TF029B-1000-F
TF029B-1000-F
    NIDEC(尼得科)
    TF029B-1000-F
TF029B-1000-F 数据手册
TF029B MICRO BLOWERS ■ FEATURES OCompact / Light weight The smallest and lightest series OAerodynamic bearings OHigh static pressures OLow vibration OLong life due to aerodynamic bearings without heat dependence OResin in full compliance with FDA standards ■ STANDARD SPECIFICATIONS ● Unless otherwise specified, the environmental conditions are 23°C±5°C, normal humidity, and atmospheric pressure range 90 to 106kPa. No. Item Part number 1 Rated Voltage 2 Direction of Rotation 3 Kind of Gas 4 TF029B-1000-F Remarks DC 12 ∼ 27 V CCW (Counter-Clockwise) Looking down from the air inlet. air Noncorrosive gas Configuration Motor with Centrifugal Blade Without driving circuit 5 Type of Motor DC Brushless Motor 6 Number of Poles 4 Poles (2 pole pairs) 7 Drive System 8 Bearings Aerodynamic Bearings 9 Impeller Centrifugal Turbo Blade 10 Mounting Direction 11 3 Phase, Bipolar Shaft vertical to ground, air inlet facing upwards No vibration, shock, or gyration is to be applied during operation. Rated Rotation Speed 36,000 r/min (reference value) at 2.0kPa, 100L/min 12 Maximum Input Coil Current 2.0 A rms max. 13 Rated Power Supply Current 0.62 A max. 14 Rated Power Consumption 14.9 W max. 15 Rated Air Flow 16 Minimum Air Flow at 2.0kPa, 100L/min, at 24V 100 L/min (at 2.0kPa) 100 L/min at 2.0 kPa TF029B MICRO BLOWERS No. Item Part number TF029B-1000-F 備考 Remarks 17 Rated Pressure 2.0 kPa at 100 L/min 18 Maximum Pressure 3.5 kPa absolute maximum pressure. at 24VDC 19 Torque Constant 20 Min. Rotation Speed 10,000 r/min 21 Maximum Rotation Speed 50,000 r/min Within the "Area of use" 22 Acoustic Audible Noise 65.0 dB(A)max. at 2.0kPa, at 100L/min measured at 1m from air inlet Include background noise 15dB(A) 23 Coil Resistance 24 Coil Inductance 25 Insulation Class 26 Insulation Resistance 27 Dielectric Strength 28 Weight 29 Rotor Inertia 30 Axial Loading 31 Operating Temperature Range 0 ∼ 50 °C 32 Operating Humidity Range 10 ∼ 95%RH 33 Storage Temperature Range -20 ∼ 60 °C 34 Storage Humidity Range 10 ∼ 95%RH 0.0014 ∼ 0.0020 N·m/A (reference value) 0.37 ∼ 0.49 Ω (reference value) 22 ∼ 29 μH (reference value) at 20°C (Between 2 phase) at 20°C, 10kHz (Between 2 phase) Class E JIS C 4003 1M Ω min. DC500V(between terminal pins and shaft holder) JIS C 4003 Leak current to be less than 1mA.(AC600V for 1sec. between terminal pins and shaft holder.) JIS C 4003 55 g (reference value) 2 10 g·cm (reference value) 3N max. maximum axial force applying to the intake (upper housing) No condensation No condensation The Blower shall satisfy Specification No.11 ∼ 27 after the following test. 35 Resistance to Vibration Kind of Vibration frequency veering Frequency Range 10 ∼ 22Hz amplitude 1mm 22 ∼ 50Hz 2 19.6m/s (2G)(acceleration) Sweep Test Time Non-operating to-and-fro, approx. 5min. X, Y, Z directions, 60min. each The Blower shall satisfy Specification No.11 ∼ 27 after the following test. 36 Resistance to Shock 2 Acceleration 294m/s (30G) Pulse Width 6ms Shock Waven Semi-sinusoidal wave Number of Shock X, Y, Z, directions, once per each direction Non-operating TF029B MICRO BLOWERS ■ P-Q CURVE CHARACTERISTICS ● Operating Range at DC 24V (1atm) ● Operating Range at DC 12V (1atm) Area of use Area of use Pressure [kPa] Pressure [kPa] 38,500 r/min 36,000 r/min 26,700 r/min 36,000 r/min 26,700 r/min Air Flow [L/min] Air Flow [L/min] ※ Conditions: Ambient temperature 23±5°C, normal humidity, atmospheric pressure (100±2kPa). The graphs above is provided for reference only. Values are not guaranteed. ※ Make sure the thermistor temperature does not exceed 80°C during blower operation. (Thermistor resistance value R(80 deg C)=1.177kΩ). ■ INTERFACE Pin No. Symbol Wire Color Signal 1 U Brown Motor Coil (U) Motor Coil (V) 2 V Red 3 W Orange Motor Coil (W) 4 TH(-) Yellow Thermistor Output(−) 5 TH(+) Green Thermistor Output(+) ※Parts used for thermistor output:  Manufacture TDK Corp. Part No. NTCG164BH103JT ● TIMING CHART U + - V + - W + - (5)(4)(3)(2)(1) 0 0 60 30 120 180 60 90 240 120 300 360 [deg] electrical degree 150 180 [deg] mechanical degree TF029B MICRO BLOWERS ■ OUTLINE DIMENSIONS Unless otherwise specified, tolerance : ± 0.5(Unit: mm) (33.6) 1.3 32.3 20.8 29.5 3.5 19.94 19.56 Ø12 Ø17 21.94 6.7 1.3 3 110± 5 2) (Ø1 20° ■ MARKING TF029B -1000-F 【Chart 1】 day 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 code 1 2 3 4 5 6 7 8 9 A B C D E F G H J K L day 21 22 23 24 25 26 27 28 29 30 31 code M N P Q R T U V W X Y Serial Number control number : alphabet (A - Z) day of manufacture : refer to Chart 1 below month of manufacture : refer to Chart 2 below 【Chart 2】 month 1 2 3 4 5 6 7 8 9 10 11 12 year of manufacture : last digit of the year (A.D.) code 1 2 3 4 5 6 7 8 9 O N D ■ Micro Blower Kit with driver For the series, Kits with driver and wire harness for the blower available.They will help customers shorten their evaluation and product development times. OKit Part Number : TF029B-1000-P List of the kit 1 2 3 Micro Blower (TF029B-1000-F) Driver (for TF029B) Wire Harness (for Driver-Power connection) The Drivers are sold separately as an optional item. (Ref.P435)
TF029B-1000-F 价格&库存
很抱歉,暂时无法提供与“TF029B-1000-F”相匹配的价格&库存,您可以联系我们找货
