HIF3H-50DA-2.5DSA(71)
    HRS(广濑)
    插件,P=2.54mm
    排母 间距:2.54mm 2x25P 直插
HIF3H-50DA-2.5DSA(71) 数据手册
2.54mm Pitch Board to Board Connector HIF3H Series ■Features 1. Product Variation Afford to connect the board to board horizontally or vertically. 2. Compatibility Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Achieve combination with other HIF3H series. ■Applications Computers, termination equipment, various kinds of electronic equipment, Office Automation machines and so on ■Product Specifications Rating Current rating: 3A Operating Temperature Range: -55 to +85ç (Note 1) Voltage rating: 300V AC Operating Humidity Range: 40 to 80% Item Storage Temperature Range: -10 to +60ç(Note 2) Operating Humidity Range: 40 to 70% (Note 2) Specification Condition 1. Insulation Resistance 1000M ohms 500V DC 2. Withstanding Voltage No flashover or insulation breakdown. 1000V AC/1 minute. 3. Contact Resistance 15m ohms max. Measured at 0.1A 4. Vibration No electrical discontinuity of 1μs or more Frequency: 10 to 55 Hz, single amplitude of 0.75 mm, 2 hours in each of the 3 directions. 5. Humidity (Steady state) Insulation resistance: 1000 ohms min. 6. Temperature Cycle 96 hours at temperature of 40ç and humidity of 90% to 95% ( -55ç: 30 minutes→15 to 35ç: 5 minutes max.→ (125ç: 30 minutes→15 to 35ç: 5 minutes max.) 5 cycles No damage, cracks, or parts looseness. 7. Durability (Mating/un-mating) Contact resistance: 15 m ohms max. 500 cycles 8. Resistance to Soldering heat No deformation of components affecting performance. Solder bath: 260ç for 10 seconds Manual soldering: 360ç for 5 seconds Note 1: Includes temperature rise caused by current flow. Note 2: The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and Humidity range covers non conducting condition of installed connectors in storage, shipment or during transportation. Note 3. Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications for a specific part number shown. ■Material Parts Insulator Receptacle Contact DS Material Finish Remarks PBT Black UL94V-0 Phosphor bronze Selective gold plated DSA Pin header ––––––– Brass or phosphor bronze Selective gold plated B53 HIF3H Series●2.54mm Pitch Board to Board Connector ■Ordering Information ●Pin Header HIF3H - * P B - 2.54 DSA q w Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. q Series Name e r t : HIF3H w Number of contacts : 4, 6, 10, 12, 14, 16, 20, 24, 26, 30, 34, 40, 50, 60, 70, 130 e P : Pin header r Contact material A: Phosphor bronze (DS: brass) B: Brass t Contact pitch : 2.54mm y Contact type DS : Right angle type DSA : Straight type W : Wrapping type ●Socket HIF3H q A - * D A - 2.54 DSA w q Series Name e r t y u : HIF3H w No symbol : Standard A : With mis-insertion preventive guide B : Similarly, guide position center 1 point type for 50, 60 and 64 contacts e Number of contacts : 4, 6, 8, 10, 12, 14, 16, 18, 20, 24, 25, 26, 30, 34, 40, 50, 60, 64, 70, 130 r Contact alignment: D: double rows S: single row t A : Straight selective gold plated B : Right angle selective gold plated y Contact pitch : 2.54mm u Contact type DS: Right angle type DSA: Straight type B54 y HIF3H Series●2.54mm Pitch Board to Board Connector Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■Receptacle Straight Through hole Type Unit:mm Part Number CL No. Number of Contacts HIF3HA- 6DA-2.54DSA(71) 618-0139-8-71 HIF3HA-10DA-2.54DSA(71) 618-0101-5-71 HIF3HA-10DA-2.54DSA(71) 618-0121-2-71 HIF3HA-12DA-2.54DSA(71) 618-0102-8-71 HIF3HA-16DA-2.54DSA(71) 618-0103-0-71 HIF3HA-16DA-2.54DSA(71) 618-0123-8-71 HIF3HA-18DA-2.54DSA(71) 618-0111-9-71 HIF3HA-20DA-2.54DSA(71) 618-0104-3-71 HIF3HA-20DA-2.54DSA(71) 618-0124-0-71 HIF3HA-24DA-2.54DSA(71) 618-0113-4-71 HIF3HA-26DA-2.54DSA(71) 618-0105-6-71 HIF3HA-26DA-2.54DSA(71) 618-0125-3-71 6 A B Part Number RoHS 10 13.7 10.16 12 16.24 12.7 16 21.32 17.78 18 23.86 20.32 20 26.4 22.86 24 31.46 27.94 26 34.02 30.48 CL No. HIF3HA-30DA-2.54DSA(71) 618-0106-9-71 8.62 5.08 HIF3HA-30DA-2.54DSA(71) 618-0126-6-71 HIF3HA-34DA-2.54DSA(71) 618-0107-1-71 HIF3HA-34DA-2.54DSA(71) 618-0127-9-71 HIF3HA-40DA-2.54DSA(71) 618-0108-4-71 YES HIF3HA-40DA-2.54DSA(71) 618-0128-1-71 Number of Contacts A B RoHS 30 39.1 35.56 34 44.18 40.64 40 51.8 48.26 50 64.5 60.96 YES 60 77.2 73.66 64 82.28 78.74 HIF3HA-50DA-2.54DSA(71) 618-0109-7-71 HIF3HA-50DA-2.54DSA(71) 618-0129-4-71 HIF3HB-50DA-2.54DSA(71) 618-0131-6-71 HIF3HA-60DA-2.54DSA(71) 618-0110-6-71 HIF3HA-60DA-2.54DSA(71) 618-0130-3-71 HIF3HB-60DA-2.54DSA(71) 618-0132-9-71 HIF3HA-64DA-2.54DSA(71) 618-0112-1-71 HIF3HA-64DA-2.54DSA(71) 618-0134-4-71 HIF3HB-64DA-2.54DSA(71) 618-0133-1-71 ■Receptacle Straight Through hole Type Part Number CL No. HIF3H-6SA-2.54DSA(71) Number of Contacts A B Unit:mm RoHS 562-0713-1-71 6 16.24 12.7 HIF3H-10SA-2.54DSA(71) 562-0719-8-71 10 26.4 HIF3H-12SA-2.54DSA(71) 562-0723-5-71 12 31.48 27.94 HIF3H-14SA-2.54DSA(71) 562-0655-7-71 14 36.56 33.02 HIF3H-20SA-2.54DSA(71) 562-0704-0-71 20 51.8 48.26 HIF3H-25SA-2.54DSA(71) 562-0705-3-71 25 64.5 60.96 22.86 YES B55 HIF3H Series●2.54mm Pitch Board to Board Connector Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■Receptacle Right Angle Through hole Type B56 Part Number CL No. Number of Contacts RoHS HIF3H- 4DB-2.54DS(71) 618-0150-0-71 4 HIF3H- 8DB-2.54DS(71) 618-0153-9-71 8 HIF3H-10DB-2.54DS(71) 618-0141-0-71 10 13.7 10.16 HIF3H-12DB-2.54DS(71) 618-0152-6-71 12 16.24 12.70 B 6.0 2.54 HIF3H-18DB-2.54DS(71) 618-0165-8-71 18 23.86 20.32 11.16 7.62 HIF3H-20DB-2.54DS(71) 618-0143-5-71 20 26.4 22.86 HIF3H-24DB-2.54DS(71) 618-0216-7-71 24 31.48 27.94 HIF3H-26DB-2.54DS(71) 618-0144-8-71 26 34.02 30.48 HIF3H-14DB-2.54DS(71) 618-0154-1-71 14 18.78 15.24 HIF3H-30DB-2.54DS(71) 618-0145-0-71 30 39.1 35.56 YES HIF3H-16DB-2.54DS(71) 618-0142-2-71 16 21.32 17.78 HIF3H-34DB-2.54DS(71) 618-0146-3-71 34 44.18 40.64 HIF3H-40DB-2.54DS(71) 618-0147-6-71 40 51.8 48.26 HIF3H-50DB-2.54DS(71) 618-0148-9-71 50 64.5 60.96 HIF3H-60DB-2.54DS(71) 618-0149-1-71 60 77.2 73.66 YES Part Number CL No. Number of Contacts ■Receptacle Right Angle Through hole Type 70 · 130 contacts Part Number CL No. HIF3H-070DB-2.54DS(71) 618-0155-4-71 70 HIF3H-130DB-2.54DS(71) 618-0151-3-71 130 Number of Contacts A B Unit:mm RoHS 94.8 086.36 171 162.56 YES A Unit:mm B RoHS A HIF3H Series●2.54mm Pitch Board to Board Connector Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■Pin Header Through hole Type Part Number CL No. Number of Contacts A B RoHS Part Number CL No. HIF3H-04PA-2.54DS(71) 618-0073-1-71 4 6 HIF3H-30PB-2.54DSA(71) 618-0207-6-71 HIF3H-06PB-2.54DSA(71) 618-0215-4-71 6 8.62 5.08 HIF3H-30P0-2.54W 618-0186-8 HIF3H-10PB-2.54DSA(71) 618-0201-0-71 HIF3H-10P0-2.54W 618-0185-5 10 13.7 10.16 HIF3H-34PB-2.54DSA(71) 618-0208-9-71 HIF3H-34P0-2.54W 618-0181-4 HIF3H-12PB-2.54DSA(71) 618-0202-2-71 12 HIF3H-14PB-2.54DSA(71) 618-0213-9-71 14 16.24 12.7 HIF3H-40PB-2.54DSA(71) 618-0209-1-71 18.78 15.24 HIF3H-40P0-2.54W 618-0182-7 HIF3H-16PB-2.54DSA(71) 618-0203-5-71 HIF3H-16PA-2.54DS(71) 618-0065-3-71 16 21.3 17.78 YES HIF3H-50PB-2.54DSA(71) 618-0210-0-71 HIF3H-60PB-2.54DSA(71) 618-0211-3-71 HIF3H-20PB-2.54DSA(71) 618-0204-8-71 HIF3H-60P0-2.54W 618-0187-0 HIF3H-20P0-2.54W 618-0183-0 HIF3H-24PB-2.54DSA(71) 618-0205-0-71 HIF3H-24PA-2.54DS(71) 618-0067-9-71 HIF3H-26PB-2.54DSA(71) 618-0206-3-71 HIF3H-26P0-2.54W 618-0184-2 2.54 20 26.4 22.86 24 31.46 27.94 26 34.02 30.48 Number of Contacts A Unit:mm B RoHS 30 39.1 35.56 34 44.18 40.64 40 51.8 48.26 50 64.5 60.96 60 77.2 73.66 YES Note 1: The stitch line area is divided in two for 50 and 60 contacts. Note 2: *indicates the number of contacts. Note 3: Wrapping is 6.0. Note 4: Wrapping is 16.0. ■Pin Header Through hole Type 70 · 130 contacts Part Number CL No. Number of Contacts HIF3H-070PB-2.54DSA(71) 618-0214-1-71 70 HIF3H-130PB-2.54DSA(71) 618-0212-6-71 130 A B Unit:mm RoHS 97.8 086.36 174 162.56 YES B57 HIF3H Series●2.54mm Pitch Board to Board Connector BPCB mounting pattern ●Pin Header Straight and Right Angle Type Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Size A List B58 Powered by TCPDF (www.tcpdf.org) ●Receptacle Right Angle Type ●Receptacle Straight Type Number of Contacts A 4 2.54 6 5.08 8 7.62 10 10.16 12 12.7 14 15.24 16 17.78 18 20.32 20 22.86 24 27.94 26 30.48 30 35.56 34 40.64 40 48.26 50 60.96 60 73.66 64 78.74 70 86.36 130 162.56
HIF3H-50DA-2.5DSA(71) 价格&库存
很抱歉,暂时无法提供与“HIF3H-50DA-2.5DSA(71)”相匹配的价格&库存,您可以联系我们找货
    • 1+52.46640
    • 10+51.37560
    • 30+50.65200
    • 100+49.92840
