DF20F-3032SCFA(04)
DF20F-3032SCFA(04)
    HRS(广濑)
    DF20F-3032SCFA(04)
DF20F-3032SCFA(04) 数据手册
1mm Pitch Double Rows Low Profile Wire-to-Board Connectors DF20 series Cable 5.4 Socket DF20A**DS-1C DF20F(G)**DP-1V(56) 5.8 Pin Header Cable 6.2 DF20F **DP-1H(59) Pin Header 5.5 Apr.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. PCB DF20A**DS-1C Socket PCB ■Features Narrower external width and length 1. Contact Pitch 1mm contact pitch allows reliable solder and cable termination. 2. Reliable electrical connection wipe Effective electrical connection is assured with a 1mm wipe of mating contacts. 3. Narrower external width and length Redesigned metal fittings decreased the overall length of the board- mount receptacle and permit end-to-end mounting of several connectors. 4. Automatic equipment board placement Straight type pin headers are supplied with a 5.4mm X 4.6mm flat platform to allow vacuum pick-up and placement on the board. Metal fitting 5. Product variations (1) Available with 10, 20, 30, 40, and 50 contacts. (2) Pin headers are available in two types : with or without board positioning bosses. (3) Depending on specific application pin headers can be ordered in straight or right angle types. ■Applications DF20F-****SCFA Contact Notebook PC, small office automation equipment, small consumer devices, portable devices. Any application requiring low profile reliable board-to-cable connection with a 28 AWG, 30 AWG, 32 AWG conductors. DF20A-**DS-1C Socket DF20F(G)-**DP-1V(56) B266 1 Pin Header 1mm Pitch, Double Rows DF20 Series●1mm Pitch Double Rows Low Profile Wire-to-Board Connectors ■Product Specifications 28 AWG : 1A 30 AWG : 0.9A 32 AWG : 0.7A Rated voltage 100V AC Rated current Rating Item Operating humidity range Storage humidity range -40% to 70% -40% to 80% Specifications 1.Insulation resistance Apr.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Operating temperature range -35°C to 85°C (Note 1,2) Storage temperature range -10°C to 60°C (Note 2) Conditions Measured at 100V DC 500Mø min. 2.Withstanding voltage No flashover or insulation breakdown Conduction of 300V AC applied for 1 minute 3.Contact resistance Measure at 100mA. 30Mø max. 4.Insertion-Extraction force 0.2 N Min., 2 N Max. 4.(per contact) Measured with a steel pin of 0.2 ±0.005 thickness 5.Vibration No electrical discontinuity of 1µs min. Frequency of 10 to 55 Hz, single amplitude of 0.75 mm, in 3 directions for 2hours 6.Humidity Contact resistance of 30mø max., insulation resistance of 100Mø min. Temperature of 40±2ç, humidity of 90% to 95%, left standing for 96 hours 7.Temperature cycle Contact resistance of 30mø max,insulation resistance of 500Mø min. (-55ç : 30min / 5ç to 35ç : 2 to 3min / 85ç : 30min / 5ç to 35ç : 2 to 3min ) for 5 cycles 8.Mechanical operation Contact resistance of 30mø max. 50 cycles 9.Resistance to Soldering heat Reflow : At the recommended temperature profile, manual solder : Soldering iron temperature of 300°C for 3 seconds No deformation of the insulator parts that will affect performance Note1 : Includes temperature rise caused by current flow. Note2 : The term “storage” refers to products stored for long periods of time prior to mounting and use. Note2 : Operating temperature range and Humidity range covers non-conducting conditions of installed connectors in storage, Note2 : shipment or transportation. Note3 : Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications for a specific part number shown. ■Materials / Finish Item Part Material Finish Remarks Socket Socket contact Insulator Polyamide Color : Beige UL94V-0 Contact Phosphor bronze Gold plating ---------- Insulator Polyamide Color : Beige UL94V-0 Contact Phosphor bronze Gold plating ---------- Metal Fitting Brass Tin-Copper plating ---------- Pin header ■Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. ●Connectors DF20 # - * DS - 1 C 1 2 3 4 1 Series name : DF20 2 Boss Type ■Pin header ■ F : Without boss ■G : With boss ■Crimp socket: A 3 Number of contacts : 10, 20, 30, 40, 50 ●Contacts 5 6 4 Connector type DS: Double-row socket DP: Double-row pin header 5 Contact pitch: 1 mm 6 Type of housing, header 7 C: Crimp housing V: Straight SMT header H: Right angle SMT header DF20 F - 2830 SCF A 1 F 1 Applicable wire size 2830 : 28 to 30 AWG 3032 : 30 to 32 AWG 2 3 2 Contact & packaging type SCF : Socket contact reel 3 Plating type A : Gold plating (* *) 4 4 Packaging Specifications 04 : 1 reel = 10,000 pieces 44 : 1 reel = 20,000 pieces B267 DF20 Series●1mm Pitch Double Rows Low Profile Wire-to-Board Connectors ■Double Row Socket A B P=1 Contact No. 2 Contact No. 1 Contact No. * Contact No. * 5 4.28 4.1 5th contact marking Contact No. 1 mark Unit : mm RoHS [Specifications number]-*, (**) Part No. HRS No. No. of Contacts A B DF20A-10DS-1C 686-0020-3 10 17.2 14.0 DF20A-20DS-1C 686-0021-6 20 12.2 19.0 DF20A-30DS-1C 686-0022-9 30 17.2 14.0 DF20A-40DS-1C 686-0023-1 40 22.2 19.0 DF20A-50DS-1C 686-0024-4 50 27.2 24.0 Blank : Bag packaging (100 pcs / pack) YES Note : Sales quantities are by the package unit (containing 100 pieces). Please order by package unit. ■Socket Crimp Contacts Part No. HRS No. DF20F-2830SCFA(**) 686-0042-6 ** DF20F-3032SCFA(**) 686-0043-9 ** DF20F-36SCFA(**) (Note 2) 686-0051-7 ** Type of contacts Quantity Plating type RoHS Reel contacts See specifications number column Gold plating YES [Specifications number] -*, (**) (04) : 10,000 pcs / reel (44) : 20,000 pcs / reel 1.45 0.7 ●Applicable Wire (Tin plated solid soft conductor) Jacket diameter 2 28 AWG (7/0.127mm) 0.5 to 0.6mm 30 AWG (7/0.1mm) 0.9 Applicable Wire Size (Stranded wire conductor) 3.3 32 AWG (7/0.08mm) ●Recommended wire ●UL1571(thin type) (Note 2) 0.5 Apr.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Shown with terminated and installed contacts ●Strip length ●1.2 to 1.9mm Note 1 : When using other than the recommended wire, contact your nearest Hirose representative. Note 2 : Contact your Hirose sales representative when using 36 AWG. ●Applicable Crimping Tools Type HRS No. Part No. Applicator 901-4572-6 AP105-DF20-2830S Press 901-0001-0 CM-105C Note 1 : Hirose Electric will not be responsible for any problems caused by use of tools other than specified. Note 2 : Please conduct crimping work according to the "Crimping work standards" and "Crimp condition table". Applicable contact DF20F-2830SCFA(**) DF20F-3032SCFA(**) ---- ■Replacement Parts List for Applicator Type Part No. HRS No. Insulation crimper AP105-DF20-2830S(61) 901-4572-6 61 Wire crimper AP105-DF20-2830S(62) 901-4572-6 62 Insulation anvil and wire anvil AP105-DF20-2830S(63) 901-4572-6 63 B268 DF20 Series●1mm Pitch Double Rows Low Profile Wire-to-Board Connectors ■ Double Row Straight Pin header B A Contact No.3 P=1 Contact No.1 Contact No. **-1 Indication of number of contacts Contact No. ** 6.4 Contact No.2 0.2 4.6 0.7 Ø0.5 1.9 D C A 0.2 BPCB Footprints A ±0.05 P=1±0.03 0.9±0.05 Contact No. 1 marking 0.85±0.1 1.9±0.05 7.2 ±0.1 4±0.1 1.8 ±0.1 0.5±0.05 0.6±0.05 .1 +0 0 .7 Ø0 Apr.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 5.4 D±0.05 Note 1 : Shaded area must be free of any electrically conductive traces to avoid contact with soldered pin header terminations. Note 2 : Required only for pin headers supplied with the positioning boss. Unit : mm Part No. HRS No. No. of contacts A B C D DF20F -10DP-1V(56) 686-0032-2 56 10 14.0 17.3 16.6 ---- DF20F -20DP-1V(56) 686-0033-5 56 20 19.0 12.3 11.6 ---- DF20F -30DP-1V(56) 686-0034-8 56 30 14.0 17.3 16.6 ---- DF20F -40DP-1V(56) 686-0035-0 56 40 19.0 22.3 21.6 ---- DF20F -50DP-1V(56) 686-0036-3 56 50 24.0 27.3 26.6 ---- DF20G-10DP-1V(56) 686-0037-6 56 10 14.0 17.3 16.6 15.7 DF20G-20DP-1V(56) 686-0038-9 56 20 19.0 12.3 11.6 10.7 DF20G-30DP-1V(56) 686-0039-1 56 30 14.0 17.3 16.6 15.7 DF20G-40DP-1V(56) 686-0040-0 56 40 19.0 22.3 21.6 20.7 DF20G-50DP-1V(56) 686-0041-3 56 50 24.0 27.3 26.6 25.7 Note 1 : Order embossed tape packaging items by the reel. (1 reel contains 1,000 pieces) Note 2 : Vacuum pick-up cap are included with embossed tape packaged connectors. Remarks RoHS Without boss YES With boss [Specifications number]-*, (**) (56) : Gold plating, embossed tape packaging B269 DF20 Series●1mm Pitch Double Rows Low Profile Wire-to-Board Connectors ■Double Row Right angle Pin header Contact No.1 Contact No.**-1 Contact No.3 Contact No.1 marking Contact No.** Contact No.2 B Indication of number of contacts P= 1 0.2 6.2 A 0.2 C +0.1 0 1.4 2.45 +0.1 0 3.8 ±0.05 1.4 +0.1 0 BPCB Footprints 2.75 ±0.05 Apr.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ** 5.5 A 5 0.6 ±0.05 P= 1 ±0.03 A ±0.05 0.75 ±0.1 D ±0.05 Note : Shaded area must be free of any electrically conductive traces to avoid contact with soldered pin header terminations. Unit : mm Part No. HRS No. No. of contacts DF20F -10DP-1H(59) 686-0027-2(59) 10 24.0 27.5 26.2 25.8 DF20F -20DP-1H(59) 686-0028-5(59) 20 29.0 12.5 11.2 10.8 DF20F -30DP-1H(59) 686-0029-8(59) 30 14.0 17.5 16.2 15.8 DF20F -40DP-1H(59) 686-0030-7(59) 40 19.0 22.5 21.2 20.8 A B C D Note : Order embossed tape packaging items by the reel. (1 reel contains 1,000 pieces) B270 Remarks RoHS Without boss YES [Specifications number]-*, (**) (59) : Gold plating, embossed tape packaging DF20 Series●1mm Pitch Double Rows Low Profile Wire-to-Board Connectors BEmbossed Carrier Tape Dimensions ●Straight pin header Ø1 12 ±0.1 +0 0 .1 0.2±0.05 A ±0.3 R0. 7 5 1.7 +0.15 0 1.5 (0.4) +0.1 0 Unreeling direction (7.9) 4±0.1 1.75 ±0.1 ●Right angle pin header 2±0.1 12±0.1 0.2±0.05 A ±0.3 R0 .75 1.7 +0.15 0 B ±0.1 C ±0.1 .1 +0 0 .5 Ø1 (0.4) 1.5 +0.1 0 (7.4) Unreeling direction ●Reel dimensions B C D 10 16 -------- 17.5 16.4 DF20F(G)-20DP-1V(56) 20 24 -------- 11.5 24.4 DF20F(G)-30DP-1V(56) 30 32 28.4 14.2 32.4 DF20F(G)-40DP-1V(56) 40 44 40.4 20.2 44.4 DF20F(G)-50DP-1V(56) 50 44 40.4 20.2 44.4 DF20F - 10DP-1H(59) 10 16 -------- 17.5 16.4 DF20F - 20DP-1H(59) 20 24 -------- 11.5 24.4 DF20F - 30DP-1H(59) 30 32 28.4 14.2 32.4 DF20F - 40DP-1H(59) 40 44 40.4 20.2 44.4 2 ±0.5 Product name label Ø1.5mm diameter feed hole depth 0.8 Ø21± Ø380 ±2 A DF20F(G)-10DP-1V(56) (Ø80) No. of Contacts ±0 .2 Part No. 2±0.5 D +2 0 Ø1 3 Apr.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. B ±0.1 C ±0.1 .5 1.75±0.1 2 ±0.1 4 ±0.1 B271 DF20 Series●1mm Pitch Double Rows Low Profile Wire-to-Board Connectors BUsage recommendation 1. Recommended Soldering Temperature Profile for IR Reflow. 10(s) max Temperature 250 240 220 200 150 Apr.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 60 to 120(s) B272 60(s) max 100 60 120 180 240 300 Time(S) Note 1 : Up to 2 cycles of reflow soldering are possible under the same conditions, provided that there is a return to normal temperature between the first and second cycle. Note 2 : The temperature indicates the board surface temperature at the points of contacts with the connector terminals. 2. Recommended Manual Soldering Conditions Soldering temperature : 290°C ±10°C, Soldering time : within 3 sec. 3. Recommended Solder Screen Thickness 0.15mm 4. Board Warping Maximum of 0.03mm at the connector center section, with both ends of the connector as reference points. 5. Cleaning Conditions Refer to "Wire-to-Board Connector Use Handbook" 6. Wiring Termination Conditions Refer to "Wire-to-Board Connector Use Handbook" Crimp contacts should be handled with care as not to cause any deformation or damage affecting the performance or termination. 7. Mating / un-mating precautions Excessive twisting and pulling on wires during mating/un-mating should be avoided as it may cause damage to connectors. 8. Precautions Refer to "Wire-to-Board Connector Use Handbook"
DF20F-3032SCFA(04) 价格&库存
很抱歉,暂时无法提供与“DF20F-3032SCFA(04)”相匹配的价格&库存,您可以联系我们找货
