PESDHC2FD7VU
PESDHC2FD7VU
    PRISEMI(上海芯导电子)
    PESDHC2FD7VU静电放电(ESD)保护器专为替代便携式应用(如手机、笔记本电脑和个人数字助理 (PDA))中的多层压敏电阻 (MLV) 而设计。它们的特点是具有大截面积结,可传导高瞬态电流,与...
PESDHC2FD7VU 数据手册
PESDHC2FD7VU Uni-directional 7V High Capacitance ESD Protector Description The PESDHC2FD7VU ESD protector is designed to replace multilayer varistors (MLVs) in portable applications such as cell phones, notebook computers, and PDA’s. They feature large cross-sectional area junctions for conducting high transient currents, offer desirable electrical characteristics for board level protection, such as fast response time, lower operating voltage, lower clamping voltage and no device degradation when compared to MLVs. The PESDHC2FD7VU protects sensitive semiconductor components from damage or upset due to electrostatic discharge (ESD) and other voltage induced transient events. The PESDHC2FD7VU is available in DFN1006-2L(Bottom View) a DFN1006-2L package with working voltages of 7 volt. It gives designer the flexibility to protect one unidirectional line in applications where arrays are not practical. Additionally, it may be “sprinkled” around the board in applications where board space is at a premium. Feature  230W Peak pulse power per line (tP = 8/20μs)  DFN1006-2L package  Replacement for MLV(0402)  Unidirectional configurations  Response time is typically < 1 ns  Protect one I/O or power line  Low clamping Voltage  RoHS compliant  Transient protection for data lines to IEC 61000-4-2(ESD) Pin 1 Pin 2 Circuit Diagram ±30KV(air), ±30KV(contact); IEC 61000-4-4 (EFT) 40A (5/50ns) Applications  Cell phone handsets and accessories  Personal digital assistants (PDA’s)  Notebooks, desktops, and servers  Portable instrumentation  Cordless phones  Digital cameras  Peripherals  MP3 players F Marking (Top View) Mechanical Characteristics  Lead finish:100% matte Sn(Tin)  Mounting position: Any  Qualified max reflow temperature:260℃  Device meets MSL 1 requirements  Pure tin plating: 7 ~ 17 um  Pin flatness:≤3mil Rev.06.5 1 www.prisemi.com ESD Protector PESDHC2FD7VU Electronics Parameter Symbol Parameter VRWM Peak Reverse Working Voltage IR Reverse Leakage Current @ VRWM VBR Breakdown Voltage @ IT IT Test Current IPP Maximum Reverse Peak Pulse Current VC Clamping Voltage @ IPP PPP Peak Pulse Power CJ Junction Capacitance IF Forward Current VF Forward Voltage @ IF IF I V VC VBR VRWM IR VF IT IPP Electrical characteristics per line@25℃( unless otherwise specified) Parameter Symbol Conditions Peak Reverse Working Voltage VRWM Breakdown Voltage VBR It =1mA Reverse Leakage Current IR VRWM =7V Clamping Voltage VC IPP=15A Junction Capacitance Cj VR=0V Min. Typ. 8.1 8.2 Max. Units 7 V 9.0 V 1 μA tP = 8/20μs 16.5 V f = 1MHz 73 pF Absolute maximum rating@25℃ Rating Symbol Value Units Peak Pulse Power ( tP = 8/20μS ) Ppp 230 W Lead Soldering Temperature TL 260 (10 sec) ℃ Operating Temperature TJ -55 to 125 ℃ TSTG -55 to 150 ℃ Storage Temperature Rev.06.5 2 www.prisemi.com ESD Protector PESDHC2FD7VU tf=8μs 100 100 80 60 % Of Rated Power IPP – Peak Pulse Current - % of IPP Typical Characteristics tP =20μs(IPP /2) 40 60 40 20 20 0 80 0 5 10 15 20 25 0 30 0 25 t - Time -μs 50 75 100 125 150 TL – Lead Temperature - ℃ Fig 1.Pulse Waveform Fig 2.Power Derating Curve 20 100 f=1MHz Pulse waveform: tp=8/20us 80 C-Junction capacitance (pF) VC-Clamping Voltage (V) 15 10 5 60 40 20 0 0 3 6 9 12 IPP-Peak pulse current (A) 15 0 18 Fig 3. Clamping voltage vs. Peak pulse current 0 0.5 1.0 1.5 2.0 VR-Reverse voltage (V) 2.5 Fig 4. Capacitance vs. Reveres voltage Peak Pulse Power (W) 10000 1000 100 10 1 10 100 Pulse Duration(us) 1000 Fig 5. Non Repetitive Peak Pulse Power vs. Pulse time Rev.06.5 3 www.prisemi.com ESD Protector PESDHC2FD7VU Solder Reflow Recommendation Peak Temp=257℃, Ramp Rate=0.802deg. ℃/sec 280 240 200 160 120 80 40 0 0 30 60 90 120 150 180 240 210 270 300 330 360 390 420 450 480 Time (sec) PCB Design For TVS diodes a low-ohmic and low-inductive path to chassis earth is absolutely mandatory in order to achieve good ESD protection. Novices in the area of ESD protection should take following suggestions to heart:  Do not use stubs, but place the cathode of the TVS diode directly on the signal trace.  Do not make false economies and save copper for the ground connection.  Place via holes to ground as close as possible to the anode of the TVS diode.  Use as many via holes as possible for the ground connection.  Keep the length of via holes in mind! The longer the more inductance they will have. Rev.06.5 4 www.prisemi.com ESD Protector PESDHC2FD7VU Product dimension (DFN1006-2L) A Dim B C E 1 R 2 D Millimeters MIN MAX MIN MAX A 0.013 0.020 0.34 0.50 B 0.000 0.002 0.00 0.05 C 0.037 0.043 0.95 1.080 D 0.022 0.027 0.55 0.68 E 0.016 0.024 0.40 0.60 F 0.008 0.012 0.20 0.30 H R F Inches 0.015Typ. 0.001 0.40Typ. 0.005 0.05 0.15 H 1.10 0.60 Unit:mm 0.40 Suggested PCB Layout Ordering information Device Package Reel Shipping PESDHC2FD7VU DFN1006-2L (Pb-Free) 7" 10000 / Tape & Reel Rev.06.5 5 www.prisemi.com ESD Protector PESDHC2FD7VU Load with information USER DIRECTION OF FEED Φ1.50 ± 0.10 2.00 ± 0.05 2.00 ± 0.05 4.00 ± 0.10 1.75 ± 0.10 3.50 ± 0.05 8.00 ± 0.10 Φ0.50 ± 0.05 Unit:mm Rev.06.5 6 www.prisemi.com ESD Protector PESDHC2FD7VU IMPORTANT NOTICE and are registered trademarks of Prisemi Electronics Co., Ltd (Prisemi) ,Prisemi reserves the right to make changes without further notice to any products herein. Prisemi makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does Prisemi assume any liability arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation special, consequential or incidental damages. “Typical” parameters which may be provided in Prisemi data sheets and/or specifications can and do vary in different applications and actual performance may vary over time. All operating parameters, including “Typicals” must be validated for each customer application by customer’s technical experts. Prisemi does not convey any license under its patent rights nor the rights of others. The products listed in this document are designed to be used with ordinary electronic equipment or devices, Should you intend to use these products with equipment or devices which require an extremely high level of reliability and the malfunction of with would directly endanger human life (such as medical instruments, aerospace machinery, nuclear-reactor controllers, fuel controllers and other safety devices), please be sure to consult with our sales representative in advance. Website: http://www.prisemi.com For additional information, please contact your local Sales Representative. ©Copyright 2009, Prisemi Electronics is a registered trademark of Prisemi Electronics. All rights are reserved. Rev.06.5 7 www.prisemi.com
PESDHC2FD7VU 价格&库存
很抱歉,暂时无法提供与“PESDHC2FD7VU”相匹配的价格&库存,您可以联系我们找货
