E6C1209RYGC2UDA
E6C1209RYGC2UDA
    EKINGLUX(亿晶源)
    SMD-4P,3.2x2.7mm
    发光二极管/LED 红色,黄绿色 SMD-4P,3.2x2.7mm 620nm~630nm,570nm~575nm 150mcd,70mcd
E6C1209RYGC2UDA 数据手册
3.2*2.7*1.1mm SMD CHIP LED E6C1209RYGC2UDA LIGHT EMITTING DIODE SPECIFICATION DESCRIPTION: E6C1209RYGC2UDA REVISION: V2.2 ISSUE DATE: 2022-03-03 Contains trade secret information which is the property of Ekinglux and shall not be made available to, or copied or used by anyone outside Ekinglux without its written authorization. Copyright © 2017 Ekinglux Optoelectronics Technology Co., Ltd. All rights reserved www.ekingluxs.com Tel:021-59909181 021-59909182 1 Sales@ekingluxs.com 3.2*2.7*1.1mm SMD CHIP LED E6C1209RYGC2UDA Features: ●Long operating life ●Low Power Consumption ●Wide Viewing Angle ●Low voltage DC operated ●RoHS Compliant Application: ●Backlight ●Decoration lighting ●motormeter ●Indicator Part Number E6C1209RYGC2UDA Dice Material AlGaInP- AlGaInP Emitted Color Red-Yellow Green Lens Color Water Clear or Diffused Electro-Optical Characteristics(Ta=25℃, @20mA) Parameter Luminous Intensity Radiation Bandwidth Forward Voltage Dominant Wavelength Viewing Angle Reverse Current Color ■ ■ ■ ■ ■ ■ ■ ■ - Symbol Min. 70 30 1.90 1.90 620 570 - IV △λ VF λd 2θ1/2 IR Typ. 100 40 15 30 2.00 2.00 625 572 120 - Max. 150 70 2.40 2.40 630 575 10 Unit mcd nm v nm deg uA Absolute Maximum Ratings(Ta=25℃) Parameter Peak Forward Current(1/10 Duty Cycle, 0.1ms Pulse Width) Forward Current Reverse Voltage Electrostatic Discharge Operating Temperature Range Storage Temperature Range Reflow Soldering www.ekingluxs.com Tel:021-59909181 Symbol IFP IF VR ESD Topr Tstg Tsld 021-59909182 2 Max. Unit 100 mA 20 mA 5 v 2000 v o -40to+90 C o -40to+90 C 260℃for 10secs Sales@ekingluxs.com 3.2*2.7*1.1mm SMD CHIP LED E6C1209RYGC2UDA Optical & Electrical Characteristics Relative Intensity vs.Wavelength 100% Relative lntensity(%) Ta=25°c 80% 60% 40% 20% 0% 350 400 450 500 550 600 650 Wavelength (nm) Permissible Forward Current(mA) 50 Forward Current(mA) Ta=25°c 40 30 20 10 1.6 2.0 2.4 2.8 3.2 Forward Voltage(V) 3.6 Relative lntensity vs.Forward Currenr 50 40 30 20 10 0 20 40 60 80 100 Ambient Temperature(°c) 1.2 1.0 Relative lntensity Relative lntensity 0 Relative lntensity vs.Ambient Temperature Ta=25°c 3.0 2.5 2.0 1.5 1.0 0 800 60 3.5 0 750 Forward Current vs.Ambient Temperature Forward Current vs.Forward Voltage 0 700 0.8 0.6 0.4 0.2 20 40 60 80 Forward Current(mA) 0 100 -20° -30° -40° Radiation Pattern -10° 0° 10° Ta=25°c 0 20 40 60 80 100 Ambient Temperature(°c) 20° 30° 40° 50° -50° -60° 60° -70° 70° 80° -80° -90° 1.0 www.ekingluxs.com 0.5 0 Tel:021-59909181 0.5 021-59909182 3 90° 1.0 Sales@ekingluxs.com 3.2*2.7*1.1mm SMD CHIP LED E6C1209RYGC2UDA Reliability Test Items And Conditions Test Items Reference Thermal Shock Test Conditions Time -40℃(30min) 100 -100℃(30min) Cycles -10℃~65℃; 10cycles 0%~90%RH MIL-STD-202G Temperature And Humidity Cyclic High Temperature Storage Low Temperature Storage High Temperature High Humidity Storage High Temperature Life Test JEITA ED-4701 200 203 JEITA ED -4071 200 201 JEITA ED -4071 200 202 JEITA ED -4071 100 103 JESD22-A108D Life Test Resistance to Sodering Heat GB/T 4937,Ⅱ, 2.2&2.3 Criterion 22 0/22 22 0/22 Ta=100℃ 1000H 22 0/22 Ta=-40℃ 1000H 22 0/22 1000H 22 0/22 1000H 22 0/22 1000H 22 0/22 2 times 22 0/22 Ta=60℃; RH=90% Ta=80℃ Ta=25℃ IF=5mA Tsol*=(240±5) ℃10secs JESD22-A108D Quantity Criteria For Judging Damage Test Items Forward Voltage Recerse Current Symbol VF IR Test Conditions IF=IFT VR=5V Luminous Intensity IV IF=IFT Resistance to Soldering Heat - - www.ekingluxs.com Criteria For Judging Damage Initial Data±10% IR≤10uA Average IV degradation≤30%;Single LED IV degradation≤50% Meterial without internal cracks,no meterial between stripped,no deaded light Tel:021-59909181 021-59909182 4 Sales@ekingluxs.com 3.2*2.7*1.1mm SMD CHIP LED E6C1209RYGC2UDA Product size (Unit:mm) A08 NOTES: 1. All dimensions are in millimeters (inches) 2. Tolerances are 0.2mm (0.008inch) unless otherwise noted Recommended Soldering Pad Design (Unit:mm) Taping and package Spec ●Tape Specification:3,000pcs Per Reel www.ekingluxs.com Tel:021-59909181 021-59909182 5 Sales@ekingluxs.com 3.2*2.7*1.1mm SMD CHIP LED E6C1209RYGC2UDA Packaging LabelStyle www.ekingluxs.com Tel:021-59909181 021-59909182 6 Sales@ekingluxs.com 3.2*2.7*1.1mm SMD CHIP LED E6C1209RYGC2UDA Table of Classification Reflow Profiles Profile Feature Sn-Pb Eutectic Assembly Pb-Free Assembly 100 °C 150 °C 150°C 60-120 seconds 200 °C 60-120 seconds 3 °C/second max 3 °C/second max Liquidous temperature (TL) Time at liquidous (tL) 183 °C 60-150 seconds 217 °C 60-150 seconds Peak package body temperature (Tp)* 230 °C ~235 °C 255 °C ~260 °C 235 °C 260 °C 20 seconds 30 seconds 6 °C/second max 6 °C/second max 6 minutes max 8 minutes max Preheat & Soak Temperature min (Tsmin) Temperature max (Tsmax) Time (Tsmin to Tsmax) (ts) Average ramp-up rate (Tsmax to Tp) Classification temperature (Tc) Time (tp) within 5 °C of the specified Classification temperature (Tc) Average ramp-down rate (Tp to Tsmax) Time 25 °C to peak temperature 1. Tolerance for peak profile temperature (Tp) is defined as a supplier minimum and a user maximum. 2.Tolerance for time at peak profile temperature (tp) is defined as a supplier minimum and a user maximum. www.ekingluxs.com Tel:021-59909181 021-59909182 7 Sales@ekingluxs.com 3.2*2.7*1.1mm SMD CHIP LED E6C1209RYGC2UDA Precautions 1. Storage: ●Moisture proof and anti-electrostatic package with moisture absorbent material is used, to keep moisture to aminimum. ●Before opening the package, the product should be kept at 30℃ or less and humidity less than 60% RH, and beused within a year. ●After opening the package, the product should be stored at 30℃ or less and humidity less than 10%RH. It is recommended that the product be operated at the workshop condition of 30℃ or less and humidity less than 60%RH. ●If the moisture absorbent material has fade away or the LEDs have exceeded the storage time, baking treatment should be performed based on the following condition: (70±5)℃ for 24 hours. 2. Static Electricity: Static electricity or surge voltage damages the LEDs. Damaged LEDs will show some unusual characteristic such as the forward voltage becomes lower, or the LEDs do not light at the low current. even not light. All devices, equipment and machinery must be properly grounded. At the same time, it is recommended that wrist bands or anti-electrostatic gloves, anti-electrostatic containers be used when dealing with the LEDs. 3. Vulcanization: LED curing is due to sulfur being in bracket and the +1 price of silver in the chemical reaction generated Ag2S in the process. It will lead to the capacity of reflecting of silver layer reducing, light color temperature drift and serious decline ,seriously affecting the performance of the product.So we should take corresponding measures to avioding vulcanization, such as to avoid using sulphur volatile substances and keeping away from high sulphur content of the material. www.ekingluxs.com Tel:021-59909181 021-59909182 8 Sales@ekingluxs.com
E6C1209RYGC2UDA
物料型号:E6C1209RYGC2UDA
器件简介: - 产品名称:3.22.71.1mm SMD CHIP LED - 特点:长寿命、低功耗、宽视角、低电压直流操作、符合RoHS标准 - 应用:背光、装饰照明、电机表、指示器
引脚分配:文档中未明确提供引脚分配信息,但通常SMD LED会有正负极引脚。
参数特性: - 发光强度:最小70 mcd,典型值100 mcd,最大150 mcd - 发光波长:红光620-630 nm,绿光570-575 nm - 正向电压:1.90-2.40 V - 反向电流:最大10 uA - 视角:120° - 绝对最大额定值:正向电流100 mA(1/10占空比,0.1ms脉宽),反向电压5 V,静电放电2000 V
功能详解: - 电光特性:在25℃,20mA条件下的发光强度、辐射带宽、正向电压、占空波长和视角等参数 - 光学与电气特性:相对强度与波长的关系,正向电流与正向电压的关系,环境温度对发光强度的影响
应用信息: - 可靠性测试项目和条件:包括热冲击、温度湿度循环、高温存储、低温存储、高温高湿存储、高温寿命测试、寿命测试、耐焊接热测试 - 损坏判断标准:包括正向电压、反向电流、发光强度、耐焊接热等
封装信息: - 产品尺寸:3.2 x 2.7 x 1.1 mm - 推荐焊接垫设计 - 胶带规格:每卷3000颗 - 包装:标签、屏蔽袋、标签样式
回流焊接曲线: - Sn-Pb共晶组装和无铅组装的预热、最高温度、时间等参数
注意事项: - 存储:防潮防静电包装,使用吸湿材料,开封后建议在30℃以下、湿度小于10%RH的条件下存储 - 静电:所有设备、设备和机械必须正确接地,处理LED时建议使用腕带或防静电手套、防静电容器 - 硫化:避免使用含硫挥发性物质,远离含硫量高的材料
E6C1209RYGC2UDA 价格&库存
很抱歉,暂时无法提供与“E6C1209RYGC2UDA”相匹配的价格&库存,您可以联系我们找货
