PNT723T503E0-2
High EB High DC gain Ultra-Small package switch transistor
Feature
This device is Pb-Free, Halogen Free/BFR Free and RoHS compliant.
¾
Package: SOT-723
¾
Emitter -Base Breakdown Voltage 11V
¾
High DC current gain typical 380
¾
Low Saturation Voltage 80mv
¾
0.15 continuous collector current
¾
NPN switch
3 - Collector
1 - Base
2 - Emitter
transistor
Mechanical Characteristics
¾
Lead finish:100% matte Sn(Tin)
¾
Mounting position: Any
¾
Qualified max reflow temperature:260℃
¾
Device meets MSL 1 requirements
¾
Pure tin plating: 7 ~ 17 um
¾
Pin flatness:≤3mil
Electrical characteristics per line@25℃( unless otherwise specified)
Parameter
Symbol
Value
Units
Collector-Emitter Breakdown Voltage
V (BR)CEO
50
V
Collector-Base Breakdown Voltage
V (BR)CBO
80
V
V (BR)EBO
11
V
IC
0.15
A
Total Dissipation @25°C
Ptot
0.15
W
Storage Temperature
Tstg
-65~150
°C
Tj
150
°C
Collector Current
Max. Operating Junction Temperature
Rev.06.2
1
www.prisemi.com
PNT723T503E0-2
Absolute maximum rating@25℃
Parameter
Symbol
Conditions
Min.
BVCBO
IC=50uA
80
V
BVCEO
IC=1mA
50
V
Emitter-Base Breakdown Voltage
BVEBO
IE=50uA
Collector Cut-off Current (IE=0)
ICBO
VCB=60V
0.1
μA
Emitter Cut-off Current(IC=0)
IEBO
VEB=7V
0.1
μA
DC Current Gain
hFE
IC=1mA,VCE=6V
250
560
VCE(sat)
IC=50mA,IB=5mA
Transition frequency
fT
Output Capacitance
Cob
Collector-Emitter Saturation Voltage
Typ.
Max.
11
Units
V
0.08
V
VCE=12V,IE=-2mA,f=100MHz
200
MHz
VCE=12V,IE=0mA,f=1MHz
2
3.5
pF
Typical Characteristics
hFE
% Of Rated Power
100
100
80
60
40
0.01
0.1
1
25
50
75
100
125
150
Ambient Temperature - TA (°C)
VCE=1V
Fig1.DC Current Gain
Fig2. Power Derating Curve
VCE(SAT)
VBE(SAT)
0.9
0.8
0.1
0.7
0.6
0.01
0.01
0.1
1
hFE=100
0.01
10
1
10
IC(A)
hFE=100
IC(A)
Fig 3.Collector-Emitter Saturation Voltage
Rev.06.2
0.1
Fig4. Base-Emitter Saturation Voltage
2
www.prisemi.com
T(ns)
PNT723T503E0-2
T(ns)
500
500
hFE=50
td
400
Tp=40us
hFE=50
Tp=40us
400
ts
300
300
tr
200
200
tf
100
100
1.0
1.5
2.0
2.5
1.0
IC(A)
hFE=100
2.0
1.5
3.0
IC(A)
2.5
hFE=100
Fig 5.Switching Times Resistive Load
Fig6. Switching Times Resistive Load
Solder Reflow Recommendation
Peak Temp=257℃, Ramp Rate=0.802deg. ℃/sec
280
240
200
160
120
80
40
60
90
120
150
180
240
210
270
300
330
360
390
420
450
480
Time (sec)
Rev.06.2
3
www.prisemi.com
PNT723T503E0-2
Product dimension (SOT-723)
(0.11)
Side View
0.437±0.013
R0.1-R0.15
9°(4x)
1.2±0.03
(0.4)
(2)
(3)
(1)
Unit:mm
(0.2)
Bottom View
1.2±0.025
0.8±0.025
0.6
0.6
0.6
0.65
0.4
0.8
1
Unit:mm
Device
Package
Shipping
PNT723T503E0-2
SOT-723 (Pb-Free)
10000 / Tape & Reel
Ordering information
Rev.06.2
4
www.prisemi.com
PNT723T503E0-2
IMPORTANT NOTICE
and
are registered trademarks of Prisemi Electronics Co., Ltd (Prisemi) ,Prisemi
reserves the right to make changes without further notice to any products herein. Prisemi makes
no warranty, representation or guarantee regarding the suitability of its products for any particular
purpose, nor does Prisemi assume any liability arising out of the application or use of any
product or circuit, and specifically disclaims any and all liability, including without limitation
special, consequential or incidental damages. “Typical” parameters which may be provided in
Prisemi data sheets and/or specifications can and do vary in different applications and actual
performance may vary over time. All operating parameters, including “Typicals” must be
validated for each customer application by customer’s technical experts. Prisemi does not
convey any license under its patent rights nor the rights of others. The products listed in this
document are designed to be used with ordinary electronic equipment or devices, Should you
intend to use these products with equipment or devices which require an extremely high level of
reliability and the malfunction of with would directly endanger human life (such as medical
instruments, aerospace machinery, nuclear-reactor controllers, fuel controllers and other safety
devices), please be sure to consult with our sales representative in advance.
Website: http://www.prisemi.com
For additional information, please contact your local Sales Representative.
©Copyright 2009, Prisemi Electronics
is a registered trademark of Prisemi Electronics.
All rights are reserved.
Rev.06.2
5
www.prisemi.com
很抱歉,暂时无法提供与“PNT723T503E0-2”相匹配的价格&库存,您可以联系我们找货
