Application Note: SY6283/SY6283A
Low Loss Power Distribution Load Switch
3A continuous, 4A peak current
Features
General Description
SY6283 and SY6283A are ultra-low RDS(ON) switch with
current limiting function to protect the power source from
over current and short circuit conditions.
Ordering Information
SY6283 □(□□)□
Temperature Code
Package Code
Optional Spec Code
Ordering Number
SY6283DRC
SY6283ADRC
Package type
DFN1.2×1.6-4
DFN1.2×1.6-4
Note
3A/Active High
3A/Active High
Distribution voltages: 2.5V to 5.5V
Over temperature shutdown and automatic retry
Reverse blocking (no body diode)
At shutdown, OUT can be forced higher than IN
Built-in softstart
Output discharge function
SY6283: No output discharge function
SY6283A: Auto output discharge function
RoHS Compliant and Halogen Free
Compact packages minimize board space:
DFN1.2x1.6-4
Typical Application Circuit
Figure 1. Schematic Diagram
AN_SY6283/A Rev. 0.9A
Figure 2. Typical Perform Characteristic
Silergy Corp. Confidential-prepared for Customer Use Only
1
AN_SY6283/SY6283A
Pin Configurations (Top View)
DFN1.2×1.6-4
Top mark: LPxyz for SY6283(Device code: LP, x=year code, y=week code, z= lot number code)
MWxyz for SY6283A(Device code: MW, x=year code, y=week code, z= lot number code)
Functional Pin Description
Pin Name
IN
Pin number
3
GND
OUT
EN
1
4
2
Pin Description
Input pin. Decouple this pin to GND with 4.7uF input
Capacitor.
Ground pin.
Output pin.
ON/OFF control. Do not leave it float.
Absolute Maximum Ratings (Note 1)
All pins-------------------------- ------------------------------------------------------------------------------------------------ 6V
Power Dissipation, PD @ TA = 25°C DFN1.2×1.6-4----------------------------------------------------------------------0.5W
Package Thermal Resistance (Note 2)
θ JA --------------------------------------------------------------------------------------------------------------200°C/W
θ JC ---------------------------------------------------------------------------------------------------------------70°C/W
Junction Temperature Range --------------------------------------------------------------------------------- -40°C to 125°C
Lead Temperature (Soldering, 10 sec.) ----------------------------------------------------------------------------------260°C
Storage Temperature Range ----------------------------------------------------------------------------------- -65°C to 150°C
Recommended Operating Conditions (Note 3)
IN---------------------------------------------------------------------------------------------------------------------- 2.5V to 5.5V
EN-------------------------------------------------------------------------------------------------------------- -0.3V to VIN+0.3V
All other pins --------------------------------------------------------------------------------------------------------------- 0-5.5V
Junction Temperature Range ---------------------------------------------------------------------------------- -40°C to 125°C
Ambient Temperature Range ----------------------------------------------------------------------------------- -40°C to 85°C
2
AN_SY6283/SY6283A
Electrical Characteristics
(VIN = 5V, CL=1uF, per channel, TA = 25°C unless otherwise specified)
Parameter
Input Voltage Range
Shutdown Input Current
Quiescent Supply Current
FET RON
Current Limit
EN Rising Threshold
EN Falling Threshold
IN UVLO Threshold
IN UVLO Hysteresis
Rising Time
Thermal
Shutdown
Temperature
Thermal Shutdown Hysteresis
Output Discharge Resistor
Symbol
VIN
ISHDN
IQ
RDS(ON)
ILIM
VIH
VIL
VIN,UVLO
VIN,HYS
tRising
Test Conditions
Output grounded, switch off
Open load, switch on
3.0
2
Typ
0.1
0.75
Unit
V
µA
µA
mΩ
A
V
V
V
V
ms
150
°C
°C
Ω
0.1
32
60
3.85
Max
5.5
1
4.7
0.8
2.4
RL=5 Ω, CL=1uF
TSD
RDSC
Min
2.5
SY6283A
Note 1: Stresses beyond “Absolute Maximum Ratings” may cause permanent damage to the device. These are for
stress ratings. Functional operation of the device at these or any other conditions beyond those indicated in the
operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for
extended periods may affect device reliability.
Note 2: θ JA is measured in the natural convection at TA = 25°C on a low effective single layer thermal conductivity
test board of JEDEC 51-3 thermal measurement standard.
Note 3: The device is not guaranteed to function outside its operating conditions
3
AN_SY6283/SY6283A
Typical Operating Characteristics
4
Fall Time (us)
AN_SY6283/SY6283A
5
AN_SY6283/SY6283A
Block diagram
(SY6283)
(SY6283A)
6
AN_SY6283/SY6283A
Operation
SY6283 is a current limited P-channel MOSFET
power switch with over current and over temperature
protections. There is no body diode across the drain
and the source of the MOSFET. It prevents the current
flow from the output to the input after the chip is
disabled.
Over-current protection
When the over-current condition is detected, the
switch is regulated to achieve constant output current.
If the over current condition lasts for a long time, and
results in a junction temperature over 150°C, the switch
will be shutdown. Once the junction temperature drops
to 130°C, the part will restart.
Supply Filter Capacitor
In order to prevent the input voltage from dropping
during hot-plug condition, a 10µF ceramic capacitor
from VIN to GND is strongly recommended. However,
higher capacitance could help to reduce the voltage
drop. Furthermore, an output short will cause ringing
on the input without the input capacitor. It could
destroy the internal circuitry when the input transient
voltage exceeds the absolute maximum supply voltage
even for a short duration.
PCB Layout Guide
For best performance of the SY6283 , the following
guidelines must be strictly followed:
GND
GND
Keep all VBUS traces as short and wide as possible
and use at least 2 ounce copper for all VBUS traces.
Place a ground plane under all circuitry to lower
both resistance and inductance and improve DC
and transient performance.
A low-ESR 150uF aluminum electrolytic or
tantalum capacitor between VOUT and GND is
Locate the output capacitor as close to the
connectors as possible to lower impedance(mainly
inductance) between the port and the capacitor
and improve transient performance.
Input and output capacitors should be placed
closed to the IC and connected to ground plane to
reduce noise coupling.
CIN
VIN
COUT
VOUT
Locate the ceramic bypass capacitors as close as
possible to the VIN pins and VOUT pins of
SY6283.
7
AN_SY6283/SY6283A
PCB Layout Guide
PCB Top Over Layer
PCB Bottom Layer
PCB Top Layer
8
AN_SY6283/SY6283A
DFN1.2x1.6-4 Package Outline
Top View
Bottom View
Side View
Notes:
All dimension in millimeter and exclude mold flash & metal burr.
9
AN_SY6283/SY6283A
Taping & Reel Specification
1.
DFN1.2x1.6 taping orientation
Feeding direction
2. Carrier Tape & Reel specification for packages
Reel
Size
Package types
Tape width
(mm)
Pocket
pitch(mm)
Reel size
(Inch)
Trailer
length(mm)
Leader length
(mm)
Qty per
reel
8
4
7"
400
160
3000
DFN1.2x1.6
3. Others: NA
10
很抱歉,暂时无法提供与“SY6283ADRC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+2.72156
- 50+2.12513
- 150+1.86955
- 500+1.55056
