RS1AG THRU RS1MG
Surface Mount Fast Recovery Rectifiers
PINNING
Reverse Voltage - 50 to 1000 V
PIN
Forward Current - 1 A
FEATURES
• For surface mounted applications
• Low profile package
• Glass Passivated Chip Junction
• Easy to pick and place
• Fast reverse recovery time
• Lead free in comply with EU RoHS 2011/65/EU directives
DESCRIPTION
1
Cathode
2
Anode
1
2
Top View
Marking Code: RS1A~RS1M
Simplified outline SMA and symbol
MECHANICAL DATA
• Case: SMA
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight: 0.055g / 0.002oz
Absolute Maximum Ratings and Characteristics
Ratings at 25 °C ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
Symbols
RS1AG
RS1BG
RS1DG
RS1GG
RS1JG
RS1KG
Maximum Repetitive Peak Reverse Voltage
V RRM
50
100
200
400
600
800
1000
V
Maximum RMS voltage
V RMS
35
70
140
280
420
560
700
V
Maximum DC Blocking Voltage
V DC
50
100
200
400
600
800
1000
V
Maximum Average Forward Rectified Current
at T c = 125 °C
I F(AV)
1
A
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
I FSM
30
A
Maximum Forward Voltage at 1 A
VF
1.3
V
IR
5
50
μA
Cj
15
pF
Parameter
Maximum DC Reverse Current
T a = 25 °C
at Rated DC Blocking Voltage
T a =125 °C
Typical Junction Capacitance
at V R =4V, f=1MHz
Maximum Reverse Recovery Time
(1)
Typical Thermal Resistance (2)
Operating and Storage Temperature Range
(1)Measured with I F = 0.5 A, I R = 1 A, I rr = 0.25 A .
REV.08
t rr
150
250
RS1MG Units
500
ns
RθJA
75
°C/W
T j , T stg
-55 ~ +150
°C
(2)P.C.B. mounted with 1.0 X 1.0" (2.54 X 2.54 cm) copper pad areas.
1 of 3
RS1AG THRU RS1MG
Fig.2 Typical Reverse Characteristics
Instaneous Reverse Current(μ A)
Average Forward Current (A)
Fig.1 Forward Current Derating Curve
1.2
1.0
0.8
0.6
0.4
0.2
Single phase half-wave 60 Hz
0.0
25
50
75
100
125
150
175
100
T J =125°C
10
1.0
T J =25°C
0.1
00
T J =25°C
1.0
0.1
pulse with 300μs
1% duty cycle
0.01
0.0
1.0
1.5
2.0
2.5
Peak Forward Surage Current (A)
30
25
10
8.3 ms Single Half Sine Wave
(JEDEC Method)
10
100
Number of Cycles
REV.08
100
120
140
T J =25°C
10
1.0
10
Reverse Voltage (V)
35
1
80
100
0.1
Fig.5 Maximum Non-Repetitive Peak
00
60
1
0.5
Instaneous Forward Voltage (V)
05
40
Fig.4 Typical Junction Capacitance
Junction Capacitance ( pF)
Instaneous Forward Current (A)
Fig.3 Typical Instaneous Forward
Characteristics
10
percent of Rated Peak Reverse Voltage (%)
Case Temperature (°C)
2 of 3
100
RS1AG THRU RS1MG
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
A
A
SMA
c
a
VM
e
A
HE
g
e
E
A
D
E
HE
c
e
g
max
2.2
4.5
2.7
5.2
0.31
1.6
1.5
min
1.9
4.0
2.3
4.7
0.15
1.3
0.9
max
87
181
106
205
12
63
59
min
75
157
91
185
6
51
35
UNIT
mm
mil
The recommended mounting pad size
2.4
(94)
mm
Unit :
(mil)
REV.08
3 of 3
a
0.3
12
Marking
Type number
Marking code
RS1AG
RS1A
1.8
(71)
1.8
(71)
1.8
(71)
g
e
A
D
RS1BG
RS1B
RS1DG
RS1D
RS1GG
RS1G
RS1JG
RS1J
RS1KG
RS1K
RS1MG
RS1M
很抱歉,暂时无法提供与“RS1GG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.07712
- 500+0.06048
- 1500+0.05130
- 5000+0.04569
- 25000+0.04094
- 50000+0.03834
