32K10A-40ML5
32K10A-40ML5
    ROSENBERGER
    SMA
32K10A-40ML5 数据手册
Technical Data Sheet RF_35/09.14/6.2 Dieses Dokument ist urheberrechtlich geschützt ● This document is protected by copyright ● Rosenberger Hochfrequenztechnik GmbH & Co. KG SMA 32K10A-40ML5 Straight Jack PCB All dimensions are in mm; tolerances according to ISO 2768 m-H Interface According to IEC 60169-15, EN 122110, MIL-STD-348A, Fig. 310 Documents PCB layout Tape & reel packaging B 163 VG08.50000 Material and plating Connector parts Center contact Outer contact Dielectric Material CuBe Brass PTFE Rosenberger Hochfrequenztechnik GmbH & Co. KG P.O.Box 1260 D-84526 Tittmoning Germany www.rosenberger.de Plating AuroDur®, gold plated AuroDur®, gold plated Tel. : +49 8684 18-0 Email : info@rosenberger.de Page 1/2 Technical Data Sheet SMA 32K10A-40ML5 Straight Jack PCB Electrical data RF_35/09.14/6.2 Dieses Dokument ist urheberrechtlich geschützt ● This document is protected by copyright ● Rosenberger Hochfrequenztechnik GmbH & Co. KG Impedance Frequency VSWR Insertion loss Insulation resistance Center contact resistance Outer contact resistance Test voltage Working voltage Power handling (at 20 °C, sea level, VSWR 1.0) RF-leakage 50  DC to 12.4 GHz  1.05 + 0.005 x f [GHz], DC to 8 GHz  1.30, 8 to 12.4 GHz  0.04 x f(GHz) dB  5 x103 M  3 m  2 m 1000 V rms 480 V rms  200 W @ 2 GHz;  100 W @ 10 GHz  100 dB up to 1 GHz - Connector only, VSWR in application depends decisive on PCB layout - Mechanical data Mating cycles Center contact captivation: axial radial Coupling test torque Recommended torque min. 100  20 N  1 Ncm max. 0.6 Nm 0.5 Nm Environmental data Temperature range Thermal shock Corrosion Vibration Shock Moisture resistance Max. soldering temperature RoHS -55°C to +155°C MIL-STD-202, Meth. 107, Cond. B MIL-STD-202, Meth. 101, Cond. B MIL-STD-202, Meth. 204, Cond. D MIL-STD-202, Meth. 213, Cond. I MIL-STD-202, Meth. 106 IEC 61760-1, +260°C for 10 sec. compliant Tooling N/A Suitable cables N/A Weight Weight 1.19 g/pce While the information has been carefully compiled to the best of our knowledge, nothing is intended as representation or warranty on our part and no statement herein shall be construed as recommendation to infringe existing patents. In the effort to improve our products, we reserve the right to make changes judged to be necessary. For the installation of the electrotechnical equipment, particular electrotechnical expertise is required. Draft Date Approved Date Rev. Engineering change number Name Date Rong Fang 22.04.04 Chr. Janßen 04.11.20 h00 20-1927 S. Huber-Siegl 04.11.20 Rosenberger Hochfrequenztechnik GmbH & Co. KG P.O.Box 1260 D-84526 Tittmoning Germany www.rosenberger.de Tel. : +49 8684 18-0 Email : info@rosenberger.de Page 2/2
32K10A-40ML5 价格&库存
很抱歉,暂时无法提供与“32K10A-40ML5”相匹配的价格&库存,您可以联系我们找货
