TRC090
TRC090
    TLC(竞沃)
    径向
    PTC自恢复保险丝 FUSE_D11.7X3.1MM_TM 60/72V 900mA
TRC090 数据手册
Revision: A Date: 2018-04-24 Page No.: 1 OF 1 PPTC RESETTALBE 电路保护元器件专业制造商 FUSES TRC(60/72V) Series Features ◆ Radial Leaded Devices ◆ Cured, flame retardant epoxy polymer insulating material meets UL 94V-0 requirements ◆ Bulk Package, or tape and reel available on most models ◆ UL(Pending), C-UL(Pending), TUV(R50322003) ◆ RoHS, Reach, HF compliance Applications Almost anywhere there is a low voltage power supply, up to 60V and a load to be protected, including: ◆ Personal computer ◆ Toys ◆ Industrial controls 电气特性 : 保持电流 跳脱电流 最大电压 最大电流 最大动作时间 消耗功率 电阻范围(Ω) P/N IH, (A) IT, (A) V max, (V) I max, (A) (A) (Sec.) Pd typ, (W) R min, R max, R1max, TRC005 0.05 0.15 60 40 0.25 5.0 0.22 7.30 11.10 25.00 TRC010 0.10 0.20 60 40 0.50 4.0 0.38 2.30 8.10 12.0 TRC017 0.17 0.34 60/72 40 0.85 3.0 0.48 2.00 5.21 8.00 TRC020 0.20 0.40 60/72 40 1.00 2.2 0.40 1.30 2.84 4.50 TRC025 0.25 0.50 60/72 40 1.25 2.5 0.45 0.90 1.95 3.00 TRC030 0.30 0.60 60/72 40 1.50 3.0 0.50 0.70 1.36 2.10 TRC040 0.40 0.80 60/72 40 2.00 3.8 0.55 0.48 0.95 1.40 TRC050 0.50 1.00 60/72 40 2.50 4.0 0.75 0.38 0.78 1.20 TRC065 0.65 1.30 60/72 40 3.25 5.3 0.90 0.24 0.54 0.74 TRC075 0.75 1.50 60/72 40 3.75 6.3 0.90 0.23 0.45 0.62 TRC090 0.90 1.80 60/72 40 4.50 7.2 1.00 0.14 0.31 0.49 TRC110 1.10 2.20 60/72 40 5.50 8.2 1.50 0.15 0.25 0.40 TRC135 1.35 2.70 60/72 40 6.75 9.6 1.70 0.12 0.19 0.32 TRC160 1.60 3.20 60/72 40 8.00 11.4 1.90 0.09 0.14 0.24 TRC185 1.85 3.70 60/72 40 9.25 12.6 2.10 0.08 0.12 0.21 TRC250 2.50 5.00 60/72 40 12.50 15.6 2.50 0.05 0.08 0.15 TRC300 3.00 6.00 60/72 40 15.00 19.8 2.80 0.04 0.06 0.12 TRC375 3.75 7.50 60/72 40 18.75 24.0 3.20 0.03 0.05 0.10 TRC500 5.0 10.0 60/72 40 25.0 24.0 3.2 0.02 0.05 0.100 TEL: 86-0769-3892 0554 FAX: 86-0769-8793 2077 E-mail:sales@tlcet.com.cn Address:No.18,5th GaoLi Road,TangXia Town,DongGuan,GuangDong,P.R China 523710 Revision: A Date: 2018-04-24 Page No.: 1 OF 2 PPTC RESETTALBE 电路保护元器件专业制造商 FUSES TRC(60/72V) Series 产品尺寸 (U nit: mm) : Manufacturer's Trademark C 110 XX C 090 XX Max. working voltage: A=16V B=30V C=60/72V E=90/120V F=250V G=600V M=265V X 090 Packaging Options: “ - ” Bulk package “ -T ” Tape & Reel XX Lot No Style1 Holding current:0.90A Style2 A B C D E 物理特性 P/N Max.(最大) Max.(最大) Typ.(标准) Min.(最小) Max.(最大) Style(样式) TRC005 7.4 12.7 5.1 7.6 3.1 1 0.50 CP TRC010 7.4 12.7 5.1 7.6 3.1 1 0.50 CP TRC017 7.4 12.7 5.1 7.6 3.1 1 0.50 CP TRC020 7.4 12.7 5.1 7.6 3.1 1 0.50 CP LeadΦmm Material(材料) TRC025 7.4 12.7 5.1 7.6 3.1 1 0.50 CP TRC030 7.4 13.4 5.1 7.6 3.1 1 0.50 CP TRC040 9.7 14.5 5.1 7.6 3.1 1 0.50 CP TRC050 9.7 15.2 5.1 7.6 3.1 1 0.60 Cu TRC065 9.7 15.2 5.1 7.6 3.1 1 0.60 Cu TRC075 10.4 16.0 5.1 7.6 3.1 1 0.60 Cu TRC090 11.7 16.7 5.1 7.6 3.1 1 0.60 Cu TRC110 13.0 18.0 5.1 7.6 3.1 2 0.80 Cu TRC135 14.5 19.6 5.1 7.6 3.1 2 0.80 Cu TRC160 16.3 21.3 5.1 7.6 3.1 2 0.80 Cu TRC185 17.8 22.9 5.1 7.6 3.1 2 0.80 Cu TRC250 21.3 26.4 10.2 7.6 3.1 2 0.80 Cu TRC300 24.9 30.0 10.2 7.6 3.1 2 0.80 Cu TRC375 28.4 33.5 10.2 7.6 3.1 2 0.80 Cu TRC500 28.4 33.5 10.2 7.6 3.1 2 0.80 Cu E-mail:sales@tlcet.com.cn TEL: 86-0769-3892 0554 FAX: 86-0769-8793 2077 Address:No.18,5th GaoLi Road,TangXia Town,DongGuan,GuangDong,P.R China 523710 PPTC RESETTALBE 电路保护元器件专业制造商 FUSES Revision: A Date: 2018-04-24 Page No.: 1 OF 3 TRC(60/72V) Series 环境温度与工作电流关系特性曲线 : 工作环境温度 P/N -40℃ -20℃ 0℃ 25℃ 40℃ 50℃ 60℃ 70℃ 85℃ TRC005 0.08 0.07 0.06 0.05 0.04 0.04 0.03 0.03 0.02 TRC010 0.16 0.14 0.12 0.10 0.08 0.07 0.06 0.05 0.04 TRC017 0.26 0.23 0.20 0.17 0.14 0.12 0.11 0.09 0.07 TRC020 0.31 0.27 0.24 0.20 0.16 0.14 0.13 0.11 0.08 TRC025 0.39 0.34 0.30 0.25 0.20 0.18 0.16 0.14 0.10 TRC030 0.47 0.41 0.36 0.30 0.24 0.22 0.19 0.16 0.12 TRC040 0.62 0.54 0.48 0.40 0.32 0.29 0.25 0.22 0.16 TRC050 0.78 0.68 0.60 0.50 0.41 0.36 0.32 0.27 0.20 TRC065 1.01 0.88 0.77 0.65 0.53 0.47 0.41 0.35 0.26 TRC075 1.16 1.02 0.89 0.75 0.61 0.54 0.47 0.41 0.30 TRC090 1.40 1.22 1.07 0.90 0.73 0.65 0.57 0.49 0.36 TRC110 1.71 1.50 1.31 1.10 0.89 0.79 0.69 0.59 0.44 TRC135 2.09 1.84 1.61 1.35 1.09 0.97 0.85 0.73 0.54 TRC160 2.48 2.18 1.90 1.60 1.30 1.15 1.01 0.86 0.64 TRC185 2.87 2.52 2.20 1.85 1.50 1.33 1.17 1.00 0.74 TRC250 3.88 3.40 2.98 2.50 2.03 1.80 1.58 1.35 1.00 TRC300 4.65 4.08 3.57 3.00 2.43 2.16 1.89 1.62 1.20 TRC375 5.81 5.10 4.46 3.75 3.04 2.70 2.36 2.03 1.50 TRC500 7.75 6.80 5.95 5.00 4.05 3.60 3.15 2.71 2.00 动作电流时间曲线表 : B C D E F G H I J K L MNO P Q R 1000 Time-to-trip(S) A=TRC005 B=TRC010 C=TRC017 D=TRC020 E=TRC025 F=TRC030 G=TRC040 H=TRC050 I=TRC065 J=TRC075 K=TRC090 L=TRC110 M=TRC135 N=TRC160 O=TRC185 P=TRC250 Q=TRC300 R=TRC375 100 10 A 1 0.1 0.01 0.001 0.1 1 10 100 Fault current(A) E-mail:sales@tlcet.com.cn TEL: 86-0769-3892 0554 FAX: 86-0769-8793 2077 Address:No.18,5th GaoLi Road,TangXia Town,DongGuan,GuangDong,P.R China 523710 PPTC RESETTALBE FUSES TLS/ 电路保护元器件专业制造商 Revision: A Date: 2018-04-24 Page No.: 1 OF 4 TRC(60/72V) Series 标准包装数量 : Model Q’t y/bag TRC005-TRC090 1000pcs TRC110-TRC185 500pcs TRC250-TRC500 200pcs Tape and Reel Specifications Devices taped using EIA468–B/IEC286-2 standards. 6、Agency Recognition: Caution:Operation beyond the rated voltage or current may result in rupture electrical arcing or flame.Specifications are subject to change without notice. E-mail:sales@tlcet.com.cn TEL: 86-0769-3892 0554 FAX: 86-0769-8793 2077 Address:No.18,5th GaoLi Road,TangXia Town,DongGuan,GuangDong,P.R China 523710
TRC090
1. 物料型号:文档中列出了多个型号,例如TRC005, TRC010, TRC017等,直到TRC500。
2. 器件简介:文档描述了一种PPTC RESETTALBE FUSES,即正温度系数(PTC)复位保险丝,它们是电路保护元器件。
3. 引脚分配:文档中没有明确提到具体的引脚分配,但提到了径向引线装置。
4. 参数特性: - 保持电流(Ihold)和跳脱电流(Ir):每个型号都有特定的保持电流和跳脱电流值。 - 最大电压(Vmax):大多数型号的最大电压为60V,部分型号为60/72V。 - 最大电流(Imax):所有型号的最大电流为40A。 - 最大动作时间:不同型号的动作时间不同,从0.25秒到25秒不等。 - 消耗功率(Pd)和电阻范围:每种型号都有对应的消耗功率和电阻范围。
5. 功能详解:文档中提到了这些保险丝适用于低电压电源保护,包括个人电脑、玩具、工业控制等。
6. 应用信息:适用于几乎所有低电压电源,最高可达60V,并需要保护负载的场合。
7. 封装信息:提供了产品尺寸和样式,以及包装选项,如散装、带卷装等。
TRC090 价格&库存
很抱歉,暂时无法提供与“TRC090”相匹配的价格&库存,您可以联系我们找货
TRC090
  • 5+0.49343
库存:40
