SD103AWS-SD103CWS
SCHOTTKY DIODES
SOD-323
FEATURES
Low forward voltage drop
Guard ring construction for transient protection
Negligible reverse recovery time
low reverse capacitance
1.35(0.053)
1.15(0.045)
2.75(0.108)
1.80(0.071)
2.30(0.091)
1.60(0.063)
MECHANICAL DATA
0.4(0.016)
Case: Molded plastic body
Terminals: Plated leads solderable per MIL-STD-750,
Method 2026
Polarity: Polarity symbols marked on case
Mounting Position: Any
Marking: SD103AWS:S4, SD103BWS:S5, SD103CWS:S6
.25(0.010)
.177(.007)
1.00(.040)
.089(.003)
0.80(.031)
.08(.003)
MIN
Dimensions in millimeters and (inches)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Maximum ratings and electrical characteristics, Single diode @TA=25
PARAMETER
SYMBOLS
SD103AWS
SD103BWS
SD103CWS
UNITS
Peak repetitive peak reverse voltage
Working peak reverse voltage
DC Blocking voltage
RMS Reverse voltage
Forward continuous current
Repetitive peak forward current @t 1.0s
Power dissipation
Thermal resistance junction to ambient
Storage temperature
VRRM
VRMS
VDC
40
30
VOLTS
VR(RMS)
28
21
350
1.5
200
300
-65 to +125
14
IFM
IFRM
Pd
RΘJA
TSTG
V
mA
A
mW
/W
Electrical ratings @TA=25
PARAMETER
Reverse breakdown voltage
SYMBOLS
SD103AWS
SD103BWS
SD103CWS
Fowrard voltage
SD103AWS
SD103BWS
SD103CWS
Capacitance between terminals
Reverse recovery time
V(BR)R
Min.
Typ.
Max.
40
30
Unit
V
VF
0.37
0.60
V
IRM
5.0
uA
Reverse current
DN:S12G05A0
CT
trr
50
10
pF
ns
Conditions
IR=10uA
IR=10uA
IR=10uA
IF=20mA
IF=200mA
VR=30V
VR=20V
VR=10V
VR=0V,f=1.0MHz
IF=IR=200mA
Irr=0.1XIR,RL=100
STAR SEA
RATINGS AND CHARACTERISTIC CURVES SD103AWS-SD103CWS
FIG. 1- TYPICAL FORWARD CHARACTERISTICS
FIG. 2-TYP. JUNCTION CAPACITANCE
VS REVERSE VOLTAGE
100
100
CJ, CAPACITANCE(pF)
IF,FORWARD CURRENT(mA)
1000
10
1.0
1.0
0.1
0.01
0.1
VR REVERSE VOLTAGE(V)
DN:S12G05A0
10
1.0
40
STAR SEA
很抱歉,暂时无法提供与“SD103AWS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.19110
- 100+0.11840
- 800+0.07820
- 3000+0.05590
- 6000+0.05310
- 30000+0.04920
- 国内价格
- 50+0.11222
- 500+0.08824
- 3000+0.07107
