RS1AF THRU RS1MF
Reverse Voltage - 50 to 1000 Volts
Forward Current - 1.0 Ampere
SURFACE MOUNT FAST RECOVERY RECTIFIER
Features
SMAF
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
For surface mounted applications
Fast switching for high efficiency
Low reverse leakage
Built-in strain relief,ideal for automated placement
0.106(2.70)
0.094(2.40)
0.063 (1.60)
0.051 (1.30)
0.146(3.70)
0.130(3.30)
High forward surge current capability
High temperature soldering guaranteed:
260°C/10 seconds at terminals
0.047(1.20)
0.035(0.90)
Glass passivated chip junction
0.008(0.20)
0.005(0.12)
0.047(1.20)
0.031(0.80)
Mechanical Data
0.193(4.90)
0.173(4.40)
Case : JEDEC SMAF Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.00095ounce, 0.027 grams
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25°C ambient temperature unlss otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SYMBOLS
MDD
RS1AF
MDD
RS1BF
VRMM
50
35
50
100
70
100
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
at TL=125℃
Peak forward surge current
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
Maximum instantaneous forward voltage at 1.0A
Maximum DC reverse current
at rated DCblocking voltage
Maximum reverse recovery time
TA=25℃
TA=125℃
(NOTE 1)
Typical junction capacitance (NOTE 2)
Typical thermal resistance (NOTE 3)
Operating junction and storage temperature range
VRMS
VDC
MDD
MDD
RS1DF RS1GF
200
140
200
400
280
400
MDD
RS1JF
600
420
600
MDD
MDD
RS1KF RS1MF
800
560
800
1000
700
1000
UNITS
V
V
V
A
I(AV)
1.0
IFSM
30
A
VF
1.30
V
IR
5.0
50.0
uA
trr
150
250
500
ns
CJ
RJA
15.0
pF
80.0
℃/W
TJ,TSTG
-55 to +150
Note:1.Reverse recovery condition IF=0.5A,IR=1.0A,Irr=0.25A
2.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
3.P.C.B. mounted with 2.0”x2.0”(5.0x5.0cm) copper pad areas
http://www.microdiode.com
Rev:2024A2
Page :1
RS1AF THRU RS1MF
Ratings And Characteristic Curves
Fig.1 Forward Current Derating Curve
Fig.2 Typical Reverse Characteristics
1.2
Instaneous Reverse Current(μ A)
100
Average Forward Current (A)
1.0
0.8
0.6
0.4
0.2
Single phase half-wave 60 Hz resistive
or inductive load
0.0
25
50
75
100
125
150
1.0
TJ=25°C
0.1
175
00
Case Temperature (°C)
60
80
100
100
Junction Capacitance (pF)
1.0
0.1
pulse with 300μ
s
1% duty cycle
0.0
0.5
1.0
1.5
140
Fig.4 Typical Junction Capacitance
10
0.01
120
percent of Rated Peak Reverse Voltage (%)
Fig.3 Typical Instaneous Forward
Characteristics TJ=25°C
Instaneous Forward Current (A)
TJ=125°C
10
2.0
TJ=25°C
10
1
2.5
0.1
1.0
10
100
Reverse Voltage (V)
Instaneous Forward Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
Peak Forward Surage Current (A)
35
30
25
10
05
00
8.3 ms Single Half Sine Wave (JEDEC
Method)
1
10
100
Number of Cycles
The curve above is for reference only.
Rev:2024A2
Page :2
RS1AF THRU RS1MF
Packing information
P0
P1
unit:mm
d
E
Item
F
B
A
Symbol
Tolerance
A
B
C
d
D
D1
D2
E
F
P
P0
P1
T
W
W1
0.1
0.1
0.1
0.05
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
SMAF
W
P
D2
T
D1
C
W1
D
Carrier width
Carrier length
Carrier depth
Sprocket hole
7" Reel outside diameter
7" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
Reel width
2.80
4.75
1.42
1.50
178.00
54.40
13.00
1.75
5.05
4.00
4.00
2.00
0.30
8.00
12.30
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
SMAF
REEL SIZE
7"
REEL
(pcs)
COMPONENT
SPACING
(m/m)
BOX
(pcs)
INNER
BOX
(m/m)
REEL
DIA,
(m/m)
CARTON
SIZE
(m/m)
CARTON
(pcs)
APPROX.
GROSS WEIGHT
(kg)
3,000
4.0
6,000
210*208*203
178
400*265*400
120,000
10.0
Suggested Pad Layout
Symbol
Unit (mm)
Unit (inch)
A
1.8
0.071
B
1.6
3.8
0.150
D
2.2
0.087
E
5.4
0.213
C
0.063
Rev:2024A2
Page :3
很抱歉,暂时无法提供与“RS1MF”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.08151
- 500+0.06516
- 3000+0.05081
- 6000+0.04536
- 24000+0.04055
- 51000+0.03803
- 国内价格
- 1+0.19845
- 200+0.06605
- 1500+0.04127
- 3000+0.03276
- 国内价格
- 1000+0.04972
- 3000+0.03543
- 国内价格
- 10+0.03240
- 100+0.02620
- 200+0.02380
- 1000+0.02160
- 国内价格
- 50+0.07702
- 600+0.06158
- 1200+0.06066
- 3000+0.04802
- 国内价格
- 10+0.02970
- 100+0.02920
- 300+0.02870
- 1000+0.28080
