SCT52240STDR
SCT52240STDR
    SCT(芯洲科技)
    SOP8
    SCT52240STDR
SCT52240STDR 数据手册
SILICON CONTENT TECHNOLOGY SCT52240 Rev 1.0 - 2018 Up to 24V Supply, 4-A Dual Channel High Speed Low Side Driver FEATURES              DESCRIPTION Wide Supply Voltage Range: 4.5V - 24V 4A Peak Source Current and 4A Peak Sink Current Stackable Output for Higher Driving Capability Negative Input Voltage Capability: Down to -5V TTL Compatible Input Logic Threshold Propagation Delay: 13ns Typical Rising and Falling Times: 8ns Typical Delay Matching: 1ns Low Quiescent Current: 55uA Output Low When Input Floating Independent Enable Logic for Each Channel Thermal Shutdown Protection: 170°C Available in SOP-8 Package APPLICATIONS      IGBT/MOSFET Gate Driver Variable Frequency-Drive (VFD) Switching Power Supply Motor Control Solar Power Inverter The SCT52240 is a wide supply, dual channel, high speed, low side gate drivers for both power MOSFET and IGBT. Each channel can source and sink 4A peak current along with rail-to-rail output capability. The 24V power supply rail enhances the driver output ringing endurance during the power device transition. The minimum 13ns input to output propagation delay enables the SCT52240 suitable for high frequency power converter application. The SCT52240 features wide input hysteresis that is compatible for TTL low voltage logic. The SCT52240 has the capability to handle negative input down to -5V, which increases the input noise immunity. The SCT52240 has very low quiescent current that reduces the stand-by loss in the power converter. The SCT52240 each channel driver adopts non-overlap driver design to avoid the shoot-through of output stage. The two channels INA and INB have critical propagation delay matching and artificial dead time implemented in output stage, which enable stackable output available when the system needs higher driving capability. The SCT52240 features 170°C thermal shut down. The SCT52240 is available in SOP-8 package TYPICAL APPLICATION SCT52240 Typical Application Application Waveform RGA ENA ENB INA OUTA GND INB VDD VDD RGB OUTB C1 For more information www.silicontent.com © 2018 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT52240 1 SCT52240 REVISION HISTORY NOTE: Page numbers for previous revisions may differ from page numbers in the current version. Revision 1.0 Released to Production. DEVICE ORDER INFORMATION PART NUMBER PACKAGE MARKING PACKAGE DISCRIPTION SCT52240STD 2240 SOP-8 1)For Tape & Reel, Add Suffix R (e.g. SCT52240STDR). ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION Over operating free-air temperature unless otherwise noted(1) Top View: SOP-8pin Plastic DESCRIPTION MIN MAX UNIT ENA, ENB -0.3 26 V ENA 1 8 ENB INA, INB -5 26 V INA 2 7 OUTA OUTA, OUTB -0.3 26 V VDD -0.3 26 V GND 3 6 VDD Operating junction temperature TJ (2) -40 150 °C INB 4 5 OUTB Storage temperature TSTG -65 150 °C (1) (2) Stresses beyond those listed under Absolut Maximum Rating may cause device permanent damage. The device is not guaranteed to function outside of its Recommended Operation Conditions. The IC includes over temperature protection to protect the device during overload conditions. Junction temperature will exceed 150°C when over temperature protection is active. Continuous operation above the specified maximum operating junction temperature will reduce lifetime PIN FUNCTIONS NAME 2 NO. PIN FUNCTION ENA 1 Channel A enable logic input, TTL compatible. Floating logic high. INA 2 Channel A logic input, TTL compatible. Floating logic low. GND 3 Power ground. Must be soldered directly to ground plane for thermal performance improvement and electrical contact. INB 4 Channel B logic input, TTL compatible. Floating logic low. OUTB 5 Channel B gate driver output VDD 6 Power Supply, must be locally bypassed by the ceramic cap. OUTA 7 Channel A gate driver output ENB 8 Channel B enable logic input, TTL compatible. Floating logic high. For more information www.silicontent.com © 2018 Silicon Content Technology Co., Ltd. Product Folder Links: SCT52240 All Rights Reserved SCT52240 RECOMMENDED OPERATING CONDITIONS Over operating free-air temperature range unless otherwise noted PARAMETER VDD VINA,INB TJ DEFINITION Supply voltage range Input voltage range Operating junction temperature MIN MAX UNIT 4.5 -5 -40 24 24 150 V °C MIN MAX UNIT -2 +2 kV -0.5 +0.5 kV ESD RATINGS PARAMETER VESD DEFINITION Human Body Model (HBM), per ANSI-JEDEC-JS-0012014 specification, all pins (1) Charged Device Model (CDM), per ANSI-JEDEC-JS-0022014specification, all pins (1) (1) HBM and CDM stressing are done in accordance with the ANSI/ESDA/JEDEC JS-001-2014 specification THERMAL INFORMATION PARAMETER RθJA RθJC THERMAL METRIC SOP-8L Junction to ambient thermal resistance (1) Junction to case thermal resistance (1) 90 39 UNIT °C/W (1) SCT provides RθJA and RθJC numbers only as reference to estimate junction temperatures of the devices. RθJA and RθJC are not a characteristic of package itself, but of many other system level characteristics such as the design and layout of the printed circuit board (PCB) on which the SCT52240 is mounted, and external environmental factors. The PCB board is a heat sink that is soldered to the leads and thermal pad of the SCT52240. Changing the design or configuration of the PCB board changes the efficiency of the heat sink and therefore the actual RθJA and RθJC. For more information www.silicontent.com © 2018 Silicon Content Technology Co., Ltd. Product Folder Links: SCT52240 All Rights Reserved 3 SCT52240 ELECTRICAL CHARACTERISTICS VDD=12V, TJ=-40°C~150°C, typical values are tested under 25°C. SYMBOL PARAMETER TEST CONDITION TYP MAX 24 V 4.5 EN=VDD=3.5V, INA=INB=GND 4.2 300 55 V mV uA EN=VDD=12V, INA=INB=GND 120 Power Supply and Output VDD Operating supply voltage VDD_UVLO Input UVLO Hysteresis IQ Supply current INPUTS VINA,INB_H Input logic high threshold VINA,INB_L Input logic low threshold VIN_Hys MIN 4.5 VDD rising 2.1 uA 2.4 V 1 V Hysteresis 1.1 V VENA,ENB_H Enable logic high threshold 2.1 VENA,ENB_L Enable logic low threshold VEN_Hys Hysteresis OUTPUTS VDD_VOH Output – output high voltage IOUT= - 10mA 150 mV VOL Output low voltage IOUT= 10mA 10 mV ISINK/SRC CLoad=10nF, FSW=1kHz 4 A IOUT= - 10mA 9 Ω ROL Output sink/source peak current Output pull high resistance (only PMOS ON) Output pull low resistance 0.6 Ω Timing TR Output rising time CLoad=1nF 8 20 ns CLoad=1nF 8 20 ns 13 25 ns 13 25 TM_IN Output falling time Input to output propagation delay, Rising edge Input to output propagation delay, Falling edge Input to output delay matching 1 4 ns TMIN_ON Minimum input pulse width CLoad=1nF 20 30 ns Thermal shutdown threshold TJ rising 170 °C 25 °C ROH TF TD_IN 0.8 UNIT 0.8 IOUT= 10mA 2.4 V 1 V 1.1 V Protection TSD 4 Hysteresis For more information www.silicontent.com © 2018 Silicon Content Technology Co., Ltd. Product Folder Links: SCT52240 All Rights Reserved SCT52240 TYPICAL CHARACTERISTICS 4.5 200.0 4.4 180.0 4.3 160.0 Supply Current (uA) Supply Voltage (v) VIN=12V, TA= 25°C. 4.2 4.1 4.0 3.9 3.8 3.7 UVLO_Rise 3.6 UVLO_Fall 140.0 120.0 100.0 80.0 60.0 VDD=3.4V VDD=12V 40.0 20.0 3.5 -50 0 50 100 -50 150 0 Temperature (ºC) 2.0 2.0 Enable Voltage (v) Input Voltage (v) 2.5 1.5 1.0 0.5 Input High Input Low 1.5 1.0 0.5 Enable High Enable Low 0.0 50 100 0.0 150 -50 0 Temperature (ºC) 50 100 150 Temperature (ºC) Figure 3. Input Threshold vs Temperature Figure 4. Enable Threshold vs Temperature 10.0 10.0 9.0 9.0 8.0 8.0 Falling Time (ns) Rising Time (ns) 150 Figure 2. Start-up current vs Temperature 2.5 0 100 Temperature (ºC) Figure 1. UVLO vs Temperature -50 50 7.0 6.0 5.0 7.0 6.0 5.0 COUT=1nF COUT=1nF 4.0 4.0 -50 0 50 100 150 -50 Temperature (ºC) Figure 5 Output Rising Time vs Temperature 0 50 100 150 Temperature (ºC) Figure 6. Output Falling Time vs Temperature For more information www.silicontent.com © 2018 Silicon Content Technology Co., Ltd. Product Folder Links: SCT52240 All Rights Reserved 5 20.0 15.0 18.0 13.0 Pull Up Resistance (Ω) Delay Time (ns) SCT52240 16.0 14.0 12.0 10.0 Input to Output High Input to Output Low 8.0 11.0 9.0 7.0 ROH 5.0 -50 0 50 100 150 -50 0 Temperature (ºC) 50 100 150 Temperature (ºC) Figure 8. ROH vs Temperature Figure 7. Input to Output Propagation Delay vs Temperature 60 2.0 VDD=4.5V 1.5 Supply Current (mA) Pull Down Resistance (Ω) 50 1.0 0.5 ROL VDD=12V VDD=24V 40 30 20 10 0 0.0 -50 0 50 100 0 150 Figure 9. ROL vs Temperature 6 200 400 600 800 1000 Frequency (kHz) Temperature (ºC) Figure 10. Operation Supply Current vs Frequency, COUT=1nF For more information www.silicontent.com © 2018 Silicon Content Technology Co., Ltd. Product Folder Links: SCT52240 All Rights Reserved SCT52240 FUNCTIONAL BLOCK DIAGRAM VDD VDD 400k ENA 1 INA 2 400k 8 ENB 7 OUTA 6 VDD 5 OUTB VDD 1M 500k GND 3 UVLO INB 4 Thermal Sensor VDD 500k 1M For more information www.silicontent.com © 2018 Silicon Content Technology Co., Ltd. Product Folder Links: SCT52240 All Rights Reserved 7 SCT52240 OPERATION Overview The SCT52240 is a dual-channel non-invertible high-speed low side driver with supporting up to 24V wide supply for both power MOSFET and IGBT. Each channel can source and sink 4A peak current along with the minimum propagation delay 13ns from input to output. The 1ns delay matching and the stackable output characteristics support higher driving capability demanding in high power converter application. The ability to handle -5V DC input increases the noise immunity of driver input stage, the 24V rail-to-rail output improves the SCT52240 output stage robustness during switching load fast transition. The SCT52240 has flexible input and enable pin configuration, table 1 shows the device output logic truth table. . Table 1: the SCT52240 Device Logic. ENA ENB INA INB OUTA OUTB H H L L L L H H L H L H H H H L H L H H H H H H L L Any Any L L Any Any Floating Floating L L Floating Floating L L L L Floating Floating L H L H Floating Floating H L H L Floating Floating H H H H VDD Power Supply The SCT52240 operates under a supply voltage range between 4.5V to 24V. For the best high-speed circuit performance, two VDD bypass capacitors in parallel are recommended to prevent noise problems on supply VDD. A 0.1-μF surface mount ceramic capacitor must be located as close as possible to the VDD to GND pins of the SCT52240. In addition, a larger capacitor (such as 1-μF or 10uF) with relatively low ESR must be connected in parallel, in order to help avoid the unexpected VDD supply glitch. The parallel combination of capacitors presents a low impedance characteristic for the expected current levels and switching frequencies in the application. Under Voltage Lockout (UVLO) SCT52240 device Under Voltage Lock Out (UVLO) rising threshold is typically 4.2 V with 300-mV typical hysteresis. When VDD is rising and the level is still below UVLO threshold, this circuit holds the output low regardless of the status of the inputs. The hysteresis prevents output bouncing when low VDD supply voltages have noise from the power supply. The capability to operate at low voltage below 5 V, is especially suited for driving new emerging wide band gap power device like GaN. For example, at power up, the driver output remains low until the VDD voltage reaches the UVLO threshold if enable pin is active or floating. The magnitude of the OUT signal rises with VDD until steady state VDD reached. The non-inverting operation in Figure 11 shows that the output remains low until the UVLO threshold reached, and then the output is in-phase with the input. 8 For more information www.silicontent.com © 2018 Silicon Content Technology Co., Ltd. Product Folder Links: SCT52240 All Rights Reserved SCT52240 VDD UVLO IN OUT Figure 11. SCT52240 Output Vs VDD Enable Function SCT52240 provides independent enable pins ENA and ENB for external control of each channel operation. The enable pins are based on a TTL compatible input-threshold logic that is independent of the supply voltage and is effectively controlled with logic signals from 3.3-V and 5-V microcontrollers. When applying a voltage higher than the high threshold (typical 2.1V) the pin, the SCT52240 enables all functions and starts gate driver operation. Driver operation is disabled when ENx voltage falls below its lower threshold (typical 1.1V). The ENx pins are internally pulled up to VDD with 400k pullup resistors. Hence, the ENx pins are left floating or Not Connected (N/C) for standard operation, where the enable feature is not required. Input Stage The input of SCT52240 is compatible on TTL input-threshold logic that is independent of the VDD supply voltage. With typically high threshold = 2.1 V and typically low threshold = 1 V, the logic level thresholds are conveniently driven with PWM control signals derived from 3.3-V and 5-V digital power-controller devices. Wider hysteresis offers enhanced noise immunity compared to traditional TTL logic implementations, where the hysteresis is typically less than 0.5V. SCT52240 also features tight control of the input pin threshold voltage that ensures stable operation across temperature. The very low input parasitic capacitance on the input pins increases switching speed and reduces the propagation delay. Output Stage The SCT52240 output stage features the pull up structure with P-type MOSFET PM1 and N-type MOSFET NM1 in parallel, as shown in Figure 12. PM1 provides the pull up capability when OUT approaches VDD and the NM1 holds off state, which guarantees the driver output is up to VDD rail. The measurable on-resistance ROH in steady state is the conduction resistance of PM1. NM1 provides a narrow instant peak sourcing current up to 4A to eliminate the turn on time and delay. During the output turn on transition, the equivalent hybrid pull on transient resistance is 1.5ROL, which is much lower than the DC measured ROH. The N-type MOSFET NM2 composes the output stage pull down structure; the ROL is the DC measurement and represents the pull down impedance. The output stage of SCT52240 provides rail-to-rail operation, and is able to supply 4A sourcing and 4A sinking peak current. The presence of the MOSFET-body diodes also offers low impedance to switching overshoots and undershoots. The outputs of the dual channel drivers are designed to withstand 500-mA reverse current without either damaging the device or logic malfunction. For more information www.silicontent.com © 2018 Silicon Content Technology Co., Ltd. Product Folder Links: SCT52240 All Rights Reserved 9 SCT52240 VDD+5V 6 VDD 5 OUT VDD BootStrap NM1 Input Logic Anti-shoot through and Dead time PM1 ROH 1M NM2 ROL Figure 12. SCT52240 Output Stage Stackable Output The SCT52240 features 1ns (typical) delay matching between dual channels, which enables dual channel outputs be stackable when the driven power device required higher driving capability. For example, in a Boost Power Factor Correction converter, there are 2 power MOSFET in parallel to support higher power output capability. The two power MOSFET are preferred to be driven by a common gate control signal. By using SCT52240, the OUTA and OUTB can be connected together to provide the higher driving capability, so does the INA and INB. As a result, a single input signal controls the stacked output combination. To support the stackable output, each channel output stage artificially implements up to 5ns dead-time to avoid the possible shoot-through between two channels as shown Figure 13. Due to the rising and falling threshold mismatch between INA and INB, cautions must be taken when implementing stackable output of OUTA and OUTB together. The maximum mismatch between INA and INB input threshold is up to 10mV (maximum cross temperature), as a result the allowed minimum slew rate of input logic signal is 2V/us. The following suggestions are recommended when INA and INB connected together and along with the OUTA and OUTB: 1. Apply the fast slew rate dv/dt on input (2 V/us or greater) to avoid the possible shoot-through between OUTA and OUTB output stage. 2. INA and INB must be connected as close to the pins as possible. 10 For more information www.silicontent.com © 2018 Silicon Content Technology Co., Ltd. Product Folder Links: SCT52240 All Rights Reserved SCT52240 6 VDD Ishort INA NM1 2 7 VINA_R VINB_R OUTA 1M NM2 Slow Input 500k GND 3 INB 4 VDD NM1 500k 5 OUTB 1M NM2 Figure 13. SCT52240 Stackable output The Figure 14 and Figure 15 shows the stackable output with 2V/us input signal. Figure 14. Driver Switching ON Figure 15. Driver Switching OFF Thermal Shutdown Once the junction temperature in the SCT52240 exceeds 170ºC, the thermal sensing circuit stops switching until the junction temperature falling below 145ºC, and the device restarts. Thermal shutdown prevents the damage on device during excessive heat and power dissipation condition. For more information www.silicontent.com © 2018 Silicon Content Technology Co., Ltd. Product Folder Links: SCT52240 All Rights Reserved 11 SCT52240 APPLICATION INFORMATION Typical Application RGA ENA INA GND INB ENB OUTA VDD VDD RGB OUTB C1 C2 Figure 16. Dual Channel Driver Typical Application Driver Power Dissipation Generally, the power dissipated in the SCT52240 depends on the gate charge required of the power device (Qg), switching frequency, and use of external gate resistors. The SCT52240 features very low quiescent currents and internal logic to eliminate any shoot-through in the output driver stage, their effect on the power dissipation within the gate driver is negligible. For the pure capacitive load, the power loss of each channel in SCT52240 is: 2 𝑃𝐺 = 𝐶𝐿𝑜𝑎𝑑 ∗ 𝑉𝐷𝐷 ∗ 𝑓𝑆𝑊 (1) Where  VDD is supply voltage  CLoad is the output capacitance  FSW is the switching frequency For the the switching load of power MOSFET, the power loss of each channel in the SCT52240 is shown in equation (2), where charging a capacitor is determined by using the equivalence Q g = CLOADVDD. The gate charge includes the effects of the input capacitance plus the added charge needed to swing the drain voltage of the power device as it switches between the ON and OFF states. Manufacturers provide specifications that provide the typical and maximum gate charge, in nC, to switch the device under specified conditions. 𝑃𝐺 Where    = 𝑄𝑔 ∗ 𝑉𝐷𝐷 ∗ 𝑓𝑆𝑊 (2) Qg is the gate charge of the power device fSW is the switching frequency VDD is the supply voltage If RG applied between driver and gate of power device to slow down the power device transition, the power dissipation of the driver shows as below: 12 For more information www.silicontent.com © 2018 Silicon Content Technology Co., Ltd. Product Folder Links: SCT52240 All Rights Reserved SCT52240 𝑃𝐺 = 1 𝑅𝑂𝐿 𝑅𝑂𝐻 ∗ 𝑄𝑔 ∗ 𝑉𝐷𝐷 ∗ 𝑓𝑆𝑊 ∗ ( + ) 2 𝑅𝑂𝐿 + 𝑅𝐺 𝑅𝑂𝐻 + 𝑅𝐺 (3) Where  ROH is the equivalent pull up resistance of SCT52240  ROL is the pull down resistance of SCT52240  RG is the gate resistance between driver output and gate of power device. For more information www.silicontent.com © 2018 Silicon Content Technology Co., Ltd. Product Folder Links: SCT52240 All Rights Reserved 13 SCT52240 Application Waveforms 14 Figure 17. Driver Switching ON Figure 18. Driver Switching OFF Figure 19. Delay Matching Rise Figure 20. Delay Matching Fall Figure 21. Stackable Output Rise Figure 22. Stackable Output Fall For more information www.silicontent.com © 2018 Silicon Content Technology Co., Ltd. Product Folder Links: SCT52240 All Rights Reserved SCT52240 Layout Guideline The SCT52240 provides the 4A output driving current and features very short rising and falling time at the power devices gate. The high di/dt causes driver output unexpected ringing when the driver output loop is not designed well. The regulator could suffer from malfunction and EMI noise problems if the power device gate has serious ringing. Below are the layout recommendations with using SCT52240 and Figure 23 is the layout example. Put the SCT52240 as close as possible to the power device to minimize the gate driving loop including the driver output and power device gate. The power supply decoupling capacitors needs to be close to the VDD pin and GND pin to reduce the supply ripple. For the output stackable application, the driver input loop of two-channel input must be strictly symmetrical to ensure the input propagation delay is the same. Star-point grounding is recommend to minimize noise coupling from one current loop to the other. The GND of the driver connects to the other circuit nodes such as source of power MOSFET or ground of PWM controller at single point. The connected paths must be as short as possible to reduce parasitic inductance. A ground plane is to provide noise shielding and thermal dissipation as well. NMOS S D ENA 1 INA 2 SCT52240 8 ENB 7 OUTA GND 3 6 VDD INB 4 5 OUTB GND G G VDD D S NMOS Figure 23. SCT52240 PCB Layout Example Thermal Considerations The maximum IC junction temperature should be restricted to 150°C under normal operating conditions. Calculate the maximum allowable dissipation, PD(max) , and keep the actual power dissipation less than or equal to P D(max) . The maximum-power-dissipation limit is determined using Equation (4). 𝑃𝐷(𝑀𝐴𝑋) = 150 − 𝑇𝐴 𝑅θJA (4) where  TA is the maximum ambient temperature for the application.  RθJA is the junction-to-ambient thermal resistance given in the Thermal Information table. The real junction-to-ambient thermal resistance RθJA of the package greatly depends on the PCB type, layout, and environmental factor. Soldering the ground pin to a large ground plate enhance the thermal performance. Using more vias connects the ground plate on the top layer and bottom layer around the IC without solder mask also improves the thermal capability. For more information www.silicontent.com © 2018 Silicon Content Technology Co., Ltd. Product Folder Links: SCT52240 All Rights Reserved 15 SCT52240 PACKAGE INFORMATION TOP VIEW BOTTOM VIEW SYMBOL SIDE VIEW NOTE: 1. 2. 3. 4. 5. 6. 16 Drawing proposed to be made a JEDEC package outline MO220 variation. Drawing not to scale. All linear dimensions are in millimeters. Thermal pad shall be soldered on the board. Dimensions of exposed pad on bottom of package do not include mold flash. Contact PCB board fabrication for minimum solder mask web tolerances between the pins. A A1 A2 b c D E E1 e L ɵ For more information www.silicontent.com © 2018 Silicon Content Technology Co., Ltd. Product Folder Links: SCT52240 Unit: Millimeter MIN TYP MAX 1.35 --1.75 0.1 --0.25 1.35 --1.55 0.33 --0.51 0.17 --0.25 4.7 5.1 5.8 6.2 3 1.27BSC 0.4 0.8 0° 8° All Rights Reserved SCT52240 TAPE AND REEL INFORMATION Feeding Direction For more information www.silicontent.com © 2018 Silicon Content Technology Co., Ltd. Product Folder Links: SCT52240 All Rights Reserved 17 SCT52240 TYPICAL APPLICATION Single Channel, Non-Inverting MOSFET Gate Drive Typical Application RG VDD VDD C1 Typical Application Waveform OUT C2 GND IN+ IN- RELATED PARTS PART NUMBERS SCT51240 DESCRIPTION COMMENTS Up to 24V Supply, 4-A Single Channel High Speed Low Side Driver  Compatible for both Inverting and Non-inverting application Supporting down to -5V input RG VDD C1  VDD OUT C2 GND IN+ IN- Figure 24. SCT51240 Inverting MOSFET Gate Drive Typical Application NOTICE: The information in this document is subject to change without notice. Users should warrant and guarantee the third party Intellectual Property rights are not infringed upon when integrating Silicon Content Technology (SCT) products into any application. SCT will not assume any legal responsibility for any said applications. For more information www.silicontent.com © 2018 Silicon Content Technology Co., Ltd. Product Folder Links: SCT52240 All Rights Reserved 18
SCT52240STDR 价格&库存
很抱歉,暂时无法提供与“SCT52240STDR”相匹配的价格&库存,您可以联系我们找货
