1.15.114.966/0000
1.15.114.966/0000
    RAFI
1.15.114.966/0000 数据手册
21.06.2017 LUMOTAST FK - Pushbutton with flush lens, rectangular collar, housing 1.15.114.966/0000 A notch on the lamp socket identifies the cathode side. Please include the desired lens in your order. General information Actuator Form of collar flat lens rectangular Dimensions Length of collar Width of collar Overall height Mounting depth with connector Mounting depth with plug-in socket Mounting hole 24 mm 18 mm 6.6 mm 30.7 mm 33.4 mm 16.2 mm Mechanical design Mounting Terminals Contact system Contact function Contact arrangement Contact materials Illumination Lamp socket click quick connection pin connector 4-pole / plug-in socket snap-action contact momentary 1 NO Au yes Bi-Pin T1 / T1¼ Mechanical characteristics Operating force max. Operating travel Switching travel Robustness max. 6N 3 mm 1.9 mm 100 N Electrical characteristics Rated voltage AC/DC max. Rated voltage AC/DC min. Rated current AC/DC max. Rated current AC/DC min. Contact resistance acc. to life max. Contact resistance when new max. Bouncing time max. 35 V 0.02 V 100 mA 0.01 mA 300 mΩ 100 mΩ 5 ms Technical data are approximate and intended solely for general orientation in the selection of a product. Subject to modifications and errors. Images and other graphics may only be similar. For more information, refer to www.rafi.de chapter Imprint / Data Protection. 21.06.2017 Other specifications Operating life (operations) Degree of protection from front side Operation temperature min. Ambient temp. operating max. without lamp / LED Ambient temp. operating max. with lamp /LED Storage temperature min. Storage temperature max. Environmental restistance Weight ROHS compliant REACH compliant 1,000,000 cycle IP65 (DIN EN 60529) -25 °C +70 °C +55 °C -40 °C +80 °C acc. to IEC 60068-2-14, -30, -33 and -78 6g yes yes Panel cut-out with plug-in socket for PCB Technical data are approximate and intended solely for general orientation in the selection of a product. Subject to modifications and errors. Images and other graphics may only be similar. For more information, refer to www.rafi.de chapter Imprint / Data Protection. 21.06.2017 with socket connector Technical data are approximate and intended solely for general orientation in the selection of a product. Subject to modifications and errors. Images and other graphics may only be similar. For more information, refer to www.rafi.de chapter Imprint / Data Protection.
1.15.114.966/0000 价格&库存
很抱歉,暂时无法提供与“1.15.114.966/0000”相匹配的价格&库存,您可以联系我们找货
