
0.015 uF
183
0.018 uF
223
0.022 uF
273
0.027 uF
333
0.033 uF
473
0.047 uF
563
0.056 uF
683
0.068 uF
823
0.082 uF
104
0.1 uF
C0G
0402
50V
0603
50V
0805
100V
50V
1206
100V
50V
1210
100V
50V
1812
100V
50V
100V
Mechanical Specifications and Packaging Specifications
Type / Code
Voltage
Capacitance Value
CML0402C0G
50 V
0.1 pF - 1000 pF
CML0603C0G
50 V - 100 V
0.1 pF - 6800 pF
50 V
CML0805C0G
0.3 pF - 1500 pF
4700 pF
1800 pF - 3900 pF
5600 pF - 8200 pF
0.01 uF - 0.022 uF
100 V
0.5 pF - 3300 pF
0.3 pF - 8200 pF
50 V
CML1206C0G
0.01 uF - 0.1 uF
100 V
0.5 pF - 3300 pF
50 V
10 pF - 0.1 uF
100 V
1 pF - 6800 pF
50 V
10 pF - 0.1 uF
100 V
3 pF - 0.01 uF
CML1210C0G
CML1812C0G
L
0.039
1.00
0.063
1.60
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.177
4.50
0.177
4.50
W
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.016
0.40
0.016
0.40
0.020
0.50
0.031
0.80
0.049
1.25
0.049
1.25
0.049
1.25
0.049
1.25
0.063
1.60
0.063
1.60
0.063
1.60
0.098
2.50
0.098
2.50
0.126
3.20
0.126
3.20
3
H
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.020
0.50
0.031
0.80
0.028
0.70
0.031
0.80
0.047
1.20
0.031
0.80
0.028
0.70
0.063
1.60
0.031
0.80
0.047
1.20
0.047
1.20
0.047
1.20
0.047
1.20
a
0.002
0.05
0.004
0.10
0.002
0.05
0.004
0.09
0.004
0.10
0.004
0.10
0.002
0.05
0.004
0.10
0.004
0.09
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.010
0.25
0.012
0.30
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
Unit
0.004
0.10
0.004
0.10
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
Packaging (7" Reel) Qty.
Paper Tape
Plastic Tape
10000
4000
4000
4000
2000
4000
4000
2000
4000
3000
2000
1000
1000
www.seielect.com
CML_C0G Series
Environmental Characteristics
Test
Test Specification
Capacitance
Should be within the specified tolerance.
Dissipation Factor
(DF)
C0G
(Class I)
Insulation Resistance
C0G
(Class I)
Test Condition
DF
≤ 0.56%
1.5 [(150 / Cr) + 7] x 10 - 4
≤ 0.15%
≤ 0.15%
C ≤ 10 nF, Ri ≥ 50000 M Ω
C > 10 nF, RI*CR ≥ 500 S
Dielectric
Withstanding
Voltage
No breakdown or damage.
Solderability
At least 95% of the terminal electrode is covered by new solder.
Visual appearance: No visible damage.
Resistance to
Soldering Heat
C0G
≤ ± 0.5% or ± 0.5 pF
whichever is larger
DF
Same to initial value
IR
Appearance: No visible damage. At least 95% of the terminal
Resistance to
Flexure of Substrate
(Bending Strength)
Appearance: No visible damage. Δ C/C: ≤ ± 10%
Termination Adhesion
No visible damage
Item
Δ C/C
C0G: Δ C/C: ≤ ± 1% or ± 1 pF, whichever is larger
Temperature Cycle
4
C0G: (Class I)
Cap ≤ 1000 pF 1.0 ± 0.2 Vrms, 1 MHz ± 10%
Cap > 1000 pF 1.0 ± 0.2 Vrms, 1 KHz ± 10%
Capacitance
Measuring Frequency Measuring Voltage
Cr < 5 pF
1 MHZ ± 10%
5 pF ≤ Cr < 50 pF
1 ± 0.2 Vrms
50 pF ≤ Cr ≤ 1000 pF
> 1000 pF
1 KHZ ± 10%
Measuring Voltage: Rated Voltage (Max 500V)
Duration: 60 ± 5 seconds
Test Humidity: ≤ 75%
Test Temperature: 25 °C ± 5 °C
Test Current: ≤ 50mA
Measuring voltage:
Class I: 300% rated voltage
Duration: 1 ~ 5 seconds
Charge/Discharge Current: 50 mA max.
Preheating Conditions: 80 to 120 °C, 10 ~ 30 seconds
Solder Temperature: 235 ± 5% (Sn/Pb: 63/37)
Duration: 2 ± 0.5 seconds
Solder Temperature: 245 ± 5 °C (Lead-free)
Preheating Conditions: 100 to 200 °C; 10 ± 2 minutes
Solder Temperature: 265 ± 5 °C
Duration: 10 ± 1 seconds
Clean the capacitor with solvent and examine it with
a 10X (min.) microscope.
Recovery Time: 24 ± 2 hours
Recovery Condition: Room temperature.
Test Board: AI2O3 or PCB
Warp: 1 mm
Speed: 0.5 mm / second
The measurement should be made with the board in the bending
position.
Unit: mm
Applied Force: 5 N
Preheating Conditions: up-category
Temperature: 1 hour
Recovery Time: 24 ± 1 hours
Initial Measurement
Cycling times: 5 times, 1 cycle, 4 steps:
Step
Temp. ( °C )
Time (min.)
Low-category temp.
1
30 ± 3
C0G: -55
2
Normal temp. (+20)
2-3
Up-category temp.
3
30 ± 3
C0G: +125
4
Normal temp. (+20)
2-3
Recovery time after test: 24 ± 2 hours
www.seielect.com
CML_C0G Series
Environmental Characteristics (cont.)
Test
Test Specification
Test Condition
Temperature: 40 ± 2 °C
Humidity: 90 ~ 95% R.H.
Duration: 500 hours
Recovery Conditions: Room temperature
Recovery Time: 24 hours (Class I)
Low-voltage (< 100 V)
Applied Voltage: 1.5 x rated voltage
Duration: 1000 hours
Temperature: 125 °C (C0G)
Applied voltage:
100 V ≤ rated voltage < 500 V: 2 multiple
500 V ≤ rated voltage ≤ 1000 V: 1.5 multiple
> 1000V rated voltage: 1.2 multiple
C0G: Δ C/C: ≤ ± 2% or ± 1 pF, whichever is larger
DF: Not more than twice of initial value.
IR: C0G: Ri ≥ 2500 M Ω or RI*CR ≥ 25 S whichever is smaller
Moisture
Resistance
Life Test
IR: C0G: Ri ≥ 4000 M Ω or RI*CR ≥ 40 S whichever is smaller
Middle and High
Voltage Life Test
IR: C0G: Ri ≥ 4000 M Ω or Ri*CR ≥ 40 S whichever is smaller
Reel Specifications
Type / Code
CML_C0G
(all sizes)
A
7.008 ± 0.079
178.00 ± 2.00
B
C
D
0.118
3.00
0.512 ± 0.020
13.00 ± 0.50
0.827 ± 0.031
21.00 ± 0.80
E
F
1.969 or more
50.00 or more
G
0.394 ± 0.059
10.00 ± 1.50
Unit
0.472 max inches
12.00 max mm
Paper Tape Specifications
Type / Code
CML0402C0G
CML0603C0G
CML0805C0G
CML1206C0G
A0
0.026
0.65
0.043
1.10
0.057
1.45
0.071
1.80
B0
0.004
0.10
0.004
0.10
0.006
0.15
0.008
0.20
0.045
1.15
0.075
1.90
0.091
2.30
0.134
3.40
T
0.004
0.10
0.004
0.10
0.006
0.15
0.008
0.20
0.031
0.80
0.043
1.10
0.043
1.10
0.043
1.10
5
below
below
max
max
max
max
max
max
W
0.315
8.00
0.315
8.00
0.315
8.00
0.315
8.00
P0
0.004
0.10
0.004
0.10
0.006
0.15
0.008
0.20
0.157
4.00
0.157
4.00
0.157
4.00
0.157
4.00
Unit
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
inches
mm
inches
mm
inches
mm
inches
mm
www.seielect.com
CML_C0G Series
Paper Tape Specifications (cont.)
Type / Code
CML0402C0G
CML0603C0G
CML0805C0G
CML1206C0G
P1
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
P2
0.002
0.05
0.004
0.10
0.004
0.10
0.004
0.10
0.079
2.00
0.157
4.00
0.157
4.00
0.157
4.00
D0
0.002
0.05
0.002
0.05
0.004
0.10
0.004
0.10
E
0.059-0/+0.004
1.5-0/+0.10
0.059-0/+0.004
1.5-0/+0.10
0.059-0/+0.004
1.5-0/+0.10
0.059-0/+0.004
1.5-0/+0.10
0.069
1.75
0.069
1.75
0.069
1.75
0.069
1.75
F
0.002
0.05
0.002
0.05
0.002
0.05
0.004
0.10
0.138
3.50
0.138
3.50
0.138
3.50
0.138
3.50
Unit
0.002
0.05
0.002
0.05
0.002
0.05
0.002
0.05
inches
mm
inches
mm
inches
mm
inches
mm
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
inches
mm
inches
mm
inches
mm
inches
mm
Unit
max
max
max
max
max
max
max
max
inches
mm
inches
mm
inches
mm
inches
mm
Plastic Tape Specifications
Type / Code
CML0805C0G
CML1206C0G
CML1210C0G
CML1812C0G
A
CML1206C0G
CML1210C0G
CML1812C0G
C
D
0.008
0.20
0.008
0.20
0.004
0.10
0.004
0.10
0.093
2.35
0.142
3.60
0.135
3.42
0.195
4.95
G
0.008
0.20
0.008
0.20
0.004
0.10
0.004
0.10
0.315
8.00
0.315
8.00
0.315
8.00
0.472
12.00
H
0.008
0.20
0.008
0.20
0.004
0.10
0.004
0.10
0.138
3.50
0.138
3.50
0.138
3.50
0.217
5.50
0.157
4.00
0.157
4.00
0.157
4.00
0.315
8.00
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.004
0.10
0.004
0.10
0.002
0.05
0.002
0.05
0.157
4.00
0.157
4.00
0.157
4.00
0.157
4.00
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.059-0/+0.004
1.5-0/+0.10
0.059-0/+0.004
1.5-0/+0.10
0.059-0/+0.004
1.5-0/+0.10
0.059-0/+0.004
1.5-0/+0.10
6
J
E
F
Type / Code
CML0805C0G
B
0.061
1.55
0.077
1.95
0.106
2.70
0.144
3.66
0.002
0.05
0.002
0.05
0.002
0.05
0.002
0.05
0.069
1.75
0.069
1.75
0.069
1.75
0.069
1.75
T
0.059
1.50
0.073
1.85
0.126
3.20
0.157
4.00
Unit
www.seielect.com
CML_X7R Series
Features:
Capacitance offering from 100 pF to 47 uF
Construction
Type / Code
Dielectric
Code
CML0402
X7R
K
± 10%
CML0603
X7R
K
± 10%
CML0805
Standard Tolerance
Code
Description
X7R
K
Capacitance Range
16 V
25 V
120 pF - 0.039 uF
0.012 uF - 0.1 uF
150 pF - 0.1 uF
0.012 uF - 0.18 uF
0.12 uF - 0.33 uF
0.12 uF - 2.2 uF
150 pF - 0.1 uF
0.12 uF - 0.39 uF
0.12 uF - 2.2 uF
150 pF - 1 uF
2.2 uF - 4.7 uF
220 pF - 10 uF
22 uF
47 uF
470 pF - 4.7 uF
6.8 uF
10 V
± 10%
CML1206
X7R
K
± 10%
CML1210
X7R
K
± 10%
CML1812
X7R
K
± 10%
50 V
100 V
150 pF - 2.2 uF
270 pF - 1 uF
Note: J = 5% tolerance may be available
How to Order
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
C
M
L
X
7
R
1
K
T
5
V
Size
Code
0402
0603
0805
1206
1210
1812
Dielectric
Code
X7R
Product Series
Code Description
Multilayer
CML
Ceramic
Capacitance Range
101
100 pF
102
1000 pF
103
0.01 uF
104
0.1 uF
105
1 uF
106
10 uF
Rev Date: 12/27/2019
Tolerance (*)
Code Description
J
± 5%
K
± 10%
Code
T
Description
7" Paper Reel
7" Plastic Tape
Packaging
Size
Refer to Packaging Specifications
1
Quantity
Max Working
Voltage
10 V
16 V
25 V
50 V
100 V
www.seielect.com
CML_X7R Series
Dielectric
X7R
Size
0402
0603
0805
1206
1210
1812
EIA
Code VDCW 10V 16V 25V 50V 10V 16V 25V 50V 100V 10V 16V 25V 50V 100V 10V 16V 25V 50V 100V 10V 16V 25V 50V 100V 16V 25V 50V 100V
101
100 pF
121
120 pF
151
150 pF
181
180 pF
201
200 pF
221
220 pF
271
270 pF
331
330 pF
391
390 pF
471
470 pF
561
560 pF
681
680 pF
751
750 pF
821
820 pF
102 1000 pF
122 1200 pF
152 1500 pF
182 1800 pF
222 2200 pF
272 2700 pF
332 3300 pF
392 3900 pF
472 4700 pF
562 5600 pF
682 6800 pF
822 8200 pF
103
0.01 uF
123 0.012 uF
153 0.015 uF
183 0.018 uF
223 0.022 uF
273 0.027 uF
333 0.033 uF
393 0.039 uF
473 0.047 uF
563 0.056 uF
683 0.068 uF
823 0.082 uF
104
0.1 uF
124
0.12 uF
154
0.15 uF
184
0.18 uF
224
0.22 uF
274
0.27 uF
334
0.33 uF
394
0.39 uF
474
0.47 uF
564
0.56 uF
684
0.68 uF
824
0.82 uF
105
1 uF
125
1.2 uF
155
1.5 uF
225
2.2 uF
335
3.3 uf
475
4.7 uF
685
6.8 uF
106
10 uF
226
22 uf
476
47 uF
2
www.seielect.com
CML_X7R Series
Type / Code
Voltage
Capacitance Range
CML0402X7R
10 V - 50 V
100 pF - 0.47 uF
CML0603X7R
10 V - 100 V
150 pF - 2.2 uF
150 pF - 0.33 uF
0.47 uF
0.56 uF - 0.68 uF
10 V
0.82 uF - 1 uF
1.5 uF
2.2 uF
3.3 uF - 10 uF
150 pF - 0.33 uF
0.47 uF
0.56 uF - 0.68 uF
CML0805X7R
16 V
0.82 uF - 1 uF
1.5 uF
2.2 uF
3.3 uF - 4.7 uF
150 pF - 0.33 uF
0.47 uF
0.56 uF - 0.68 uF
25 V
0.82 uF - 1 uF
1.5 uF - 2.2 uF
3.3 uF - 4.7 uF
L
0.039
1.00
0.063
1.60
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
W
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.020
0.50
0.031
0.80
0.049
1.25
0.049
1.25
0.049
1.25
0.049
1.25
0.049
1.25
0.049
1.25
0.049
1.25
0.049
1.25
0.049
1.25
0.049
1.25
0.049
1.25
0.049
1.25
0.049
1.25
0.049
1.25
0.049
1.25
0.049
1.25
0.049
1.25
0.049
1.25
0.049
1.25
0.049
1.25
3
H
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.020
0.50
0.031
0.80
0.031
0.80
0.031
0.80
0.047
1.20
0.039
1.00
0.047
1.20
0.031
0.80
0.047
1.20
0.031
0.80
0.031
0.80
0.047
1.20
0.039
1.00
0.047
1.20
0.031
0.80
0.047
1.20
0.031
0.80
0.031
0.80
0.047
1.20
0.039
1.00
0.047
1.20
0.047
1.20
a
0.002
0.05
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.010
0.25
0.012
0.30
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
Unit
0.004
0.10
0.004
0.10
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
Paper Tape Plastic Tape
10000
4000
4000
4000
3000
3000
3000
4000
2000
4000
4000
3000
3000
3000
4000
2000
4000
4000
3000
3000
2000
2000
www.seielect.com
CML_X7R Series
Mechanical Specifications and Packaging Specifications (cont.)
Type / Code
Voltage
Capacitance Range
150 pF - 0.33 uF
0.47 uF
50 V
0.56 uF - 0.68 uF
0.82 uF - 1 uF
CML0805X7R
1.5 uF - 2.2 uF
100 pF
100 V
150 pF - 0.047 uF
0.056 uF - 0.1 uF
200 pF - 0.33 uF
0.47 uF - 0.68 uF
10 V
0.82 uF - 1.5 uF
2.2 uF - 3.3 uF
4.7 uF - 22 uF
200 pF - 0.33 uF
0.47 uF - 0.68 uF
16 V - 25 V
0.82 uF - 1.5 uF
2.2 uF - 3.3 uF
CML1206X7R
4.7 uF - 10 uF
200 pF - 0.33 uF
0.47 uF - 0.68 uF
50 V
0.82 uF - 1.5 uF
2.2 uF - 3.3 uF
4.7 uF
150 pF - 0.056 uF
100 V
0.068 uF - 0.33 uF
0.47 uF - 1 uF
L
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
W
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.049
1.25
0.049
1.25
0.049
1.25
0.049
1.25
0.049
1.25
0.049
1.25
0.049
1.25
0.049
1.25
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
4
H
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.031
0.80
0.031
0.80
0.047
1.20
0.039
1.00
0.047
1.20
0.028
0.70
0.031
0.80
0.047
1.20
0.031
0.80
0.047
1.20
0.031
0.80
0.047
1.20
0.063
1.60
0.031
0.80
0.047
1.20
0.031
0.80
0.047
1.20
0.063
1.60
0.031
0.80
0.047
1.20
0.031
0.80
0.047
1.20
0.063
1.60
0.031
0.80
0.047
1.20
0.063
1.60
a
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.020
0.50
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
Unit
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
4000
4000
3000
3000
3000
4000
4000
3000
4000
3000
4000
3000
2000
4000
3000
4000
3000
2000
4000
3000
4000
3000
2000
4000
3000
2000
www.seielect.com
CML_X7R Series
Type / Code
Voltage
Capacitance Range
220 pF - 0.47 uF
0.68 uF - 1 uF
10 V
4.7 uF
10 uF
47 uF
220 pF - 0.47 uF
0.68 uF - 1 uF
16 V - 25 V
4.7 uF
CML1210X7R
10 uF
22 uF
220 pF - 0.47 uF
0.68 uF - 1 uF
50 V
4.7 uF
10 uF
150 pF - 0.22 uF
100 V
0.33 uF - 2.2 uF
470 pF - 1 uF
16 V - 25 V
1.5 uF - 6.8 uF
470 pF - 1 uF
CML1812X7R
50 V
1.5 uF - 4.7 uF
270 pF - 0.56 uF
100 V
0.68 uF - 1 uF
L
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.177
4.50
0.177
4.50
0.177
4.50
0.177
4.50
0.177
4.50
0.177
4.50
W
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.016
0.40
0.016
0.40
0.016
0.40
0.016
0.40
0.016
0.40
0.016
0.40
0.098
2.50
0.098
2.50
0.098
2.50
0.098
2.50
0.098
2.50
0.098
2.50
0.098
2.50
0.098
2.50
0.098
2.50
0.098
2.50
0.098
2.50
0.098
2.50
0.098
2.50
0.098
2.50
0.098
2.50
0.098
2.50
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
5
H
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.047
1.20
0.063
1.60
0.047
1.20
0.071
1.80
0.098
2.50
0.047
1.20
0.063
1.60
0.047
1.20
0.071
1.80
0.098
2.50
0.047
1.20
0.063
1.60
0.071
1.80
0.098
2.50
0.055
1.40
0.063
1.60
0.063
1.60
0.071
1.80
0.063
1.60
0.071
1.80
0.063
1.60
0.063
1.60
a
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.010
0.25
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.010
0.25
0.004
0.10
0.004
0.10
0.004
0.10
0.010
0.25
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.009
0.24
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
Unit
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
2000
2000
2000
2000
500
2000
2000
2000
2000
500
2000
2000
2000
500
2000
2000
1000
1000
1000
1000
1000
500
www.seielect.com
CML_X7R Series
Test
Capacitance
Dissipation
Factor
(DF)
X7R
X7R
(Class II) (≥ 0402)
Insulation
Resistance
X7R
(Class II)
Test Specification
Test Condition
X7R: (Class II)
Cap ≤ 10uF 1.0 ± 0.2 Vrms, 1 KHz ± 10%
Cap > 10uF 0.5 ± 0.1 Vrms, 120 Hz ± 10%
≥ 50V
≤ 2.5%
25V
16V
≤ 3.5% (C < 0.47uF)
≤ 10.0% (C ≥ 0.47uF)
10V
≤ 5% (C < 0.15uF)
≤ 10.0% ( C ≥ 0.15 uF)
C ≤ 25nF, Ri ≥ 10000M Ω
C > 25nF, RI*CR > 100S
Dielectric
Withstanding
Voltage
Solderability
Resistance to
Soldering
Heat
Item
X7R
Δ C/C
-5 ~ + 10%
DF
IR
Appearance: No visible damage. At least 95% of the terminal electrode is covered
by new solder.
Resistance to
Flexure of
Substrate
(Bending
Strength)
Termination
Adhesion
No visible damage
Measuring Voltage: Rated Voltage (Max 500 V)
Test Current: ≤ 50 mA
Measuring voltage:
Class II: 250% rated voltage
Warp: 1 mm
Speed: 0.5mm / second
bending position.
Unit: mm
Applied Force: 5 N
Preheating Conditions: up-category temperature 1 hour
Initial Measurement
Step
Temp. ( °C )
Time (min.)
Low-category
1
30 ± 3
temp.
X7R: -55
Normal temp.
2
2-3
(+20)
X7R: Δ C/C: ≤ ± 10%
Temperature
Cycle
3
Up-category temp.
30 ± 3
X7R: +125
Normal temp.
4
2-3
(+20)
6
www.seielect.com
CML_X7R Series
Test
Moisture
Resistance
Life Test
Middle and
High Voltage
Life Test
Test Specification
Test Condition
X7R: Δ C/C: ≤ ± 10%
IR: X7R: Ri ≥ 1000M Ω or RI*CR ≥ 25S whichever is smaller
Duration: 500 hours
Recovery Time: 48 hours (Class II)
Temperature: 125 °C (X7R)
Applied voltage: 100 V ≤ rated voltage < 500 V: 2 multiple
500V ≤ rated voltage ≤ 1000 V: 1.5 multiple
> 1000 V rated voltage: 1.2 multiple
X7R: Δ C/C: ≤ ± 20%
IR: X7R: Ri ≥ 2000M Ω or RI*CR ≥ 50 S whichever is smaller
X7R: Δ C/C: ≤ ± 20%
IR: X7R Ri ≥ 2000M Ω or Ri*CR ≥ 50 S whichever is smaller
Reel Specifications
Type / Code
CML_X7R
(all sizes)
A
7.008 ± 0.079
178.00 ± 2.00
B
C
D
0.118
3.00
0.512 ± 0.020
13.00 ± 0.50
0.827 ± 0.031
21.00 ± 0.80
E
F
1.969 or more
50.00 or more
G
0.394 ± 0.059
10.00 ± 1.50
Unit
0.472 max inches
12.00 max mm
Type / Code
CML0402X7R
CML0603X7R
CML0805X7R
CML1206X7R
A0
0.026
0.65
0.043
1.10
0.057
1.45
0.071
1.80
B0
0.004
0.10
0.004
0.10
0.006
0.15
0.008
0.20
0.045
1.15
0.075
1.90
0.091
2.30
0.134
3.40
T
0.004
0.10
0.004
0.10
0.006
0.15
0.008
0.20
0.031
0.80
0.043
1.10
0.043
1.10
0.043
1.10
7
below
below
max
max
max
max
max
max
W
0.315
8.00
0.315
8.00
0.315
8.00
0.315
8.00
P0
0.004
0.10
0.004
0.10
0.006
0.15
0.008
0.20
0.157
4.00
0.157
4.00
0.157
4.00
0.157
4.00
Unit
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
inches
mm
inches
mm
inches
mm
inches
mm
www.seielect.com
CML_X7R Series
Type / Code
CML0402X7R
CML0603X7R
CML0805X7R
CML1206X7R
P1
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
P2
0.002
0.05
0.004
0.10
0.004
0.10
0.004
0.10
0.079
2.00
0.157
4.00
0.157
4.00
0.157
4.00
D0
0.002
0.05
0.002
0.05
0.004
0.10
0.004
0.10
E
0.059-0/+0.004
1.5-0/+0.10
0.059-0/+0.004
1.5-0/+0.10
0.059-0/+0.004
1.5-0/+0.10
0.059-0/+0.004
1.5-0/+0.10
0.069
1.75
0.069
1.75
0.069
1.75
0.069
1.75
F
0.002
0.05
0.002
0.05
0.002
0.05
0.004
0.10
0.138
3.50
0.138
3.50
0.138
3.50
0.138
3.50
Unit
0.002
0.05
0.002
0.05
0.002
0.05
0.002
0.05
inches
mm
inches
mm
inches
mm
inches
mm
Type / Code
CML0805X7R
CML1206X7R
CML1210X7R
CML1812X7R
A
CML1206X7R
CML1210X7R
CML1812X7R
C
D
0.008
0.20
0.008
0.20
0.004
0.10
0.004
0.10
0.093
2.35
0.142
3.60
0.135
3.42
0.195
4.95
G
0.008
0.20
0.008
0.20
0.004
0.10
0.004
0.10
0.315
8.00
0.315
8.00
0.315
8.00
0.472
12.00
H
0.008
0.20
0.008
0.20
0.004
0.10
0.004
0.10
0.138
3.50
0.138
3.50
0.138
3.50
0.217
5.50
0.157
4.00
0.157
4.00
0.157
4.00
0.315
8.00
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.004
0.10
0.004
0.10
0.002
0.05
0.002
0.05
0.157
4.00
0.157
4.00
0.157
4.00
0.157
4.00
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.059-0/+0.004
1.5-0/+0.10
0.059-0/+0.004
1.5-0/+0.10
0.059-0/+0.004
1.5-0/+0.10
0.059-0/+0.004
1.5-0/+0.10
8
J
E
F
Type / Code
CML0805X7R
B
0.061
1.55
0.077
1.95
0.106
2.70
0.144
3.66
0.002
0.05
0.002
0.05
0.002
0.05
0.002
0.05
0.069
1.75
0.069
1.75
0.069
1.75
0.069
1.75
T
0.059
1.50
0.073
1.85
0.126
3.20
0.157
4.00
Unit
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
inches
mm
inches
mm
inches
mm
inches
mm
Unit
max
max
max
max
max
max
max
max
inches
mm
inches
mm
inches
mm
inches
mm
www.seielect.com
CML_Y5V Series
Features:
-30 °C to 85 °C operating temperature range
Capacitance offering from 1000 pF to 22 uF
Construction
Type / Code
Dielectric
Code
Standard Tolerance
Code
Description
CML0402
Y5V
Z
+80% / -20%
CML0603
Y5V
Z
+80% / -20%
CML0805
Y5V
Z
+80% / -20%
CML1206
Y5V
Z
+80% / -20%
CML1210
Y5V
Z
+80% / -20%
CML1812
Y5V
Z
+80% / -20%
Note: M = ±20% tolerance may be available
Capacitance Range
16 V
25 V
1000 pF - 0.1 uF
0.12 uF - 0.18 uF
0.12 uF - 0.47 uF
0.12 uF - 1 uF
10000 pF - 0.1 uF
10000 pF - 0.82 uF
0.18 uF - 2.2 uF
0.012 uF - 0.1 uF
1 uF - 4.7 uF
10000 pF - 1 uF
2.2 uF - 4.7 uF
10 uF
10 V
50 V
100 V
0.015 uF - 1 uF
0.15 uF - 2.2 uF
How to Order
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
C
M
L
Y
5
V
1
Z
T
5
V
Size
Code
0402
0603
0805
1206
1210
1812
Dielectric
Code
Y5V
Product Series
Code Description
Multilayer
CML
Ceramic
Capacitance Range
0.1pF to 0.10uF (E6)
102
1000 pF
103
0.01 uF
104
0.1 uF
105
1 uF
106
10 uF
Rev Date: 01/20/2020
Tolerance (*)
Code Description
M
± 20%
Z
+80%/-20%
Code
T
Description
7" Paper Reel
7" Plastic Tape
Packaging
Size
1
Quantity
Max Working
Voltage
10 V
16 V
25 V
50 V
100 V
www.seielect.com
CML_Y5V Series
Dielectric
Y5V
EIA
Size
0402
0603
0805
1206
1210
Code VDCW
10V 16V 25V 50V 10V 16V 25V 50V 100 10V 16V 25V 50V 100V 10V 16V 25V 50V 100V 10V
102 1000 pF
122 1200 pF
152 1500 pF
182 1800 pF
222 2200 pF
272 2700 pF
332 3300 pF
392 3900 pF
472 4700 pF
562 5600 pF
682 6800 pF
822 8200 pF
103
0.01 uF
123 0.012 uF
153 0.015 uF
183 0.018 uf
223 0.022 uF
273 0.027 uF
333 0.033 uF
393 0.039 uF
473 0.047 uF
563 0.056 uF
683 0.068 uF
823 0.082 uF
104
0.1 uF
124
0.12 uF
154
0.15 uF
224
0.22 uF
334
0.33 uF
394
0.39 uF
474
0.47 uF
564
0.56 uF
684
0.68 uF
824
0.82 uF
105
1 uF
125
1.2 uF
135
1.3 uF
155
1.5 uF
225
2.2 uF
335
3.3 uF
475
4.7 uF
685
6.8 uF
106
10 uF
226
22 uF
2
1812
16V
www.seielect.com
CML_Y5V Series
Type / Code
Voltage
Capacitance Range
CML0402Y5V
10 V - 50 V
1000 pF - 1 uF
CML0603Y5V
10 V - 100 V
1000 pF - 10 uF
1000 pF - 0.22 uF
10 V
0.33 uF - 2.2 uF
3.3 uF - 22 uF
1000 pF - 0.22 uF
16 V
0.33 uF - 2.2 uF
3.3 uF - 10 uF
CML0805Y5V
1000 pF - 0.22 uF
25 V
0.33 uF - 2.2 uF
3.3 uF - 4.7 uF
1000 pF - 0.22 uF
50 V
0.33 uF - 2.2 uF
100 V
0.01 uF - 0.1 uF
1000 pF - 10 uF
10 V - 16 V
22 uF
CML1206Y5V
25 V
1000 pF - 10 uF
50 V - 100 V
1000 pF - 4.7 uF
CML1210Y5V
100 V
0.015 uF - 1 uF
CML1812Y5V
100 V
0.15 uF - 2.2 uF
L
0.039
1.00
0.063
1.60
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.177
4.50
W
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.016
0.40
0.020
0.50
0.031
0.80
0.049
1.25
0.049
1.25
0.049
1.25
0.049
1.25
0.049
1.25
0.049
1.25
0.049
1.25
0.049
1.25
0.049
1.25
0.049
1.25
0.049
1.25
0.049
1.25
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.098
2.50
0.126
3.20
3
H
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.020
0.50
0.031
0.80
0.028
0.70
0.031
0.80
0.047
1.20
0.028
0.70
0.031
0.80
0.047
1.20
0.028
0.70
0.031
0.80
0.047
1.20
0.028
0.70
0.031
0.80
0.028
0.70
0.031
0.80
0.063
1.60
0.031
0.80
0.031
0.80
0.039
1.00
0.063
1.60
a
0.002
0.05
0.004
0.09
0.020
0.50
0.004
0.10
0.004
0.10
0.002
0.05
0.004
0.10
0.004
0.10
0.002
0.05
0.004
0.10
0.004
0.10
0.002
0.05
0.004
0.10
0.002
0.05
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.010
0.25
0.012
0.30
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
Paper Tape
Plastic Tape
Unit
0.004
0.10
0.004
0.10
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
10000
4000
4000
4000
3000
4000
4000
3000
4000
4000
3000
4000
4000
4000
4000
2000
4000
4000
2000
1000
www.seielect.com
CML_Y5V Series
Test
Test Specification
Test Condition
Capacitance
Y5V: (Class II)
Dissipation
Factor
(DF)
Y5V
(Class II)
Insulation
Resistance
Y5V
(Class II)
≥ 25V
≤ 7% (C < 1uF)
≤ 9% (C ≥ 1uF)
16V
10V
≤ 15%
≤ 15%
C ≤ 25 nF, Ri ≥ 4,000 M Ω
C > 25 nF, Ri*CR > 100 S
Dielectric
Withstanding
Voltage
Solderability
Resistance to
Soldering Heat
Item
Δ C/C
DF
IR
Y5V
-10 ~ +20%
Resistance to
Flexure of
Substrate
(Bending
Strength)
Termination
Adhesion
No visible damage
Temperature
Cycle
Applied Force: 5 N
Initial Measurement
Step
Temp. ( °C )
Time (min.)
Low-category temp.
1
30 ± 3
Y5V: -25
2
Normal temp. (+20)
2-3
Up-category temp.
3
30 ± 3
Y5V: +85
4
Normal temp. (+20)
2-3
Y5V: Δ C/C: ≤ ± 20%
Measuring voltage:
Warp: 1mm
bending position.
Unit: mm
4
www.seielect.com
CML_Y5V Series
Test
Moisture
Resistance
Life Test
Middle and
High Voltage
Life Test
Test Specification
Test Condition
Y5V: Δ C/C: ≤ ± 30%
IR: Y5V: Ri ≥ 1000 M Ω or Ri*CR ≥ 25 S whichever is smaller
Duration: 500 hours
Low-voltage ( 1000V rated voltage: 1.2 multiple
Temperature: 85 °C (Y5V)
Y5V: Δ C/C: ≤ ± 30%
IR: Y5V: Ri ≥ 2000 M Ω or Ri*CR ≥ 50 S whichever is smaller
Y5V: Δ C/C: ≤ ± 30%
IR: Y5V Ri ≥ 2000M Ω or Ri*CR ≥ 50 S whichever is smaller
Reel Specifications
Type / Code
CML_Y5V
(all sizes)
A
7.008 ± 0.079
178.00 ± 2.00
B
C
D
0.118
3.00
0.512 ± 0.020
13.00 ± 0.50
0.827 ± 0.031
21.00 ± 0.80
E
F
1.969 or more
50.00 or more
G
0.394 ± 0.059
10.00 ± 1.50
Unit
0.472 max inches
12.00 max mm
Type / Code
CML0402Y5V
CML0603Y5V
CML0805Y5V
CML1206Y5V
A0
0.026
0.65
0.043
1.10
0.057
1.45
0.071
1.80
B0
0.004
0.10
0.004
0.10
0.006
0.15
0.008
0.20
0.045
1.15
0.075
1.90
0.091
2.30
0.134
3.40
T
0.004
0.10
0.004
0.10
0.006
0.15
0.008
0.20
0.031
0.80
0.043
1.10
0.043
1.10
0.043
1.10
5
below
below
max
max
max
max
max
max
W
0.315
8.00
0.315
8.00
0.315
8.00
0.315
8.00
P0
0.004
0.10
0.004
0.10
0.006
0.15
0.008
0.20
0.157
4.00
0.157
4.00
0.157
4.00
0.157
4.00
Unit
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
inches
mm
inches
mm
inches
mm
inches
mm
www.seielect.com
CML_Y5V Series
Type / Code
CML0402Y5V
CML0603Y5V
CML0805Y5V
CML1206Y5V
P1
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
P2
0.002
0.05
0.004
0.10
0.004
0.10
0.004
0.10
0.079
2.00
0.157
4.00
0.157
4.00
0.157
4.00
D0
0.002
0.05
0.002
0.05
0.004
0.10
0.004
0.10
E
0.059-0/+0.004
1.5-0/+0.10
0.059-0/+0.004
1.5-0/+0.10
0.059-0/+0.004
1.5-0/+0.10
0.059-0/+0.004
1.5-0/+0.10
0.069
1.75
0.069
1.75
0.069
1.75
0.069
1.75
F
0.002
0.05
0.002
0.05
0.002
0.05
0.004
0.10
0.138
3.50
0.138
3.50
0.138
3.50
0.138
3.50
Unit
0.002
0.05
0.002
0.05
0.002
0.05
0.002
0.05
inches
mm
inches
mm
inches
mm
inches
mm
Type / Code
CML0805Y5V
CML1206Y5V
CML1210Y5V
CML1812Y5V
A
CML1206Y5V
CML1210Y5V
CML1812Y5V
C
D
0.008
0.20
0.008
0.20
0.004
0.10
0.004
0.10
0.093
2.35
0.142
3.60
0.135
3.42
0.195
4.95
G
0.008
0.20
0.008
0.20
0.004
0.10
0.004
0.10
0.315
8.00
0.315
8.00
0.315
8.00
0.472
12.00
H
0.008
0.20
0.008
0.20
0.004
0.10
0.004
0.10
0.138
3.50
0.138
3.50
0.138
3.50
0.217
5.50
0.157
4.00
0.157
4.00
0.157
4.00
0.315
8.00
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.004
0.10
0.004
0.10
0.002
0.05
0.002
0.05
0.157
4.00
0.157
4.00
0.157
4.00
0.157
4.00
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.059-0/+0.004
1.5-0/+0.10
0.059-0/+0.004
1.5-0/+0.10
0.059-0/+0.004
1.5-0/+0.10
0.059-0/+0.004
1.5-0/+0.10
6
J
E
F
Type / Code
CML0805Y5V
B
0.061
1.55
0.077
1.95
0.106
2.70
0.144
3.66
0.002
0.05
0.002
0.05
0.002
0.05
0.002
0.05
0.069
1.75
0.069
1.75
0.069
1.75
0.069
1.75
T
0.059
1.50
0.073
1.85
0.126
3.20
0.157
4.00
Unit
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
inches
mm
inches
mm
inches
mm
inches
mm
Unit
max
max
max
max
max
max
max
max
inches
mm
inches
mm
inches
mm
inches
mm
www.seielect.com
