PMM1W5V6
PMM1W5V6
    PRISEMI(上海芯导电子)
    SMF(SOD-123FL)
    独立式 耐压:5.6V 电流:10UA@2V
PMM1W5V6 数据手册
PMM1W3V3 THRU PMM1W330 Silicon Planar Zener Diodes Description Total power dissipation: Max. 1 W. Wide zener reverse voltage range 3.3V to 330V. 1 2 Pin2 Pin1 Pin1 Small plastic package suitable for surface mounted design. Absolute Maximum Ratings And Characteristics (Ta=25℃) Parameter Symbol Power Dissipation at TL=75°C Forward Voltage at IF = 200 mA Typical thermal resistance juncting to ambient Operating and Storage Temperature Range (1) Value PO 1 W VF 1.2 V RθJA 55 ℃/W Tj,Tstg -55~+150 ℃ (1) Thermal resistance from junction to ambient at P.C.B. mounted with 0.2 X 0.2" (5 X 5 mm) copper areas p Rev.06.2 Unit Silicon Planar Zener Diodes PMM1W3V3 THRU PMM1W330 Characteristics at Ta = 25°C Dynamic Zener Voltage Range (1) IZT VZT(at IZT) Type Min(V) Nom(V) Max(V) ZZT(at IZT) Reverse Current IR at VR Admissible (mA) Max (Ω) Max(μA) (V) IZM (mA) 10 100 1 285 PMM1W3V3 3.10 3.3 3.50 75 PMM1W3V6 3.40 3.6 3.80 69 10 100 1 263 PMM1W3V9 3.70 3.9 4.10 64 9.0 50 1 243 PMM1W4V3 4.05 4.3 4.56 58 9.0 25 1 219 PMM1W4V7 4.50 4.7 4.93 53 8.0 10 1 202 PMM1W5V1 4.84 5.1 5.36 49 7.0 10 1 186 PMM1W5V6 5.32 5.6 5.88 45 5.0 10 2 170 PMM1W6V2 5.89 6.2 6.51 41 2.0 10 3 153 PMM1W6V8 6.46 6.8 7.14 37 3.5 10 4 140 PMM1W7V5 7.12 7.5 7.88 34 4.0 10 5 126 PMM1W8V2 7.79 8.2 8.61 31 4.5 10 6 116 PMM1W9V1 8.64 9.1 9.56 28 5.0 10 7 104 PMM1W10 9.50 10 10.5 25 7.0 10 7 95 PMM1W11 10.4 11 11.6 23 8.0 5 8 86 PMM1W12 11.4 12 12.6 21 9.0 5 9 79 PMM1W13 12.3 13 13.7 19 10 5 10 72 PMM1W15 14.2 15 15.8 17 14 5 11 63 PMM1W16 15.2 16 16.8 16 16 5 12 59 PMM1W18 17.1 18 18.9 14 20 5 13 52 PMM1W20 19.0 20 21.0 13 22 5 15 47 PMM1W22 20.9 22 23.1 12 23 5 17 43 PMM1W24 22.8 24 25.2 11 25 5 18 39 PMM1W27 25.6 27 28.4 9.5 35 5 21 35 PMM1W30 28.5 30 31.5 8.5 40 5 23 31 PMM1W33 31.3 33 34.7 7.5 45 5 25 28 PMM1W36 34.2 36 37.8 7.0 50 5 27 26 PMM1W39 37.0 39 41.0 6.5 60 5 30 24 PMM1W43 40.9 43 45.2 6.0 70 1 32 22 PMM1W47 44.7 47 49.4 5.5 80 1 35 20 PMM1W51 48.5 51 53.6 5.0 95 1 38 18 PMM1W56 53.2 56 58.8 4.5 110 1 42 17 PMM1W62 58.9 62 65.1 4.0 125 1 47 15 PMM1W68 64.6 68 71.4 3.7 150 1 52 14 PMM1W75 71.2 75 78.8 3.3 175 1 56 12 PMM1W82 77.9 82 86.1 3.0 200 1 62 11 PMM1W91 86.5 91 95.6 2.8 250 1 69 10 PMM1W100 95.0 100 105 2.5 350 1 76 9.5 PMM1W110 103 110 116 2.3 450 1 84 8.6 PMM1W120 114 120 127 2.0 550 1 91 7.8 PMM1W135 125 135 142 1.9 700 1 100 7.0 Rev.06.2 2 www.prisemi.com Silicon Planar Zener Diodes PMM1W3V3 THRU PMM1W330 Dynamic Zener Voltage Range (1) IZT VZT(at IZT) Type Min(V) Nom(V) Max(V) ZZT(at Reverse Current IZT) IR at VR Admissible (mA) Max (Ω) Max(μA) (V) IZM (mA) PMM1W150 140 150 157 1.8 900 1 110 6.3 PMM1W165 155 165 172 1.6 1100 1 120 5.8 PMM1W180 170 180 191 1.4 1200 1 135 5.2 PMM1W200 189 200 211 1.2 1400 1 150 4.7 PMM1W220 209 220 231 1.0 1600 1 165 4.3 PMM1W240 229 240 251 1.0 1800 1 180 3.9 PMM1W260 249 260 271 1.0 2000 1 190 3.7 PMM1W280 269 280 291 1.0 2100 1 205 3.4 PMM1W300 289 300 315 1.0 2300 1 230 3.1 PMM1W330 313 330 346 1.0 2500 1 250 2.8 Solder Reflow Recommendation Peak Temp=257℃, Ramp Rate=0.802deg. ℃/sec 280 240 200 160 120 80 40 0 0 30 60 90 120 150 180 240 210 270 300 330 360 390 420 450 480 Time (sec) PCB Design For TVS diodes a low-ohmic and low-inductive path to chassis earth is absolutely mandatory in order to achieve good ESD protection. Novices in the area of ESD protection should take following suggestions to heart:  Do not use stubs, but place the cathode of the TVS diode directly on the signal trace.  Do not make false economies and save copper for the ground connection.  Place via holes to ground as close as possible to the anode of the TVS diode.  Use as many via holes as possible for the ground connection.  Keep the length of via holes in mind! The longer the more inductance they will have. Rev.06.2 3 www.prisemi.com Silicon Planar Zener Diodes PMM1W3V3 THRU PMM1W330 Product dimension (SOD-123FL) Dim Inches Millimeters MIN MAX MIN MAX A 0.031 0.047 0.80 1.20 C 0.002 0.010 0.05 0.25 HE 0.138 0.154 3.50 3.90 E 0.061 0.077 1.55 1.95 D 0.098 0.114 2.50 2.90 g 0.020 0.043 0.50 1.10 e 0.024 0.039 0.60 1.00 7° ∠ Ordering information Rev.06.2 Device Package Reek Shipping PMM1WXXX SOD-123FL(Pb-Free) 7" 3000/ Tape & Reel 4 www.prisemi.com Silicon Planar Zener Diodes PMM1W3V3 THRU PMM1W330 IMPORTANT NOTICE and are registered trademarks of Prisemi Electronics Co., Ltd (Prisemi) ,Prisemi reserves the right to make changes without further notice to any products herein. Prisemi makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does Prisemi assume any liability arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation special, consequential or incidental damages. “Typical” parameters which may be provided in Prisemi data sheets and/or specifications can and do vary in different applications and actual performance may vary over time. All operating parameters, including “Typicals” must be validated for each customer application by customer’s technical experts. Prisemi does not convey any license under its patent rights nor the rights of others. The products listed in this document are designed to be used with ordinary electronic equipment or devices, Should you intend to use these products with equipment or devices which require an extremely high level of reliability and the malfunction of with would directly endanger human life (such as medical instruments, aerospace machinery, nuclear-reactor controllers, fuel controllers and other safety devices), please be sure to consult with our sales representative in advance. Website: http://www.prisemi.com For additional information, please contact your local Sales Representative. ©Copyright 2009, Prisemi Electronics is a registered trademark of Prisemi Electronics. All rights are reserved. Rev.06.2 5 www.prisemi.com
PMM1W5V6 价格&库存
很抱歉,暂时无法提供与“PMM1W5V6”相匹配的价格&库存,您可以联系我们找货
