2F-ZZ-0002
2F-ZZ-0002
    UDE
    2F-ZZ-0002
2F-ZZ-0002 数据手册
To: Customer P/N: UDE P/N: 2F-ZZ-0002 Description: RJ45 1X4 Tab Up Through Hole 10/100/1000 Base-T Contact Area : Gold Flash LED: L-Green/Orange;R-Green Spec No. 2F-16003-00 Approved Checked Update Date 2016/10/11 Revision A Prepared 2F-ZZ-0002 Spec No. : 2F-16003-00 1. MECHANICAL DIMENSION 1.1 Product Dimension 2016/10/11 Unit:mm General Tolerance : -1- X.X : ± 0.38 X.XX : ± 0.20 www.ude-corp.com 2F-ZZ-0002 Spec No. : 2F-16003-00 1.2 Recommended PCB Layout Component Side of Board All dimension tolerances are ±0.05mm unless otherwise specified Table1 Layout Trace component Grounding Test Point Via Hole PTH NPTH Component side X X O X X X O Inner layer O NA O NA O X O Bottom side O O O O O X O Layer X--Forbid; O--OK; NA--Not Applicable. 2016/10/11 -2- www.ude-corp.com 2F-ZZ-0002 Spec No. : 2F-16003-00 1.3 Recommended Panel Cutout 1.4 Packing Information 20 pcs finished goods per tray 6 trays(120 pcs finished goods) per inner box 4 Inner boxes(480 pcs finished goods) per master carton 2016/10/11 -3- www.ude-corp.com 2F-ZZ-0002 Spec No. : 2F-16003-00 1.5 Standard RJ45 Plug Specification - All dimensions follow : FCC subpart F, 68,500, Figure (C)(2)(i) & (C)(2)(ii) & (C)(3)(i) IEC 60603-7 - All plugs must be meeting the requirements of plug Go & No-Go gauge. Gauge follow : FCC subpart F, 68,500, Figure (C)(4)(i) & (C)(5)(i) - There must be no damage to Housing and Locking Latch. - There must be no nicks and cuts in cable. - Durability : 750 cycles generally 2016/10/11 -4- www.ude-corp.com 2F-ZZ-0002 Spec No. : 2F-16003-00 2. REQUIREMENTS 2.1 Design and Construction Product shall be of design, construction and physical dimensions specified on applicable. 2.2 Material 2.2.1 Terminal Parts (Underplating : 50μ" min. Nickel overall) 2.2.1.1 RJ Terminal : Phosphor Bronze, Thickness=0.30mm Finish : Contact Area : Gold Flash 2.2.1.2 Input Terminal : Brass, Thickness=0.35mm Finish : 100μ" min. Matte. Tin 2.2.1.3 LED Terminal : Brass, Thickness=0.35mm Finish : 100μ" min. Matte Tin 2.2.1.4 Case Terminal : Brass, Thickness=0.30mm Finish : 100μ" min. Tin 2.2.1.5 Capacitance Terminal : Phosphor Bronze, Thickness=0.35mm Finish : 100μ" min. Tin 2.2.2 Plastic Parts 2.2.2.1 Housing : PA6T, Black 2.2.2.2 Case : PA6T, Black 2.2.2.3 RJ Insert Molding : PBT, Black 2.2.3 Shield Parts 2.2.3.1 Shield : Stainless Steel, Thickness=0.20mm, Pre-soldering 2016/10/11 -5- www.ude-corp.com 2F-ZZ-0002 Spec No. : 2F-16003-00 2.3 Operating and Storage Temperature Operating Temperature : -40°C to +85°C Storage Temperature : -40°C to +85°C 2.4 RJ45 specifications Insulation Resistance :500MΩ min. Insertion force with the latch depressed :22N max Removal force with the latch depressed :44N max Locking Force of Plug Latch : 50N min. @ 60+/-5 sec Durability : 750 cycles 2.5 Performance and Test Description Product is designed to meet electrical, mechanical and environmental performance requirements specified in below table. All tests are performed at ambient environmental conditions per MIL-STD-1344A and EIA-364 unless otherwise specified. 2.6 Packaging and Packing All parts shall be packaged and packed to protect against physical damage、corrosion and deterioration during shipment and storage. 2016/10/11 -6- www.ude-corp.com 2F-ZZ-0002 Spec No. : 2F-16003-00 3. ELECTRICAL CHARACTERISTICS @ 25℃ 3.1 Schematic PHY Side (INPUT) Cable Side (RJ45 OUTPUT) CT R5 1:1 TD1+ R10 C1 TX1+ 75Ω TD1- R9 C2 TX11:1 TD2+ R8 C3 TX2+ 75Ω C6 TX2- TD2- R7 1:1 TD3+ R4 C4 TX3+ 75Ω TD3- R3 C5 TX31:1 TD4+ R2 C7 TX4+ 75Ω C8 TX4- TD4- R1 2KV,1000pF CT R6 L4 L2 Green Orange Green L3 L1 Emitting Color Green Orange 2016/10/11 λp (nm) 570 605 Vf @If=20mA 1.7 ~2.6 V 1.7 ~2.6 V -7- Ir @Vr=5V 10μA max. 10μA max. www.ude-corp.com 2F-ZZ-0002 Spec No. : 2F-16003-00 3.2 Transmitter filter & Receiver filter Type : Balance low pass 100Ω impedance Insertion loss : 1~100 MHz -1.0dB max. Return loss : 1~30 MHz -18dB min. load 100Ω 30~60MHz -16dB min. load 100Ω 60~80MHz -12dB min. load 100Ω 80~100MHz -10dB min. load 100Ω 3.3 Common Mode Rejection @ 1~100 MHz -30dB min. 3.4 Cross Talk @ 1~100 MHz 3.5 Inductance -30dB min. @ 100KHz, 0.1V, 8mA DC BIAS Input (R10-R9), Input(R8-R7), Input (R4-R3), Input(R2-R1): 350 μH min. 3.6 HiPot Test Input(R10-R9) To Output(C1-C2) : 1500Vac 60s or 2250Vdc 60s Input(R8-R7) To Output(C3-C6) : 1500Vac 60s or 2250Vdc 60s Input(R4-R3) To Output(C4-C5) : 1500Vac 60s or 2250Vdc 60s Input(R2-R1) To Output(C7-C8) : 1500Vac 60s or 2250Vdc 60s 2016/10/11 -8- www.ude-corp.com 2F-ZZ-0002 Spec No. : 2F-16003-00 4. DIPPING TEMPERATURE PROFILE 2016/10/11 -9- www.ude-corp.com 2F-ZZ-0002 Spec No. : 2F-16003-00 5. Revision History Issue Date Revision 2016/10/11 2016/10/11 A Comments Initial Release . Operator Bluce - 10 - www.ude-corp.com
2F-ZZ-0002 价格&库存
很抱歉,暂时无法提供与“2F-ZZ-0002”相匹配的价格&库存,您可以联系我们找货
