SW-504
SW-504
    BRAINBOXES
    SW-504
SW-504 数据手册
UK +44 (0)151 220 2500 // USA +1 855 958 2502 // JAPAN +81-3-3683-0509 www.brainboxes.com // sales@brainboxes.com SW-504 Industrial 4 Port Ethernet Switch 10/100 4 Port Unmanaged Ethernet Switch DIN Mountable • 4 Port 10/100 Mbs Ethernet Switch • Redundant dual power inputs: +5V to +30V DC • Compact design with integral DIN mount • No software required - Simply plug in and connect • Industrial temperature range +5 to +30 Volt Power Input enables the device to be run from a standard car battery ideal for in vehicle applications GB AEOF 00031/11 Non conducting polyamide casing with removable numbered power terminal for easy wiring Integral DIN mount and slim design takes up minimal cabinet space UK +44 (0)151 220 2500 // USA +1 855 958 2502 // JAPAN +81-3-3683-0509 www.brainboxes.com // sales@brainboxes.com SW-504 Industrial 4 Port Ethernet Switch 10/100 No software needed: Simply plug in any ethernet cable -40ºC to +80ºC/-40ºF to +176ºF temperature range All Ethernet ports are Auto MDI/ MDIX supporting straight through or crossover Ethernet cables Non-conducting polyamide case Integral DIN mount with ground Power consumption is optimised based on the status of the link device Automatic detection of data transmission speed: 10 or 100 MBps 2k Byte maximum packet size – improves the efficiency of bulk data transfer and system performance Broadcast Storm protection Connectors Screw Terminals Wire Thickness Power Supply Power Consumption Power Supply input Isolation Environmental Operating Temperature Storage Temperature Ambient Relative Humidity Magjack LED Information Link/Activity LED Ethernet Ethernet Port Protection Housing Dual redundant power input: +5VDC to +30VDC Easy Wire Removable screw terminal block 3.5mm pitch, #22 - #14, 0.5mm2-2.5mm2 pin power supply 0.150 inch, 3.81mm, 20 pins, 12+8 screw terminals, #26 - #16 AWG, 0.14mm2-1.3mm2 1.1 Watts Max : 220 mAmps@+5VDC/36mAmps@+30VDC Unregulated +5V to +30Volts DC, reverse polarity protection 1500VRMS Magnetic isolation from Ethernet -40ºC to +80ºC/-40ºF to +176ºF -40ºC to +80ºC/-40ºF to +176ºF 5 to 95% (non-condensing) Solid green Flashing Green Connection established Data communication 4 x RJ45 jack, 10/100Mhz autosensing, crossover auto sensing (Auto MDIX) 1,500 Volts magnetic isolation between ports IP-20 rated non-conducting polyamide case UK +44 (0)151 220 2500 // USA +1 855 958 2502 // JAPAN +81-3-3683-0509 www.brainboxes.com // sales@brainboxes.com SW-504 Industrial 4 Port Ethernet Switch 10/100 Power Terminal Pin Outs Ethernet Ports x4 Pin Outs PIN FUNCTION PIN FUNCTION 1 -V 1 RD+ / TD+ 2 +VA 2 RD- / TD- 3 +VB 3 TD+ / RD+ 4 -V 4 NC 5 Functional Earth 5 NC 6 TD- / RD- 7 NC 8 NC Lifetime Warranty and Support: We can help with every aspect of your project, from getting you up and running to custom application. UK +44 (0)151 220 2500 // USA +1 855 958 2502 // JAPAN +81-3-3683-0509 www.brainboxes.com // sales@brainboxes.com SW-504 Industrial 4 Port Ethernet Switch 10/100 Packaging Information Packaging Quick Start Guide Device Ethernet Switch 4 port Packaged Weight 0.207 kg, 7.30 ounces Packaged Dims 160x135x49 mm, 6.3x5.3x1.9 inches GTIN Universal Code 837324009873 Approvals Industry Approvals Microsoft Certified Gold Partner, WEEE, RoHS, AEO (C-TPAT), CE, METL Complies with UL 60950-1 Product Support Warranty Lifetime - online registration required Support Lifetime Web, Email and Phone Support from fully qualified, friendly staff who work in and alongside the Product Development Team Additional Information OEM option Available for bulk buy OEM Made In Manufactured in the UK by Brainboxes Winner 2005 European Electronics Industry Awards ‘Manufacturer of the Year’ Brainboxes operate a ‘Perfect Fit Custom Design’ policy for volume users. More info:sales@brainboxes.com Customisable PW-600 PW-650 SW Range Power supply with connectors for UK, USA, EU and AUS mains socket. ‘Tails’ are suitable for connecting to screw terminal blocks. Power supply with USB connector and prewired screw terminal block. Suitable for use with 5V USB ports. Switch products available in a range of formats and specifications. www.brainboxes.com © Brainboxes 2020 BBSW280220
SW-504 价格&库存
很抱歉,暂时无法提供与“SW-504”相匹配的价格&库存,您可以联系我们找货
SW-504
    • 1+578.67610
    库存:111
    SW-504
    • 1+657.459951+85.32630
    • 5+633.602975+82.23010
    • 10+605.7408110+78.61410
    库存:149
