HL-304H3GD
HL-304H3GD
    HONGLITRONIC(鸿利光电)
    插件,D=3mm
    发光二极管/LED 黄绿色 插件,D=3mm 565nm~575nm 55mcd
HL-304H3GD 数据手册
HL-304H3GD HL-304H3GD ATTENTION OBSERVE PRECAUTIONS FOR HANDLING ELECTROSTATIC DISCHARGE SENSIT IVE DEVICES Features •φ3 LAMP LED •LOW POWER CONSUMPTION. • CABINED VIEW ING ANGLE. •IDEAL FOR BACKLIGHT AND INDICATOR. •PACKAGE: 1000PCS / BAG. Description This devices are made with TS InGaN. Package Dimensions 3.8 1.5MAX 1.0 3.0 5.3 3.0 29.0 0.5 2 1 1.5 1:ANODE 2:CATHODE 2.54 1 Dimension Tolerance (UNIT:mm) Tolerance Grade 0.5~3 3~6 6~30 30~120 ±0.1 ±0.2 ±0.3 ±0.5 Chip SPEC NO.: 2 Lens Color Material Emitting Color InGaN/SiC Greenish Yellow REV NO.:A/2 Color Diffused DATE:Nov/02/2010 PDF 文件使用 "pdfFactory Pro" 试用版本创建 ÿwww.fineprint.com.cn PAGE:1/4 HL-304H3GD ■Absolute Maximum Rating Item Symbol Value Unit Forward Current IF 20 mA Peak Forward Current* IFP 100 mA Reverse Voltage VR 5 V Power Dissipation PD 80 mW Electrostatic discharge ESD 2000 V Operation Temperature Topr -30∽+80 ℃ Storage Temperature Tstg -30∽+80 ℃ Lead Soldering Temperature* Tsol Max. 260℃ for 5sec Max. *IFP Conditions:Pulse Width≤10msec *Tsol Conditions:3mm from the base of the epoxy bulb ■ Typical Optical/ Electrical Characteristics Item Luminous Intensity Forward Voltage Viewing Angle Prcp Wavelength Recommend Forward Current Reverse Current Notes: Ta=25℃ Symbol Condition Rank Iv VF IF=20mA Min. Typ. Max. Unit E 22 30 mcd F 30 40 mcd G 40 55 mcd 1.8 2.2 2.6 V 2θ 1/2 -- 50 -- deg λD 565 -- 575 nm IF(rec) -- -- -- 20 mA IR Vr=5V -- -- 20 uA Tolerance :VF±0.1V,λd±2 nm,IV(φV) ±15%,2θ 1/2±15% SPEC NO.: REV NO.:A/2 DATE:Nov/02/2010 PDF 文件使用 "pdfFactory Pro" 试用版本创建 www.fineprint.com.cn PAGE:2/4 HL-304H3GD ■ Reliability Performance Test Items And Result Test Duration Sample Size AC/RE 1000 hrs 22 pcs 0/1 100 cycles 22 pcs 0/1 100 cycles 22 pcs 0/1 1000 hrs 22 pcs 0/1 Ta=100℃±5℃ 1000 hrs 22pcs 0/1 Ta=-40℃±5℃ 1000 hrs 22 pcs 0/1 1times 22 pcs 0/1 3times 22pcs 0/1 Test Classification Test Item Test Conditions Life Test Room Temperature DC Operating Life Test Ta=25℃±5℃,IF =20mA 100℃±5℃ 5min ↑↓ -40℃±5℃ 5min. 100℃±5℃ 30min ↑↓5min -40℃±5℃ 30min. 85℃±5℃/85% RH IF=5mA Thermal Shock Test Temperature Cycle Test Environment Test High Temperature & High Humidity Test High Temperature Storage Low Temperature Storage Resistance to Soldering Heat Mechanical Test Lead Integrity 60 50 40 30 20 10 0 20 40 60 80 100 1.6 1.4 1.2 1.0 0.8 0.6 0.4 -25 120 Forward Current vs.Forward Voltage 50 75 100 125 Luminous Spertrum(Ta=25℃) 2.8 40 Forward Voltage VF(V) Forward Current If(mA) 25 Forward Voltage vs. Ambient Temperature 50 30 20 10 0 0 Ambient Temperature Ta(℃) Ambient Temperature Ta(℃) 1.6 1.8 2.0 2.2 2.4 2.6 Forward Voltage VF(V) SPEC NO.: 2.8 SPECTRAL RADIANCE 100 2.6 RELATIVE RESPONSE 100%=1.642e-G01 Forward Current If(mA) Relative Intensity vs. Ambient Temperature Relative Intensity IV%(mcd) Forward Current vs. Ambient Temperature 0 Temp=260℃max T=5sec max Load 2.5N(0.25kgf) 0° ~ 90° ~0° 2.4 2.2 2.0 1.8 1.6 -25 0 25 50 75 100 Ambient Temperature Ta(℃) REV NO.:A/2 125 80 60 40 20 0 400 500 DATE:Nov/02/2010 PDF 文件使用 "pdfFactory Pro" 试用版本创建 www.fineprint.com.cn 600 700 800 nm PAGE:3/4 HL-304H3GD Soldering: 1. Manual Of Soldering The temperature of the iron tip should not be higher than 300℃and Soldering within 3 seconds per solder-land is to be observed. 2. DIP soldering (Wave Soldering): Preheating:120℃~150℃,within 120~180 sec. Operation heating:245℃±5℃ within 5 sec.260℃(Max) Gradual Cooling (Avoid quenching). SPEC NO.: REV NO.:A/2 DATE:Nov/02/2010 PDF 文件使用 "pdfFactory Pro" 试用版本创建 ÿwww.fineprint.com.cn PAGE:4/4
HL-304H3GD
物料型号:HL-304H3GD
器件简介: - 采用TS InGaN材料制造 - 适用于背光和指示器 - 低功耗 - 封装视角 - 包装:1000PCS/袋
引脚分配: - 1:阳极 - 2:阴极
参数特性: - 正向电流:20mA - 峰值正向电流:100mA - 反向电压:5V - 功率耗散:80mW - 静电放电:2000V - 工作温度:-30°C至+80°C - 存储温度:-30°C至+80°C - 引脚焊接温度:最高260°C,持续5秒
功能详解: - 发光强度:22mcd至55mcd - 正向电压:1.8V至2.6V - 视角:50° - 主波长:565nm至575nm - 推荐正向电流:20mA - 反向电流:在5V反向电压下小于20μA
应用信息: - 适用于背光和指示器
封装信息: - 尺寸:φ3 LAMP LED - 封装尺寸:3.0mm x 5.3mm x 1.5mm
可靠性性能测试项目和结果包括: - 常温直流工作寿命测试 - 热冲击测试 - 温度循环测试 - 高温高湿测试 - 高温存储 - 低温存储 - 机械测试:抗焊接热 - 引脚完整性
焊接说明: - 手动焊接:烙铁尖端温度不超过300℃,每个焊点焊接时间不超过3秒。 - 波峰焊接:预热120℃至150℃,持续120至180秒;操作加热245℃±5℃,持续5秒,最大260℃。
HL-304H3GD 价格&库存
很抱歉,暂时无法提供与“HL-304H3GD”相匹配的价格&库存,您可以联系我们找货
HL-304H3GD
  • 10+0.33394
  • 100+0.26493
  • 300+0.23048
  • 1000+0.19635
库存:1148
