NJM4741M
NJM4741M
    JRC(⽇本无线)
    NJM4741M
NJM4741M 数据手册
Designated client product This product will be discontinued its production in the near term. And it is provided for customers currently in use only, with a time limit. It can not be available for your new project. Please select other new or existing products. For more information, please contact our sales office in your region. New Japan Radio Co.,Ltd. www.njr.com NJM4741 GENERAL PURPOSE QUAD OPERATIONAL AMPLIFIER ■ GENERAL DESCRIPTION The NJM4741 consists of four independent high-gain operational amplifiers that are designed for high slew rate, wide band, and good noise characteristics. ■ FEATURES ● Operating Voltage ● Wide Band ● Slew Rate ● Low Input Noise Voltage ● Low Distortion ● Package Outline ● Bipolar Technology ( ±4V~±20V ) ( 3.5MHz typ. ) ( 1.6V/μs typ. ) ( 9nV/√Hz typ. ) ( 0.0005 typ. ) DIP14,DMP14 ■ PACKAGE OUTLINE NJM4741D NJM4741M ■ PIN CONFIGURATION NJM4741D NJM4741M PIN FUNCTION 1.A OUTPUT 2.A –INPUT 3.A +INPUT + 4.V 5.B +INPUT 6.B –INPUT 7.B OUTPUT 8.C OUTPUT 9.C –INPUT 10.C +INPUT 11. V 12.D +INPUT 13.D –INPUT 14.D OUTPUT ■ EQUIVALENT CIRCUIT ( 1/4 Shown ) Ver.2017-10-23 -1- NJM4741 ■ ABSOLUTE MAXIMUM RATINGS ( Ta=25˚C ) PARAMETER Supply Voltage Differential Input Voltage Input Voltage SYMBOL + V /V VID VIC Power Dissipation PD Operating Temperature Range Storage Temperature Range Topr Tstg RATINGS ± 20 ± 30 ± 15 ( note ) ( DIP14 ) 500 ( DMP14 ) 300 -40~+85 -40~+125 UNIT V V V mW ˚C ˚C ( note ) When the supply voltage is less than ±15V,the absolute maximum input voltage is equal to the supply voltage. ■ ELECTRICAL CHARACTERISTICS ( Ta=25˚C,V+/V-=±15V ) PARAMETER Input Offset Voltage Input Offset Current Input Bias Current Large Signal Voltage Gain Operating Current Common Mode Rejection Ratio Supply Voltage Rejection Ratio Maximum Output Voltage 1 Maximum Output Voltage 2 Input Common Mode Voltage Range Slew Rate Equivalent Input Noise Voltage Channel Separation SYMBOL VIO IIO IB AV ICC CMR SVR VOM1 VOM2 VICM SR en CS TEST CONDITION RS≤100Ω RL≥2kΩ,VO=±10V RL≥10kΩ RL≥2kΩ Av=1 f=1kHz f=10kHz,Input Referred MIN. 88 80 80 ± 12 ± 10 ± 12 - TYP. 1.0 5 60 110 5 120 120 ± 13.7 ± 12.5 ± 14 1.6 9 108 MAX. 5.0 50 300 7 - UNIT mV nA nA dB mA dB dB V V V V/μs nV/√Hz dB ( note ) The application that leads to the extreme difference of power dissipation between channels may cause the mutual interference by the temperature gradient on the chip. -2- Ver.2017-10-23 NJM4741 ■ TYPICAL CHARACTERISTICS Ver.2017-10-23 -3- NJM4741 ■ TYPICAL CHARACTERISTICS -4- Ver.2017-10-23 NJM4741 ■ TYPICAL CHARACTERISTICS [CAUTION] The specifications on this databook are only given for information , without any guarantee as regards either mistakes or omissions. The application circuits in this databook are described only to show representative usages of the product and not intended for the guarantee or permission of any right including the industrial rights. Ver.2017-10-23 -5-
NJM4741M 价格&库存
很抱歉,暂时无法提供与“NJM4741M”相匹配的价格&库存,您可以联系我们找货
