ESP-WROOM-32D
ESP-WROOM-32D
    ESPRESSIF(乐鑫)
    ESP-WROOM-32D
ESP-WROOM-32D 数据手册
ESP32 Series Datasheet Including: ESP32-D0WD-V3 ESP32-D0WDR2-V3 ESP32-U4WDH ESP32-S0WD – Not Recommended for New Designs (NRND) ESP32-D0WD – Not Recommended for New Designs (NRND) ESP32-D0WDQ6 – Not Recommended for New Designs (NRND) ESP32-D0WDQ6-V3 – Not Recommended for New Designs (NRND) Version 4.0 Espressif Systems Copyright © 2022 www.espressif.com About This Document This document provides the specifications of ESP32 series of chips. Document Updates Please always refer to the latest version on https://www.espressif.com/en/support/download/documents. Revision History For any changes to this document over time, please refer to the last page. Documentation Change Notification Espressif provides email notifications to keep customers updated on changes to technical documentation. Please subscribe at www.espressif.com/en/subscribe. Note that you need to update your subscription to receive notifications of new products you are not currently subscribed to. Certification Download certificates for Espressif products from www.espressif.com/en/certificates. Contents Contents 1 Overview 8 1.1 Featured Solutions 8 1.1.1 Ultra-Low-Power Solution 8 1.1.2 Complete Integration Solution 8 1.2 Wi-Fi Key Features 8 1.3 Bluetooth Key Features 9 1.4 MCU and Advanced Features 9 1.4.1 CPU and Memory 9 1.4.2 Clocks and Timers 10 1.4.3 Advanced Peripheral Interfaces 10 1.4.4 Security 11 1.5 Applications (A Non-exhaustive List) 11 1.6 Block Diagram 12 2 Pin Definitions 13 2.1 Pin Layout 13 2.2 Pin Description 15 2.3 Power Scheme 19 2.4 Strapping Pins 21 3 Functional Description 24 3.1 CPU and Memory 24 3.1.1 CPU 24 3.1.2 Internal Memory 24 3.1.3 External Flash and SRAM 25 3.1.4 Memory Map 25 3.2 3.3 3.4 3.5 3.6 Timers and Watchdogs 27 3.2.1 64-bit Timers 27 3.2.2 Watchdog Timers 27 System Clocks 28 3.3.1 CPU Clock 28 3.3.2 RTC Clock 28 3.3.3 Audio PLL Clock 28 Radio 28 3.4.1 2.4 GHz Receiver 29 3.4.2 2.4 GHz Transmitter 29 3.4.3 Clock Generator 29 Wi-Fi 29 3.5.1 Wi-Fi Radio and Baseband 30 3.5.2 Wi-Fi MAC 30 Bluetooth 30 3.6.1 30 Bluetooth Radio and Baseband Espressif Systems 3 Submit Documentation Feedback ESP32 Series Datasheet v4.0 Contents 3.6.2 Bluetooth Interface 31 3.6.3 Bluetooth Stack 31 3.6.4 Bluetooth Link Controller 31 3.7 RTC and Low-Power Management 32 4 Peripherals and Sensors 34 4.1 Descriptions of Peripherals and Sensors 34 4.1.1 General Purpose Input/Output Interface (GPIO) 34 4.1.2 Analog-to-Digital Converter (ADC) 34 4.1.3 Hall Sensor 35 4.1.4 Digital-to-Analog Converter (DAC) 35 4.1.5 Touch Sensor 35 4.1.6 Ultra-Low-Power (ULP) Coprocessor 36 4.1.7 Ethernet MAC Interface 36 4.1.8 SD/SDIO/MMC Host Controller 36 4.1.9 SDIO/SPI Slave Controller 37 4.1.10 Universal Asynchronous Receiver Transmitter (UART) 37 4.1.11 I2C Interface 37 4.1.12 I2S Interface 38 4.1.13 Infrared Remote Controller (RMT) 38 4.1.14 Pulse Counter (PCNT) 38 4.1.15 Pulse Width Modulation (PWM) 38 4.1.16 LED PWM 38 4.1.17 Serial Peripheral Interface (SPI) 39 4.1.18 TWAI Controller 39 4.1.19 Accelerator 39 4.2 Peripheral Pin Configurations 40 5 Electrical Characteristics 45 5.1 Absolute Maximum Ratings 45 5.2 Recommended Operating Conditions 45 5.3 DC Characteristics (3.3 V, 25 °C) 46 5.4 Reliability Qualifications 46 5.5 RF Power-Consumption Specifications 47 5.6 Wi-Fi Radio 47 5.7 Bluetooth Radio 48 5.7.1 Receiver – Basic Data Rate 48 5.7.2 Transmitter – Basic Data Rate 48 5.7.3 Receiver – Enhanced Data Rate 49 5.7.4 Transmitter – Enhanced Data Rate 49 5.8 6 Bluetooth LE Radio 50 5.8.1 Receiver 50 5.8.2 Transmitter 51 Package Information Espressif Systems 52 4 Submit Documentation Feedback ESP32 Series Datasheet v4.0 Contents 7 Part Number and Ordering Information 53 8 Related Documentation and Resources 54 Appendix A – ESP32 Pin Lists 55 A.1. Notes on ESP32 Pin Lists 55 A.2. GPIO_Matrix 57 A.3. Ethernet_MAC 62 A.4. IO_MUX 62 Revision History 64 Espressif Systems 5 Submit Documentation Feedback ESP32 Series Datasheet v4.0 List of Tables List of Tables 1 Pin Description 15 2 Pin-to-Pin Mapping Between Chip and Embedded Flash/PSRAM 18 3 Connection Between Chip and External Flash/PSRAM 18 4 Description of ESP32 Power-up and Reset Timing Parameters 20 5 Strapping Pins 22 6 Parameter Descriptions of Setup and Hold Times for the Strapping Pins 23 7 Memory and Peripheral Mapping 26 8 Power Consumption by Power Modes 32 9 ADC Characteristics 34 10 ADC Calibration Results 35 11 Capacitive-Sensing GPIOs Available on ESP32 35 12 Peripheral Pin Configurations 40 13 Absolute Maximum Ratings 45 14 Recommended Operating Conditions 45 15 DC Characteristics (3.3 V, 25 °C) 46 16 Reliability Qualifications 46 17 RF Power-Consumption Specifications 47 18 Wi-Fi Radio Characteristics 47 19 Receiver Characteristics – Basic Data Rate 48 20 Transmitter Characteristics – Basic Data Rate 48 21 Receiver Characteristics – Enhanced Data Rate 49 22 Transmitter Characteristics – Enhanced Data Rate 50 23 Receiver Characteristics – Bluetooth LE 50 24 Transmitter Characteristics – Bluetooth LE 51 25 ESP32 Ordering Information 53 26 Notes on ESP32 Pin Lists 55 27 GPIO_Matrix 57 28 Ethernet_MAC 62 Espressif Systems 6 Submit Documentation Feedback ESP32 Series Datasheet v4.0 List of Figures List of Figures 1 Functional Block Diagram 12 2 ESP32 Pin Layout (QFN 6*6, Top View) 13 3 ESP32 Pin Layout (QFN 5*5, Top View) 14 4 ESP32 Power Scheme 20 5 ESP32 Power-up and Reset Timing 20 6 Setup and Hold Times for the Strapping Pins 23 7 Address Mapping Structure 25 8 QFN48 (6x6 mm) Package 52 9 QFN48 (5x5 mm) Package 52 10 ESP32 Part Number Description 53 Espressif Systems 7 Submit Documentation Feedback ESP32 Series Datasheet v4.0 1 Overview 1 Overview ESP32 is a single 2.4 GHz Wi-Fi-and-Bluetooth combo chip designed with the TSMC low-power 40 nm technology. It is designed to achieve the best power and RF performance, showing robustness, versatility and reliability in a wide variety of applications and power scenarios. The ESP32 series of chips includes ESP32-D0WD-V3, ESP32-D0WDR2-V3, ESP32-U4WDH, ESP32-S0WD (NRND), ESP32-D0WDQ6-V3 (NRND), ESP32-D0WD (NRND), and ESP32-D0WDQ6 (NRND), among which, • ESP32-S0WD (NRND), ESP32-D0WD (NRND), and ESP32-D0WDQ6 (NRND) are based on chip revision v1 or chip revision v1.1. • ESP32-D0WD-V3, ESP32-D0WDR2-V3, ESP32-U4WDH, and ESP32-D0WDQ6-V3 (NRND) are based on chip revision v3.0 or chip revision v3.1. For details on part numbers and ordering information, please refer to Section 7. For details on chip revisions, please refer to ESP32 Chip Revision v3.0 User Guide and ESP32 Series SoC Errata. 1.1 Featured Solutions 1.1.1 Ultra­Low­Power Solution ESP32 is designed for mobile, wearable electronics, and Internet-of-Things (IoT) applications. It features all the state-of-the-art characteristics of low-power chips, including fine-grained clock gating, multiple power modes, and dynamic power scaling. For instance, in a low-power IoT sensor hub application scenario, ESP32 is woken up periodically only when a specified condition is detected. Low-duty cycle is used to minimize the amount of energy that the chip expends. The output of the power amplifier is also adjustable, thus contributing to an optimal trade-off between communication range, data rate and power consumption. Note: For more information, refer to Section 3.7 RTC and Low-Power Management. 1.1.2 Complete Integration Solution ESP32 is a highly-integrated solution for Wi-Fi-and-Bluetooth IoT applications, with around 20 external components. ESP32 integrates an antenna switch, RF balun, power amplifier, low-noise receive amplifier, filters, and power management modules. As such, the entire solution occupies minimal Printed Circuit Board (PCB) area. ESP32 uses CMOS for single-chip fully-integrated radio and baseband, while also integrating advanced calibration circuitries that allow the solution to remove external circuit imperfections or adjust to changes in external conditions. As such, the mass production of ESP32 solutions does not require expensive and specialized Wi-Fi testing equipment. 1.2 Wi­Fi Key Features • 802.11 b/g/n Espressif Systems 8 Submit Documentation Feedback ESP32 Series Datasheet v4.0 1 Overview • 802.11 n (2.4 GHz), up to 150 Mbps • WMM • TX/RX A-MPDU, RX A-MSDU • Immediate Block ACK • Defragmentation • Automatic Beacon monitoring (hardware TSF) • 4 × virtual Wi-Fi interfaces • Simultaneous support for Infrastructure Station, SoftAP, and Promiscuous modes Note that when ESP32 is in Station mode, performing a scan, the SoftAP channel will be changed. • Antenna diversity Note: For more information, please refer to Section 3.5 Wi-Fi. 1.3 Bluetooth Key Features • Compliant with Bluetooth v4.2 BR/EDR and Bluetooth LE specifications • Class-1, class-2 and class-3 transmitter without external power amplifier • Enhanced Power Control • +9 dBm transmitting power • NZIF receiver with –94 dBm Bluetooth LE sensitivity • Adaptive Frequency Hopping (AFH) • Standard HCI based on SDIO/SPI/UART • High-speed UART HCI, up to 4 Mbps • Bluetooth 4.2 BR/EDR Bluetooth LE dual mode controller • Synchronous Connection-Oriented/Extended (SCO/eSCO) • CVSD and SBC for audio codec • Bluetooth Piconet and Scatternet • Multi-connections in Classic Bluetooth and Bluetooth LE • Simultaneous advertising and scanning 1.4 MCU and Advanced Features 1.4.1 CPU and Memory • Xtensa® single-/dual-core 32-bit LX6 microprocessor(s) • CoreMark® score: Espressif Systems 9 Submit Documentation Feedback ESP32 Series Datasheet v4.0 1 Overview – 1 core at 240 MHz: 504.85 CoreMark; 2.10 CoreMark/MHz – 2 cores at 240 MHz: 994.26 CoreMark; 4.14 CoreMark/MHz • 448 KB ROM • 520 KB SRAM • 16 KB SRAM in RTC • QSPI supports multiple flash/SRAM chips 1.4.2 Clocks and Timers • Internal 8 MHz oscillator with calibration • Internal RC oscillator with calibration • External 2 MHz ~ 60 MHz crystal oscillator (40 MHz only for Wi-Fi/Bluetooth functionality) • External 32 kHz crystal oscillator for RTC with calibration • Two timer groups, including 2 × 64-bit timers and 1 × main watchdog in each group • One RTC timer • RTC watchdog 1.4.3 Advanced Peripheral Interfaces • 34 × programmable GPIOs • 12-bit SAR ADC up to 18 channels • 2 × 8-bit DAC • 10 × touch sensors • 4 × SPI • 2 × I2S • 2 × I2C • 3 × UART • 1 host (SD/eMMC/SDIO) • 1 slave (SDIO/SPI) • Ethernet MAC interface with dedicated DMA and IEEE 1588 support • TWAI® , compatible with ISO 11898-1 (CAN Specification 2.0) • RMT (TX/RX) • Motor PWM • LED PWM up to 16 channels • Hall sensor Espressif Systems 10 Submit Documentation Feedback ESP32 Series Datasheet v4.0 1 Overview 1.4.4 Security • Secure boot • Flash encryption • 1024-bit OTP, up to 768-bit for customers • Cryptographic hardware acceleration: – AES – Hash (SHA-2) – RSA – ECC – Random Number Generator (RNG) 1.5 Applications (A Non­exhaustive List) – Agriculture robotics • Generic Low-power IoT Sensor Hub • Generic Low-power IoT Data Loggers • Audio Applications • Cameras for Video Streaming – Internet music players • Over-the-top (OTT) Devices – Live streaming devices • Speech Recognition – Internet radio players • Image Recognition – Audio headsets • Mesh Network • Health Care Applications • Home Automation – Health monitoring – Light control – Baby monitors – Smart plugs • Wi-Fi-enabled Toys – Smart door locks – Remote control toys • Smart Building – Proximity sensing toys – Smart lighting – Educational toys – Energy monitoring • Wearable Electronics • Industrial Automation – Industrial wireless control – Smart watches – Industrial robotics – Smart bracelets • Retail & Catering Applications • Smart Agriculture – Smart greenhouses – POS machines – Smart irrigation – Service robots Espressif Systems 11 Submit Documentation Feedback ESP32 Series Datasheet v4.0 1 Overview 1.6 Block Diagram RF receive Bluetooth baseband Clock generator I2C I2S Wi-Fi MAC Wi-Fi baseband RF transmit SDIO UART TWAI® ETH Cryptographic hardware acceleration Core and memory 2 or 1 x Xtensa® 32bit LX6 Microprocessors RMT PWM ROM Balun SPI Bluetooth link controller Switch Embedded Flash or PSRAM SRAM SHA RSA AES RNG Touch sensor RTC DAC ADC PMU ULP coprocessor Recovery memory Timers Figure 1: Functional Block Diagram Note: Products in the ESP32 series differ from each other in terms of their support for embedded flash or PSRAM and the number of CPUs they have. For details, please refer to Section 7 Part Number and Ordering Information. Espressif Systems 12 Submit Documentation Feedback ESP32 Series Datasheet v4.0 2 Pin Definitions 2 Pin Definitions CAP1 CAP2 VDDA XTAL_P XTAL_N VDDA GPIO21 U0TXD U0RXD GPIO22 GPIO19 VDD3P3_CPU 48 47 46 45 44 43 42 41 40 39 38 37 2.1 Pin Layout VDDA 1 36 GPIO23 LNA_IN 2 35 GPIO18 VDD3P3 3 34 GPIO5 VDD3P3 4 33 SD_DATA_1 SENSOR_VP 5 32 SD_DATA_0 SENSOR_CAPP 6 31 SD_CLK SENSOR_CAPN 7 30 SD_CMD SENSOR_VN 8 29 SD_DATA_3 CHIP_PU 9 28 SD_DATA_2 VDET_1 10 27 GPIO17 VDET_2 11 26 VDD_SDIO 32K_XP 12 25 GPIO16 13 14 15 16 17 18 19 20 21 22 23 24 32K_XN GPIO25 GPIO26 GPIO27 MTMS MTDI VDD3P3_RTC MTCK MTDO GPIO2 GPIO0 GPIO4 ESP32 49 GND Figure 2: ESP32 Pin Layout (QFN 6*6, Top View) Espressif Systems 13 Submit Documentation Feedback ESP32 Series Datasheet v4.0 CAP1 CAP2 VDDA XTAL_P XTAL_N VDDA GPIO21 U0TXD U0RXD GPIO22 48 47 46 45 44 43 42 41 40 39 2 Pin Definitions VDDA 1 38 GPIO19 LNA_IN 2 37 VDD3P3_CPU VDD3P3 3 36 GPIO23 VDD3P3 4 35 GPIO18 SENSOR_VP 5 34 GPIO5 SENSOR_CAPP 6 33 SD_DATA_1 SENSOR_CAPN 7 32 SD_DATA_0 SENSOR_VN 8 31 SD_CLK CHIP_PU 9 30 SD_CMD VDET_1 10 29 SD_DATA_3 VDET_2 11 28 SD_DATA_2 32K_XP 12 27 GPIO17 32K_XN 13 26 VDD_SDIO GPIO25 14 25 GPIO16 15 16 17 18 19 20 21 22 23 24 GPIO26 GPIO27 MTMS MTDI VDD3P3_RTC MTCK MTDO GPIO2 GPIO0 GPIO4 ESP32 49 GND Figure 3: ESP32 Pin Layout (QFN 5*5, Top View) Note: For details on ESP32’s part numbers and the corresponding packaging, please refer to Section 7 Part Number and Ordering Information. Espressif Systems 14 Submit Documentation Feedback ESP32 Series Datasheet v4.0 2 Pin Definitions Espressif Systems 2.2 Pin Description Table 1: Pin Description Name No. Type Function Analog Analog power supply (2.3 V ∼ 3.6 V) VDDA 1 P LNA_IN 2 I/O VDD3P3 3 P Analog power supply (2.3 V ∼ 3.6 V) VDD3P3 4 P Analog power supply (2.3 V ∼ 3.6 V) RF input and output VDD3P3_RTC 5 I GPIO36, ADC1_CH0, RTC_GPIO0 SENSOR_CAPP 6 I GPIO37, ADC1_CH1, RTC_GPIO1 SENSOR_CAPN 7 I GPIO38, ADC1_CH2, RTC_GPIO2 SENSOR_VN 8 I GPIO39, ADC1_CH3, RTC_GPIO3 15 Submit Documentation Feedback SENSOR_VP High: On; enables the chip CHIP_PU 9 I Low: Off; the chip powers off Note: Do not leave the CHIP_PU pin floating. ESP32 Series Datasheet v4.0 VDET_1 10 I GPIO34, ADC1_CH6, RTC_GPIO4 VDET_2 11 I GPIO35, ADC1_CH7, RTC_GPIO5 32K_XP 12 I/O GPIO32, ADC1_CH4, RTC_GPIO9, TOUCH9, 32K_XP (32.768 kHz crystal oscillator input) 32K_XN 13 I/O GPIO33, ADC1_CH5, RTC_GPIO8, TOUCH8, 32K_XN (32.768 kHz crystal oscillator output) GPIO25 14 I/O GPIO25, ADC2_CH8, RTC_GPIO6, DAC_1, EMAC_RXD0 GPIO26 15 I/O GPIO26, ADC2_CH9, RTC_GPIO7, DAC_2, EMAC_RXD1 GPIO27 16 I/O GPIO27, ADC2_CH7, RTC_GPIO17, TOUCH7, EMAC_RX_DV MTMS 17 I/O GPIO14, ADC2_CH6, RTC_GPIO16, TOUCH6, EMAC_TXD2, HSPICLK, HS2_CLK, MTDI 18 I/O GPIO12, ADC2_CH5, RTC_GPIO15, TOUCH5, EMAC_TXD3, HSPIQ, HS2_DATA2, SD_DATA2, MTDI VDD3P3_RTC 19 P MTCK 20 I/O GPIO13, ADC2_CH4, RTC_GPIO14, TOUCH4, EMAC_RX_ER, HSPID, HS2_DATA3, SD_DATA3, MTCK MTDO 21 I/O GPIO15, ADC2_CH3, RTC_GPIO13, TOUCH3, EMAC_RXD3, HS2_CMD, MTDO SD_CLK, MTMS Input power supply for RTC IO (2.3 V ∼ 3.6 V) HSPICS0, SD_CMD, No. Type Function GPIO2 22 I/O GPIO2, ADC2_CH2, RTC_GPIO12, TOUCH2, GPIO0 23 I/O GPIO0, ADC2_CH1, RTC_GPIO11, TOUCH1, EMAC_TX_CLK, CLK_OUT1, GPIO4 24 I/O GPIO4, ADC2_CH0, RTC_GPIO10, TOUCH0, EMAC_TX_ER, HSPIWP, HSPIHD, VDD_SDIO 16 Submit Documentation Feedback GPIO16 25 I/O GPIO16, HS1_DATA4, U2RXD, EMAC_CLK_OUT VDD_SDIO 26 P GPIO17 27 I/O GPIO17, HS1_DATA5, U2TXD, EMAC_CLK_OUT_180 SD_DATA_2 28 I/O GPIO9, HS1_DATA2, U1RXD, SD_DATA2, SPIHD SD_DATA_3 29 I/O GPIO10, HS1_DATA3, U1TXD, SD_DATA3, SPIWP SD_CMD 30 I/O GPIO11, HS1_CMD, U1RTS, SD_CMD, SPICS0 SD_CLK 31 I/O GPIO6, HS1_CLK, U1CTS, SD_CLK, SPICLK SD_DATA_0 32 I/O GPIO7, HS1_DATA0, U2RTS, SD_DATA0, SPIQ SD_DATA_1 33 I/O GPIO8, HS1_DATA1, U2CTS, SD_DATA1, SPID Output power supply: 1.8 V or the same voltage as VDD3P3_RTC VDD3P3_CPU GPIO5 34 I/O GPIO5, HS1_DATA6, VSPICS0, EMAC_RX_CLK GPIO18 35 I/O GPIO18, HS1_DATA7, VSPICLK GPIO23 36 I/O GPIO23, HS1_STROBE, VSPID VDD3P3_CPU 37 P GPIO19 38 I/O GPIO19, U0CTS, VSPIQ, EMAC_TXD0 GPIO22 39 I/O GPIO22, U0RTS, VSPIWP, EMAC_TXD1 U0RXD 40 I/O GPIO3, U0RXD, CLK_OUT2 U0TXD 41 I/O GPIO1, U0TXD, CLK_OUT3, EMAC_RXD2 GPIO21 42 I/O GPIO21, VSPIHD, EMAC_TX_EN Input power supply for CPU IO (1.8 V ∼ 3.6 V) ESP32 Series Datasheet v4.0 Analog VDDA 43 P Analog power supply (2.3 V ∼ 3.6 V) XTAL_N 44 O External crystal output XTAL_P 45 I External crystal input VDDA 46 P Analog power supply (2.3 V ∼ 3.6 V) CAP2 47 I Connects to a 3.3 nF (10%) capacitor and 20 kΩ resistor in parallel to CAP1 HS2_DATA0, SD_DATA0 HS2_DATA1, SD_DATA1 2 Pin Definitions Espressif Systems Name No. Type Function CAP1 48 I Connects to a 10 nF series capacitor to ground GND 49 P Ground Note: For a quick reference guide to using the IO_MUX, Ethernet MAC, and GIPO Matrix pins of ESP32, please refer to Appendix ESP32 Pin Lists. 2 Pin Definitions Espressif Systems Name 17 Submit Documentation Feedback ESP32 Series Datasheet v4.0 2 Pin Definitions Table 2 lists the pin-to-pin mapping between the chip and the embedded flash/PSRAM. The chip pins listed here are not recommended for other usage. For the data port connection between ESP32 and external flash/PSRAM please refer to Table 3. Table 2: Pin­to­Pin Mapping Between Chip and Embedded Flash/PSRAM ESP32­U4WDH Embedded Flash (4 MB) SD_DATA_1 IO0/DI GPIO17 IO1/DO SD_DATA_0 IO2/WP# SD_CMD IO3/HOLD# SD_CLK CLK GPIO16 CS# GND VSS VDD_SDIO VDD ESP32­D0WDR2­V3 Embedded PSRAM (2 MB) SD_DATA_1 SIO0/SI SD_DATA_0 SIO1/SO SD_DATA_3 SIO2 SD_DATA_2 SIO3 SD_CLK SCLK GPIO16 * CE# GND VSS VDD_SDIO VDD Table 3: Connection Between Chip and External Flash/PSRAM Chip Pin External Flash SD_DATA_1/SPID IO0/DI SD_DATA_0/SPIQ IO1/DO SD_DATA_3/SPIWP IO2/WP# SD_DATA_2/SPIHD IO3/HOLD# SD_CLK CLK SD_CMD CS# GND VSS VDD_SDIO VDD Chip Pin SD_DATA_1 SIO0/SI SD_DATA_0 SIO1/SO SD_DATA_3 SIO2 SD_DATA_2 SIO3 SD_CLK/GPIO17* SCLK GPIO16 Espressif Systems External PSRAM * CE# GND VSS VDD_SDIO VDD 18 Submit Documentation Feedback ESP32 Series Datasheet v4.0 2 Pin Definitions Note: 1. SD_CLK and GPIO17 pins are available to connect to the SCLK signal of external PSRAM. • If SD_CLK pin is selected, one GPIO (i.e., GPIO17) will be saved. The saved GPIO can be used for other purposes. This connection has passed internal tests, but relevant certification has not been completed. • Or GPIO17 pin is used to connect to the SCLK signal. This connection has passed relevant certification, see certificates for ESP32-WROVER-E. Please select the proper pin for your specific applications. 2. If GPIO16 is used to connect to PSRAM’s CE# signal, please add a pull-up resistor at the GPIO16 pin. See Figure: Schematics of ESP32-WROVER-E. 3. As the embedded flash/PSRAM in ESP32-U4WDH/ESP32-D0WDR2-V3 operates at 3.3 V, VDD_SDIO must be powered by VDD3P3_RTC via a 6 Ω resistor. See Figure 4. 2.3 Power Scheme ESP32’s digital pins are divided into three different power domains: • VDD3P3_RTC • VDD3P3_CPU • VDD_SDIO VDD3P3_RTC is also the input power supply for RTC and CPU. VDD3P3_CPU is also the input power supply for CPU. VDD_SDIO connects to the output of an internal LDO whose input is VDD3P3_RTC. When VDD_SDIO is connected to the same PCB net together with VDD3P3_RTC, the internal LDO is disabled automatically. The power scheme diagram is shown below: Espressif Systems 19 Submit Documentation Feedback ESP32 Series Datasheet v4.0 2 Pin Definitions VDD3P3_RTC 1.8 V R=6Ω LDO LDO VDD3P3_CPU 1.1 V LDO 1.1 V VDD_SDIO 3.3 V/1.8 V SDIO RTC CPU Domain Domain Domain Figure 4: ESP32 Power Scheme The internal LDO can be configured as having 1.8 V, or the same voltage as VDD3P3_RTC. It can be powered off via software to minimize the current of flash/SRAM during the Deep-sleep mode. Notes on CHIP_PU: • The illustration below shows the ESP32 power-up and reset timing. Details about the parameters are listed in Table 4. t0 t1 VDD3P3_RTC Min VDD VIL_nRST CHIP_PU Figure 5: ESP32 Power­up and Reset Timing Table 4: Description of ESP32 Power­up and Reset Timing Parameters Parameters t0 Espressif Systems Description Time between the 3.3 V rails being brought up and CHIP_PU being activated 20 Submit Documentation Feedback Min. Unit 50 µs ESP32 Series Datasheet v4.0 2 Pin Definitions Parameters t1 Description Duration of CHIP_PU signal level < VIL_nRST (refer to its value in Table 15 DC Characteristics) to reset the chip Min. Unit 50 µs • In scenarios where ESP32 is powered on and off repeatedly by switching the power rails, while there is a large capacitor on the VDD33 rail and CHIP_PU and VDD33 are connected, simply switching off the CHIP_PU power rail and immediately switching it back on may cause an incomplete power discharge cycle and failure to reset the chip adequately. An additional discharge circuit may be required to accelerate the discharge of the large capacitor on rail VDD33, which will ensure proper power-on-reset when the ESP32 is powered up again. • When a battery is used as the power supply for the ESP32 series of chips and modules, a supply voltage supervisor is recommended, so that a boot failure due to low voltage is avoided. Users are recommended to pull CHIP_PU low if the power supply for ESP32 is below 2.3 V. Notes on power supply: • The operating voltage of ESP32 ranges from 2.3 V to 3.6 V. When using a single-power supply, the recommended voltage of the power supply is 3.3 V, and its recommended output current is 500 mA or more. • PSRAM and flash both are powered by VDD_SDIO. If the chip has an embedded flash, the voltage of VDD_SDIO is determined by the operating voltage of the embedded flash. If the chip also connects to an external PSRAM, the operating voltage of external PSRAM must match that of the embedded flash. This also applies if the chip has an embedded PSRAM but also connects to an external flash. • When VDD_SDIO 1.8 V is used as the power supply for external flash/PSRAM, a 2 kΩ grounding resistor should be added to VDD_SDIO. For the circuit design, please refer to Figure ESP32­WROVER Schematics, in ESP32-WROVER Datasheet. • When the three digital power supplies are used to drive peripherals, e.g., 3.3 V flash, they should comply with the peripherals’ specifications. 2.4 Strapping Pins There are five strapping pins: • MTDI • GPIO0 • GPIO2 • MTDO • GPIO5 Software can read the values of these five bits from register ”GPIO_STRAPPING”. During the chip’s system reset release (power-on-reset, RTC watchdog reset and brownout reset), the latches of the strapping pins sample the voltage level as strapping bits of ”0” or ”1”, and hold these bits until the chip is powered down or shut down. The strapping bits configure the device’s boot mode, the operating voltage of VDD_SDIO and other initial system settings. Espressif Systems 21 Submit Documentation Feedback ESP32 Series Datasheet v4.0 2 Pin Definitions Each strapping pin is connected to its internal pull-up/pull-down during the chip reset. Consequently, if a strapping pin is unconnected or the connected external circuit is high-impedance, the internal weak pull-up/pull-down will determine the default input level of the strapping pins. To change the strapping bit values, users can apply the external pull-down/pull-up resistances, or use the host MCU’s GPIOs to control the voltage level of these pins when powering on the chip. After reset release, the strapping pins work as normal-function pins. Refer to Table 5 for a detailed boot-mode configuration by strapping pins. Table 5: Strapping Pins Voltage of Internal LDO (VDD_SDIO) Pin MTDI Default 3.3 V 1.8 V Pull-down 0 1 Booting Mode Pin Default SPI Boot Download Boot GPIO0 Pull-up 1 0 GPIO2 Pull-down Don’t-care 0 Enabling/Disabling Debugging Log Print over U0TXD During Booting Pin Default U0TXD Active U0TXD Silent MTDO Pull-up 1 0 Timing of SDIO Slave FE Sampling FE Sampling RE Sampling RE Sampling Pin Default FE Output RE Output FE Output RE Output MTDO Pull-up 0 0 1 1 GPIO5 Pull-up 0 1 0 1 Note: • FE: falling-edge, RE: rising-edge. • Firmware can configure register bits to change the settings of “Voltage of Internal LDO (VDD_SDIO)” and “Timing of SDIO Slave”, after booting. • For ESP32 chips that contain an embedded flash or PSRAM, users need to note the logic level of MTDI. For example, ESP32-U4WDH contains an embedded flash that operates at 3.3 V, therefore, the MTDI should be low. The illustration below shows the setup and hold times for the strapping pins before and after the CHIP_PU signal goes high. Details about the parameters are listed in Table 6. Espressif Systems 22 Submit Documentation Feedback ESP32 Series Datasheet v4.0 2 Pin Definitions t0 CHIP_PU t1 VIL_nRST VIH Strapping pin Figure 6: Setup and Hold Times for the Strapping Pins Table 6: Parameter Descriptions of Setup and Hold Times for the Strapping Pins Parameters Description Min. Unit t0 Setup time before CHIP_PU goes from low to high 0 ms t1 Hold time after CHIP_PU goes high 1 ms Espressif Systems 23 Submit Documentation Feedback ESP32 Series Datasheet v4.0 3 Functional Description 3 Functional Description This chapter describes the functions integrated in ESP32. 3.1 CPU and Memory 3.1.1 CPU ESP32 contains one or two low-power Xtensa® 32-bit LX6 microprocessor(s) with the following features: • 7-stage pipeline to support the clock frequency of up to 240 MHz (160 MHz for ESP32-S0WD (NRND)) • 16/24-bit Instruction Set provides high code-density • Support for Floating Point Unit • Support for DSP instructions, such as a 32-bit multiplier, a 32-bit divider, and a 40-bit MAC • Support for 32 interrupt vectors from about 70 interrupt sources The single-/dual-CPU interfaces include: • Xtensa RAM/ROM Interface for instructions and data • Xtensa Local Memory Interface for fast peripheral register access • External and internal interrupt sources • JTAG for debugging 3.1.2 Internal Memory ESP32’s internal memory includes: • 448 KB of ROM for booting and core functions • 520 KB of on-chip SRAM for data and instructions • 8 KB of SRAM in RTC, which is called RTC FAST Memory and can be used for data storage; it is accessed by the main CPU during RTC Boot from the Deep-sleep mode. • 8 KB of SRAM in RTC, which is called RTC SLOW Memory and can be accessed by the ULP coprocessor during the Deep-sleep mode. • 1 Kbit of eFuse: 256 bits are used for the system (MAC address and chip configuration) and the remaining 768 bits are reserved for customer applications, including flash-encryption and chip-ID. • Embedded flash or PSRAM Note: Products in the ESP32 series differ from each other, in terms of their support for embedded flash or PSRAM and the size of them. For details, please refer to Section 7 Part Number and Ordering Information. Espressif Systems 24 Submit Documentation Feedback ESP32 Series Datasheet v4.0 3 Functional Description 3.1.3 External Flash and SRAM ESP32 supports multiple external QSPI flash and SRAM chips. More details can be found in Chapter SPI in the ESP32 Technical Reference Manual. ESP32 also supports hardware encryption/decryption based on AES to protect developers’ programs and data in flash. ESP32 can access the external QSPI flash and SRAM through high-speed caches. • Up to 16 MB of external flash can be mapped into CPU instruction memory space and read-only memory space simultaneously. – When external flash is mapped into CPU instruction memory space, up to 11 MB + 248 KB can be mapped at a time. Note that if more than 3 MB + 248 KB are mapped, cache performance will be reduced due to speculative reads by the CPU. – When external flash is mapped into read-only data memory space, up to 4 MB can be mapped at a time. 8-bit, 16-bit and 32-bit reads are supported. • External SRAM can be mapped into CPU data memory space. SRAM up to 8 MB is supported and up to 4 MB can be mapped at a time. 8-bit, 16-bit and 32-bit reads and writes are supported. Note: After ESP32 is initialized, firmware can customize the mapping of external SRAM or flash into the CPU address space. 3.1.4 Memory Map The structure of address mapping is shown in Figure 7. The memory and peripheral mapping of ESP32 is shown in Table 7. Figure 7: Address Mapping Structure Espressif Systems 25 Submit Documentation Feedback ESP32 Series Datasheet v4.0 3 Functional Description Table 7: Memory and Peripheral Mapping Category Embedded Memory Target Start Address End Address Size Internal ROM 0 0x4000_0000 0x4005_FFFF 384 KB Internal ROM 1 0x3FF9_0000 0x3FF9_FFFF 64 KB Internal SRAM 0 0x4007_0000 0x4009_FFFF 192 KB 0x3FFE_0000 0x3FFF_FFFF 0x400A_0000 0x400B_FFFF 0x3FFA_E000 0x3FFD_FFFF 0x3FF8_0000 0x3FF8_1FFF 0x400C_0000 0x400C_1FFF 0x5000_0000 0x5000_1FFF 8 KB 0x3F40_0000 0x3F7F_FFFF 4 MB Internal SRAM 1 Internal SRAM 2 RTC FAST Memory RTC SLOW Memory External Memory Peripheral Espressif Systems External Flash 128 KB 200 KB 8 KB 0x400C_2000 0x40BF_FFFF 11 MB+248 KB External RAM 0x3F80_0000 0x3FBF_FFFF 4 MB DPort Register 0x3FF0_0000 0x3FF0_0FFF 4 KB AES Accelerator 0x3FF0_1000 0x3FF0_1FFF 4 KB RSA Accelerator 0x3FF0_2000 0x3FF0_2FFF 4 KB SHA Accelerator 0x3FF0_3000 0x3FF0_3FFF 4 KB Secure Boot 0x3FF0_4000 0x3FF0_4FFF 4 KB Cache MMU Table 0x3FF1_0000 0x3FF1_3FFF 16 KB PID Controller 0x3FF1_F000 0x3FF1_FFFF 4 KB UART0 0x3FF4_0000 0x3FF4_0FFF 4 KB SPI1 0x3FF4_2000 0x3FF4_2FFF 4 KB SPI0 0x3FF4_3000 0x3FF4_3FFF 4 KB GPIO 0x3FF4_4000 0x3FF4_4FFF 4 KB RTC 0x3FF4_8000 0x3FF4_8FFF 4 KB IO MUX 0x3FF4_9000 0x3FF4_9FFF 4 KB SDIO Slave 0x3FF4_B000 0x3FF4_BFFF 4 KB UDMA1 0x3FF4_C000 0x3FF4_CFFF 4 KB I2S0 0x3FF4_F000 0x3FF4_FFFF 4 KB UART1 0x3FF5_0000 0x3FF5_0FFF 4 KB I2C0 0x3FF5_3000 0x3FF5_3FFF 4 KB UDMA0 0x3FF5_4000 0x3FF5_4FFF 4 KB SDIO Slave 0x3FF5_5000 0x3FF5_5FFF 4 KB RMT 0x3FF5_6000 0x3FF5_6FFF 4 KB PCNT 0x3FF5_7000 0x3FF5_7FFF 4 KB SDIO Slave 0x3FF5_8000 0x3FF5_8FFF 4 KB LED PWM 0x3FF5_9000 0x3FF5_9FFF 4 KB eFuse Controller 0x3FF5_A000 0x3FF5_AFFF 4 KB Flash Encryption 0x3FF5_B000 0x3FF5_BFFF 4 KB PWM0 0x3FF5_E000 0x3FF5_EFFF 4 KB TIMG0 0x3FF5_F000 0x3FF5_FFFF 4 KB TIMG1 0x3FF6_0000 0x3FF6_0FFF 4 KB SPI2 0x3FF6_4000 0x3FF6_4FFF 4 KB SPI3 0x3FF6_5000 0x3FF6_5FFF 4 KB 26 Submit Documentation Feedback ESP32 Series Datasheet v4.0 3 Functional Description Category Peripheral Target Start Address End Address Size SYSCON 0x3FF6_6000 0x3FF6_6FFF 4 KB I2C1 0x3FF6_7000 0x3FF6_7FFF 4 KB SDMMC 0x3FF6_8000 0x3FF6_8FFF 4 KB EMAC 0x3FF6_9000 0x3FF6_AFFF 8 KB TWAI 0x3FF6_B000 0x3FF6_BFFF 4 KB PWM1 0x3FF6_C000 0x3FF6_CFFF 4 KB I2S1 0x3FF6_D000 0x3FF6_DFFF 4 KB UART2 0x3FF6_E000 0x3FF6_EFFF 4 KB PWM2 0x3FF6_F000 0x3FF6_FFFF 4 KB PWM3 0x3FF7_0000 0x3FF7_0FFF 4 KB RNG 0x3FF7_5000 0x3FF7_5FFF 4 KB 3.2 Timers and Watchdogs 3.2.1 64­bit Timers There are four general-purpose timers embedded in the chip. They are all 64-bit generic timers which are based on 16-bit prescalers and 64-bit auto-reload-capable up/down-timers. The timers feature: • A 16-bit clock prescaler, from 2 to 65536 • A 64-bit timer • Configurable up/down timer: incrementing or decrementing • Halt and resume of time-base counter • Auto-reload at alarming • Software-controlled instant reload • Level and edge interrupt generation For detailed information, please refer to Chapter Timer Group (TIMG) in ESP32 Technical Reference Manual. 3.2.2 Watchdog Timers The chip has three watchdog timers: one in each of the two timer modules (called the Main Watchdog Timer, or MWDT) and one in the RTC module (called the RTC Watchdog Timer, or RWDT). These watchdog timers are intended to recover from an unforeseen fault causing the application program to abandon its normal sequence. A watchdog timer has four stages. Each stage may trigger one of three or four possible actions upon the expiry of its programmed time period, unless the watchdog is fed or disabled. The actions are: interrupt, CPU reset, core reset, and system reset. Only the RWDT can trigger the system reset, and is able to reset the entire chip, including the RTC itself. A timeout value can be set for each stage individually. During flash boot the RWDT and the first MWDT start automatically in order to detect, and recover from, booting problems. The watchdogs have the following features: Espressif Systems 27 Submit Documentation Feedback ESP32 Series Datasheet v4.0 3 Functional Description • Four stages, each of which can be configured or disabled separately • A programmable time period for each stage • One of three or four possible actions (interrupt, CPU reset, core reset, and system reset) upon the expiry of each stage • 32-bit expiry counter • Write protection that prevents the RWDT and MWDT configuration from being inadvertently altered • SPI flash boot protection If the boot process from an SPI flash does not complete within a predetermined time period, the watchdog will reboot the entire system. For detailed information, please refer to Chapter Watchdog Timers (WDT) in ESP32 Technical Reference Manual. 3.3 System Clocks 3.3.1 CPU Clock Upon reset, an external crystal clock source is selected as the default CPU clock. The external crystal clock source also connects to a PLL to generate a high-frequency clock (typically 160 MHz). In addition, ESP32 has an internal 8 MHz oscillator. The application can select the clock source from the external crystal clock source, the PLL clock or the internal 8 MHz oscillator. The selected clock source drives the CPU clock directly, or after division, depending on the application. 3.3.2 RTC Clock The RTC clock has five possible sources: • external low-speed (32 kHz) crystal clock • external crystal clock divided by 4 • internal RC oscillator (typically about 150 kHz, and adjustable) • internal 8 MHz oscillator • internal 31.25 kHz clock (derived from the internal 8 MHz oscillator divided by 256) When the chip is in the normal power mode and needs faster CPU accessing, the application can choose the external high-speed crystal clock divided by 4 or the internal 8 MHz oscillator. When the chip operates in the low-power mode, the application chooses the external low-speed (32 kHz) crystal clock, the internal RC clock or the internal 31.25 kHz clock. 3.3.3 Audio PLL Clock The audio clock is generated by the ultra-low-noise fractional-N PLL. For detailed information, please refer to Chapter Reset and Clock in ESP32 Technical Reference Manual. 3.4 Radio The radio module consists of the following blocks: Espressif Systems 28 Submit Documentation Feedback ESP32 Series Datasheet v4.0 3 Functional Description • 2.4 GHz receiver • 2.4 GHz transmitter • bias and regulators • balun and transmit-receive switch • clock generator 3.4.1 2.4 GHz Receiver The 2.4 GHz receiver demodulates the 2.4 GHz RF signal to quadrature baseband signals and converts them to the digital domain with two high-resolution, high-speed ADCs. To adapt to varying signal channel conditions, RF filters, Automatic Gain Control (AGC), DC offset cancelation circuits and baseband filters are integrated in the chip. 3.4.2 2.4 GHz Transmitter The 2.4 GHz transmitter modulates the quadrature baseband signals to the 2.4 GHz RF signal, and drives the antenna with a high-powered Complementary Metal Oxide Semiconductor (CMOS) power amplifier. The use of digital calibration further improves the linearity of the power amplifier, enabling state-of-the-art performance in delivering up to +20.5 dBm of power for an 802.11b transmission and +18 dBm for an 802.11n transmission. Additional calibrations are integrated to cancel any radio imperfections, such as: • Carrier leakage • I/Q phase matching • Baseband nonlinearities • RF nonlinearities • Antenna matching These built-in calibration routines reduce the amount of time required for product testing, and render the testing equipment unnecessary. 3.4.3 Clock Generator The clock generator produces quadrature clock signals of 2.4 GHz for both the receiver and the transmitter. All components of the clock generator are integrated into the chip, including all inductors, varactors, filters, regulators and dividers. The clock generator has built-in calibration and self-test circuits. Quadrature clock phases and phase noise are optimized on-chip with patented calibration algorithms which ensure the best performance of the receiver and the transmitter. 3.5 Wi­Fi ESP32 implements a TCP/IP and full 802.11 b/g/n Wi-Fi MAC protocol. It supports the Basic Service Set (BSS) STA and SoftAP operations under the Distributed Control Function (DCF). Power management is handled with minimal host interaction to minimize the active-duty period. Espressif Systems 29 Submit Documentation Feedback ESP32 Series Datasheet v4.0 3 Functional Description 3.5.1 Wi­Fi Radio and Baseband The ESP32 Wi-Fi Radio and Baseband support the following features: • 802.11 b/g/n • 802.11 n MCS0-7 in both 20 MHz and 40 MHz bandwidth • 802.11 n MCS32 (RX) • 802.11 n 0.4 µs guard-interval • up to 150 Mbps of data rate • Receiving STBC 2×1 • Up to 20.5 dBm of transmitting power • Adjustable transmitting power • Antenna diversity ESP32 supports antenna diversity with an external RF switch. One or more GPIOs control the RF switch and selects the best antenna to minimize the effects of channel fading. 3.5.2 Wi­Fi MAC The ESP32 Wi-Fi MAC applies low-level protocol functions automatically. They are as follows: • 4 × virtual Wi-Fi interfaces • Simultaneous Infrastructure BSS Station mode/SoftAP mode/Promiscuous mode • RTS protection, CTS protection, Immediate Block ACK • Defragmentation • TX/RX A-MPDU, RX A-MSDU • TXOP • WMM • CCMP (CBC-MAC, counter mode), TKIP (MIC, RC4), WAPI (SMS4), WEP (RC4) and CRC • Automatic beacon monitoring (hardware TSF) 3.6 Bluetooth The chip integrates a Bluetooth link controller and Bluetooth baseband, which carry out the baseband protocols and other low-level link routines, such as modulation/demodulation, packet processing, bit stream processing, frequency hopping, etc. 3.6.1 Bluetooth Radio and Baseband The Bluetooth Radio and Baseband support the following features: • Class-1, class-2 and class-3 transmit output powers, and a dynamic control range of up to 21 dB • π/4 DQPSK and 8 DPSK modulation Espressif Systems 30 Submit Documentation Feedback ESP32 Series Datasheet v4.0 3 Functional Description • High performance in NZIF receiver sensitivity with a minimum sensitivity of -94 dBm • Class-1 operation without external PA • Internal SRAM allows full-speed data-transfer, mixed voice and data, and full piconet operation • Logic for forward error correction, header error control, access code correlation, CRC, demodulation, encryption bit stream generation, whitening and transmit pulse shaping • ACL, SCO, eSCO, and AFH • A-law, µ-law, and CVSD digital audio CODEC in PCM interface • SBC audio CODEC • Power management for low-power applications • SMP with 128-bit AES 3.6.2 Bluetooth Interface • Provides UART HCI interface, up to 4 Mbps • Provides SDIO/SPI HCI interface • Provides PCM/I2S audio interface 3.6.3 Bluetooth Stack The Bluetooth stack of the chip is compliant with the Bluetooth v4.2 BR/EDR and Bluetooth LE specifications. 3.6.4 Bluetooth Link Controller The link controller operates in three major states: standby, connection and sniff. It enables multiple connections, and other operations, such as inquiry, page, and secure simple-pairing, and therefore enables Piconet and Scatternet. Below are the features: • Classic Bluetooth – Device Discovery (inquiry, and inquiry scan) – Connection establishment (page, and page scan) – Multi-connections – Asynchronous data reception and transmission – Synchronous links (SCO/eSCO) – Master/Slave Switch – Adaptive Frequency Hopping and Channel assessment – Broadcast encryption – Authentication and encryption – Secure Simple-Pairing – Multi-point and scatternet management Espressif Systems 31 Submit Documentation Feedback ESP32 Series Datasheet v4.0 3 Functional Description – Sniff mode – Connectionless Slave Broadcast (transmitter and receiver) – Enhanced power control – Ping • Bluetooth Low Energy – Advertising – Scanning – Simultaneous advertising and scanning – Multiple connections – Asynchronous data reception and transmission – Adaptive Frequency Hopping and Channel assessment – Connection parameter update – Data Length Extension – Link Layer Encryption – LE Ping 3.7 RTC and Low­Power Management With the use of advanced power-management technologies, ESP32 can switch between different power modes. • Power modes – Active mode: The chip radio is powered on. The chip can receive, transmit, or listen. – Modem­sleep mode: The CPU is operational and the clock is configurable. The Wi-Fi/Bluetooth baseband and radio are disabled. – Light­sleep mode: The CPU is paused. The RTC memory and RTC peripherals, as well as the ULP coprocessor are running. Any wake-up events (MAC, host, RTC timer, or external interrupts) will wake up the chip. – Deep­sleep mode: Only the RTC memory and RTC peripherals are powered on. Wi-Fi and Bluetooth connection data are stored in the RTC memory. The ULP coprocessor is functional. – Hibernation mode: The internal 8 MHz oscillator and ULP coprocessor are disabled. The RTC recovery memory is powered down. Only one RTC timer on the slow clock and certain RTC GPIOs are active. The RTC timer or the RTC GPIOs can wake up the chip from the Hibernation mode. Table 8: Power Consumption by Power Modes Power mode Description Wi-Fi Tx packet Active (RF working) Wi-Fi/BT Tx packet Wi-Fi/BT Rx and listening Espressif Systems 32 Submit Documentation Feedback Power consumption Please refer to Table 17 for details. ESP32 Series Datasheet v4.0 3 Functional Description Power mode Description 240 MHz Modem-sleep The CPU is powered on. 160 MHz * * Normal speed: 80 MHz Light-sleep Deep-sleep Hibernation Power off Power consumption Dual-core chip(s) 30 mA ~ 68 mA Single-core chip(s) N/A Dual-core chip(s) 27 mA ~ 44 mA Single-core chip(s) 27 mA ~ 34 mA Dual-core chip(s) 20 mA ~ 31 mA Single-core chip(s) 20 mA ~ 25 mA - 0.8 mA The ULP coprocessor is powered on. 150 µA ULP sensor-monitored pattern 100 µA @1% duty RTC timer + RTC memory 10 µA RTC timer only 5 µA CHIP_PU is set to low level, the chip is powered off. 1 µA Note: • * Among the ESP32 series of SoCs, ESP32-D0WD-V3, ESP32-D0WDR2-V3, ESP32-U4WDH, ESP32-D0WD (NRND), ESP32-D0WDQ6 (NRND), and ESP32-D0WDQ6-V3 (NRND) have a maximum CPU frequency of 240 MHz, ESP32-S0WD (NRND) has a maximum CPU frequency of 160 MHz. • When Wi-Fi is enabled, the chip switches between Active and Modem-sleep modes. Therefore, power consumption changes accordingly. • In Modem-sleep mode, the CPU frequency changes automatically. The frequency depends on the CPU load and the peripherals used. • During Deep-sleep, when the ULP coprocessor is powered on, peripherals such as GPIO and RTC I2C are able to operate. • When the system works in the ULP sensor-monitored pattern, the ULP coprocessor works with the ULP sensor periodically and the ADC works with a duty cycle of 1%, so the power consumption is 100 µA. Espressif Systems 33 Submit Documentation Feedback ESP32 Series Datasheet v4.0 4 Peripherals and Sensors 4 Peripherals and Sensors 4.1 Descriptions of Peripherals and Sensors 4.1.1 General Purpose Input/Output Interface (GPIO) ESP32 has 34 GPIO pins which can be assigned various functions by programming the appropriate registers. There are several kinds of GPIOs: digital-only, analog-enabled, capacitive-touch-enabled, etc. Analog-enabled GPIOs and Capacitive-touch-enabled GPIOs can be configured as digital GPIOs. Most of the digital GPIOs can be configured as internal pull-up or pull-down, or set to high impedance. When configured as an input, the input value can be read through the register. The input can also be set to edge-trigger or level-trigger to generate CPU interrupts. Most of the digital IO pins are bi-directional, non-inverting and tristate, including input and output buffers with tristate control. These pins can be multiplexed with other functions, such as the SDIO, UART, SPI, etc. (More details can be found in the Appendix, Table IO_MUX.) For low-power operations, the GPIOs can be set to hold their states. For more information, please refer to Chapter IO MUX and GPIO Matrix (GPIO, IO MUX) in ESP32 Technical Reference Manual. 4.1.2 Analog­to­Digital Converter (ADC) ESP32 integrates 12-bit SAR ADCs and supports measurements on 18 channels (analog-enabled pins). The ULP coprocessor in ESP32 is also designed to measure voltage, while operating in the sleep mode, which enables low-power consumption. The CPU can be woken up by a threshold setting and/or via other triggers. With appropriate settings, the ADCs can be configured to measure voltage on 18 pins maximum. Table 9 describes the ADC characteristics. Table 9: ADC Characteristics Parameter DNL (Differential nonlinearity) INL (Integral nonlinearity) Sampling rate Description Min Max Unit –7 7 LSB –12 12 LSB RTC controller – 200 ksps DIG controller – 2 RTC controller; ADC connected to an external 100 nF capacitor; DC signal input; ambient temperature at 25 °C; Wi-Fi&Bluetooth off Msps Notes: • When atten = 3 and the measurement result is above 3000 (voltage at approx. 2450 mV), the ADC accuracy will be worse than described in the table above. • To get better DNL results, users can take multiple sampling tests with a filter, or calculate the average value. • The input voltage range of GPIO pins within VDD3P3_RTC domain should strictly follow the DC characteristics provided in Table 15. Otherwise, measurement errors may be introduced, and chip performance may be affected. By default, there are ±6% differences in measured results between chips. ESP-IDF provides couple of calibration methods for ADC1. Results after calibration using eFuse Vref value are shown in Table 10. For higher accuracy, Espressif Systems 34 Submit Documentation Feedback ESP32 Series Datasheet v4.0 4 Peripherals and Sensors users may apply other calibration methods provided in ESP-IDF, or implement their own. Table 10: ADC Calibration Results Parameter Total error Description Min Max Unit Atten = 0, effective measurement range of 100 ∼ 950 mV –23 23 mV Atten = 1, effective measurement range of 100 ∼ 1250 mV –30 30 mV Atten = 2, effective measurement range of 150 ∼ 1750 mV –40 40 mV Atten = 3, effective measurement range of 150 ∼ 2450 mV –60 60 mV For more information, please refer to Chapter On-Chip Sensors and Analog Signal Processing in ESP32 Technical Reference Manual. 4.1.3 Hall Sensor ESP32 integrates a Hall sensor based on an N-carrier resistor. When the chip is in the magnetic field, the Hall sensor develops a small voltage laterally on the resistor, which can be directly measured by the ADC. For more information, please refer to Chapter On-Chip Sensors and Analog Signal Processing in ESP32 Technical Reference Manual. 4.1.4 Digital­to­Analog Converter (DAC) Two 8-bit DAC channels can be used to convert two digital signals into two analog voltage signal outputs. The design structure is composed of integrated resistor strings and a buffer. This dual DAC supports power supply as input voltage reference. The two DAC channels can also support independent conversions. For more information, please refer to Chapter On-Chip Sensors and Analog Signal Processing in ESP32 Technical Reference Manual. 4.1.5 Touch Sensor ESP32 has 10 capacitive-sensing GPIOs, which detect variations induced by touching or approaching the GPIOs with a finger or other objects. The low-noise nature of the design and the high sensitivity of the circuit allow relatively small pads to be used. Arrays of pads can also be used, so that a larger area or more points can be detected. The 10 capacitive-sensing GPIOs are listed in Table 11. Table 11: Capacitive­Sensing GPIOs Available on ESP32 Capacitive-sensing signal name Espressif Systems Pin name T0 GPIO4 T1 GPIO0 T2 GPIO2 T3 MTDO T4 MTCK T5 MTDI T6 MTMS T7 GPIO27 T8 32K_XN T9 32K_XP 35 Submit Documentation Feedback ESP32 Series Datasheet v4.0 4 Peripherals and Sensors For more information, please refer to Chapter On-Chip Sensors and Analog Signal Processing in ESP32 Technical Reference Manual. 4.1.6 Ultra­Low­Power (ULP) Coprocessor The ULP coprocessor and RTC memory remain powered on during the Deep-sleep mode. Hence, the developer can store a program for the ULP coprocessor in the RTC slow memory to access the peripheral devices, internal timers and internal sensors during the Deep-sleep mode. This is useful for designing applications where the CPU needs to be woken up by an external event, or a timer, or a combination of the two, while maintaining minimal power consumption. For more information, please refer to Chapter ULP Coprocessor (ULP) in ESP32 Technical Reference Manual. 4.1.7 Ethernet MAC Interface An IEEE-802.3-2008-compliant Media Access Controller (MAC) is provided for Ethernet LAN communications. ESP32 requires an external physical interface device (PHY) to connect to the physical LAN bus (twisted-pair, fiber, etc.). The PHY is connected to ESP32 through 17 signals of MII or nine signals of RMII. The following features are supported on the Ethernet MAC (EMAC) interface: • 10 Mbps and 100 Mbps rates • Dedicated DMA controller allowing high-speed transfer between the dedicated SRAM and Ethernet MAC • Tagged MAC frame (VLAN support) • Half-duplex (CSMA/CD) and full-duplex operation • MAC control sublayer (control frames) • 32-bit CRC generation and removal • Several address-filtering modes for physical and multicast address (multicast and group addresses) • 32-bit status code for each transmitted or received frame • Internal FIFOs to buffer transmit and receive frames. The transmit FIFO and the receive FIFO are both 512 words (32-bit) • Hardware PTP (Precision Time Protocol) in accordance with IEEE 1588 2008 (PTP V2) • 25 MHz/50 MHz clock output For more information, please refer to Chapter Ethernet Media Access Controller (MAC) in ESP32 Technical Reference Manual. 4.1.8 SD/SDIO/MMC Host Controller An SD/SDIO/MMC host controller is available on ESP32, which supports the following features: • Secure Digital memory (SD mem Version 3.0 and Version 3.01) • Secure Digital I/O (SDIO Version 3.0) • Consumer Electronics Advanced Transport Architecture (CE-ATA Version 1.1) • Multimedia Cards (MMC Version 4.41, eMMC Version 4.5 and Version 4.51) Espressif Systems 36 Submit Documentation Feedback ESP32 Series Datasheet v4.0 4 Peripherals and Sensors The controller allows up to 80 MHz clock output in three different data-bus modes: 1-bit, 4-bit, and 8-bit. It supports two SD/SDIO/MMC4.41 cards in a 4-bit data-bus mode. It also supports one SD card operating at 1.8 V. For more information, please refer to Chapter SD/MMC Host Controller in ESP32 Technical Reference Manual. 4.1.9 SDIO/SPI Slave Controller ESP32 integrates an SD device interface that conforms to the industry-standard SDIO Card Specification Version 2.0, and allows a host controller to access the SoC, using the SDIO bus interface and protocol. ESP32 acts as the slave on the SDIO bus. The host can access the SDIO-interface registers directly and can access shared memory via a DMA engine, thus maximizing performance without engaging the processor cores. The SDIO/SPI slave controller supports the following features: • SPI, 1-bit SDIO, and 4-bit SDIO transfer modes over the full clock range from 0 to 50 MHz • Configurable sampling and driving clock edge • Special registers for direct access by host • Interrupts to host for initiating data transfer • Automatic loading of SDIO bus data and automatic discarding of padding data • Block size of up to 512 bytes • Interrupt vectors between the host and the slave, allowing both to interrupt each other • Supports DMA for data transfer For more information, please refer to Chapter SDIO Slave Controller in ESP32 Technical Reference Manual. 4.1.10 Universal Asynchronous Receiver Transmitter (UART) ESP32 has three UART interfaces, i.e., UART0, UART1, and UART2, which provide asynchronous communication (RS232 and RS485) and IrDA support, communicating at a speed of up to 5 Mbps. UART provides hardware management of the CTS and RTS signals and software flow control (XON and XOFF). All of the interfaces can be accessed by the DMA controller or directly by the CPU. For more information, please refer to Chapter UART Controller (UART) in ESP32 Technical Reference Manual. 4.1.11 I2C Interface ESP32 has two I2C bus interfaces which can serve as I2C master or slave, depending on the user’s configuration. The I2C interfaces support: • Standard mode (100 Kbit/s) • Fast mode (400 Kbit/s) • Up to 5 MHz, yet constrained by SDA pull-up strength • 7-bit/10-bit addressing mode • Dual addressing mode Espressif Systems 37 Submit Documentation Feedback ESP32 Series Datasheet v4.0 4 Peripherals and Sensors Users can program command registers to control I2C interfaces, so that they have more flexibility. For more information, please refer to Chapter I2C Controller (I2C) in ESP32 Technical Reference Manual. 4.1.12 I2S Interface Two standard I2S interfaces are available in ESP32. They can be operated in master or slave mode, in full duplex and half-duplex communication modes, and can be configured to operate with an 8-/16-/32-/48-/64-bit resolution as input or output channels. BCK clock frequency, from 10 kHz up to 40 MHz, is supported. When one or both of the I2S interfaces are configured in the master mode, the master clock can be output to the external DAC/CODEC. Both of the I2S interfaces have dedicated DMA controllers. PDM and BT PCM interfaces are supported. For more information, please refer to Chapter I2S Controller (I2S) in ESP32 Technical Reference Manual. 4.1.13 Infrared Remote Controller (RMT) The infrared remote controller supports eight channels of infrared remote transmission and receiving. By programming the pulse waveform, it supports various infrared protocols. Eight channels share a 512 x 32-bit block of memory to store the transmitting or receiving waveform. For more information, please refer to Chapter Remote Control Peripheral (RMT) in ESP32 Technical Reference Manual. 4.1.14 Pulse Counter (PCNT) The pulse counter captures pulse and counts pulse edges through seven modes. It has eight channels, each of which captures four signals at a time. The four input signals include two pulse signals and two control signals. When the counter reaches a defined threshold, an interrupt is generated. For more information, please refer to Chapter Pulse Count Controller (PCNT) in ESP32 Technical Reference Manual. 4.1.15 Pulse Width Modulation (PWM) The Pulse Width Modulation (PWM) controller can be used for driving digital motors and smart lights. The controller consists of PWM timers, the PWM operator and a dedicated capture sub-module. Each timer provides timing in synchronous or independent form, and each PWM operator generates a waveform for one PWM channel. The dedicated capture sub-module can accurately capture events with external timing. For more information, please refer to Chapter Motor Control PWM (PWM) in ESP32 Technical Reference Manual. 4.1.16 LED PWM The LED PWM controller can generate 16 independent channels of digital waveforms with configurable periods and duties. The 16 channels of digital waveforms operate with an APB clock of 80 MHz. Eight of these channels have the option of using the 8 MHz oscillator clock. Each channel can select a 20-bit timer with configurable counting range, while its accuracy of duty can be up to 16 bits within a 1 ms period. Espressif Systems 38 Submit Documentation Feedback ESP32 Series Datasheet v4.0 4 Peripherals and Sensors The software can change the duty immediately. Moreover, each channel automatically supports step-by-step duty increase or decrease, which is useful for the LED RGB color-gradient generator. For more information, please refer to Chapter LED PWM Controller (LEDC) in ESP32 Technical Reference Manual. 4.1.17 Serial Peripheral Interface (SPI) ESP32 features three SPIs (SPI, HSPI and VSPI) in slave and master modes in 1-line full-duplex and 1/2/4-line half-duplex communication modes. These SPIs also support the following general-purpose SPI features: • Four modes of SPI transfer format, which depend on the polarity (CPOL) and the phase (CPHA) of the SPI clock • Up to 80 MHz (The actual speed it can reach depends on the selected pads, PCB tracing, peripheral characteristics, etc.) • up to 64-byte FIFO All SPIs can also be connected to the external flash/SRAM and LCD. Each SPI can be served by DMA controllers. For more information, please refer to Chapter SPI Controller (SPI) in ESP32 Technical Reference Manual. 4.1.18 TWAI Controller ESP32 family has a TWAI® controller with the following features: • compatible with ISO 11898-1 protocol (CAN Specification 2.0) • standard frame format (11-bit ID) and extended frame format (29-bit ID) • bit rates: – from 25 Kbit/s to 1 Mbit/s in chip revision v0.0/v1.0/v1.1 – from 12.5 Kbit/s to 1 Mbit/s in chip revision v3.0/v3.1 • multiple modes of operation: Normal, Listen Only, and Self-Test • 64-byte receive FIFO • special transmissions: single-shot transmissions and self reception • acceptance filter (single and dual filter modes) • error detection and handling: error counters, configurable error interrupt threshold, error code capture, arbitration lost capture For more information, please refer to Chapter Two-wire Automotive Interface (TWAI) in ESP32 Technical Reference Manual. 4.1.19 Accelerator ESP32 is equipped with hardware accelerators of general algorithms, such as AES (FIPS PUB 197), SHA (FIPS PUB 180-4), RSA, and ECC, which support independent arithmetic, such as Big Integer Multiplication and Big Integer Modular Multiplication. The maximum operation length for RSA, ECC, Big Integer Multiply and Big Integer Modular Multiplication is 4096 bits. Espressif Systems 39 Submit Documentation Feedback ESP32 Series Datasheet v4.0 4 Peripherals and Sensors The hardware accelerators greatly improve operation speed and reduce software complexity. They also support code encryption and dynamic decryption, which ensures that code in the flash will not be hacked. 4.2 Peripheral Pin Configurations Table 12: Peripheral Pin Configurations Interface ADC DAC Touch Sensor JTAG Espressif Systems Signal Pin Function ADC1_CH0 SENSOR_VP ADC1_CH1 SENSOR_CAPP ADC1_CH2 SENSOR_CAPN ADC1_CH3 SENSOR_VN ADC1_CH4 32K_XP ADC1_CH5 32K_XN ADC1_CH6 VDET_1 ADC1_CH7 VDET_2 ADC2_CH0 GPIO4 ADC2_CH1 GPIO0 ADC2_CH2 GPIO2 ADC2_CH3 MTDO ADC2_CH4 MTCK ADC2_CH5 MTDI ADC2_CH6 MTMS ADC2_CH7 GPIO27 ADC2_CH8 GPIO25 ADC2_CH9 GPIO26 DAC_1 GPIO25 DAC_2 GPIO26 TOUCH0 GPIO4 TOUCH1 GPIO0 TOUCH2 GPIO2 TOUCH3 MTDO TOUCH4 MTCK TOUCH5 MTDI TOUCH6 MTMS TOUCH7 GPIO27 TOUCH8 32K_XN TOUCH9 32K_XP MTDI MTDI MTCK MTCK MTMS MTMS MTDO MTDO Two 12-bit SAR ADCs Two 8-bit DACs Capacitive touch sensors JTAG for software debugging 40 Submit Documentation Feedback ESP32 Series Datasheet v4.0 4 Peripherals and Sensors Interface Signal Pin Function HS2_CLK MTMS HS2_CMD MTDO SD/SDIO/MMC Host HS2_DATA0 GPIO2 Controller HS2_DATA1 GPIO4 HS2_DATA2 MTDI HS2_DATA3 MTCK Supports SD memory card V3.01 standard PWM0_OUT0~2 PWM1_OUT_IN0~2 Three channels of 16-bit timers generate PWM0_FLT_IN0~2 Motor PWM PWM1_FLT_IN0~2 PWM0_CAP_IN0~2 PWM waveforms. Each channel has a pair Any GPIO Pins of output signals, three fault detection signals, three event-capture signals, and PWM1_CAP_IN0~2 three sync signals. PWM0_SYNC_IN0~2 PWM1_SYNC_IN0~2 SD_CLK MTMS SD_CMD MTDO SDIO/SPI Slave SD_DATA0 GPIO2 Controller SD_DATA1 GPIO4 SD_DATA2 MTDI SD_DATA3 MTCK SDIO interface that conforms to the industry standard SDIO 2.0 card specification U0RXD_in U0CTS_in U0DSR_in U0TXD_out U0RTS_out U0DTR_out UART U1RXD_in Any GPIO Pins U1CTS_in Three UART devices with hardware flow-control and DMA U1TXD_out U1RTS_out U2RXD_in U2CTS_in U2TXD_out U2RTS_out I2CEXT0_SCL_in I2CEXT0_SDA_in I2CEXT1_SCL_in I2C I2CEXT1_SDA_in I2CEXT0_SCL_out Any GPIO Pins Two I2C devices in slave or master mode I2CEXT0_SDA_out I2CEXT1_SCL_out I2CEXT1_SDA_out LED PWM Espressif Systems ledc_hs_sig_out0~7 ledc_ls_sig_out0~7 Any GPIO Pins 16 independent channels @80 MHz clock/RTC CLK. Duty accuracy: 16 bits. 41 Submit Documentation Feedback ESP32 Series Datasheet v4.0 4 Peripherals and Sensors Interface Signal Pin Function I2S0I_DATA_in0~15 I2S0O_BCK_in I2S0O_WS_in I2S0I_BCK_in I2S0I_WS_in I2S0I_H_SYNC I2S0I_V_SYNC I2S0I_H_ENABLE I2S0O_BCK_out I2S0O_WS_out Stereo input and output from/to the audio I2S0I_BCK_out codec; parallel LCD data output; parallel I2S0I_WS_out I2S I2S0O_DATA_out0~23 I2S1I_DATA_in0~15 camera data input. Any GPIO Pins I2S1O_BCK_in Note: I2S0_CLK and I2S1_CLK can only I2S1O_WS_in be mapped to GPIO0, U0RXD (GPIO3), or I2S1I_BCK_in U0TXD (GPIO1) via IO MUX by selecting I2S1I_WS_in GPIO functions CLK_OUT1, CLK_OUT2, I2S1I_H_SYNC and CLK_OUT3. For more information, see I2S1I_V_SYNC Table 4-3. IO MUX Pad Summary in I2S1I_H_ENABLE ESP32 Technical Reference Manual. I2S1O_BCK_out I2S1O_WS_out I2S1I_BCK_out I2S1I_WS_out I2S1O_DATA_out0~23 RMT I2S0_CLK GPIO0, U0RXD, I2S1_CLK or U0TXD RMT_SIG_IN0~7 RMT_SIG_OUT0~7 Any GPIO Pins HSPIQ_in/_out chip-select, MOSI and MISO. These SPIs HSPICLK_in/_out can be connected to LCD and other HSPI_CS0_in/_out external devices. They support the HSPI_CS1_out HSPI_CS2_out SPI VSPIQ_in/_out receiver of various waveforms Standard SPI consists of clock, HSPID_in/_out General Purpose Eight channels for an IR transmitter and following features: Any GPIO Pins • Both master and slave modes; • Four sub-modes of the SPI transfer VSPID_in/_out format; VSPICLK_in/_out • Configurable SPI frequency; VSPI_CS0_in/_out • Up to 64 bytes of FIFO and DMA. VSPI_CS1_out VSPI_CS2_out Espressif Systems 42 Submit Documentation Feedback ESP32 Series Datasheet v4.0 4 Peripherals and Sensors Interface Parallel QSPI EMAC Signal Pin Function SPIHD SD_DATA_2 SPIWP SD_DATA_3 SPICS0 SD_CMD SPICLK SD_CLK SPIQ SD_DATA_0 SPID SD_DATA_1 HSPICLK MTMS HSPICS0 MTDO HSPIQ MTDI HSPID MTCK HSPIHD GPIO4 HSPIWP GPIO2 VSPICLK GPIO18 VSPICS0 GPIO5 VSPIQ GPIO19 VSPID GPIO23 VSPIHD GPIO21 VSPIWP GPIO22 EMAC_TX_CLK GPIO0 EMAC_RX_CLK GPIO5 EMAC_TX_EN GPIO21 EMAC_TXD0 GPIO19 EMAC_TXD1 GPIO22 EMAC_TXD2 MTMS EMAC_TXD3 MTDI EMAC_RX_ER MTCK EMAC_RX_DV GPIO27 EMAC_RXD0 GPIO25 EMAC_RXD1 GPIO26 EMAC_RXD2 U0TXD EMAC_RXD3 MTDO EMAC_CLK_OUT GPIO16 Supports Standard SPI, Dual SPI, and Quad SPI that can be connected to the external flash and SRAM Ethernet MAC with MII/RMII interface EMAC_CLK_OUT_180 GPIO17 Espressif Systems EMAC_TX_ER GPIO4 EMAC_MDC_out Any GPIO Pins EMAC_MDI_in Any GPIO Pins EMAC_MDO_out Any GPIO Pins EMAC_CRS_out Any GPIO Pins EMAC_COL_out Any GPIO Pins 43 Submit Documentation Feedback ESP32 Series Datasheet v4.0 4 Peripherals and Sensors Interface Signal Pin Function pcnt_sig_ch0_in0 pcnt_sig_ch1_in0 pcnt_ctrl_ch0_in0 pcnt_ctrl_ch1_in0 pcnt_sig_ch0_in1 pcnt_sig_ch1_in1 pcnt_ctrl_ch0_in1 pcnt_ctrl_ch1_in1 pcnt_sig_ch0_in2 pcnt_sig_ch1_in2 pcnt_ctrl_ch0_in2 pcnt_ctrl_ch1_in2 pcnt_sig_ch0_in3 pcnt_sig_ch1_in3 pcnt_ctrl_ch0_in3 Pulse Counter pcnt_ctrl_ch1_in3 pcnt_sig_ch0_in4 Operating in seven different modes, the Any GPIO Pins pulse counter captures pulse and counts pulse edges. pcnt_sig_ch1_in4 pcnt_ctrl_ch0_in4 pcnt_ctrl_ch1_in4 pcnt_sig_ch0_in5 pcnt_sig_ch1_in5 pcnt_ctrl_ch0_in5 pcnt_ctrl_ch1_in5 pcnt_sig_ch0_in6 pcnt_sig_ch1_in6 pcnt_ctrl_ch0_in6 pcnt_ctrl_ch1_in6 pcnt_sig_ch0_in7 pcnt_sig_ch1_in7 pcnt_ctrl_ch0_in7 pcnt_ctrl_ch1_in7 twai_rx TWAI twai_tx twai_bus_off_on Any GPIO Pins Compatible with ISO 11898-1 protocol (CAN Specification 2.0) twai_clkout Espressif Systems 44 Submit Documentation Feedback ESP32 Series Datasheet v4.0 5 Electrical Characteristics 5 Electrical Characteristics 5.1 Absolute Maximum Ratings Stresses beyond the absolute maximum ratings listed in the table below may cause permanent damage to the device. These are stress ratings only, and do not refer to the functional operation of the device that should follow the recommended operating conditions. Table 13: Absolute Maximum Ratings Symbol Parameter VDDA, VDD3P3, VDD3P3_RTC, Voltage applied to power supply pins per VDD3P3_CPU, VDD_SDIO power domain Ioutput * Cumulative IO output current Tstore Storage temperature Min Max Unit –0.3 3.6 - 1200 mA –40 150 °C V * The chip worked properly after a 24-hour test in ambient temperature at 25 °C, and the IOs in three domains (VDD3P3_RTC, VDD3P3_CPU, VDD_SDIO) output high logic level to ground. 5.2 Recommended Operating Conditions Table 14: Recommended Operating Conditions Symbol VDDA, VDD3P3_RTC, Parameter note 1 VDD_SDIO (3.3 V mode) VDD3P3_CPU VDD3P3, note 2 Voltage applied to power supply pins per power domain Voltage applied to power supply pin Current delivered by external power IV DD supply T note 4 Operating temperature Min Typ Max Unit 2.3/3.0note 3 3.3 3.6 V 1.8 3.3 3.6 V 0.5 - - A –40 - 125 °C 1. When writing eFuse, VDD3P3_RTC should be at least 3.3 V. 2. • VDD_SDIO works as the power supply for the related IO, and also for an external device. Please refer to the Appendix IO_MUX of this datasheet for more details. • VDD_SDIO can be sourced internally by the ESP32 from the VDD3P3_RTC power domain: – When VDD_SDIO operates at 3.3 V, it is driven directly by VDD3P3_RTC through a 6 Ω resistor, therefore, there will be some voltage drop from VDD3P3_RTC. – When VDD_SDIO operates at 1.8 V, it can be generated from ESP32’s internal LDO. The maximum current this LDO can offer is 40 mA, and the output voltage range is 1.65 V ~ 2.0 V. • VDD_SDIO can also be driven by an external power supply. • Please refer to Power Scheme, section 2.3, for more information. 3. • Chips with a 3.3 V flash or PSRAM embedded: this minimum voltage is 3.0 V; • Chips with no flash or PSRAM embedded: this minimum voltage is 2.3 V; • For more information, see Table 25 ESP32 Ordering Information. 4. • The operating temperature of ESP32-U4WDH ranges from –40 °C to 105 °C, due to the flash embedded in it. • The operating temperature of ESP32-D0WDR2-V3 ranges from -40 °C to 85 °C, due to the PSRAM embedded in it. • The other chips in this series have no embedded flash or PSRAM, so their range of operating temperatures is –40 °C ~ 125 °C. Espressif Systems 45 Submit Documentation Feedback ESP32 Series Datasheet v4.0 5 Electrical Characteristics 5.3 DC Characteristics (3.3 V, 25 °C) Table 15: DC Characteristics (3.3 V, 25 °C) Symbol Min Typ Pin capacitance - 2 VIH High-level input voltage 1 - VDD +0.3 V VIL Low-level input voltage –0.3 - 0.25×VDD1 V IIH High-level input current - - 50 nA IIL Low-level input current - - 50 nA VOH High-level output voltage 0.8×VDD1 - - V VOL Low-level output voltage - - 0.1×VDD1 V - 40 - mA - 40 - mA - 20 - mA - 28 - mA CIN Parameter High-level source current 1 (VDD = 3.3 V, IOH 0.75×VDD VDD3P3_CPU power domain 1, 2 VDD3P3_RTC VOH >= 2.64 V, output drive strength set to the maximum) power domain 1, 2 VDD_SDIO power domain 1, 3 Max Unit - 1 pF Low-level sink current IOL (VDD1 = 3.3 V, VOL = 0.495 V, output drive strength set to the maximum) RP U Resistance of internal pull-up resistor - 45 - kΩ RP D Resistance of internal pull-down resistor - 45 - kΩ - - 0.6 VIL_nRST Low-level input voltage of CHIP_PU to power off the chip V Notes: 1. Please see Table IO_MUX for IO’s power domain. VDD is the I/O voltage for a particular power domain of pins. 2. For VDD3P3_CPU and VDD3P3_RTC power domain, per-pin current sourced in the same domain is gradually reduced from around 40 mA to around 29 mA, VOH >=2.64 V, as the number of current-source pins increases. 3. For VDD_SDIO power domain, per-pin current sourced in the same domain is gradually reduced from around 30 mA to around 10 mA, VOH >=2.64 V, as the number of current-source pins increases. 5.4 Reliability Qualifications ESP32 chip series passed all reliability qualifications listed in Table 16. Table 16: Reliability Qualifications Test Item HTOL (High Temperature Operating Life) ESD (Electro-Static Discharge Sensitivity) Latch up Preconditioning Espressif Systems Test Condition Test Standard 125 °C, 1000 hours JESD22-A108 HBM (Human Body Mode) 1 ± 2000 V CDM (Charge Device Mode) 2 ± 500 V Current trigger ± 200 mA Voltage trigger 1.5 × VDDmax JESD22-A114 JESD22-C101F JESD78 Bake 24 hours @125 °C J-STD-020, Moisture soak (level 3: 192 hours @30 °C, 60% RH) JESD47, IR reflow solder: 260 + 0 °C, 20 seconds, three times JESD22-A113 46 Submit Documentation Feedback ESP32 Series Datasheet v4.0 5 Electrical Characteristics Test Item TCT (Temperature Cycling Test) Autoclave Test uHAST (Highly Accelerated Stress Test, unbiased) HTSL (High Temperature Storage Life) Test Condition Test Standard –65 °C / 150 °C, 500 cycles JESD22-A104 121 °C, 100% RH, 96 hours JESD22-A102 130 °C, 85% RH, 96 hours JESD22-A118 150 °C, 1000 hours JESD22-A103 1. JEDEC document JEP155 states that 500 V HBM allows safe manufacturing with a standard ESD control process. 2. JEDEC document JEP157 states that 250 V CDM allows safe manufacturing with a standard ESD control process. 5.5 RF Power­Consumption Specifications The power consumption measurements are taken with a 3.3 V supply at 25 °C of ambient temperature at the RF port. All transmitters’ measurements are based on a 50% duty cycle. Table 17: RF Power­Consumption Specifications Mode Min Typ Max Unit Transmit 802.11b, DSSS 1 Mbps, POUT = +19.5 dBm - 240 - mA Transmit 802.11g, OFDM 54 Mbps, POUT = +16 dBm - 190 - mA Transmit 802.11n, OFDM MCS7, POUT = +14 dBm - 180 - mA Receive 802.11b/g/n - 95 ~ 100 - mA Transmit BT/BLE, POUT = 0 dBm - 130 - mA Receive BT/BLE - 95 ~ 100 - mA Typ Max Unit MHz 5.6 Wi­Fi Radio Table 18: Wi­Fi Radio Characteristics Parameter Condition Operating frequency range Output impedance TX power note3 Sensitivity Espressif Systems note2 note1 Min - 2412 - 2484 - - note 2 - 12 13 14 dBm 18.5 19.5 20.5 dBm 11b, 1 Mbps - –98 - dBm 11b, 11 Mbps - –88 - dBm 11g, 6 Mbps - –93 - dBm 11g, 54 Mbps - –75 - dBm 11n, HT20, MCS0 - –93 - dBm 11n, HT20, MCS7 - –73 - dBm 11n, HT40, MCS0 - –90 - dBm 11n, HT40, MCS7 - –70 - dBm 11n, MCS7 11b mode 47 Submit Documentation Feedback Ω ESP32 Series Datasheet v4.0 5 Electrical Characteristics Parameter Condition Adjacent channel rejection Min Typ Max Unit 11g, 6 Mbps - 27 - dB 11g, 54 Mbps - 13 - dB 11n, HT20, MCS0 - 27 - dB 11n, HT20, MCS7 - 12 - dB 1. Device should operate in the frequency range allocated by regional regulatory authorities. Target operating frequency range is configurable by software. 2. The typical value of ESP32’s Wi-Fi radio output impedance is different between chips in different QFN packages. For ESP32 chips with a QFN 6×6 package, the value is 30+j10 Ω. For ESP32 chips with a QFN 5×5 package, the value is 35+j10 Ω. 3. Target TX power is configurable based on device or certification requirements. 5.7 Bluetooth Radio 5.7.1 Receiver – Basic Data Rate Table 19: Receiver Characteristics – Basic Data Rate Parameter Conditions Min Typ Max Unit Sensitivity @0.1% BER - –90 –89 –88 dBm Maximum received signal @0.1% BER - 0 - - dBm Co-channel C/I - - +7 - dB F = F0 + 1 MHz - - –6 dB F = F0 – 1 MHz - - –6 dB F = F0 + 2 MHz - - –25 dB F = F0 – 2 MHz - - –33 dB F = F0 + 3 MHz - - –25 dB F = F0 – 3 MHz - - –45 dB 30 MHz ~ 2000 MHz –10 - - dBm 2000 MHz ~ 2400 MHz –27 - - dBm 2500 MHz ~ 3000 MHz –27 - - dBm 3000 MHz ~ 12.5 GHz –10 - - dBm - –36 - - dBm Adjacent channel selectivity C/I Out-of-band blocking performance Intermodulation 5.7.2 Transmitter – Basic Data Rate Table 20: Transmitter Characteristics – Basic Data Rate Parameter Conditions Min Typ Max RF transmit power (see note under Table 20) - - 0 - dBm Gain control step - - 3 - dB RF power control range - –12 - +9 dBm +20 dB bandwidth - - 0.9 - MHz F = F0 ± 2 MHz - –47 - dBm F = F0 ± 3 MHz - –55 - dBm Adjacent channel transmit power Espressif Systems 48 Submit Documentation Feedback Unit ESP32 Series Datasheet v4.0 5 Electrical Characteristics Parameter Conditions Min Typ Max Unit F = F0 ± > 3 MHz - –60 - ∆ f 1avg - - - 155 kHz ∆ f 2max - 133.7 - - kHz ∆ f 2avg /∆ f 1avg - - 0.92 - - ICFT - - –7 - kHz Drift rate - - 0.7 - kHz/50 µs Drift (DH1) - - 6 - kHz Drift (DH5) - - 6 - kHz dBm Note: There are a total of eight power levels from 0 to 7, and the transmit power ranges from –12 dBm to 9 dBm. When the power level rises by 1, the transmit power increases by 3 dB. Power level 4 is used by default and the corresponding transmit power is 0 dBm. 5.7.3 Receiver – Enhanced Data Rate Table 21: Receiver Characteristics – Enhanced Data Rate Parameter Conditions Min Typ Max Unit π/4 DQPSK Sensitivity @0.01% BER - –90 –89 –88 dBm Maximum received signal @0.01% BER - - 0 - dBm Co-channel C/I - - 11 - dB F = F0 + 1 MHz - –7 - dB F = F0 – 1 MHz - –7 - dB F = F0 + 2 MHz - –25 - dB F = F0 – 2 MHz - –35 - dB F = F0 + 3 MHz - –25 - dB F = F0 – 3 MHz - –45 - dB Adjacent channel selectivity C/I 8DPSK Sensitivity @0.01% BER - –84 –83 –82 dBm Maximum received signal @0.01% BER - - –5 - dBm C/I c-channel - - 18 - dB F = F0 + 1 MHz - 2 - dB F = F0 – 1 MHz - 2 - dB F = F0 + 2 MHz - –25 - dB F = F0 – 2 MHz - –25 - dB F = F0 + 3 MHz - –25 - dB F = F0 – 3 MHz - –38 - dB Adjacent channel selectivity C/I 5.7.4 Transmitter – Enhanced Data Rate Espressif Systems 49 Submit Documentation Feedback ESP32 Series Datasheet v4.0 5 Electrical Characteristics Table 22: Transmitter Characteristics – Enhanced Data Rate Parameter Conditions RF transmit power (see note under Table 20) - - 0 - dBm Gain control step - - 3 - dB RF power control range - –12 - +9 π/4 DQPSK max w0 - - –0.72 - kHz π/4 DQPSK max wi - - –6 - kHz π/4 DQPSK max |wi + w0| - - –7.42 - kHz 8DPSK max w0 - - 0.7 - kHz 8DPSK max wi - - –9.6 - kHz 8DPSK max |wi + w0| - - –10 - kHz RMS DEVM - 4.28 - % 99% DEVM - 100 - % Peak DEVM - 13.3 - % RMS DEVM - 5.8 - % 99% DEVM - 100 - % Peak DEVM - 14 - % F = F0 ± 1 MHz - –46 - dBm F = F0 ± 2 MHz - –40 - dBm F = F0 ± 3 MHz - –46 - dBm F = F0 +/– > 3 MHz - - –53 dBm - - 100 - π/4 DQPSK modulation accuracy 8 DPSK modulation accuracy In-band spurious emissions EDR differential phase coding Min Typ Max Unit dBm % 5.8 Bluetooth LE Radio 5.8.1 Receiver Table 23: Receiver Characteristics – Bluetooth LE Parameter Conditions Min Typ Max Unit Sensitivity @30.8% PER - –94 –93 –92 dBm Maximum received signal @30.8% PER - 0 - - dBm Co-channel C/I - - +10 - dB F = F0 + 1 MHz - –5 - dB F = F0 – 1 MHz - –5 - dB F = F0 + 2 MHz - –25 - dB F = F0 – 2 MHz - –35 - dB F = F0 + 3 MHz - –25 - dB F = F0 – 3 MHz - –45 - dB 30 MHz ~ 2000 MHz –10 - - dBm 2000 MHz ~ 2400 MHz –27 - - dBm 2500 MHz ~ 3000 MHz –27 - - dBm 3000 MHz ~ 12.5 GHz –10 - - dBm - –36 - - dBm Adjacent channel selectivity C/I Out-of-band blocking performance Intermodulation Espressif Systems 50 Submit Documentation Feedback ESP32 Series Datasheet v4.0 5 Electrical Characteristics 5.8.2 Transmitter Table 24: Transmitter Characteristics – Bluetooth LE Parameter Conditions Min Typ Max RF transmit power (see note under Table 20) - - 0 - dBm Gain control step - - 3 - dB RF power control range - –12 - +9 dBm F = F0 ± 2 MHz - –52 - dBm F = F0 ± 3 MHz - –58 - dBm F = F0 ± > 3 MHz - –60 - dBm ∆ f 1avg - - - 265 kHz ∆ f 2max - 247 - - kHz ∆ f 2avg /∆ f 1avg - - 0.92 - - ICFT - - –10 - kHz Drift rate - - 0.7 - kHz/50 µs Drift - - 2 - kHz Adjacent channel transmit power Espressif Systems 51 Submit Documentation Feedback Unit ESP32 Series Datasheet v4.0 6 Package Information 6 Package Information Pin 1 Pin 2 Pin 3 Pin 1 Pin 2 Pin 3 Figure 8: QFN48 (6x6 mm) Package D D2 L PIN #1 DDT BY MARKING in 1 Pn 2 PIN #1 ID C0.350 L 48L SLP (5x5r1r1) E L + e_f E2 0 a.a.a. C bl 48X 0 a.a.a. C TOP VIEw BOTTOM VIEw 1//lccclCI Dimensional Ref. REF. Min. Norn. Max. A 0.800 0.850 0.900 A1 0.000 -- 0.050 A3 0.203 Ref. D 4.950 5.000 5.050 E 4.950 5.000 5.050 02 3.650 3.700 3.750 E2 3.650 3.700 3.750 b 0.130 0.180 0.230 b1 0.070 0.120 0.170 L 0.300 0.350 0.400 e 0.350 BSC Tol. of Form&Position aaa 0.10 bbb 0.10 CCC 0.10 0.05 ddd eee 0.08 0.10 fff Notes SIDE VIEw 1. All DIMENSIONS ARE IN MILLIMETERS, 2, DIMENSIONING AND T LERANCING PER JEDEC M -220, □ □ Figure 9: QFN48 (5x5 mm) Package Note: The pins of the chip are numbered in an anti-clockwise direction from Pin 1 in the top view. For information about tape, reel, and product marking, please refer to Espressif Chip Package Information. Espressif Systems 52 Submit Documentation Feedback ESP32 Series Datasheet v4.0 7 Part Number and Ordering Information 7 Part Number and Ordering Information ESP32 D 0 WD R2 H V3 Q6 Q6 PSRAM R2: 2 MB PSRAM flash 0 2 D/U S Figure 10: ESP32 Part Number Description The table below provides the ordering information of the ESP32 series of chips. Table 25: ESP32 Ordering Information Ordering code1 Chip Revision2 Core Embedded Package flash/PSRAM VDD_SDIO voltage ESP32-D0WD-V3 Dual core v3.0/v3.14 — QFN 5*5 1.8 V/3.3 V ESP32-D0WDR2-V3 Dual core v3.0/v3.14 2 MB PSRAM QFN 5*5 3.3 V ESP32-U4WDH Dual core3 v3.0/v3.14 4 MB flash (80 MHz) QFN 5*5 3.3 V ESP32-D0WDQ6-V3 (NRND) Dual core v3.0/v3.14 — QFN 6*6 1.8 V/3.3 V Dual core v1.0/v1.1 5 — QFN 5*5 1.8 V/3.3 V v1.0/v1.1 5 — QFN 6*6 1.8 V/3.3 V v1.0/v1.1 5 — QFN 5*5 1.8 V/3.3 V ESP32-D0WD (NRND) ESP32-D0WDQ6 (NRND) ESP32-S0WD (NRND) Dual core Single core 1 All above chips support Wi-Fi b/g/n + Bluetooth/Bluetooth LE Dual Mode connection. 2 The differences between ESP32 chip revisions and the way to distinguish the revisions used in each chip are described in ESP32 Series SoC Errata. 3 Effectively on December 2, 2021, ESP32-U4WDH is produced as dual-core instead of single core, see PCN-2021-021 for more details. 4 Effectively on October 13, 2022, the chips are produced with chip revision v3.1 inside, see PCN20220901 for more details. 5 Effectively on October 13, 2022, the chips are produced with chip revision v1.1 inside, see PCN20220901 for more details. Espressif Systems 53 Submit Documentation Feedback ESP32 Series Datasheet v4.0 8 Related Documentation and Resources 8 Related Documentation and Resources Related Documentation • ESP32 Technical Reference Manual – Detailed information on how to use the ESP32 memory and peripherals. • ESP32 Hardware Design Guidelines – Guidelines on how to integrate the ESP32 into your hardware product. • ESP32 ECO and Workarounds for Bugs – Correction of ESP32 design errors. • Certificates http://espressif.com/en/support/documents/certificates • ESP32 Product/Process Change Notifications (PCN) http://espressif.com/en/support/documents/pcns • ESP32 Advisories – Information on security, bugs, compatibility, component reliability. http://espressif.com/en/support/documents/advisories • Documentation Updates and Update Notification Subscription http://espressif.com/en/support/download/documents Developer Zone • ESP-IDF Programming Guide for ESP32 – Extensive documentation for the ESP-IDF development framework. • ESP-IDF and other development frameworks on GitHub. http://github.com/espressif • ESP32 BBS Forum – Engineer-to-Engineer (E2E) Community for Espressif products where you can post questions, share knowledge, explore ideas, and help solve problems with fellow engineers. http://esp32.com/ • The ESP Journal – Best Practices, Articles, and Notes from Espressif folks. http://blog.espressif.com/ • See the tabs SDKs and Demos, Apps, Tools, AT Firmware. http://espressif.com/en/support/download/sdks-demos Products • ESP32 Series SoCs – Browse through all ESP32 SoCs. http://espressif.com/en/products/socs?id=ESP32 • ESP32 Series Modules – Browse through all ESP32-based modules. http://espressif.com/en/products/modules?id=ESP32 • ESP32 Series DevKits – Browse through all ESP32-based devkits. http://espressif.com/en/products/devkits?id=ESP32 • ESP Product Selector – Find an Espressif hardware product suitable for your needs by comparing or applying filters. http://products.espressif.com/#/product-selector?language=en Contact Us • See the tabs Sales Questions, Technical Enquiries, Circuit Schematic & PCB Design Review, Get Samples (Online stores), Become Our Supplier, Comments & Suggestions. http://espressif.com/en/contact-us/sales-questions Espressif Systems 54 Submit Documentation Feedback ESP32 Series Datasheet v4.0 Appendix A Appendix A – ESP32 Pin Lists A.1. Notes on ESP32 Pin Lists Table 26: Notes on ESP32 Pin Lists No. 1 Description In Table IO_MUX, the boxes highlighted in yellow indicate the GPIO pins that are input-only. Please see the following note for further details. GPIO pins 34-39 are input-only. These pins do not feature an output driver or internal pull- 2 up/pull-down circuitry. The pin names are: SENSOR_VP (GPIO36), SENSOR_CAPP (GPIO37), SENSOR_CAPN (GPIO38), SENSOR_VN (GPIO39), VDET_1 (GPIO34), VDET_2 (GPIO35). The pins are grouped into four power domains: VDDA (analog power supply), VDD3P3_RTC (RTC power supply), VDD3P3_CPU (power supply of digital IOs and CPU cores), VDD_SDIO 3 (power supply of SDIO IOs). VDD_SDIO is the output of the internal SDIO-LDO. The voltage of SDIO-LDO can be configured at 1.8 V or be the same as that of VDD3P3_RTC. The strapping pin and eFuse bits determine the default voltage of the SDIO-LDO. Software can change the voltage of the SDIO-LDO by configuring register bits. For details, please see the column “Power Domain” in Table IO_MUX. The functional pins in the VDD3P3_RTC domain are those with analog functions, including the 4 32 kHz crystal oscillator, ADC, DAC, and the capacitive touch sensor. Please see columns “Analog Function 0 ~ 2” in Table IO_MUX. 5 These VDD3P3_RTC pins support the RTC function, and can work during Deep-sleep. For example, an RTC-GPIO can be used for waking up the chip from Deep-sleep. The GPIO pins support up to six digital functions, as shown in columns “Function 0 ~ 5” In Table IO_MUX. The function selection registers will be set as “N”, where N is the function number. Below are some definitions: • SD_* is for signals of the SDIO slave. • HS1_* is for Port 1 signals of the SDIO host. • HS2_* is for Port 2 signals of the SDIO host. 6 • MT* is for signals of the JTAG. • U0* is for signals of the UART0 module. • U1* is for signals of the UART1 module. • U2* is for signals of the UART2 module. • SPI* is for signals of the SPI01 module. • HSPI* is for signals of the SPI2 module. • VSPI* is for signals of the SPI3 module. Espressif Systems 55 Submit Documentation Feedback ESP32 Series Datasheet v4.0 Appendix A No. Description Each column about digital “Function” is accompanied by a column about “Type”. Please see the following explanations for the meanings of “type” with respect to each “function” they are associated with. For each “Function-N”, “type” signifies: • I: input only. If a function other than “Function-N” is assigned, the input signal of “Function-N” is still from this pin. • I1: input only. If a function other than “Function-N” is assigned, the input signal of “Function-N” is always “1”. • I0: input only. If a function other than “Function-N” is assigned, the input signal of 7 “Function-N” is always “0”. • O: output only. • T: high-impedance. • I/O/T: combinations of input, output, and high-impedance according to the function signal. • I1/O/T: combinations of input, output, and high-impedance, according to the function signal. If a function is not selected, the input signal of the function is “1”. For example, pin 30 can function as HS1_CMD or SD_CMD, where HS1_CMD is of an “I1/O/T” type. If pin 30 is selected as HS1_CMD, this pin’s input and output are controlled by the SDIO host. If pin 30 is not selected as HS1_CMD, the input signal of the SDIO host is always “1”. Each digital output pin is associated with its configurable drive strength. Column “Drive Strength” in Table IO_MUX lists the default values. The drive strength of the digital output pins can be configured into one of the following four options: • 0: ~5 mA 8 • 1: ~10 mA • 2: ~20 mA • 3: ~40 mA The default value is 2. The drive strength of the internal pull-up (wpu) and pull-down (wpd) is ~75 µA. Column “At Reset” in Table IO_MUX lists the status of each pin during reset, including input- 9 enable (ie=1), internal pull-up (wpu) and internal pull-down (wpd). During reset, all pins are output-disabled. Column “After Reset” in Table IO_MUX lists the status of each pin immediately after reset, 10 including input-enable (ie=1), internal pull-up (wpu) and internal pull-down (wpd). After reset, each pin is set to “Function 0”. The output-enable is controlled by digital Function 0. Table Ethernet_MAC is about the signal mapping inside Ethernet MAC. The Ethernet MAC 11 supports MII and RMII interfaces, and supports both the internal PLL clock and the external clock source. For the MII interface, the Ethernet MAC is with/without the TX_ERR signal. MDC, MDIO, CRS and COL are slow signals, and can be mapped onto any GPIO pin through the GPIO-Matrix. Table GPIO Matrix is for the GPIO-Matrix. The signals of the on-chip functional modules can 12 be mapped onto any GPIO pin. Some signals can be mapped onto a pin by both IO-MUX and GPIO-Matrix, as shown in the column tagged as “Same input signal from IO_MUX core” in Table GPIO Matrix. Espressif Systems 56 Submit Documentation Feedback ESP32 Series Datasheet v4.0 Appendix A No. Description *In Table GPIO_Matrix�the column “Default Value if unassigned” records the default value of 13 the an input signal if no GPIO is assigned to it. The actual value is determined by register GPIO_FUNCm_IN_INV_SEL and GPIO_FUNCm_IN_SEL. (The value of m ranges from 1 to 255.) A.2. GPIO_Matrix Table 27: GPIO_Matrix Signal No. Input signals Default Same input value if signal from unassigned* Output enable of IO_MUX core Output signals output signals 0 SPICLK_in 0 yes SPICLK_out SPICLK_oe 1 SPIQ_in 0 yes SPIQ_out SPIQ_oe 2 SPID_in 0 yes SPID_out SPID_oe 3 SPIHD_in 0 yes SPIHD_out SPIHD_oe 4 SPIWP_in 0 yes SPIWP_out SPIWP_oe 5 SPICS0_in 0 yes SPICS0_out SPICS0_oe 6 SPICS1_in 0 no SPICS1_out SPICS1_oe 7 SPICS2_in 0 no SPICS2_out SPICS2_oe 8 HSPICLK_in 0 yes HSPICLK_out HSPICLK_oe 9 HSPIQ_in 0 yes HSPIQ_out HSPIQ_oe 10 HSPID_in 0 yes HSPID_out HSPID_oe 11 HSPICS0_in 0 yes HSPICS0_out HSPICS0_oe 12 HSPIHD_in 0 yes HSPIHD_out HSPIHD_oe 13 HSPIWP_in 0 yes HSPIWP_out HSPIWP_oe 14 U0RXD_in 0 yes U0TXD_out 1’d1 15 U0CTS_in 0 yes U0RTS_out 1’d1 16 U0DSR_in 0 no U0DTR_out 1’d1 17 U1RXD_in 0 yes U1TXD_out 1’d1 18 U1CTS_in 0 yes U1RTS_out 1’d1 23 I2S0O_BCK_in 0 no I2S0O_BCK_out 1’d1 24 I2S1O_BCK_in 0 no I2S1O_BCK_out 1’d1 25 I2S0O_WS_in 0 no I2S0O_WS_out 1’d1 26 I2S1O_WS_in 0 no I2S1O_WS_out 1’d1 27 I2S0I_BCK_in 0 no I2S0I_BCK_out 1’d1 28 I2S0I_WS_in 0 no I2S0I_WS_out 1’d1 29 I2CEXT0_SCL_in 1 no I2CEXT0_SCL_out 1’d1 30 I2CEXT0_SDA_in 1 no I2CEXT0_SDA_out 1’d1 31 pwm0_sync0_in 0 no sdio_tohost_int_out 1’d1 32 pwm0_sync1_in 0 no pwm0_out0a 1’d1 33 pwm0_sync2_in 0 no pwm0_out0b 1’d1 34 pwm0_f0_in 0 no pwm0_out1a 1’d1 Espressif Systems 57 Submit Documentation Feedback ESP32 Series Datasheet v4.0 Appendix A Signal No. Default Same input value if signal from Input signals unassigned* 35 pwm0_f1_in 36 Output enable of IO_MUX core Output signals output signals 0 no pwm0_out1b 1’d1 pwm0_f2_in 0 no pwm0_out2a 1’d1 37 - 0 no pwm0_out2b 1’d1 39 pcnt_sig_ch0_in0 0 no - 1’d1 40 pcnt_sig_ch1_in0 0 no - 1’d1 41 pcnt_ctrl_ch0_in0 0 no - 1’d1 42 pcnt_ctrl_ch1_in0 0 no - 1’d1 43 pcnt_sig_ch0_in1 0 no - 1’d1 44 pcnt_sig_ch1_in1 0 no - 1’d1 45 pcnt_ctrl_ch0_in1 0 no - 1’d1 46 pcnt_ctrl_ch1_in1 0 no - 1’d1 47 pcnt_sig_ch0_in2 0 no - 1’d1 48 pcnt_sig_ch1_in2 0 no - 1’d1 49 pcnt_ctrl_ch0_in2 0 no - 1’d1 50 pcnt_ctrl_ch1_in2 0 no - 1’d1 51 pcnt_sig_ch0_in3 0 no - 1’d1 52 pcnt_sig_ch1_in3 0 no - 1’d1 53 pcnt_ctrl_ch0_in3 0 no - 1’d1 54 pcnt_ctrl_ch1_in3 0 no - 1’d1 55 pcnt_sig_ch0_in4 0 no - 1’d1 56 pcnt_sig_ch1_in4 0 no - 1’d1 57 pcnt_ctrl_ch0_in4 0 no - 1’d1 58 pcnt_ctrl_ch1_in4 0 no - 1’d1 61 HSPICS1_in 0 no HSPICS1_out HSPICS1_oe 62 HSPICS2_in 0 no HSPICS2_out HSPICS2_oe 63 VSPICLK_in 0 yes VSPICLK_out_mux VSPICLK_oe 64 VSPIQ_in 0 yes VSPIQ_out VSPIQ_oe 65 VSPID_in 0 yes VSPID_out VSPID_oe 66 VSPIHD_in 0 yes VSPIHD_out VSPIHD_oe 67 VSPIWP_in 0 yes VSPIWP_out VSPIWP_oe 68 VSPICS0_in 0 yes VSPICS0_out VSPICS0_oe 69 VSPICS1_in 0 no VSPICS1_out VSPICS1_oe 70 VSPICS2_in 0 no VSPICS2_out VSPICS2_oe 71 pcnt_sig_ch0_in5 0 no ledc_hs_sig_out0 1’d1 72 pcnt_sig_ch1_in5 0 no ledc_hs_sig_out1 1’d1 73 pcnt_ctrl_ch0_in5 0 no ledc_hs_sig_out2 1’d1 74 pcnt_ctrl_ch1_in5 0 no ledc_hs_sig_out3 1’d1 75 pcnt_sig_ch0_in6 0 no ledc_hs_sig_out4 1’d1 76 pcnt_sig_ch1_in6 0 no ledc_hs_sig_out5 1’d1 77 pcnt_ctrl_ch0_in6 0 no ledc_hs_sig_out6 1’d1 78 pcnt_ctrl_ch1_in6 0 no ledc_hs_sig_out7 1’d1 Espressif Systems 58 Submit Documentation Feedback ESP32 Series Datasheet v4.0 Appendix A Signal No. Input signals Default Same input value if signal from unassigned* Output enable of IO_MUX core Output signals output signals 79 pcnt_sig_ch0_in7 0 no ledc_ls_sig_out0 1’d1 80 pcnt_sig_ch1_in7 0 no ledc_ls_sig_out1 1’d1 81 pcnt_ctrl_ch0_in7 0 no ledc_ls_sig_out2 1’d1 82 pcnt_ctrl_ch1_in7 0 no ledc_ls_sig_out3 1’d1 83 rmt_sig_in0 0 no ledc_ls_sig_out4 1’d1 84 rmt_sig_in1 0 no ledc_ls_sig_out5 1’d1 85 rmt_sig_in2 0 no ledc_ls_sig_out6 1’d1 86 rmt_sig_in3 0 no ledc_ls_sig_out7 1’d1 87 rmt_sig_in4 0 no rmt_sig_out0 1’d1 88 rmt_sig_in5 0 no rmt_sig_out1 1’d1 89 rmt_sig_in6 0 no rmt_sig_out2 1’d1 90 rmt_sig_in7 0 no rmt_sig_out3 1’d1 91 - - - rmt_sig_out4 1’d1 92 - - - rmt_sig_out6 1’d1 94 twai_rx 1 no rmt_sig_out7 1’d1 95 I2CEXT1_SCL_in 1 no I2CEXT1_SCL_out 1’d1 96 I2CEXT1_SDA_in 1 no I2CEXT1_SDA_out 1’d1 97 host_card_detect_n_1 0 no host_ccmd_od_pullup_en_n 1’d1 98 host_card_detect_n_2 0 no host_rst_n_1 1’d1 99 host_card_write_prt_1 0 no host_rst_n_2 1’d1 100 host_card_write_prt_2 0 no gpio_sd0_out 1’d1 101 host_card_int_n_1 0 no gpio_sd1_out 1’d1 102 host_card_int_n_2 0 no gpio_sd2_out 1’d1 103 pwm1_sync0_in 0 no gpio_sd3_out 1’d1 104 pwm1_sync1_in 0 no gpio_sd4_out 1’d1 105 pwm1_sync2_in 0 no gpio_sd5_out 1’d1 106 pwm1_f0_in 0 no gpio_sd6_out 1’d1 107 pwm1_f1_in 0 no gpio_sd7_out 1’d1 108 pwm1_f2_in 0 no pwm1_out0a 1’d1 109 pwm0_cap0_in 0 no pwm1_out0b 1’d1 110 pwm0_cap1_in 0 no pwm1_out1a 1’d1 111 pwm0_cap2_in 0 no pwm1_out1b 1’d1 112 pwm1_cap0_in 0 no pwm1_out2a 1’d1 113 pwm1_cap1_in 0 no pwm1_out2b 1’d1 114 pwm1_cap2_in 0 no pwm2_out1h 1’d1 115 pwm2_flta 1 no pwm2_out1l 1’d1 116 pwm2_fltb 1 no pwm2_out2h 1’d1 117 pwm2_cap1_in 0 no pwm2_out2l 1’d1 118 pwm2_cap2_in 0 no pwm2_out3h 1’d1 119 pwm2_cap3_in 0 no pwm2_out3l 1’d1 120 pwm3_flta 1 no pwm2_out4h 1’d1 Espressif Systems 59 Submit Documentation Feedback ESP32 Series Datasheet v4.0 Appendix A Signal No. Input signals Default Same input value if signal from unassigned* Output enable of IO_MUX core Output signals output signals 121 pwm3_fltb 1 no pwm2_out4l 1’d1 122 pwm3_cap1_in 0 no - 1’d1 123 pwm3_cap2_in 0 no twai_tx 1’d1 124 pwm3_cap3_in 0 no twai_bus_off_on 1’d1 125 - - - twai_clkout 1’d1 140 I2S0I_DATA_in0 0 no I2S0O_DATA_out0 1’d1 141 I2S0I_DATA_in1 0 no I2S0O_DATA_out1 1’d1 142 I2S0I_DATA_in2 0 no I2S0O_DATA_out2 1’d1 143 I2S0I_DATA_in3 0 no I2S0O_DATA_out3 1’d1 144 I2S0I_DATA_in4 0 no I2S0O_DATA_out4 1’d1 145 I2S0I_DATA_in5 0 no I2S0O_DATA_out5 1’d1 146 I2S0I_DATA_in6 0 no I2S0O_DATA_out6 1’d1 147 I2S0I_DATA_in7 0 no I2S0O_DATA_out7 1’d1 148 I2S0I_DATA_in8 0 no I2S0O_DATA_out8 1’d1 149 I2S0I_DATA_in9 0 no I2S0O_DATA_out9 1’d1 150 I2S0I_DATA_in10 0 no I2S0O_DATA_out10 1’d1 151 I2S0I_DATA_in11 0 no I2S0O_DATA_out11 1’d1 152 I2S0I_DATA_in12 0 no I2S0O_DATA_out12 1’d1 153 I2S0I_DATA_in13 0 no I2S0O_DATA_out13 1’d1 154 I2S0I_DATA_in14 0 no I2S0O_DATA_out14 1’d1 155 I2S0I_DATA_in15 0 no I2S0O_DATA_out15 1’d1 156 - - - I2S0O_DATA_out16 1’d1 157 - - - I2S0O_DATA_out17 1’d1 158 - - - I2S0O_DATA_out18 1’d1 159 - - - I2S0O_DATA_out19 1’d1 160 - - - I2S0O_DATA_out20 1’d1 161 - - - I2S0O_DATA_out21 1’d1 162 - - - I2S0O_DATA_out22 1’d1 163 - - - I2S0O_DATA_out23 1’d1 164 I2S1I_BCK_in 0 no I2S1I_BCK_out 1’d1 165 I2S1I_WS_in 0 no I2S1I_WS_out 1’d1 166 I2S1I_DATA_in0 0 no I2S1O_DATA_out0 1’d1 167 I2S1I_DATA_in1 0 no I2S1O_DATA_out1 1’d1 168 I2S1I_DATA_in2 0 no I2S1O_DATA_out2 1’d1 169 I2S1I_DATA_in3 0 no I2S1O_DATA_out3 1’d1 170 I2S1I_DATA_in4 0 no I2S1O_DATA_out4 1’d1 171 I2S1I_DATA_in5 0 no I2S1O_DATA_out5 1’d1 172 I2S1I_DATA_in6 0 no I2S1O_DATA_out6 1’d1 173 I2S1I_DATA_in7 0 no I2S1O_DATA_out7 1’d1 174 I2S1I_DATA_in8 0 no I2S1O_DATA_out8 1’d1 175 I2S1I_DATA_in9 0 no I2S1O_DATA_out9 1’d1 Espressif Systems 60 Submit Documentation Feedback ESP32 Series Datasheet v4.0 Appendix A Signal No. Input signals Default Same input value if signal from unassigned* Output enable of IO_MUX core Output signals output signals 176 I2S1I_DATA_in10 0 no I2S1O_DATA_out10 1’d1 177 I2S1I_DATA_in11 0 no I2S1O_DATA_out11 1’d1 178 I2S1I_DATA_in12 0 no I2S1O_DATA_out12 1’d1 179 I2S1I_DATA_in13 0 no I2S1O_DATA_out13 1’d1 180 I2S1I_DATA_in14 0 no I2S1O_DATA_out14 1’d1 181 I2S1I_DATA_in15 0 no I2S1O_DATA_out15 1’d1 182 - - - I2S1O_DATA_out16 1’d1 183 - - - I2S1O_DATA_out17 1’d1 184 - - - I2S1O_DATA_out18 1’d1 185 - - - I2S1O_DATA_out19 1’d1 186 - - - I2S1O_DATA_out20 1’d1 187 - - - I2S1O_DATA_out21 1’d1 188 - - - I2S1O_DATA_out22 1’d1 189 - - - I2S1O_DATA_out23 1’d1 190 I2S0I_H_SYNC 0 no pwm3_out1h 1’d1 191 I2S0I_V_SYNC 0 no pwm3_out1l 1’d1 192 I2S0I_H_ENABLE 0 no pwm3_out2h 1’d1 193 I2S1I_H_SYNC 0 no pwm3_out2l 1’d1 194 I2S1I_V_SYNC 0 no pwm3_out3h 1’d1 195 I2S1I_H_ENABLE 0 no pwm3_out3l 1’d1 196 - - - pwm3_out4h 1’d1 197 - - - pwm3_out4l 1’d1 198 U2RXD_in 0 yes U2TXD_out 1’d1 199 U2CTS_in 0 yes U2RTS_out 1’d1 200 emac_mdc_i 0 no emac_mdc_o emac_mdc_oe 201 emac_mdi_i 0 no emac_mdo_o emac_mdo_o_e 202 emac_crs_i 0 no emac_crs_o emac_crs_oe 203 emac_col_i 0 no emac_col_o emac_col_oe 204 pcmfsync_in 0 no bt_audio0_irq 1’d1 205 pcmclk_in 0 no bt_audio1_irq 1’d1 206 pcmdin 0 no bt_audio2_irq 1’d1 207 - - - ble_audio0_irq 1’d1 208 - - - ble_audio1_irq 1’d1 209 - - - ble_audio2_irq 1’d1 210 - - - pcmfsync_out pcmfsync_en 211 - - - pcmclk_out pcmclk_en 212 - - - pcmdout pcmdout_en 213 - - - ble_audio_sync0_p 1’d1 214 - - - ble_audio_sync1_p 1’d1 215 - - - ble_audio_sync2_p 1’d1 224 - - - sig_in_func224 1’d1 Espressif Systems 61 Submit Documentation Feedback ESP32 Series Datasheet v4.0 Appendix A Signal No. Input signals Default Same input value if signal from unassigned* Output enable of IO_MUX core Output signals output signals 225 - - - sig_in_func225 1’d1 226 - - - sig_in_func226 1’d1 227 - - - sig_in_func227 1’d1 228 - - - sig_in_func228 1’d1 A.3. Ethernet_MAC Table 28: Ethernet_MAC PIN Name Function6 MII (int_osc) MII (ext_osc) RMII (int_osc) RMII (ext_osc) GPIO0 EMAC_TX_CLK TX_CLK (I) TX_CLK (I) CLK_OUT(O) EXT_OSC_CLK(I) GPIO5 EMAC_RX_CLK RX_CLK (I) RX_CLK (I) - - GPIO21 EMAC_TX_EN TX_EN(O) TX_EN(O) TX_EN(O) TX_EN(O) GPIO19 EMAC_TXD0 TXD[0](O) TXD[0](O) TXD[0](O) TXD[0](O) GPIO22 EMAC_TXD1 TXD[1](O) TXD[1](O) TXD[1](O) TXD[1](O) MTMS EMAC_TXD2 TXD[2](O) TXD[2](O) - - MTDI EMAC_TXD3 TXD[3](O) TXD[3](O) - - MTCK EMAC_RX_ER RX_ER(I) RX_ER(I) - - GPIO27 EMAC_RX_DV RX_DV(I) RX_DV(I) CRS_DV(I) CRS_DV(I) GPIO25 EMAC_RXD0 RXD[0](I) RXD[0](I) RXD[0](I) RXD[0](I) GPIO26 EMAC_RXD1 RXD[1](I) RXD[1](I) RXD[1](I) RXD[1](I) U0TXD EMAC_RXD2 RXD[2](I) RXD[2](I) - - MTDO EMAC_RXD3 RXD[3](I) RXD[3](I) - - GPIO16 EMAC_CLK_OUT CLK_OUT(O) - CLK_OUT(O) - GPIO17 EMAC_CLK_OUT_180 CLK_OUT_180(O) - CLK_OUT_180(O) - GPIO4 EMAC_TX_ER TX_ERR(O)* TX_ERR(O)* - - In GPIO Matrix* - MDC(O) MDC(O) MDC(O) MDC(O) In GPIO Matrix* - MDIO(IO) MDIO(IO) MDIO(IO) MDIO(IO) In GPIO Matrix* - CRS(I) CRS(I) - - In GPIO Matrix* - COL(I) COL(I) - - *Notes: 1. The GPIO Matrix can be any GPIO. 2. The TX_ERR (O) is optional. A.4. IO_MUX For the list of IO_MUX pins, please see the next page. Espressif Systems 62 Submit Documentation Feedback ESP32 Series Datasheet v4.0 Power Supply Pin 1 VDDA 2 Analog Pin Digital Pin VDD3P3 4 VDD3P3 Analog Function0 Analog Function1 Analog Function2 RTC Function0 RTC Function1 Function0 Type Function1 Type Function2 Type Function3 Type Function4 Type Function5 Type Drive Strength (2’d2: 20 mA) At Reset After Reset VDDA supply in LNA_IN 3 Power Domain VDD3P3 VDD3P3 supply in VDD3P3 supply in 5 SENSOR_VP VDD3P3_RTC ADC1_CH0 RTC_GPIO0 GPIO36 I GPIO36 I oe=0, ie=0 oe=0, ie=0 6 SENSOR_CAPP VDD3P3_RTC ADC1_CH1 RTC_GPIO1 GPIO37 I GPIO37 I oe=0, ie=0 oe=0, ie=0 7 SENSOR_CAPN VDD3P3_RTC ADC1_CH2 RTC_GPIO2 GPIO38 I GPIO38 I oe=0, ie=0 oe=0, ie=0 8 SENSOR_VN VDD3P3_RTC ADC1_CH3 RTC_GPIO3 GPIO39 I GPIO39 I oe=0, ie=0 oe=0, ie=0 9 CHIP_PU VDD3P3_RTC 10 VDET_1 VDD3P3_RTC RTC_GPIO4 GPIO34 I GPIO34 I oe=0, ie=0 oe=0, ie=0 11 VDET_2 VDD3P3_RTC RTC_GPIO5 GPIO35 I GPIO35 I oe=0, ie=0 oe=0, ie=0 12 32K_XP VDD3P3_RTC XTAL_32K_P ADC1_CH4 TOUCH9 RTC_GPIO9 GPIO32 I/O/T GPIO32 I/O/T 2'd2 oe=0, ie=0 oe=0, ie=0 13 32K_XN VDD3P3_RTC XTAL_32K_N ADC1_CH5 TOUCH8 RTC_GPIO8 GPIO33 I/O/T GPIO33 I/O/T 2'd2 oe=0, ie=0 oe=0, ie=0 ADC1_CH6 ADC1_CH7 GPIO25 VDD3P3_RTC DAC_1 ADC2_CH8 RTC_GPIO6 GPIO25 I/O/T GPIO25 I/O/T EMAC_RXD0 I 2'd2 oe=0, ie=0 oe=0, ie=0 15 GPIO26 VDD3P3_RTC DAC_2 ADC2_CH9 RTC_GPIO7 GPIO26 I/O/T GPIO26 I/O/T EMAC_RXD1 I 2'd2 oe=0, ie=0 oe=0, ie=0 16 GPIO27 VDD3P3_RTC ADC2_CH7 TOUCH7 RTC_GPIO17 GPIO27 I/O/T GPIO27 I/O/T EMAC_RX_DV I 2'd2 oe=0, ie=0 oe=0, ie=0 17 MTMS VDD3P3_RTC ADC2_CH6 TOUCH6 RTC_GPIO16 MTMS I0 HSPICLK I/O/T GPIO14 I/O/T HS2_CLK O SD_CLK I0 EMAC_TXD2 O 2'd2 oe=0, ie=0 oe=0, ie=1, wpu 18 MTDI VDD3P3_RTC ADC2_CH5 TOUCH5 RTC_GPIO15 MTDI I1 HSPIQ I/O/T GPIO12 I/O/T HS2_DATA2 I1/O/T SD_DATA2 I1/O/T EMAC_TXD3 O 2'd2 oe=0, ie=1, wpd oe=0, ie=1, wpd MTCK I1 HSPID I/O/T GPIO13 I/O/T HS2_DATA3 I1/O/T SD_DATA3 I1/O/T EMAC_RX_ER I 2'd2 oe=0, ie=0 oe=0, ie=1, wpd EMAC_RXD3 I 2'd2 oe=0, ie=1, wpu oe=0, ie=1, wpu 2'd2 oe=0, ie=1, wpd oe=0, ie=1, wpd 19 VDD3P3_RTC VDD3P3_RTC supply in 20 MTCK VDD3P3_RTC ADC2_CH4 TOUCH4 RTC_GPIO14 21 MTDO VDD3P3_RTC ADC2_CH3 TOUCH3 RTC_GPIO13 I2C_SDA MTDO O/T HSPICS0 I/O/T GPIO15 I/O/T HS2_CMD I1/O/T SD_CMD I1/O/T 22 GPIO2 VDD3P3_RTC ADC2_CH2 TOUCH2 RTC_GPIO12 I2C_SCL GPIO2 I/O/T HSPIWP I/O/T GPIO2 I/O/T HS2_DATA0 I1/O/T SD_DATA0 I1/O/T 23 GPIO0 VDD3P3_RTC ADC2_CH1 TOUCH1 RTC_GPIO11 I2C_SDA GPIO0 I/O/T CLK_OUT1 O GPIO0 I/O/T EMAC_TX_CLK I 2'd2 oe=0, ie=1, wpu oe=0, ie=1, wpu 24 GPIO4 VDD3P3_RTC ADC2_CH0 TOUCH0 RTC_GPIO10 I2C_SCL GPIO4 I/O/T HSPIHD I/O/T GPIO4 I/O/T HS2_DATA1 I1/O/T SD_DATA1 I1/O/T EMAC_TX_ER O 2'd2 oe=0, ie=1, wpd oe=0, ie=1, wpd GPIO16 VDD_SDIO 25 63 Submit Documentation Feedback 14 GPIO16 I/O/T GPIO16 I/O/T HS1_DATA4 I1/O/T U2RXD I1 EMAC_CLK_OUT O 2'd2 oe=0, ie=0 oe=0, ie=1 27 GPIO17 VDD_SDIO GPIO17 I/O/T GPIO17 I/O/T HS1_DATA5 I1/O/T U2TXD O EMAC_CLK_OUT_180 O 2'd2 oe=0, ie=0 oe=0, ie=1 28 SD_DATA_2 VDD_SDIO SD_DATA2 I1/O/T SPIHD I/O/T GPIO9 I/O/T HS1_DATA2 I1/O/T U1RXD I1 2'd2 oe=0, ie=1, wpu oe=0, ie=1, wpu 29 SD_DATA_3 VDD_SDIO SD_DATA3 I0/O/T SPIWP I/O/T GPIO10 I/O/T HS1_DATA3 I1/O/T U1TXD O 2'd2 oe=0, ie=1, wpu oe=0, ie=1, wpu 30 SD_CMD VDD_SDIO SD_CMD I1/O/T SPICS0 I/O/T GPIO11 I/O/T HS1_CMD I1/O/T U1RTS O 2'd2 oe=0, ie=1, wpu oe=0, ie=1, wpu 31 SD_CLK VDD_SDIO SD_CLK I0 SPICLK I/O/T GPIO6 I/O/T HS1_CLK O U1CTS I1 2'd2 oe=0, ie=1, wpu oe=0, ie=1, wpu 32 SD_DATA_0 VDD_SDIO SD_DATA0 I1/O/T SPIQ I/O/T GPIO7 I/O/T HS1_DATA0 I1/O/T U2RTS O 2'd2 oe=0, ie=1, wpu oe=0, ie=1, wpu 33 SD_DATA_1 VDD_SDIO SD_DATA1 I1/O/T SPID I/O/T GPIO8 I/O/T HS1_DATA1 I1/O/T U2CTS I1 2'd2 oe=0, ie=1, wpu oe=0, ie=1, wpu 34 GPIO5 VDD3P3_CPU GPIO5 I/O/T VSPICS0 I/O/T GPIO5 I/O/T HS1_DATA6 I1/O/T 2'd2 oe=0, ie=1, wpu oe=0, ie=1, wpu 35 GPIO18 VDD3P3_CPU GPIO18 I/O/T VSPICLK I/O/T GPIO18 I/O/T HS1_DATA7 I1/O/T 2'd2 oe=0, ie=0 oe=0, ie=1 36 GPIO23 VDD3P3_CPU GPIO23 I/O/T VSPID I/O/T GPIO23 I/O/T HS1_STROBE I0 2'd2 oe=0, ie=0 oe=0, ie=1 26 37 VDD_SDIO VDD_SDIO supply out/in VDD3P3_CPU EMAC_RX_CLK I VDD3P3_CPU supply in 38 GPIO19 VDD3P3_CPU GPIO19 I/O/T VSPIQ I/O/T GPIO19 I/O/T U0CTS I1 EMAC_TXD0 O 2'd2 oe=0, ie=0 oe=0, ie=1 39 GPIO22 VDD3P3_CPU GPIO22 I/O/T VSPIWP I/O/T GPIO22 I/O/T U0RTS O EMAC_TXD1 O 2'd2 oe=0, ie=0 oe=0, ie=1 40 U0RXD VDD3P3_CPU U0RXD I1 CLK_OUT2 O GPIO3 I/O/T 2'd2 oe=0, ie=1, wpu oe=0, ie=1, wpu 41 U0TXD VDD3P3_CPU U0TXD O CLK_OUT3 O GPIO1 I/O/T EMAC_RXD2 I 2'd2 oe=0, ie=1, wpu oe=0, ie=1, wpu GPIO21 VDD3P3_CPU GPIO21 I/O/T VSPIHD I/O/T GPIO21 I/O/T EMAC_TX_EN O 2'd2 oe=0, ie=0 oe=0, ie=1 42 43 VDDA 44 45 ESP32 Series Datasheet v4.0 46 VDDA supply in XTAL_N VDDA XTAL_P VDDA VDDA VDDA supply in 47 CAP2 48 CAP1 Total Number 8 14 VDDA VDDA 26 Notes: • wpu: weak pull-up; • wpd: weak pull-down; • ie: input enable; • oe: output enable; • Please see Table: Notes on ESP32 Pin Lists for more information.(请参考表:管脚清单说明。) Espressif www.espressif.com Appendix A Espressif Systems IO_MUX Pin No. Revision History Revision History Date Version Release notes Updated the description in Section 1 Added two notes below Table 3 Added a new item to “Notes on power supply” in Section 2.3 2022.10 v4.0 Updated Figure 10 Added a new column “VDD_SDIO Voltage” in Table 25 Updated the bit rates in Section 4.1.18 Added Not Recommended for New Designs (NRND) label to the ESP32-S0WD variant Added a new chip variant ESP32-D0WDR2-V3 Added Table 2: Pin-to-Pin Mapping Between Chip and Embedded Flash/PSRAM and Table 3: Connection Between Chip and External Flash/PSRAM 2022.03 v3.9 Updated Figure 9: QFN48 (5x5 mm) Package Updated Appendix A.4. IO_MUX Updated Table 12: Peripheral Pin Configurations Provided links to ESP32 Technical Reference Manual in Section 3: Functional Description Upgraded ESP32-U4WDH variant from single-core to dual-core, PCN-2021-021 (estimated effective date: December 2, 2021). see The single- core version coexists with the new dual-core version around December 2, 2021. The physical product is subject to batch tracking. Added CoreMark® score in Section 1.4: MCU and Advanced Features 2021.10 v3.8 Updated the description to TWAI in Section 4.1.18: TWAI Controller Added Not Recommended for New Designs (NRND) label to the ESP32D0WDQ6-V3 variant Provided a link to Espressif Chip Package Information in Section 6: Package Information Updated Section 1.3: Bluetooth Key Features Removed ESP32-D2WD variant Updated the wording in Section 3.6.1 2021.07 v3.7 Updated pin function numbers starting from Function0 Added Not Recommended for New Designs (NRND) label to ESP32-D0WD and ESP32-D0WDQ6 variants Updated Figure 1: Functional Block Diagram Updated Table 16: Reliability Qualifications Updated Figure 4: ESP32 Power Scheme 2021.03 V3.6 Updated Table 14: Recommended Operating Conditions Updated the notes below Table 4: Description of ESP32 Power-up and Reset Timing Parameters Provided more information about TWAI® in Table 7, Table 12, Table 8, and Section 4.1 Espressif Systems 64 Submit Documentation Feedback ESP32 Series Datasheet v4.0 Revision History Date Version Release notes Updated the description for CAP2 from 3 nF to 3.3 nF 2021.01 V3.5 Added TWAI® in Section 1.4.3: Advanced Peripheral Interfaces Updated Figure 1: Functional Block Diagram Updated the reset values for MTCK, MTMS, GPIO27 in Appendix IO_MUX Added one chip variant: ESP32-U4WDH 2020.04 V3.4 Updated some figures in Table 8, 18, 19, 21, 23, 24 Added a note under Table 20 2020.01 V3.3 2019.10 V3.2 Added two chip variants: ESP32-D0WD-V3 and ESP32-D0WDQ6-V3. Added a note under Table 9. Updated Figure 5: ESP32 Power-up and Reset Timing. Added pin-pin mapping between ESP32-D2WD and the embedded flash under 2019.07 V3.1 Table 1 Pin Description; Updated Figure 10 ESP32 Part Number. 2019.04 V3.0 Added information about the setup and hold times for the strapping pins in Section 2.4: Strapping Pins. Applied new formatting to Table 1: Pin Description; 2019.02 V2.9 Fixed typos with respect to the ADC1 channel mappings in Table 12: Peripheral Pin Configurations. Changed the RF power control range in Table 20, Table 22 and Table 24 from –12 2019.01 V2.8 ~ +12 to –12 ~ +9 dBm; Small text changes. 2018.11 V2.7 2018.10 V2.6 Updated Section 1.5; Updated pin statuses at reset and after reset in Table IO_MUX. Updated QFN package drawings in Chapter 6: Package Information. • Added ”Cumulative IO output current” entry to Table 13: Absolute Maximum Ratings; 2018.08 V2.5 • Added more parameters to Table 15: DC Characteristics; • Changed the power domain names in Table IO_MUX to be consistent with the pin names. • Deleted information on Packet Traffic Arbitration (PTA); • Added Figure 5: ESP32 Power-up and Reset Timing in Section 2.3: Power 2018.07 V2.4 Scheme; • Added the power consumption of dual-core SoCs in Table 8: Power Consumption by Power Modes; • Updated section 4.1.2: Analog-to-Digital Converter (ADC). 2018.06 V2.3 Espressif Systems Added the power consumption at CPU frequency of 160 MHz in Table 8: Power Consumption by Power Modes. 65 Submit Documentation Feedback ESP32 Series Datasheet v4.0 Revision History Date Version Release notes • Changed the voltage range of VDD3P3_RTC from 1.8-3.6V to 2.3-3.6V in Table 1: Pin Description; • Updated Section 2.3: Power Scheme; • Updated Section 3.1.3: External Flash and SRAM; • Updated Table 8: Power Consumption by Power Modes; • Deleted content about temperature sensor; Changes to electrical characteristics: • Updated Table 13: Absolute Maximum Ratings; 2018.05 V2.2 • Added Table 14: Recommended Operating Conditions; • Added Table 15: DC Characteristics; • Added Table 16: Reliability Qualifications; • Updated the values of ”Gain control step” and ”Adjacent channel transmit power” in Table 20: Transmitter Characteristics - Basic Data Rate; • Updated the values of ”Gain control step”, ”π/4 DQPSK modulation accuracy”, ”8 DPSK modulation accuracy” and ”In-band spurious emissions” in Table 22: Transmitter Characteristics – Enhanced Data Rate; • Updated the values of ”Gain control step”, ”Adjacent channel transmit power” in Table 24: Transmitter Characteristics - BLE. • Deleted software-specific features; 2018.01 V2.1 • Deleted information on LNA pre-amplifier; • Specified the CPU speed and flash speed of ESP32-D2WD; • Added notes to Section 2.3: Power Scheme. 2017.12 V2.0 Added a note on the sequence of pin number in Chapter 6. • Updated the description of the pin CHIP_PU in Table 1; • Added a note to Section 2.3: Power Scheme; • Updated the description of the chip’s system reset in Section 2.4: Strapping 2017.10 V1.9 Pins; • Added a description of antenna diversity and selection to Section 3.5.1; • Deleted ”Association sleep pattern” in Table 8 and added notes to Active sleep and Modem-sleep. 2017.08 V1.8 Espressif Systems • Added Table 4.2 in Section 4; • Corrected a typo in Figure 1. 66 Submit Documentation Feedback ESP32 Series Datasheet v4.0 Revision History Date Version Release notes • Changed the transmitting power to +12 dBm; the sensitivity of NZIF receiver to -97 dBm in Section 1.3; • Added a note to Table 1 Pin Description; • Added 160 MHz clock frequency in section 3.1.1; • Changed the transmitting power from 21 dBm to 20.5 dBm in Section 3.5.1; • Changed the dynamic control range of class-1, class-2 and class-3 transmit output powers to ”up to 24 dBm”; and changed the dynamic range of NZIF receiver sensitivity to ”over 97 dB” in Section 3.6.1; • Updated Table 8: Power Consumption by Power Modes, and added two notes to it; 2017.08 V1.7 • Updated sections 4.1.1, 4.1.9; • Updated Table 13: Absolute Maximum Ratings; • Updated Table 17: RF Power Consumption Specifications, and changed the duty cycle on which the transmitters’ measurements are based by 50%. • Updated Table 18: Wi-Fi Radio Characteristics and added a note on “Output impedance” to it; • Updated parameter ”Sensitivity” in Table 19, 21, 23; • Updated parameters ”RF transmit power” and ”RF power control range”, and added parameter ”Gain control step” in Table 20, 22, 24; • Deleted Chapters: ”Touch Sensor” and ”Code Examples”; • Added a link to certification download. Corrected two typos: 2017.06 V1.6 • Changed the number of external components to 20 in Section 1.1.2; • Changed the number of GPIO pins to 34 in Section 4.1.1. • Changed the power supply range in Section: 1.4.1 CPU and Memory; • Updated the note in Section 2.3: Power Scheme; 2017.06 V1.5 • Updated Table 13: Absolute Maximum Ratings; • Changed the drive strength values of the digital output pins in Note 8, in Table 26: Notes on ESP32 Pin Lists; • Added the option to subscribe for notifications of documentation changes. • Added a note to the frequency of the external crystal oscillator in Section 1.4.2: Clocks and Timers; • Added a note to Section 2.4: Strapping Pins; • Updated Section 3.7: RTC and Low-Power Management; 2017.05 V1.4 • Changed the maximum driving capability from 12 mA to 80 mA, in Table 13: Absolulte Maximum Ratings; • Changed the input impedance value of 50Ω, in Table 18: Wi-Fi Radio Characteristics, to output impedance value of 30+j10 Ω; • Added a note to No.8 in Table 26: Notes on ESP32 Pin Lists; • Deleted GPIO20 in Table IO_MUX. • Added Appendix: ESP32 Pin Lists; 2017.04 V1.3 • Updated Table: Wi-Fi Radio Characteristics; • Updated Figure: ESP32 Pin Layout (for QFN 5*5). Espressif Systems 67 Submit Documentation Feedback ESP32 Series Datasheet v4.0 Revision History Date Version 2017.03 V1.2 Release notes • Added a note to Table: Pin Description; • Updated the note in Section: Internal Memory. • Added Chapter: Part Number and Ordering Information; • Updated Section: MCU and Advanced Features; • Updated Section: Block Diagram; • Updated Chapter: Pin Definitions; 2017.02 V1.1 • Updated Section: CPU and Memory; • Updated Section: Audio PLL Clock; • Updated Section: Absolute Maximum Ratings; • Updated Chapter: Package Information; • Updated Chapter: Learning Resources. 2016.08 V1.0 Espressif Systems First release. 68 Submit Documentation Feedback ESP32 Series Datasheet v4.0 Disclaimer and Copyright Notice Information in this document, including URL references, is subject to change without notice. ALL THIRD PARTY’S INFORMATION IN THIS DOCUMENT IS PROVIDED AS IS WITH NO WARRANTIES TO ITS AUTHENTICITY AND ACCURACY. NO WARRANTY IS PROVIDED TO THIS DOCUMENT FOR ITS MERCHANTABILITY, NONINFRINGEMENT, FITNESS FOR ANY PARTICULAR PURPOSE, NOR DOES ANY WARRANTY OTHERWISE ARISING OUT OF ANY PROPOSAL, SPECIFICATION OR SAMPLE. All liability, including liability for infringement of any proprietary rights, relating to use of information in this document is disclaimed. No licenses express or implied, by estoppel or otherwise, to any intellectual property rights are granted herein. The Wi-Fi Alliance Member logo is a trademark of the Wi-Fi Alliance. The Bluetooth logo is a registered trademark of Bluetooth SIG. www.espressif.com All trade names, trademarks and registered trademarks mentioned in this document are property of their respective owners, and are hereby acknowledged. Copyright © 2022 Espressif Systems (Shanghai) Co., Ltd. All rights reserved.
ESP-WROOM-32D 价格&库存
很抱歉,暂时无法提供与“ESP-WROOM-32D”相匹配的价格&库存,您可以联系我们找货
