SD103AW
SD103AW
    STARSEA(星海)
    SOD-123
    丝印S4 电压:40V 电流:350MA
SD103AW 数据手册
SD103AW-SD103CW SCHTTKY DIODES SOD-123 FEATURES 1.80(.071) Low forward voltage drop Guard ring construction for transient protection Negligible reverse recovery time low reverse capacitance 1.40(.055) 3.86(0.152) 2.84(0.112) 3.56(0.145) 2.54(0.100) MECHANICAL DATA .71(0.028) Case: Molded plastic body Terminals: Plated leads solderable per MIL-STD-750, Method 2026 Polarity: Polarity symbols marked on case Mounting Position: Any Marking: SD103AW:S4, SD103BW:S5, SD103CW:S6 .50(0.020) .15(.006) 1.35(.053) MAX .94(.037) .25(.010) MIN Dimensions in millimeters and (inches) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Maximum ratings and electrical characteristics, Single diode @TA=25C PARAMETER SYMBOLS SD103AW SD103BW SD103CW UNITS Peak repetitive peak reverse voltage Working peak reverse voltage DC Blocking voltage RMS Reverse voltage Forward continuous current Repetitive peak forward current @t 1.0s Power dissipation Thermal resistance junction to ambient Storage temperature VRRM VRWM VDC 40 30 20 VOLTS VR(RMS) 28 21 350 1.5 400 300 -65 to +125 14 IFM IFRM Pd RΘJA TSTG V mA A mW C/W C Electrical ratings @TA=25 C PARAMETER Reverse breakdown voltage SYMBOLS SD103AW SD103BW SD103CW Fowrard voltage Reverse current Capacitance between terminals Reverse recovery time DN:S11G08A0 SD103AW SD103BW SD103CW V(BR)R Min. Typ. Max. 40 30 20 Unit V VF 0.37 0.60 V IRM 5.0 uA CT trr 50 10 pF ns Conditions IR=100uA IR=100uA IR=100uA IF=20mA IF=200mA VR=30V VR=20V VR=10V VR=0V,f=1.0MHz IF=IR=200mA Irr=0.1XIR,RL=100 STAR SEA RATINGS AND CHARACTERISTIC CURVES SD103AW-SD103CW FIG. 1- TYPICAL FORWARD CHARACTERISTICS FIG. 2-TYP. JUNCTION CAPACITANCE VS REVERSE VOLTAGE 100 100 CJ, CAPACITANCE(pF) IF,FORWARD CURRENT(mA) 1000 10 1.0 1.0 0.1 0.01 0.1 0 0.5 VF, FORWARD VOLTAGE(V) DN:S11G08A0 10 1.0 0 10 20 30 40 VR REVERSE VOLTAGE.(V) STAR SEA
SD103AW
- 物料型号:SD103AW、SD103BW、SD103CW - 器件简介:这些是肖特基二极管,具有低正向电压降、保护瞬态的护环结构、可忽略的反向恢复时间和低反向电容。 - 引脚分配:文档中未明确说明具体的引脚分配,但提到了极性符号标记在封装上。 - 参数特性:包括最大重复峰值反向电压、工作峰值反向电压、直流阻断电压、RMS反向电压、正向连续电流、重复峰值正向电流、功率耗散、结到环境的热阻和存储温度等。 - 功能详解:文档提供了正向特性图和典型结电容图,展示了不同反向电压下的正向电流和正向电压关系,以及在特定条件下的结电容。 - 应用信息:文档中没有明确提到应用信息。 - 封装信息:封装为模塑塑料体,引脚为可焊的镀层引线,符合MIL-STD-750, Method 2026标准。
SD103AW 价格&库存
很抱歉,暂时无法提供与“SD103AW”相匹配的价格&库存,您可以联系我们找货
