ERWE401LGN682MEF5M
ERWE401LGN682MEF5M
    NCC(贵弥功)
    AEC_D76.2X155MM
    贴片铝电解电容 AEC_D76.2X155MM
ERWE401LGN682MEF5M 数据手册
LARGE CAPACITANCE ALUMINUM ELECTROLYTIC CAPACITORS Inverter-use screw terminal, 85℃ RWE RWF Series Longer life ・Rated voltage range : 350 to 550Vdc ・Endurance with ripple current : 85℃ 2,000 hours ・RoHS2 Compliant RWE ◆SPECIFICATIONS Items Characteristics Category Temperature Range Rated Voltage Range Capacitance Tolerance Leakage Current -25 to +85℃ 350 to 550Vdc ±20% (M) I=0.02CV or 5mA, whichever is smaller. Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V) Dissipation Factor (tanδ) Low Temperature Characteristics (at 20℃, 120Hz) (at 20℃ after 5 minutes) 0.25 max. (at 20℃, 120Hz) Rated Voltage (Vdc) 350 to 450V 500 & 550V C(-25℃)/C(+20℃) (at 120Hz) ≧0.7 ≧0.6 When measured between the terminals that are connected to each other and to the mounting clamp on the insulating sleeve covering the case by using an insulation resistance meter of 500Vdc, the insulation resistance shall not be less than 100MΩ. When a voltage of 2,000Vac is applied for 1 minute between the terminals that are connected to each other and to the mounting clamp on the insulating sleeve covering the case, there shall not be electrical damage. The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated ripple current is applied (the peak voltage shall not exceed the rated voltage) for 2,000 hours at 85℃. Capacitance change ≦±20% of the initial value D.F. (tanδ) ≦300% of the initial specified value Leakage current ≦The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 500 hours at 85℃ without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4. Capacitance change ≦±20% of the initial value D.F. (tanδ) ≦300% of the initial specified value Leakage current ≦The initial specified value Capacitance change Insulation Resistance Insulation Withstanding Voltage Endurance Shelf Life ◆DIMENSIONS (Screw-Mount) [mm] ● Mounting Clamp Code : B ● Mounting 450±50 H B±1 F ±1 φD+1.8max. Sleeve (PVC : Black) Vent 6 300±50 8 J G±1 L+4max. Plastic disk φD 35 50 63.5 76.2 φ35 to φ63.5 : G=6 φ76.2 & φ89 : G=5 A 58.0 78.0 90.0 104.5 B 44.0 64.0 76.0 90.0 Clamp Code : C 3600 3 A±1 W±1 W 48.0 68.0 80.0 93.5 H 3.5 4.5 4.5 4.5 F 12.7 22.4 28.0 31.5 φD 50 63.5 76.2 89 4.5 Code : LG K±1 E±1 ● Terminal E 32.5 38.1 44.5 50.8 K 37.0 43.5 50.0 56.5 F 22.4 28.0 31.5 31.5 J 14.0 14.0 14.0 16.0 Plus hexagon-headed screw :M5×0.8×10 Maximum screw tightening torque :3.23Nm * The screw and the mounting clamp are separately supplied and not attached to the product. ◆PART NUMBERING SYSTEM 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 E RWE A A A L G N A A A M A A A U Supplement code Size code Capacitance tolerance code Capacitance code (ex. 680µF:681, 6,800µF:682) Mounting clamp code (N, B, C) Terminal code Voltage code (ex. 350V:351, 500V:501) Series code Category Please refer to "Product code guide (screw-mount terminal type)" Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001U LARGE CAPACITANCE ALUMINUM ELECTROLYTIC CAPACITORS Inverter-use screw terminal, 85℃ RWESeries ◆STANDARD RATINGS WV (Vdc) 350 400 450 Cap (µF) 390 680 1,000 1,200 1,500 2,200 3,300 3,300 3,900 4,700 4,700 5,600 6,800 8,200 12,000 330 560 820 1,000 1,200 1,800 2,200 2,700 3,300 3,900 3,900 4,700 5,600 6,800 10,000 270 470 680 820 1,000 1,200 1,500 1,800 2,200 Rated ripple current Case size tanδ (Arms/ φD×L(mm) 85℃, 120Hz) 35 × 50 35 × 80 35 × 100 35 × 120 50 × 75 50 × 96 50 × 130 63.5 × 96 63.5 × 115 63.5 × 130 76.2 × 96 76.2 × 115 76.2 × 130 76.2 × 155 89 × 155 35 × 50 35 × 80 35 × 100 35 × 120 50 × 75 50 × 96 50 × 130 63.5 × 96 63.5 × 115 63.5 × 130 76.2 × 96 76.2 × 115 76.2 × 130 76.2 × 155 89 × 155 35 × 50 35 × 80 35 × 100 35 × 120 50 × 75 50 × 96 50 × 115 50 × 130 63.5 × 96 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 1.90 2.90 3.80 4.20 4.70 6.30 8.80 8.80 10.3 12.0 11.7 12.6 15.9 19.0 22.5 1.70 2.70 3.40 3.90 4.20 5.70 7.20 7.90 9.50 10.9 10.6 12.6 14.5 17.3 20.5 1.60 2.40 3.10 3.50 3.90 4.70 5.60 6.50 7.20 Part No. ERWE351LGB391MA50U ERWE351LGB681MA80U ERWE351LGB102MAA0U ERWE351LGB122MAC0U ERWE351LGC152MC75U ERWE351LGC222MC96U ERWE351LGC332MCD0U ERWE351LGC332MD96U ERWE351LGC392MDB5U ERWE351LGC472MDD0U ERWE351LGC472ME96U ERWE351LGC562MEB5U ERWE351LGC682MED0U ERWE351LGC822MEF5U ERWE351LGC123MFF5U ERWE401LGB331MA50U ERWE401LGB561MA80U ERWE401LGB821MAA0U ERWE401LGB102MAC0U ERWE401LGC122MC75U ERWE401LGC182MC96U ERWE401LGC222MCD0U ERWE401LGC272MD96U ERWE401LGC332MDB5U ERWE401LGC392MDD0U ERWE401LGC392ME96U ERWE401LGC472MEB5U ERWE401LGC562MED0U ERWE401LGC682MEF5U ERWE401LGC103MFF5U ERWE451LGB271MA50U ERWE451LGB471MA80U ERWE451LGB681MAA0U ERWE451LGB821MAC0U ERWE451LGC102MC75U ERWE451LGC122MC96U ERWE451LGC152MCB5U ERWE451LGC182MCD0U ERWE451LGC222MD96U WV (Vdc) 450 500 550 Cap (µF) Rated ripple current Case size tanδ (Arms/ φD×L(mm) 85℃, 120Hz) 2,700 3,300 3,300 3,900 4,700 5,600 8,200 120 270 330 390 470 680 820 1,000 1,000 1,500 1,500 1,800 2,200 2,700 3,900 100 180 270 330 390 560 560 680 680 820 820 1,200 1,500 1,800 2,200 3,300 63.5 × 115 63.5 × 130 76.2 × 96 76.2 × 115 76.2 × 130 76.2 × 155 89 × 155 35 × 50 35 × 80 35 × 100 35 × 120 50 × 75 50 × 96 50 × 115 50 × 130 63.5 × 96 63.5 × 115 76.2 × 96 63.5 × 130 76.2 × 115 76.2 × 155 89 × 155 35 × 50 35 × 80 35 × 100 35 × 120 50 × 75 50 × 96 63.5 × 96 50 × 115 63.5 × 115 50 × 130 63.5 × 130 76.2 × 96 76.2 × 115 76.2 × 130 76.2 × 155 89 × 155 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 8.60 10.0 9.80 11.5 13.3 15.7 18.6 0.70 1.20 1.40 1.70 1.80 2.50 2.90 3.40 3.40 4.50 4.60 5.20 6.10 7.70 10.1 0.60 1.00 1.30 1.60 1.70 2.10 2.50 2.70 3.00 3.10 3.50 4.20 5.00 5.80 7.00 9.30 Part No. ERWE451LGC272MDB5U ERWE451LGC332MDD0U ERWE451LGC332ME96U ERWE451LGC392MEB5U ERWE451LGC472MED0U ERWE451LGC562MEF5U ERWE451LGC822MFF5U ERWE501LGB121MA50U ERWE501LGB271MA80U ERWE501LGB331MAA0U ERWE501LGB391MAC0U ERWE501LGC471MC75U ERWE501LGC681MC96U ERWE501LGC821MCB5U ERWE501LGC102MCD0U ERWE501LGC102MD96U ERWE501LGC152MDB5U ERWE501LGC152ME96U ERWE501LGC182MDD0U ERWE501LGC222MEB5U ERWE501LGC272MEF5U ERWE501LGC392MFF5U ERWE551LGB101MA50U ERWE551LGB181MA80U ERWE551LGB271MAA0U ERWE551LGB331MAC0U ERWE551LGC391MC75U ERWE551LGC561MC96U ERWE551LGC561MD96U ERWE551LGC681MCB5U ERWE551LGC681MDB5U ERWE551LGC821MCD0U ERWE551LGC821MDD0U ERWE551LGC122ME96U ERWE551LGC152MEB5U ERWE551LGC182MED0U ERWE551LGC222MEF5U ERWE551LGC332MFF5U ◆RATED RIPPLE CURRENT MULTIPLIERS ・Frequency Multipliers Frequency (Hz) Coefficient 50 0.8 120 1.0 300 1.1 1k 1.3 3k 1.4 Note : The endurance of capacitors is reduced with internal heating produced by ripple current at the rate of halving the lifetime with every 5 to 10℃ rise. When long life performance is required in actual use, the rms ripple current has to be reduced. Also, for the RWE series capacitors, using them at operating voltage less than their rated voltage can extend their lifetime. For details, please contact a representative of Nippon Chemi-Con. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001U
ERWE401LGN682MEF5M 价格&库存
很抱歉,暂时无法提供与“ERWE401LGN682MEF5M”相匹配的价格&库存,您可以联系我们找货
