DATA SHEET
GENERAL PURPOSE CHIP RESISTORS
RC_L series
±0.1%, ±0.5%, ±1%, ±5%
Sizes 0075/0100/0201/0402/0603/0805/
1206/1210/1218/2010/2512
Product specification – August 02, 2022 V.12
RoHS compliant & Halogen free
Chip Resistor Surface Mount
SCOPE
This specification describes RC
series chip resistors with lead
free terminations made by thick
film process.
RC_L
SERIES
2
10
0075 to 2512
ORDERING INFORMATION - GLOBAL PART NUMBER
Global part numbers are identified by the series, size, tolerance, packing
type, temperature coefficient, taping reel and resistance value.
GLOBAL PART NUMBER
RC XXXX X X X XX XXXX L
(1)
APPLICATIONS
All general purpose application
(2) (3) (4)
(5)
(6)
(7)
(1) SIZE
0075/0100/0201/0402/0603/0805/1206/1210/1218/2010/2512
FEATURES
Halogen Free Epoxy
RoHS compliant
Products with lead free
terminations meet RoHS
requirements
Pb-glass contained in
electrodes, resistors element
and glass are exempted by
RoHS
Reducing environmentally
hazardous wastes
High component and equipment
reliability
Saving of PCB space
None forbidden-materials used in
products/production
(2) TOLERANCE
B = ± 0.1%
D = ± 0.5%
F = ± 1.0%
J = ± 5.0% (for jumper ordering, use code of J)
(3) PACKAGING TYPE
R = Paper taping reel
K = Embossed taping reel
S = ESD safe reel (0075/0100 only)
(4) TEMPERATURE COEFFICIENT OF RESISTANCE
- = Based on spec.
(5) TAPING REEL & POWER
07 = 7 inch dia. Reel & Standard power
10 = 10 inch dia. Reel
13 = 13 inch dia. Reel
7W = 7 inch dia. Reel & 2 x standard power
7N = 7 inch dia. Reel, ESD safe reel (0075/0100 only)
3W = 13 inch dia. Reel & 2 x standard power
(6) RESISTANCE VALUE
There are 2~4 digits indicated the resistance value.
Letter R/K/M is decimal point
Example:
97R6 = 97.6Ω
9K76 = 9760Ω
1M = 1,000,000Ω
(7) DEFAULT CODE
Letter L is the system default code for ordering only.(Note)
ORDERING EXAMPLE
The ordering code for a RC0402 0.0625W chip resistor value 100KΩwith
±5% tolerance, supplied in 7-inch tape reel of 10,000 units per reel is:
RC0402JR-07100KL.
NOTE
1. All our RSMD products meet RoHS compliant and Halogen Free. "LFP" of the internal 2D
reel label mentions "Lead Free Process".
2. On customized label, "LFP" or specific symbol can be printed.
www.yageo.com
Aug. 02, 2022 V.12
RC_L
SERIES
3
10
0075 to 2512
MARKING
RC0075 / RC0100 / RC0201 / RC0402
No Marking
ynsc007
Fig. 1
RC0603
1%, 0.5%,E24 exception values 10/11/13/15/20/75 of E24 series
YNSC037
Fig. 2 240 = 24 × 100 = 24
88
YNSC038
1%, 0.5%, E96 refer to EIA-96 marking method, including values
Fig. 3 88A = 806 × 100 = 806 Ω
03
YNSC001
5%, E24 series : 3 digits
First two digits for significant figure and 3rd digit for number of zeros
Fig. 4 Value = 10 KΩ
RC0805 / RC1206 / RC1210 / RC2010 / RC2512
00
YNSC004
1%, 0.5%, E24/E96 series : 4 digits
First three digits for significant figure and 4th digit for number of zeros
Fig. 5 Value = 10 KΩ
03
YNSC001
Fig. 6 Value = 10 KΩ
RC1218
YNSC099
E-24 series: 3 digits, ± 5%
Fig. 7 Value = 10 KΩ
00
YNSC103
Both E-24 and E-96 series: 4 digits, ± 1% & ± 0.5%
Fig. 8 Value = 10 KΩ
For further marking information, please see special data sheet "Chip resistors marking".
www.yageo.com
Aug. 02, 2022 V.12
RC_L
4
10
0075 to 2512
SERIES
Outlines
CONSTRUCTION
The resistor is constructed on top of a high-grade
ceramic body. Internal metal electrodes are added
on each end to make the contacts to the thick
film resistive element. The composition of the
resistive element is a noble metal imbedded into a
glass and covered by a second glass to prevent
environmental influences. The resistor is laser
trimmed to the rated resistance value. The
resistor is covered with a protective epoxy
coat, finally the two external terminations (matte
tin on Ni-barrier) are added, as shown in Fig.9.
For dimensions, please refer to Table 1
marking layer
overcoat
primary glass layer
resistive layer
(Jumper chip is a conductor)
inner electrode
termination(Ni/matte tin)
inner electrode
H
ceramic substrate
I2
overcoat
I1
W
YNSC086
L
9
Fig. 9 Chip resistor outlines
DIMENSION
Table 1
TYPE
RC0075
L (mm)
W (mm)
H (mm)
I1 (mm)
I2 (mm)
0.30±0.01
0.15±0.01
0.13±0.01
0.08±0.03
0.08±0.03
RC0100
0.40±0.02
0.20±0.02
0.13±0.02
0.10±0.03
0.10±0.03
RC0201
0.60±0.03
0.30±0.03
0.23±0.03
0.10±0.05
0.15±0.05
RC0402
1.00±0.05
0.50±0.05
0.35±0.05
0.20±0.10
0.25±0.10
RC0603
1.60±0.10
0.80±0.10
0.45±0.10
0.25±0.15
0.25±0.15
RC0805
2.00±0.10
1.25±0.10
0.50±0.10
0.35±0.20
0.35±0.20
RC1206
3.10±0.10
1.60±0.10
0.55±0.10
0.45±0.20
0.45±0.20
RC1210
3.10±0.10
2.60±0.15
0.55±0.10
0.45±0.15
0.50±0.20
RC1218
3.10±0.10
4.60±0.10
0.55±0.10
0.45±0.20
0.40±0.20
RC2010
5.00±0.10
2.50±0.15
0.55±0.10
0.60±0.20
0.55±0.20
RC2512
6.35±0.10
3.10±0.15
0.55±0.10
0.60±0.20
0.60±0.20
ELECTRICAL CHARACTERISTICS
Table 2
CHARACTERISTICS
POWER
OPERATING
TEMPERATURE
RANGE
-55℃ to 125℃
RC0075
1/50 outlines
W
Fig.
4 Chip resistor
MAXIMUM
WORKING
VOLTAGE
10V
MAXIMUM
DIELECTRIC
OVERLOAD WITHSTANDING
VOLTAGE
VOLTAGE
25V
25V
RESISTANCE
RANGE
TEMPERATURE
COEFFICIENT
JUMPER
CRITERIA
5% (E24)
10Ω≦R
很抱歉,暂时无法提供与“RC0603FR-1075RL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+0.885811+0.11513
- 10+0.2209210+0.02872
- 25+0.1660725+0.02159
- 50+0.1323450+0.01720
- 100+0.10769100+0.01400
- 250+0.08295250+0.01078
- 500+0.06901500+0.00897
- 1000+0.058341000+0.00759
- 5000+0.041395000+0.00538
- 国内价格 香港价格
- 10000+0.0365410000+0.00475
- 20000+0.0326720000+0.00425
- 30000+0.0307930000+0.00401
- 50000+0.0287750000+0.00374
- 70000+0.0276070000+0.00359
- 100000+0.02651100000+0.00345
