PCCG-LFP14.4V15A
PCCG-LFP14.4V15A
    OTHER
    PCCG-LFP14.4V15A
PCCG-LFP14.4V15A 数据手册
PCCG-LFP14.4V15A 14.4V 15A Lithium Iron Phosphate (LiFePO4) Battery Charger ■ SPECIFICATIONS Item Description Smart CC/CV 12.8V / 15A LiFePO� Battery Charger w/ 4ft alligator clips cable CAUTION: Designed for charging 12.8V LiFePO4 batteries only Input Output Environmental Mechanical Rating Input Voltage (VAC) 100 ~ 240 (47 - 63Hz) Input Voltage Range (VAC) 90 ~ 264 (47 - 63Hz) Max Input Current (A) 3 Output Voltage (VDC) 14.4 ± 0.2V Output Current (A) 15± 5% Safety & EMC IEC60601-1 & EN55014 / EN61000 Max Output Power (W) 216 LED Color Green ON: Fully Charged Red ON: Charging Red Flashing: Fault LED Off: No AC Power Short Circuit Protection Present, Self-Recovery Reverse Polarity Protection Present, Self-Recovery Operating Temperature (ºC) -10 ~ +40 Operating Humidity (%) 5 ~ 95 Storage Temperature (ºC) -40 ~ +70 Storage Humidity (%) 5 ~ 95 Maximum Altitude (m) 3000 Weight (approx.) (kg) 1.2 Size (case only) L x W x H (mm) 203 x 100 x 54 Input Plug 2-prong USA Output Cable Length (ft) 4 Output Connector Black Alligator - Negative Red Alligator - Positive 54 REV V2.2 zeusbatteryproducts.com 877.469.4255 sales@zeusbatteryproducts.com
PCCG-LFP14.4V15A 价格&库存
很抱歉,暂时无法提供与“PCCG-LFP14.4V15A”相匹配的价格&库存,您可以联系我们找货
