MB8F
MB8F
    HOTTECH(合科泰)
    MBF
MB8F 数据手册
MB05F-MB10F SURFACE MOUNT BRIDGE RECTIFIER FEATURES ~  UL Recognized Component ~  High surge current capability  Ideal for Printed Circuit Board  Plastic Package - UL Flammability MBF Classification 94V-0 .193(4.9) .177(4.5) MECHANICAL DATA  Mounting Position: Any .008(0.2) .014(.35) .006(.15)  Terminals: Plated leads solderable per .031(0.8) .019(0.5) MTL-STD-750,Method 2026 .169(4.3) .153(3.9) .043(1.1) .023(0.6) .065(1.7) .059(1.5)  Case: Transfer Molded Epoxy .275(7.0)MAX .067(1.7) .057(1.3) .043(1.1) .027(0.7) .067(1.7) .057(1.3) .106(2.7) .09(2.3) Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Rating at 25℃ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive load. For capacitive load, derate current by 20% MB 05F MB 1F MB 2F MB 4F MB 6F MB 8F MB 10F Unit VRRM 50 100 200 400 600 800 1000 V Maximum RMS Voltage VRMS 35 70 140 280 420 560 700 V Maximum DC Blocking Voltage VDC 50 100 200 400 600 800 1000 V Characteristic Symbol Maximum Recurrent Peak Reverse Voltage Maximum Average Forward Rectified Current @TA=40°C I(AV) 0.8 A Non-Repetitive Peak Forward Surge Current 8.3ms Single half sine-wave superimposed on rated load (JEDEC Method) I FSM Peak Forward Voltage at 0.8A DC VFM 1.0 V IRM 5.0 500 μA Typical Junction Capacitance CJ 15 pF Typical Thermal Resistance (Note 1) RθJA 75 °C/W Operating and Storage Temperature Range Tj, TSTG -55 to +150 °C Maximum DC Reverse Current at Rated DC Blocking Voltage @TA=25°C @TA=100°C 35 A Notes: 1. On aluminum substrate P.C.B. with an area of 0.8" x 0.8" (20 x 20mm) mounted on 0.05 x 0.05" (1.3 x 1.3mm) solder pad ©GUANGDONG HOTTECH INDUSTRIAL CO.,LTD E-mail:hkt@heketai.com 1/2 MB05F-MB10F SURFACE MOUNT BRIDGE RECTIFIER Fig. 2 Typical Forward Characteristics (per leg) Fig. 1 Output Current Derating Curve IF, INSTANTANEOUS FORWARD CURRENT (A) I(AV), AVERAGE FORWARD RECTIFIED CURRENT (A) Typical Characteristics 1.0 0.8 Al. Substrate PC Board 0.6 0.4 Glass Epoxy PC Board 0.2 0 Resistive or Inductive Load 0 40 80 120 10 1.0 0.1 TA= 25°C Pulse Width = 300µs 0.01 0.2 160 0.6 0.8 1.0 1.2 1.4 1.6 VF, INSTANTANEOUS FORWARD VOLTAGE (V) TA, AMBIENT TEMPERATURE (°C) Fig. 3 Maximum Peak Forward Surge Current (per leg) 35 Fig. 4 Typical Junction Capacitance 100 TJ = 25°C f = 1.0MHz 30 Cj, JUNCTION CAPACITANCE (pF) IFSM, PEAK FORWARD SURGE CURRENT (A) 0.4 20 10 0 TA = 25°C Single Half Sine-Wave Pulse Width =8.3ms (JEDEC Method) 1.0 10 1 10 NUMBER OF CYCLES AT 60 Hz ©GUANGDONG HOTTECH INDUSTRIAL CO.,LTD 1 10 100 VR, REVERSE VOLTAGE (V) E-mail:hkt@heketai.com 2/2
MB8F
物料型号:MB05F-MB10F
器件简介: - 这些是表面安装桥式整流器,具有以下特点: - UL认可的组件 - 高浪涌电流能力 - 适合印刷电路板塑料封装,符合UL可燃性分类94V-0
引脚分配: - 引脚为镀锡的,可按照MTL-STD-750标准方法2026进行焊接。
参数特性: - 尺寸:最大尺寸为2.7 x 1.7 x 1.3毫米 - 最大重复峰值反向电压(VRRM):50V至1000V不等 - 最大RMS电压(VRMS):35V至700V不等 - 最大直流阻断电压(Voc):与VRRM相同 - 最大平均正向整流电流(L(AV)):在40°C时,MB 4F为0.8A - 非重复峰值正向浪涌电流(IFSM):MB 4F为35A - 0.8A直流下的正向峰值电压(VFM):MB 4F为1.0V - 最大直流反向电流(IRM):在25°C和额定直流阻断电压下,MB 1F为5.0uA,500uA - 典型结电容(CJ):MB 2F为15pF - 典型热阻(RaJA):MB 1F为75°C/W - 工作和存储温度范围(T TSTG):-55°C至+150°C
功能详解: - 文档提供了输出电流降额曲线图、典型正向特性图、最大峰值正向浪涌电流图和典型结电容图。
应用信息: - 这些整流器适用于电阻性或感性负载,对于电容性负载,需要将电流降低20%。
封装信息: - 封装类型为表面安装,具体封装材料为转移模塑环氧树脂。
很抱歉,暂时无法提供与“MB8F”相匹配的价格&库存,您可以联系我们找货
