DSS12 THRU DSS110
SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER
Reverse Voltage - 20 to 100 Volts
Forward Current - 1.0 Ampere
SOD-123FL
FEATURES
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
Metal silicon junction,majority carrier conduction
Low power loss,high efficiency
High forward surge current capability
High temperature soldering guaranteed:
260 C/10 seconds,0.375”(9.5mm) lead length,
5 lbs. (2.3kg) tension
1.8± 0.2
1.0±0.2
Cathode Band
Top View
1.3± 0.15
0.10-0.30
2.8±0.2
0.6±0.25
MECHANICAL DATA
Case: JEDEC SOD-123FL molded plastic body
Terminals: Solderable per MIL-STD-750,
Method 2026
Polarity: Color band denotes cathode end
Mounting Position: Any
Weight:0.0007 ounce, 0.02 grams
3.7±0.2
Dimensions in millimeters
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
SYMBOLS DSS12 DSS13 DSS14 DSS15 DSS16 DSS17 DSS18 DSS19 DSS110
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
Peak forward surge current
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
Maximum instantaneous forward voltage at 1.0A
Maximum DC reverse current
TA=25 C
at rated DC blocking voltage
TA=100 C
Typical junction capacitance (NOTE 1)
D12
D13
D14
D15
D16
D17
D18
D19
D110
21
30
40
28
40
50
35
50
60
42
60
70
49
70
80
56
80
90
63
90
100
70
100
UNITS
I(AV)
1.0
VOLTS
VOLTS
VOLTS
Amp
IFSM
25.0
Amps
VRRM
VRMS
VDC
VF
CJ
RθJA
Operating junction temperature range
Storage temperature range
TJ
TSTG
0.85
Volts
0.5
IR
Typical thermal resistance (NOTE 2)
0.70
0.55
mA
5.0
10.0
80
110
pF
K/W
180
C
-55 to +150
-55 to +125
-55 to +150
C
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.PCB mounted on 0.2*0.2" (5.0*5.0mm) coppeer pad area.
STAR SEA
FIG. 1- FORWARD CURRENT DERATING CURVE
1
0.8
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
0.6
0.4
DSS12-DSS16
DSS17-DSS110
0.2
50
75
100
125
150
PEAK FORWARD SURGE CURRENT,
AMPERES
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
RATINGS AND CHARACTERISTIC CURVES DSS12 THRU DSS110
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
30
8.3ms SINGLE HALF SINE-WAVE
(JEDEC Method)
25
10
5.0
175
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
1
TJ=25 C
PULSE WIDTH=300 µs
1%DUTY CYCLE
0.1
DSS12-DSS14
DSS15-DSS16
DSS17-DSS110
0.01
0.2
0.4
0.6
0.8
1.0
10
100
NUMBER OF CYCLES AT 60 Hz
1.1
INSTANTANEOUS REVERSE CURRENT,
MILLIAMPERES
CURRENT,AMPERES
LEAD TEMPERATURE, C
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
100
10
TJ=100 C
1
TJ=75 C
0.1
0.001
INSTANTANEOUS FORWARD VOLTAGE,
VOLTS
TJ=25 C
0.01
60
80
100
PERCENT OF PEAK REVERSE VOLTAGE,%
JUNCTION CAPACITANCE, pF
FIG. 5-TYPICAL JUNCTION CAPACITANCE
2000
1000
DSS12-DSS14
DSS15-DSS110
100
TJ=25 C
10
0.1
1.0
10
100
REVERSE VOLTAGE,VOLTS
STAR SEA
很抱歉,暂时无法提供与“DSS14”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.13274
- 500+0.10476
- 3000+0.08921
- 6000+0.07992
- 国内价格
- 1+0.45320
- 200+0.15180
- 1500+0.09460
- 3000+0.07513
