1N4001G
THRU
1N4007G
Technical Data
Data Sheet N0544, Rev. A
1N4001G THRU 1N4007G
1.0A GLASS PASSIVATED RECTIFIER
Features
Diffused Junction
Low Forward Voltage Drop
High Current Capability
High Reliability
High Surge Current Capability
This is a Pb − Free Device
“-HF” suffix is for Halogen Free Device
All SMC parts are traceable to the wafer lot
Additional testing can be offered upon request
DO-41
Circuit Diagram
Mechanical Data
Case: molded plastic
Terminals: Plated leads, solderable per MIL-STD202, Method 208
Polarity: Cathode band
Mounting Position: Any
Weight:0.34 grams(approx)
Maximum Ratings and Electrical Characteristics @TA=25°C unless otherwise specified
Single Phase, half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%.
Type Number
Symbol
Peak Repetitive Reverse Voltage
Working Peak Reverse Voltage
DC Blocking Voltage
VRRM
VRWM
VR
RMS Reverse Voltage
VRMS
1N
1N
1N
1N
1N
1N
1N
Units
4001G 4002G 4003G 4004G 4005G 4006G 4007G
50
5
100
1
200
2
400
4
600
6
800
8
1000
1
V
35
3
70
7
140
1
280
2
420
4
560
5
700
1
V
Average forward rectified output current
@TA = 75°C
IO
1.0
A
Non-Repetitive Peak Forward Surge Current
8.3ms Single half sine-wave superimposed on
rated load (JEDEC Method)
IFSM
30
A
Forward Voltage
@IF =1.0A
VFM
1.0
V
Peak Reverse Current
At Rated DC Blocking Voltage
@TA = 25°C
@TA = 100°C
IRM
5.0
50
µA
Typical Junction Capacitance (Note 2)
CJ
8
pF
Typical Thermal Resistance Junction to
Ambient (Note 1)
RθJA
100
°C/W
Operating Junction Temperature Range
TJ
-65 to +175
°C
TSTG
-65 to +175
°C
Storage Temperature Range
Note: 1. Leads maintained at ambient temperature at a distance of 9.5mm from the case
2. Measured at 1MHz and applied reverse voltage of 4.0V D.C.
China - Germany - Korea - Singapore - United States
http://www.smc-diodes.com - sales@ smc-diodes.com
1N4001G
THRU
1N4007G
Technical Data
Ratings and Characteristics Curves
1N4001G
THRU
1N4007G
Technical Data
Mechanical Dimensions DO-41
SYMBOL
Ordering Information
Device
1N4001G-1N4007G
1N4001GTA1N4007GTA
Package
DO-41
(Pb-Free)
DO-41
(Pb-Free)
Millimeters
Inches
Min.
Max.
Min.
Max.
A
25.4
1.000
B
4.06
5.21
0.160
0.205
C
0.71
0.864
0.028
0.034
D
2.00
2.72
0.079
0.107
Marking Diagram
Shipping
Where XXXXX is YYWWL
1N4001G
SSG
HF
YY
WW
L
5000pcs / Tape
5000pcs / Tape
1N4001G
For information on tape and reel specifications, including part
orientation and tape sizes, please refer to our tape and reel
packaging specification.
= Type Number
= SSG
= Halogen Free
= Year
= Week
= Lot Number
Cautions:Molding resin
Epoxy resin UL:94V-0
1N4001G-HF
Carrier Tape Specification DO-41
SYMBOL
Millimeters
Min.
Max.
A
4.50
5.50
B
50.9
53.9
Z
1.20
T
5.60
6.40
E
0.80
IL1-L2I
1.0
1N4001G
THRU
1N4007G
Technical Data
DISCLAIMER:
1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product
characteristics. Before ordering, purchasers are advised to contact the SMC Diode Solutions sales department for the latest version of
the datasheet(s).
2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment,
medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by
means of users’ fail-safe precautions or other arrangement .
3- In no event shall SMC Diode Solutions be liable for any damages that may result from an accident or any other cause during
operation of the user’s units according to the datasheet(s). SMC Diode Solution assumes no responsibility for any intellectual property
claims or any other problems that may result from applications of information, products or circuits described in the datasheets.
4- In no event shall SMC Diode Solutions be liable for any failure in a semiconductor device or any secondary damage resulting from use
at a value exceeding the absolute maximum rating.
5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC Diode Solutions.
6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC
Diode Solutions.
7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will
hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third
party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and
regulations..
很抱歉,暂时无法提供与“1N4007GTA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.72424
- 5+1.33013
- 25+0.95244
- 100+0.68970
- 420+0.26931
- 1155+0.25453
- 50000+0.25043
- 100000+0.24550
