VLP-04V-1
VLP-04V-1
    JST
    P=6.2mm
    2X2P 6.2MM
VLP-04V-1 数据手册
VL CONNECTOR (HIGH CURRENT TYPE) 6.2mm pitch/Disconnectable Crimp style connectors Wire-to-wire connectors (Combined use for both wire-to-wire and wire-to-board connections) Specifications ––––––––––––––––––– This VL connector is 6.2 mm pitch wire-to-wire and wire-to-board connector, designed for large current. The connector suitable for the large electric current has been realized by using highly-conducting material, so that the connection of large current circuit enables. • Housing lances • Retainer • Suited for large carrent • Panel lock • Current rating: 23 A AC, DC (Refer to the following table.) • Voltage rating: 600 V AC, DC • Temperature range: -25˚C to +90˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 7 mΩ max. After environmental tests/ 10 mΩ max. • Insulation resistance: 1,000 MΩ min. • Withstanding voltage: 2,000 VAC/minute • Applicable wire: AWG #20 to #12 0.5 to 3.5 mm2 • Applicable panel thickness: 0.5 to 2.0 mm * In using the products, refer to "Handling Precaution for Terminal and Connector" described on our website (Technical documents of Product information page). * Contact JST for details. * RoHS2 compliance Note: The current rating mentioned above is applied only in the combination of socket contact and pin contact for high current. When either is a normal product, please be careful because the current rating of the normal product is applied. Current unit: A Standards –––––––––––––––––––– 0 #14 Wire size (AWG) #16 #18 #20 18 15 11 9 23 18 15 11 9 3 22 17 14 10 8 4 21 16 13 9 8 No. of circuits #12 1 23 2 Recognized E60389 1 Certified LR20812 2R9351103 Panel layout and Assembly layout Inner-housing lock Inner-housing lock 12.2 19.3 (including retainer) 40.5 40.5 44.1 (including retainer) 44.1 (including retainer) Outer-housing lock 14.6 21.7 (including retainer) Outer-housing lock 40.5 44.1 (including retainer) 40.5 Shape I Shape II 44.1 (including retainer) E A B D C D 12.2 ±0.13 C E B 0.5 ±0.13 4.2 ±0.13 A 18.6 ±0.13 9.8 ±0.13 9.8 ±0.13 No. of circuits 2 3 4 4 (Single-row) Receptacle housing Model No. VLR-02V VLR-03V VLR-04V VLR-04VN Note: 1. Punch holes in the panel according to the figures and table shown above. Burrs must be removed. 2. The strength of the panel must be considered when punching two or more holes. 3. The connector must be inserted from the same side as the hole is punched. 1 Panel hole dimensions (mm) General tolerance Panel hole shape A B C D E 1 13.8 20.6 5.7 8.5 1.4 1 20.0 26.8 5.7 8.5 1.4 2 13.8 20.6 7.0 15.4 4.2 1 26.2 33.0 5.7 8.5 1.4 A, B, D: 0.13 C, E: 0.1 Applicable panel thickness (mm) 0.5∼2.0 VL CONNECTOR (HIGH CURRENT TYPE) Contact Applicable wire mm2 AWG # Model No. Pin contact Socket contact Pin contact 4.1 3.2 TSJ SVSM-61T-S2.0 SVSF-61T-S2.0 Insulation O.D. (mm) 0.5∼2.0 20∼14 1.9∼3.4 0.5+0.5∼ 0.75+1.25 20+20∼ 18+16 1.9+1.9∼ 2.1+2.7 3.5 12 4.1 SVSM-81T-S2.0 SVSF-81T-S2.0 Q'ty/ reel 2,000 22.2 1.7 Material and Finish 3.6 2 Phosphor bronze, tin-plated (reflow treatment) 2 3.1 RoHS2 compliance 4.1 TSJ Socket contact Crimping machine Crimp applicator Contact 16.7 3.6 2 1.7 SVSM-61T-S2.0 SVSF-61T-S2.0 3.1 SVSM-81T-S2.0 Applicator Dies MK/SVF/M-81-20 APLMK SVF/M81-20 MKS-L SVSF-81T-S2.0 − − − AP-K2N Crimp applicator with dies MK/SVF/M-61-20 APLMK SVF/M61-20 MKS-L − − − Note: Contact JST for fully automatic crimping applicator. Contact position location numbers Retainer Retainer Contact position numbers are stamped Receptacle housing Plug housing Receptacle housing 4 3 L JST 2 1 4 3 2 1 3 1 3 1 4 2 3 1 2 2 L JST L JST 1 3 2 1 4 2 2 1 L JST 1 Plug housing L JST 3 2 4 1 3 2 4 3 2 3 2 1 1 3 2 L JST L JST 4 3 2 1 1 2 L JST 2 1 1 L JST 2 4 1 3 1 4 2 3 2 1 3 2 JST L 2 1 1 1 1 1 L JST 2 3 4 2 VL CONNECTOR (HIGH CURRENT TYPE) Housing Material: Housing...PA 66, UL94V-0, white Retainer...Glass-filled PA 66, UL94V-0, ivory No. of Voltage Current rating circuits rating Receptacle housing (for pin contact) 23A Q’ty/ bag VLS-01V Q’ty/ bag 500 3 Q’ty/ bag 11 2.8 500 9.4 Q’ty/ bag VLP-02V L JST L JST 13.4 2 13.4 2 VLR-02V 13 29.5 3.4 9.2 6.2 600V VLP-01V 7.2 1 Q’ty/ bag Retainer 7.2 VLR-01VF (Without panel lock product) Plug housing (for socket contact) 7.3 1,000 9.4 VLS-02V (commonly used for 2-circuit housing and 4-circuit housing) Q’ty/ bag 1 1 23A 8.2 11 2.8 8.4 11.4 600V 3.4 13 2 29.5 3 500 VLP-02V-1 500 9.4 1 L JST 15 L JST 2 13.4 1,000 5.9 2 VLR-02VF (Without panel lock product) 1 8.2 13 29.5 3 Q’ty/ bag 5.2 8.4 Q’ty/ bag VLP-03V Q’ty/ bag VLS-03V 1 L 3.4 2 JST 19.6 3 VLR-03V 11 3 22A 11 2.8 8.4 17.6 13 19.6 600V 2 L JST 3 VLP-03V-1 500 1,000 29.5 5.9 19.6 3 9.4 1 8.2 2 L JST 3.4 3 1 500 13 5.2 8.4 VLP-04V Q’ty/ bag VLS-02V Q’ty/ bag 3 1 13.4 2 4 13.4 2 4 Q’ty/ bag 3.4 VLR-04V 11 1 3 L JST L JST 3 15 11 2.8 15.4 11.4 3.4 13 29.5 500 VLP-04V-1 500 VLR-04VF (Without panel lock product) 15 3 13.4 1 21A 3 600V 9.4 4 2 2 4 4 1,000 5.9 15 L JST 1 L JST 3 13 29.5 VLR-04VN 5.2 15.4 Q’ty/ bag VLP-04VN-1 VLS-08V Q’ty/ bag 4 3.4 Q’ty/ bag 11 23.8 25.8 2 L JST 25.8 3 L JST 3 4 500 2 500 1 1 3.4 13 8.2 RoHS2 compliance Note: 1. Contact JST for special products. 3 3 29.5 11 5.2 8.4 5.9 9.4 1,000
VLP-04V-1 价格&库存
很抱歉,暂时无法提供与“VLP-04V-1”相匹配的价格&库存,您可以联系我们找货
