COH-4065LVC-200-10
COH-4065LVC-200-10
    TAICA(泰克)
    COH-4065LVC-200-10
COH-4065LVC-200-10 数据手册
Thermal Conductive GEL http://www.taica.co.jp/gel-english/ 2017.09 Excellent Cushioning and Vibration Damping Performance Shock Absorption & Vibration Damping ′ s ( Alpha GEL ) softness allows for deflection required for shock absorption and vibration damping, providing excellent cushioning and vibration damping performance. Superior Durability Durability is highly resistant to ozone, UV rays and chemicals,making it possible to use in a variety of locations. In addition, its performance is maintained even after repeated compression. Stable Performance Even In a Harsh Environment Stability ′ s properties show little change in the -40℃( -40 F) to 200℃ ( 392 F) range, providing stable performance. Outstanding Platform for Additional Functions and Enhanced Performance Function On top of the unique combination of excellent features, also works as a reliable foundation for additional functions and for enhancing performance without compromising the merits softness brings. Extremely High Safety Safety ′ s composition makes it harmless to the human body and to the environment, causing no allergies when touched, and emitting no harmful gases when burned. Taica,s Know-how Engineering & Know-How You can count on us for enhanced cushioning, vibration damping, tender feel, and more. Years of accumulated expertise and know-how, mastery of fine-tuning softness, designing and making optimum gel parts --- together all of these help cope with a variety of changing environments and needs of customers around the globe. A raw egg dropped from a height of 18m(60') equivalent to the sixth floor of a building remains unbroken when caught by a sheet of only 2 cm (0.8")thick. http://www.taica.co.jp/gel-english/ Sheet-type Thermal Conductive GEL TM ◆Lambda GEL/COH [Thermal Conductivity and Flexibility] Features 10 Offers outstanding thermal conductivity and excellent heat dissipation. Adhere to rough surfaces and push out all air gaps. Good electrical insulators and flame retardant. 9 Hard Flexibility Soft General Properties Grade Item COH-1016LVC COH-1019LVC COH-4000LVC COH-4065LVC COH-3114LVC Characteristics Thermal conductivity (W/ (m・K) ) Our tests 8.2 Hot Wire (※1) Method 3 Appearance Specific gravity Tensile strength(MPa) Volume resistivity(Ω・cm) Dielectric breakdown strength (kV/mm) Elongation(%) Compression set(%) 〈50Hz〉 Dielectric constant 〈1kHz〉 〈1MHz〉 〈50Hz〉 Dielectric dissipation factor 〈1kHz〉 〈1MHz〉 RoHS controlled substances (※2) Temperature range(℃) One side non tacky type (※1)Hot Wire Method : Using the QTM-500 Quick Thermal Conductivity Meter,from Kyoto Electronics Manufacturing Co.,LTD. (※2)Temperature Range of Use: Range of measured stable thermal conductivity and hardness properties. Please conduct appropriate reliability testing under actual usage conditions. ※Not Specified Values The flow of heat TM benefits Hard thermal conductive sheet stresses IC and PCB. TM Heatsink Heat Hard thermal conductive sheet Heatsink Heatsink Heat source Heat source Heat source PCB Air gap ●Softness of releases stress and absorbs tolerance. TM Heatsink Heatsink TM COH-1019LVC Heatsink TM Heat source Heat source Heat source PCB Directions ◆ Slowly peel off one side of the protective film of . ◆ Carefully place    sheet on the heat source or heatsink without air gap. ◆ Peel off the remaining layer from    with no air gap in between the sheet and heat dissipating device or heat   generating device. TM TM TM Delivery Format 【Basic Specifications】 Sheet size 400×400mm Sheet thickness 0.5、1.0、2.0、3.0mm ※       COH-4065LVC ,COH3114LVC 1.0、2.0、3.0mm Notes ● To the best of our knowledge, the information and statements on this brochure are believed to be true and reliable; however, the PRODUCTS described herein are sold WITHOUT ANY GUARANTEE OR WARRANTY INCLUDING THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR PARTICULAR PURPOSES since the application and conditions of each use vary and change, and are beyond the control of manufacturer and seller(s). The customers and users of the PRODUCTS shall assume the responsibility for determining the suitability of the PRODUCTS based on their tests and for whatever risks and liability associated with the use of the PRODUCTS. NEITHER MANUFACTURER NOR SELLER(S) SHALL BE LIABLE EITHER IN TORT OR CONTRACT OR ANY OTHER CAUSE FOR ANY KIND OF LOSS OF PROFITS OR DAMAGE, INCIDENTAL, DIRECT, OR CONSEQUENTIAL, ARISING OUT OF OR IN CONNECTION WITH THE USE OF OR THE INABILITY TO USE THE PRODUCTS. It is highly recommended that users would not use the products shown in the brochure in medical applications, particularly for implantation use. ● ● The users shall be aware of the fact that silicone oil could bleed from silicone-gel. It is therefore that any user should be responsible for conducting reliability test in advance before delivering the products in the market. The silicone-gel contains low molecular siloxane, which could be volatile. ● ● The seller or manufacturer shall not be responsible for any defects to the supplied product, unless it is proven that the supplied product has defects attributed to the intent or neg ligence of the manufacturer. If that is the case a replacement product shall be provided. ● The seller or manufacturer shall not be responsible for any recommendations, proposals and suggestions or matters not stated in this catalogue, unless otherwise agreed in writing and signed by duly authorized representatives of the seller or manufacturer. ● The customer shall be legally responsible for the import and export of the products of Taica Corporation. Please inform yourself about the laws and regulations of the relevant countries regarding import and export prior to your purchase. *The copyright of this brochure belongs to Taica Corporation. It is prohibited to copy and to use the contents of this brochure without our prior consent. and are trademarks of Taica Corporation, registered in Japan,the United States and / or other countries. http://www.taica.co.jp/gel-english/ Takanawa Sengakuji-ekimae Bldg. 3F, 2-18-10 Takanawa, Minato-ku, Tokyo 108-0074 JAPAN Phone: +81-3-6367-6624 FAX: +81-3-6367-6620 E-mail: gel.overseas@taica.co.jp 2017.09 Paste-type (Grease) Thermal Conductive GEL TM Fill gaps around the heat source for improving heat dissipation. Eliminate running and vaporization problems. Easily spreads over heat generating devices. ◆Lambda GEL/DP Features Very soft paste-type (grease)GEL with thermal conducting properties. Cross-linked particles of eliminate running and vaporization problems seen with traditional grease and phase change materials. Good electrical insulators. TM General Properties Grade Item Thermal conductivity (W/(m・K) ) Remark 6.5 4.8 Hot Wire Method (※1) 2.0 1.6 JIS R 2616 51 55 JIS K 6249(1/4cone) Gray Gray 2.8 2.6 JIS K 6249 5.9×1013 7.2×1014 JIS K 6249 5.0 5.6 JIS K 6249 〈50Hz〉 8.9 7.6 JIS K 6249 〈1kHz〉 7.8 6.7 JIS K 6249 〈1MHz〉 7.0 6.6 JIS K 6249 0.234 0.017 JIS K 6249 0.061 0.007 JIS K 6249 0.015 0.005 JIS K 6249 Less than 700 Less than 900 Less than 1 Less than 3 Not detected Not detected -40∼200 -40∼150 Appearance Specific gravity Volume resistivity(Ω・cm) Dielectric breakdown strength (kV/mm) 〈50Hz〉 Dielectric 〈1kHz〉 dissipation factor 〈1MHz〉 Low molecular weight Siloxane level ΣD4-10(ppm) DP-200 Our tests Hardness (Cone penetration 1/10mm, not mixed) Dielectric constant DP-100 Solvent Extraction Method Head Space Method (※2) RoHS controlled substances Temperature range(℃) (※1)Hot Wire Method : Using the QTM-500 Quick Thermal Conductivity Meter,    from Kyoto Electronics Manufacturing Co.,LTD. (※2)Head Space Method : at 70℃ ※Not Specified Values DP-100 【Filling Example】 【Clamping Torque Dependency】 Transistor:MT-200Type Area:7.7cm2 0.3 Heat source DP-100 DP-200 Thickness(mm) DP-100 0.2 DP-100 enclosure enclosure 0.1 0.0 0 10 20 30 40 50 60 Clamping torque(N・m) 【Thermal Resistance】 DP-200 【Coating Example】 Transistor:MT-200 type Heat input:20V Thickness (mm) 0.10 0.20 0.30 0.13 0.15 0.18 0.17 0.22 DP-200 Heat source DP-100 DP-200 0.15 Spatula Heatsink DP-200 Heat source Heat source DP-200 0.13 (℃/W) Delivery Format 【Basic Specifications】 DP-100/DP-200 Syringe 30mL Notes To the best of our knowledge, the information and statements on this brochure are believed to be true and reliable; however, the PRODUCTS described herein are sold WITHOUT ANY GUARANTEE OR WARRANTY INCLUDING THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR PARTICULAR PURPOSES since the application and conditions of each use vary and change, and are beyond the control of manufacturer and seller(s). The customers and users of the PRODUCTS shall assume the responsibility for determining the suitability of the PRODUCTS based on their tests and for whatever risks and liability associated with the use of the PRODUCTS. NEITHER MANUFACTURER NOR SELLER(S) SHALL BE LIABLE EITHER IN TORT OR CONTRACT OR ANY OTHER CAUSE FOR ANY KIND OF LOSS OF PROFITS OR DAMAGE, INCIDENTAL, DIRECT, OR CONSEQUENTIAL, ARISING OUT OF OR IN CONNECTION WITH THE USE OF OR THE INABILITY TO USE THE PRODUCTS. ● It is highly recommended that users would not use the products shown in the brochure in medical applications, particularly for implantation use. ● The users shall be aware of the fact that silicone oil could bleed from silicone-gel. It is therefore that any user should be responsible for conducting reliability test in advance before delivering the products in the market. ● The silicone-gel contains low molecular siloxane, which could be volatile. ● The seller or manufacturer shall not be responsible for any defects to the supplied product, unless it is proven that the supplied product has defects attributed to the intent or negligence of the manufacturer. If that is the case a replacement product shall be provided. ● ● The seller or manufacturer shall not be responsible for any recommendations, proposals and suggestions or matters not stated in this catalogue, unless otherwise agreed in writing and signed by duly authorized representatives of the seller or manufacturer. The customer shall be legally responsible for the import and export of the products of Taica Corporation. Please inform yourself about the laws and regulations of the relevant countries regarding import and export prior to your purchase. ● *The copyright of this brochure belongs to Taica Corporation. It is prohibited to copy and to use the contents of this brochure without our prior consent. and are trademarks of Taica Corporation, registered in Japan,the United States and / or other countries. http://www.taica.co.jp/gel-english/ Takanawa Sengakuji-ekimae Bldg. 3F, 2-18-10 Takanawa, Minato-ku, Tokyo 108-0074 JAPAN Phone: +81-3-6367-6624 FAX: +81-3-6367-6620 E-mail: gel.overseas@taica.co.jp 2017.09
COH-4065LVC-200-10
1. 物料型号:文档中提到了多种型号的热导性凝胶,包括COH-1016LVC、COH-1019LVC、COH-4000LVC、COH-4065LVC和COH-3114LVC,以及DP-100和DP-200。
2. 器件简介:Taica的热导性凝胶以其卓越的缓冲和减震性能、耐用性、稳定性和安全性而著称。它们可以承受极端温度范围,对环境和人体无害。
3. 引脚分配:文档中没有提及引脚分配,因为这是关于材料而非电子元件的文档。
4. 参数特性:文档详细列出了不同型号凝胶的热导率、硬度、外观、比重、拉伸强度、体积电阻率、介电强度、伸长率、压缩永久变形、介电常数和介电损耗因子等参数。
5. 功能详解:热导性凝胶不仅具有良好的热传导性和柔韧性,还能填充粗糙表面的空气间隙,作为良好的电绝缘体和阻燃材料。
6. 应用信息:文档描述了热导性凝胶在电子设备中的应用,如减少IC和PCB的热应力,并通过其柔软性吸收公差。
7. 封装信息:提供了基本规格,包括片材尺寸、厚度,以及以400mm x 400mm尺寸、不同厚度(0.5、1.0、2.0、3.0mm)交付的格式。
COH-4065LVC-200-10 价格&库存
很抱歉,暂时无法提供与“COH-4065LVC-200-10”相匹配的价格&库存,您可以联系我们找货
COH-4065LVC-200-10
  • 1+355.523871+46.08267
  • 10+314.5897010+40.77682
  • 25+299.6275125+38.83743
  • 50+288.7712150+37.43025
  • 100+278.29853100+36.07279
  • 250+265.01653250+34.35119
库存:258
