MXD8621C
SPDT Switch for 3G/4G Application
VED
APPRO
This document contains information that is confidential and proprietary to Maxscend Microelectronics
Company Limited (Maxscend) and may not be reproduced in any form without express written consent of
Maxscend. No transfer or licensing of technology is implied by this document.
Page 1 of 6
Maxscend Microelectronics Company Limited. All rights reserved.
Maxscend Confidential
MXD8621C – SPDT Switch for 3G/4G Application
General Description
Applications
The MXD8621C is a Single-Pole, Double-Throw
(SPDT)
LTE/WCDMA/GSM
receive
GSM/WCDMA/LTE receive
switch.
Switching is controlled by an integrated GPIO
Features
interface with a single control pin.
Broadband frequency range: 0.1 to 3.0 GHz
Low insertion loss: 0.45 dB @ 2.7 GHz
High isolation: 25 dB up to 2.7 GHz
P0.1dB 29dBm
No external DC blocking capacitors required
Single GPIO control line with VDD voltage
No external DC blocking capacitors are required
as long as no DC voltage is applied on any RF
path.
The MXD8621C is provided in a compact 1.1mm x
regulator:
0.7mm x 0.45mm 6-lead DFN package that meets
VCTL= 1.6 to 3.00 V
requirements for board-level assembly.
VDD= 2.5 to 3.00 V
A
functional
block
diagram
and
the
pin
Small, 6-Lead DFN, 400 um pitch (1.1mm x
0.7mmx 0.45 mm) package
configuration are shown in Figure 1.
Functional Block Diagram and Pin Function
RF1
1
RF2
6
V1
2
GND
5
ANT
3
RF1
4
VDD
ANT
RF2
Logic and Supply
VDD
V1
Figure 1 Functional Block Diagram and Pin-out (Top View)
Page 2 of 6
Application Circuit
VDD
4
VDD
C1
100pF
3
RF1
RF1
5 MXD
2
8621C
ANT
GND
RFIN
6
V1
V1
1
RF2
RF2
C2
100pF
Figure 2 MXD8621C Application Circuit
Table 1. Pin Description
Pin No.
Name
Description
1
2
3
RF2
GND
RF1
RF I/O. Throw 1 of the switch.
Ground
RF I/O. Throw 2 of the switch.
Pin No.
6
5
4
Name
V1
ANT
VDD
Description
Digital
Antenna
Supply
Truth Table
Table 2.
State
Active Path
ANT to RF1
ANT to RF2
V1
Note: “1” = 1.6 V to 3.00 V. “0” = 0 V to +0.3 V.
Recommended Operation Range
Table 3.
Parameters
Operation Frequency
Power supply
Switch Control Voltage High
Switch Control Voltage Low
Symbol
Min
Typ
Max
f1
0.1
2.5
1.6
1.8
3.0
3.0
0.3
VDD
VCTL_H
VCTL_L
Units
GHz
V
V
V
Page 3 of 6
Specifications
Table 4.Electrical Specifications
Parameter
Specification
Min.
Typical
Max.
Symbol
Units
Test Condition
DC Specifications
Supply voltage
Control voltage:
Low
High
Current on V1 pin
Supply current
VDD
2.5
2.8
3.0
V
VCTL_L
VCTL_H
ICTL
IDD
+0.3
+3.0
5
60
V
V
μA
μA
10
μs
2
μs
mVpp
0.40
0.45
0.50
dB
dB
dB
dB
dB
dB
700 to 960 MHz
1710 to 2170 MHz
2170 to 2690 MHz
700 to 960 MHz
1710 to 2170 MHz
2170 to 2690 MHz
dB
700 to 2690 MHz
DC supply turnon/turn-off time
ton
RF path switching
time
tsw
Supply ripple
VPP
0.5
VDD= 2.8 V, V1 = VCTL_H
Measured from 50% of final VDD
supply voltage to 90% of final RF
power
From one active state to another
active state transition, measured
from 50% of final control voltage to
90% of final RF power
RF Specifications
Insertion loss (RF1 or
RF2 to ANT pin)
IL
Isolation (ANT to RF1
or RF2)
ISO
32
27
22
0.25
0.28
0.35
35
30
25
RL
15
Input return loss (ANT
to RF1 or RF2)
Voltage Standing
Wave Ratio, all ports
0.1dB compression
point (from antenna
to RF1 and RF2)
2nd Harmonic (ANT
to RF1 or RF2)
3rd Harmonic (ANT to
RF1 or RF2)
Referenced to 50 Ω,
700 to 2690 MHz
29
dBm
Tested at 950 MHz
2fo
-85
dBm
3fo
-83
dBm
VSWR
1.25:1
28
1.5:1
fo = 700 to 2700 MHz, PIN = +10
dBm
Absolute Maximum Ratings
Table 5. Maximum ratings
Parameters
Symbol
Minimum
Maximum
Units
Supply voltage
Digital control voltage
RF input power
Operating temperature
VDD
VCTL
PIN
TOP
+2.5
V
V
dBm
–30
+3.3
+3.0
+29
+85
Storage temperature
TSTG
–55
+150
Electrostatic Discharge
Human body model
(HBM), Class 1C
Machine Model (MM),
Class A
Charged device model
(CDM), Class III
ESD_HBM
1000
ESD_MM
100
ESD_CDM
500
V
Note: Exposure to maximum rating conditions for extended periods may reduce device reliability. There is no damage to device with
only one parameter set at the limit and all other parameters set at or below their nominal value. Exceeding any of the limits listed
here may result in permanent damage to the device.
Page 4 of 6
Package Outline Dimension
aaa
A
D
C
B
bbb C
E
ccc
0.200
e
A2
C
C
aaa C
TOP VIEW
A3
A
SIDE VIEW
A1
PIN 1 ID.
0.050
0.200
A
A
AA
A
A
B
PIN1 ID
0.050
BOTTOM VIEW
0.123±0.05
0.123±0.05
B
eee
0.2±0.05
C B A
0.2±0.05
A
ddd
0.2±0.05
C B A
0.2±0.05
Figure 3. Package outline dimension
Page 5 of 6
Reflow Chart
tP
TP
Critical Zone
TL to TP
Ramp-up
Temperature
TL
TSmax
tL
TSmin
Ramp-down
tS
Preheat
t 25 ℃ to Peak
Time
Figure 4. Recommended Lead-Free Reflow Profile
Table 6.
Profile Parameter
Lead-Free Assembly, Convection, IR/Convection
Ramp-up rate(TSmax to Tp)
3℃/second max.
Preheat temperature(TSmin to TSmax)
150℃ to 200℃
Preheat time(ts)
60 - 180 seconds
Time above TL , 217℃(tL)
60 - 150 seconds
Peak temperature(Tp)
260℃
Time within 5℃ of peak temperature(tp)
20 - 40 seconds
Ramp-down rate
6℃/second max.
Time 25℃ to peak temperature
8 minutes max.
ESD Sensitivity
Integrated circuits are ESD sensitive and can be damaged by static electric charge. Proper ESD
protection techniques should be used when handling these devices.
RoHS Compliant
This product does not contain lead, mercury, cadmium, hexavalent chromium, polybrominated biphenyls
(PBB) and polybrominated diphenyl ethers (PBDE), and are considered RoHS compliant.
1.0.1
Page 6 of 6
很抱歉,暂时无法提供与“MXD8621C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.33416
- 100+0.26417
- 300+0.22918
- 1000+0.20294
- 6000+0.16654
