1.5SMC6.8(A) - 1.5SMC200(A)
Taiwan Semiconductor
1500W, 6.8V - 200V Surface Mount Transient Voltage Suppressor
FEATURES
KEY PARAMETERS
Ideal for automated placement
Glass passivated junction
Excellent clamping capability
Fast response time: Typically less than 1.0ps
Typical IR less than 1μA above 10V
Moisture sensitivity level: level 1, per J-STD-020
AEC-Q101 qualified available:
ordering code with suffix “H”
● Compliant to RoHS Directive 2011/65/EU and
in accordance to WEEE 2002/96/EC
PARAMETER
VALUE
UNIT
VWM
5.5 - 171
V
VBR
6.8 - 200
V
PPK
1500
W
TJ MAX
150
°C
Package
DO-214AB (SMC)
Configuration
Single die
APPLICATIONS
● Immunization of sensitive devices in automotive,
telecommunications, consumer electronics, and industrial
equipment from electrostatic discharge (ESD) and transient
voltages induced by load switching and lightning
MECHANICAL DATA
Case:DO-214AB (SMC)
Molding compound meets UL 94V-0 flammability rating
Terminal:Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity:As marked
Weight: 0.21 g (approximately)
DO-214AB (SMC)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
Peak power dissipation at TA=25°C, tp=1ms
(1)
Steady state power dissipation at TA=25°C
Peak forward surge current, 8.3 ms single half sine-wave
superimposed on rated load
(2)
Forward Voltage @ IF=50A for Unidirectional only
Junction temperature
SYMBOL
VALUE
UNIT
PPK
1500
W
PD
6.5
W
IFSM
200
A
VF
3.5 / 5.0
V
TJ
-55 to +150
°C
-55 to +150
°C
Storage temperature
TSTG
Notes:
1. Non-repetitive current pulse per Fig. 3 and derated above TA=25°C per Fig. 2
2. VF=3.5V on 1.5SMC6.8 - 1.5SMC91 and VF=5.0V on 1.5SMC100 - 1.5SMC200
Devices for Bipolar Applications
1. For bidirectional use C or CA suffix for types 1.5SMC6.8 - types 1.5SMC200A
2. Electrical characteristics apply in both directions
1
Version: P1903
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
Junction-to-ambient thermal resistance
RӨJA
50
°C/W
Junction-to-case thermal resistance
RӨJC
15
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
Part number
1.5SMC6.8
1.5SMC6.8A
1.5SMC7.5
1.5SMC7.5A
1.5SMC8.2
1.5SMC8.2A
1.5SMC9.1
1.5SMC9.1A
1.5SMC10
1.5SMC10A
1.5SMC11
1.5SMC11A
1.5SMC12
1.5SMC12A
1.5SMC13
1.5SMC13A
1.5SMC15
1.5SMC15A
1.5SMC16
1.5SMC16A
1.5SMC18
1.5SMC18A
1.5SMC20
1.5SMC20A
1.5SMC22
1.5SMC22A
1.5SMC24
1.5SMC24A
1.5SMC27
1.5SMC27A
1.5SMC30
1.5SMC30A
1.5SMC33
1.5SMC33A
1.5SMC36
1.5SMC36A
1.5SMC39
1.5SMC39A
1.5SMC43
1.5SMC43A
1.5SMC47
1.5SMC47A
1.5SMC51
Marking
code
DDJ
DEJ
DFJ
DGJ
DHJ
DKJ
DLJ
DMJ
DNJ
DPJ
DQJ
DRJ
DSJ
DTJ
DUJ
DVJ
DWJ
DXJ
DYJ
DZJ
EDJ
EEJ
EFJ
EGJ
EHJ
EKJ
ELJ
EMJ
ENJ
EPJ
EQJ
ERJ
ESJ
ETJ
EUJ
EVJ
EWJ
EXJ
EYJ
EZJ
FDJ
FEJ
FFJ
Breakdown
voltage
(Note 1)
VBR@IT
(V)
MIN.
6.12
6.46
6.75
7.13
7.38
7.79
8.19
8.65
9.00
9.50
9.90
10.5
10.8
11.4
11.7
12.4
13.5
14.3
14.4
15.2
16.2
17.1
18.0
19.0
19.8
20.9
21.6
22.8
24.3
25.7
27.0
28.5
29.7
31.4
32.4
34.2
35.1
37.1
38.7
40.9
42.3
44.7
45.9
MAX.
7.48
7.14
8.25
7.88
9.02
8.61
10.00
9.55
11.00
10.5
12.1
11.6
13.2
12.6
14.3
13.7
16.5
15.8
17.6
16.8
19.8
18.9
22.0
21.0
24.2
23.1
26.4
25.2
29.7
28.4
33.0
31.5
36.3
34.7
39.6
37.8
42.9
41.0
47.3
45.2
51.7
49.4
56.1
Test
current
IT
(mA)
Working
stand-off
voltage
VWM
(V)
Maximum
blocking
leakage
current
IR@VWM
(µA)
10
10
10
10
10
10
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
5.50
5.80
6.05
6.40
6.63
7.02
7.37
7.78
8.10
8.55
8.92
9.40
9.72
10.2
10.5
11.1
12.1
12.8
12.9
13.6
14.5
15.3
16.2
17.1
17.8
18.8
19.4
20.5
21.8
23.1
24.3
25.6
26.8
28.2
29.1
30.8
31.6
33.3
34.8
36.8
38.1
40.2
41.3
1000
1000
500
500
200
200
50
50
10
10
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
2
Maximum
peak
Maximum Maximum
impulse clamping Temperature
current
voltage
Coefficient
of VBR
(Note 2)
VC@IPPM
IPPM
(V)
(%/°C)
(A)
145
150
134
139
126
130
114
117
105
108
97
100
91
94
82
86
71
74
67
70
59
60
54
56
49
51
45
47
40
42
36
38
33
34
30
31
27
29
25
26
23
24
21
10.8
10.5
11.7
11.3
12.5
12.1
13.8
13.4
15.0
14.5
16.2
15.6
17.3
16.7
19.0
18.2
22.0
21.2
23.5
22.5
26.5
25.5
29.1
27.7
31.9
30.6
34.7
33.2
39.1
37.5
43.5
41.4
47.7
45.7
52.0
49.9
56.4
53.9
61.9
59.3
67.8
64.8
73.5
0.057
0.057
0.061
0.061
0.065
0.065
0.068
0.068
0.073
0.073
0.075
0.075
0.078
0.078
0.081
0.081
0.084
0.084
0.086
0.086
0.088
0.088
0.090
0.090
0.092
0.092
0.094
0.094
0.096
0.096
0.097
0.097
0.098
0.098
0.099
0.099
0.100
0.100
0.101
0.101
0.101
0.101
0.102
Version: P1903
Part number
1.5SMC51A
1.5SMC56
1.5SMC56A
1.5SMC62
1.5SMC62A
1.5SMC68
1.5SMC68A
1.5SMC75
1.5SMC75A
1.5SMC82
1.5SMC82A
1.5SMC91
1.5SMC91A
1.5SMC100
1.5SMC100A
1.5SMC110
1.5SMC110A
1.5SMC120
1.5SMC120A
1.5SMC130
1.5SMC130A
1.5SMC150
1.5SMC150A
1.5SMC160
1.5SMC160A
1.5SMC170
1.5SMC170A
1.5SMC180
1.5SMC180A
1.5SMC200
1.5SMC200A
Marking
code
FGJ
FHJ
FKJ
FLJ
FMJ
FNJ
FPJ
FQJ
FRJ
FSJ
FTJ
FUJ
FVJ
FWJ
FXJ
FYJ
FZJ
GDJ
GEJ
GFJ
GGJ
GHJ
GKJ
GLJ
GMJ
GNJ
GPJ
GQJ
GRJ
GSJ
GTJ
Breakdown
voltage
(Note 1)
VBR@IT
(V)
MIN.
48.5
50.4
53.2
55.8
58.9
61.2
64.6
67.5
71.3
73.8
77.9
81.9
86.5
90
95
99
105
108
114
117
124
135
143
144
152
153
162
162
171
180
190
MAX.
53.6
61.6
58.8
68.2
65.1
74.8
71.4
82.5
78.8
90.2
86.1
100
95.5
110
105
121
116
132
126
143
137
165
158
176
168
187
179
198
189
220
210
Test
current
IT
(mA)
Working
stand-off
voltage
VWM
(V)
Maximum
blocking
leakage
current
IR@VWM
(µA)
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
43.6
45.4
47.8
50.2
53.0
55.1
58.1
60.7
64.1
66.4
70.1
73.7
77.8
81.0
85.5
89.2
94.0
97.2
102.0
105.0
111.0
121.0
128.0
130.0
136.0
138.0
145.0
146.0
154.0
162.0
171.0
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
Maximum
peak
Maximum Maximum
current
voltage
Coefficient
of VBR
(Note 2)
VC@IPPM
IPPM
(V)
(%/°C)
(A)
22
70.1
0.102
19
80.5
0.103
0.103
17
89.0
0.104
18
85.0
0.104
16
98.0
0.104
17
92.0
0.104
14
108
0.105
15
103
0.105
13
118
0.105
13.9
113
0.105
12
131
0.106
12.6
125
0.106
10.9
144
0.106
11.4
137
0.106
9.9
158
0.107
10.3
152
0.107
9.1
173
0.107
9.5
165
0.107
8.4
187
0.107
8.7
179
0.107
7.3
215
0.108
7.6
207
0.108
6.8
230
0.108
7.1
219
0.108
6.4
244
0.108
6.7
234
0.108
6.1
258
0.108
6.4
246
0.108
5.4
287
0.108
5.7
274
0.108
Notes:
1. VBR measure after IT applied for 30ms, IT=square wave pulse or equivalent
2. Surge current waveform per Fig. 3 and derate per Fig. 2
3. For bipolar types having VWM of 10 V and under, the IR limit is doubled
4. For bidirectional use C or CA suffix for types 1.5SMC6.8 - 1.5SMC200A
5. All terms and symbols are consistent with ANSI/IEEE C62.35
3
Version: P1903
ORDERING INFORMATION
ORDERING CODE
(Note 1, 2, 3)
PACKAGE
PACKING
1.5SMCxxxxHR7G
SMC
850 / 7" Plastic reel
1.5SMCxxxxHR6G
SMC
3,000 / 13" Paper reel
1.5SMCxxxxHM6G
SMC
3,000 / 13" Plastic reel
1.5SMCxxxx R7G
SMC
1.5SMCxxxx R6G
SMC
1.5SMCxxxx M6G
SMC
1.5SMCxxxxHV7G
Matrix SMC
1.5SMCxxxxHV6G
Matrix SMC
1.5SMCxxxx V7G
Matrix SMC
1.5SMCxxxx V6G
Matrix SMC
1.5SMCxxxxHR7
SMC
1.5SMCxxxxHR6
SMC
1.5SMCxxxxHM6
SMC
1.5SMCxxxx R7
SMC
1.5SMCxxxx R6
SMC
1.5SMCxxxx M6
SMC
Note 1:
"xxxx" defines voltage from 6.8V
(1.5SMC6.8) to 200V (1SMC200A)
Note 2:
"H" means AEC-Q101 qualified
Note 3:
"G" means green compound (halogen free)
4
Version: P1903
CHARACTERISTICS CURVES
Fig.1 Peak Pulse Power Rating Curve
Fig.2 Pulse Derating Curve
PEAK PULSE POWER (PPPM) OR CURRENT (IPP)
DERATING IN PERCENTAGE (%)
NON-REPETITIVE
PULSE WAVEFORM
SHOWN in FIG.3
10
1
0.1
0.1
1
10
100
tp, PULSE WIDTH, (μs)
1000
125
100
75
50
25
50
75
100
125
150
175
200
TA, AMBIENT TEMPERATURE (°C)
Fig.3 Clamping Power Pulse Waveform
Fig.4 Typical Junction Capacitance
10000
140
Peak value
IPPM
120
Pulse width(td) is defined
as the point where the peak
current decays to 50% of IPPM
CJ, JUNCTION CAPACITANCE (pF) A
PPK, PEAK PULSE POWER (KW)
100
100
Rise time tr=10μs to 100% of IPPM
80
Half value-IPPM/2
10/1000μs, waveform
as defined by R.E.A.
60
40
td
UNIDIRECTIONAL
BIDRECTIONA
VR=0
1000
100
VR-RATED
STAND-OFF
VOLTAGE
f=1.0MHz
Vsig=50mVp-p
10
1
1.5
2
2.5
1
3
t, TIME (ms)
10
100
V(BR), BREAKDOWN VOLTAGE (V)
5
Version: P1903
IFSM, PEAK FORWARD SURGE CURRENT (A)
Fig.5 Maximum Non-repetitive Forward Surge Current
Unidirectional Only
200
8.3ms Single Half Sine Wave
180
160
140
120
100
80
60
40
10
100
NUMBER OF CYCLES AT 60 Hz
6
Version: P1903
PACKAGE OUTLINE DIMENSIONS
DO-214AB (SMC)
Unit (mm)
DIM.
Unit (inch)
Min.
Max.
Min.
Max.
A
2.90
3.20
0.114
0.126
B
6.60
7.11
0.260
0.280
C
5.59
6.22
0.220
0.245
D
2.00
2.62
0.079
0.103
E
1.00
1.60
0.039
0.063
F
7.75
8.13
0.305
0.320
G
0.10
0.20
0.004
0.008
H
0.15
0.31
0.006
0.012
SUGGESTED PAD LAYOUT
Symbol
Unit (mm)
Unit (inch)
A
3.30
0.130
B
2.50
0.098
C
6.80
0.268
D
4.40
0.173
E
9.40
0.370
MARKING DIAGRAM
SMC
Matrix SMC
P/N
=Marking Code
G
=Green Compound
YW
=Date Code
F
=Factory Code
Note: Cathode band for unidirectional products only
7
Version: P1903
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
8
Version: P1903
很抱歉,暂时无法提供与“1.5SMC33AHV6G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+10.94040
- 10+9.12600
- 30+8.12160
- 100+6.99840
