Additional Resources:
Product Page
3D Model
date
08/05/2022
page 1 of 4
MODEL: CMS-34348N | DESCRIPTION: SPEAKER
FEATURES
• miniature speaker
• 380 Hz resonant frequency
• Nd-Fe-B magnet
SPECIFICATIONS
parameter
conditions/description
min
typ
max
units
input power
maximum power: IEC-60268-5, filter 60s on/120s off, 10
cycles at room temp
3.0
4.0
W
impedance
at 1.0 kHz, 1.0 V
6.8
8
9.2
Ω
resonant frequency (Fo)
at 1.0 V
frequency response
output SPL -10 dB
304
Fo
380
sound pressure level
at 1.0 W, 0.5 m ave, at 0.8, 1.0, 1.2, 1.5 kHz
at 3.0 W, 0.5 m ave, at 0.8, 1.0, 1.2, 1.5 kHz
77
82
distortion
at 1.0 kHz, 1.0 W
buzz, rattle, etc.
must be normal at sine wave between
Fo ~ 20,000 Hz
dimensions
34 x 34 x 14.5
magnet
Nd-Fe-B
material
ABS77D
cone material
PU
terminal
solder terminals
80
85
456
Hz
10,000
Hz
83
88
dB
dB
5
4.9
V
mm
weight
30
g
operating temperature
-20
55
°C
storage temperature
-30
65
°C
RoHS
Notes:
yes
1. All specifications measured at 5~35°C, humidity at 45~85%, under 86~106 kPa pressure, unless otherwise noted.
SOLDERABILITY
parameter
min
typ
max
units
hand soldering
for maximum 3 seconds
370
380
390
°C
cuidevices.com
Product Page
3D Model
CUI DEVICES | MODEL: CMS-34348N | DESCRIPTION: SPEAKER
date 08/05/2022 | page 2 of 4
MECHANICAL DRAWING
units: mm
tolerance: ±0.5 mm
326,7,9(32/$5,7<
FREQUENCY RESPONSE CURVE
Frequency Response.Magn dB re 20.00μ PA AT 1 W / 0.5 m
cuidevices.com
很抱歉,暂时无法提供与“CMS-34348N”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 560+44.95480560+5.44827
- 国内价格 香港价格
