R317580000
R317580000
    RADIALL
    R317580000
R317580000 数据手册
Technical Data Sheet BULKHEAD SEAL RECEPTACLE - PAGE 1/2 ISSUE 31-05-21H SERIES SHV PART NUMBER R317580000 All dimensions are in mm. Tolerances according ISO 2768 m-H . pn . ao COMPONENTS Body Center contact Outer contact Insulator Gasket Others parts - MATERIALS BRASS BRASS PTFE SILICONE RUBBER BRASS - PLATING (m) NICKEL GOLD OVER NICKEL - NICKEL - This document contains proprietary information and such information shall not be disclosed to any third party for any purpose whatsoever or used for manufacturing purposes without prior written agreement from Radiall. The data defined in this document are given as an indication, in the effort to improve our products; we reserve the right to make any changes judged necessary. Technical Data Sheet BULKHEAD SEAL RECEPTACLE - PAGE 2/2 SERIES SHV ISSUE 31-05-21H PART NUMBER R317580000 PACKAGING Standard 1 Unit - Other Contact us ELECTRICAL CHARACTERISTICS Impedance Frequency 1.2 + VSWR Insertion loss RF leakage -( Voltage rating Dielectric withstanding voltage Insulation resistance 50 0-2 0,3000 NA NA * 10000 5000  GHz x F(GHz) Maxi F(GHz) dB Maxi - F(GHz)) dB Maxi Veff Maxi Veff mini M mini ENVIRONMENTAL Operating temperature Hermetic seal Panel leakage -65/+165 NA NA °C Atm.cm3/s MECHANICAL CHARACTERISTICS SPECIFICATION Center contact retention Axial force – Mating End Axial force – Opposite end Torque Recommended torque Mating Panel nut Mating life Nominal Weight (Add +15% for max weight) 27 27 NA NA 250 500 20,0000 N mini N mini N.cm mini OTHER CHARACTERISTICS N.cm N.cm Cycles mini g Assembly instruction: Others: *6000 V eff (DC) *3500 V rms (AC) This document contains proprietary information and such information shall not be disclosed to any third party for any purpose whatsoever or used for manufacturing purposes without prior written agreement from Radiall. The data defined in this document are given as an indication, in the effort to improve our products; we reserve the right to make any changes judged necessary.
R317580000 价格&库存
很抱歉,暂时无法提供与“R317580000”相匹配的价格&库存,您可以联系我们找货
R317580000
    R317580000
      R317580000
        • 1+172.81858
        • 10+169.17727
        • 50+164.55376
        • 100+160.26564
        • 250+156.58839
        库存:735
