BC817-40/SNR
BC817-40/SNR
    NEXPERIA(安世)
    SOT23-3
    BC817-40/SNR
BC817-40/SNR 数据手册
BC817 series 45 V, 500 mA NPN general-purpose transistors Rev. 8 — 1 July 2022 Product data sheet 1. General description NPN general-purpose transistor in a small SOT23 (TO-236AB) Surface-Mounted Device (SMD) plastic package. Table 1. Product overview Type number Package BC817 PNP complement Nexperia JEDEC JEITA SOT23 TO-236AB - BC807 BC817-16 BC807-16 BC817-25 BC807-25 BC817-40 BC807-40 2. Features and benefits • • High current Three current gain selections 3. Applications • General-purpose switching and amplification 4. Quick reference data Table 2. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VCEO collector-emitter voltage open base; Tamb = 25 °C - - 45 V IC collector current Tamb = 25 °C - - 500 mA ICM peak collector current single pulse; tp ≤ 1 ms; Tamb = 25 °C - - 1 A hFE DC current gain [1] 100 - 600 BC817-16 [1] 100 - 250 BC817-25 [1] 160 - 400 BC817-40 [1] 250 - 600 BC817 [1] pulsed; tp ≤ 300 μs; δ ≤ 0.02 VCE = 1 V; IC = 100 mA Tamb = 25 °C BC817 series Nexperia 45 V, 500 mA NPN general-purpose transistors 5. Pinning information Table 3. Pinning Pin Symbol Description 1 B base 2 E emitter 3 C collector Simplified outline Graphic symbol 3 C B E 1 2 sym123 6. Ordering information Table 4. Ordering information Type number Package BC817 Name Description Version TO-236AB Plastic surface-mounted package; 3 leads SOT23 BC817-16 BC817-25 BC817-40 7. Marking Table 5. Marking Type number Marking code[1] BC817 6D% BC817-16 6A% BC817-25 6B% BC817-40 6C% [1] % = placeholder for manufacturing site code BC817_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 1 July 2022 © Nexperia B.V. 2022. All rights reserved 2 / 13 BC817 series Nexperia 45 V, 500 mA NPN general-purpose transistors 8. Limiting values Table 6. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VCBO collector-base voltage open emitter; Tamb = 25 °C - 50 V VCEO collector-emitter voltage open base; Tamb = 25 °C - 45 V VEBO emitter-base voltage open collector; Tamb = 25 °C - 5 V IC collector current Tamb = 25 °C - 500 mA ICM peak collector current single pulse; tp ≤ 1 ms; Tamb = 25 °C - 1 A IBM peak base current single pulse; tp ≤ 1 ms; Tamb = 25 °C - 200 mA Ptot total power dissipation Tamb ≤ 25 °C [1] [2] - 250 mW [3] [2] - 345 mW Tj junction temperature - 150 °C Tamb ambient temperature -65 150 °C Tstg storage temperature -65 150 °C [1] [2] [3] Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. Valid for all available selection groups. 2 Device mounted on an FR4 PCB, single-sided copper, tin-plated; mounting pad for collector 1 cm . aaa-028120 400 Ptot (mW) (1) 300 (2) 200 100 0 -75 -25 25 75 125 175 Tamb (°C) 2 (1) FFR4 PCB, single-sided copper; 1 cm (2) FR4 PCB, single-sided copper; standard footprint Fig. 1. Power derating curves BC817_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 1 July 2022 © Nexperia B.V. 2022. All rights reserved 3 / 13 BC817 series Nexperia 45 V, 500 mA NPN general-purpose transistors 9. Thermal characteristics Table 7. Thermal characteristics Symbol Parameter Conditions Rth(j-a) in free air [1] [2] [3] thermal resistance from junction to ambient Min Typ Max Unit [1] [2] - - 500 K/W [3] [2] - - 362 K/W Device mounted on an FR4 Printed-Circuit-Board (PCB); single-sided copper; tin-plated and standard footprint. Valid for all available selection groups. 2 Device mounted on an FR4 PCB, single-sided copper, tin-plated; monting pad for collector 1 cm . aaa-028112 103 duty cycle = 1 Zth(j-a) (K/W) 0.75 102 0.50 0.33 0.20 0.10 0.05 10 0.02 0.01 0 1 -5 10 10-4 10-3 10-2 10-1 1 10 102 tp (s) 103 FR4 PCB, single-sided, tin-plated and standard footprint Fig. 2. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values aaa-028113 103 duty cycle = 1 Zth(j-a) (K/W) 0.75 102 0.50 0.33 0.20 0.10 0.05 10 0.02 0.01 0 1 10-5 10-4 10-3 10-2 10-1 1 10 102 tp (s) 103 2 FR4 PCB, single-sided copper, tin-plated; mounting pad for collector 1 cm . Fig. 3. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values BC817_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 1 July 2022 © Nexperia B.V. 2022. All rights reserved 4 / 13 BC817 series Nexperia 45 V, 500 mA NPN general-purpose transistors 10. Characteristics Table 8. Characteristics Symbol Parameter Conditions Min Typ Max Unit V(BR)CBO collector-base breakdown voltage IC = 100 µA; IE = 0 A; Tamb = 25 °C 50 - - V V(BR)CEO collector-emitter breakdown voltage IC = 10 mA; IE = 0 A; Tamb = 25 °C 45 - - V V(BR)EBO emitter-base breakdown voltage IE = 100 µA; IC = 0 A; Tamb = 25 °C 5 - - V ICBO collector-base cut-off current VCB = 20 V; IE = 0 A; Tamb = 25 °C - - 100 nA VCB = 20 V; IE = 0 A; Tj = 150 °C - - 5 μA IEBO emitter-base cut-off current VEB = 5 V; IC = 0 A; Tamb = 25 °C - - 100 nA hFE DC current gain BC817 [1] 100 - 600 BC817-16 [1] 100 - 250 BC817-25 [1] 160 - 400 BC817-40 [1] 250 - 600 VCE = 1 V; IC = 100 mA; Tamb = 25 °C hFE DC current gain VCE = 1 V; IC = 500 mA; Tamb = 25 °C [1] 40 - - VCEsat collector-emitter saturation voltage IC = 500 mA; IB = 50 mA; Tamb = 25 °C [1] - - 700 mV VBE base-emitter voltage VCE = 1 V; IC = 500 mA; Tamb = 25 °C [1] [2] - - 1.2 V fT transition frequency VCE = 5 V; IC = 10 mA; f = 100 MHz; Tamb = 25 °C 100 - - MHz Cc collector capacitance VCB = 10 V; IE = ie = 0 A; f = 1 MHz; Tamb = 25 °C - 3 - pF [1] [2] pulsed; tp ≤ 300 μs; δ ≤ 0.02 VBE decreases by about 2 mV/K with increasing temperature. BC817_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 1 July 2022 © Nexperia B.V. 2022. All rights reserved 5 / 13 BC817 series Nexperia 45 V, 500 mA NPN general-purpose transistors 006aaa131 400 006aaa134 10 hFE 300 VBEsat (V) (1) 200 1 (2) (1) (2) (3) (3) 100 0 10- 1 1 10 102 I C (mA) 103 10- 1 10- 1 VCE = 1 V (1) Tamb = 150 °C (2) Tamb = 25 °C (3) Tamb = -55 °C Fig. 4. 1 102 10 I C (mA) 103 IC/IB = 10 (1) Tamb = -55 °C (2) Tamb = 25 °C (3) Tamb = 150 °C BC817-16: DC current gain as a function of collector current; typical values Fig. 5. 006aaa137 1 BC817-16: Base-emitter saturation voltage as a function of collector current; typical values 006aaa140 1.2 (5) IC (A) VCEsat (V) (4) (3) (2) 0.8 (1) (6) (7) 10- 1 (8) (9) 0.4 (10) (1) (2) (3) 10- 2 10- 1 1 10 102 I C (mA) 0 103 IC/IB = 10 (1) Tamb = 150 °C (2) Tamb = 25 °C (3) Tamb = -55 °C Fig. 6. Fig. 7. Product data sheet 1 2 3 4 VCE (V) 5 Tamb = 25 °C (1) IB = 16.0 mA (2) IB = 14.4 mA (3) IB = 12.8 mA (4) IB = 11.2 mA (5) IB = 9.6 mA (6) IB = 8.0 mA (7) IB = 6.4 mA (8) IB = 4.8 mA (9) IB = 3.2 mA (10) IB = 1.6 mA BC817-16: Collector-emitter saturation voltage as a function of collector current; typical values BC817_SER 0 BC817-16: Collector current as a function of collector-emitter voltage; typical values All information provided in this document is subject to legal disclaimers. Rev. 8 — 1 July 2022 © Nexperia B.V. 2022. All rights reserved 6 / 13 BC817 series Nexperia 45 V, 500 mA NPN general-purpose transistors 006aaa132 600 hFE (1) VBEsat (V) (2) 1 400 (3) 1 (3) 102 10 I C (mA) 103 10- 1 10- 1 VCE = 1 V (1) Tamb = 150 °C (2) Tamb = 25 °C (3) Tamb = -55 °C Fig. 8. (1) (2) 200 0 10- 1 006aaa135 10 1 102 10 I C (mA) 103 IC/IB = 10 (1) Tamb = -55 °C (2) Tamb = 25 °C (3) Tamb = 150 °C BC817-25: DC current gain as a function of collector current; typical values 006aaa138 1 Fig. 9. BC817-25: Base-emitter saturation voltage as a function of collector current; typical values 006aaa141 1.2 VCEsat (V) (6) IC (A) 10- 1 (5) (4) (3) (2) (1) 0.8 (7) (8) (1) (9) (2) 10- 2 0.4 (3) (10) 10- 3 10- 1 1 10 102 I C (mA) 103 0 IC/IB = 10 (1) Tamb = 150 °C (2) Tamb = 25 °C (3) Tamb = -55 °C 0 1 2 3 4 VCE (V) 5 Tamb = 25 °C (1) IB = 13.0 mA (2) IB = 11.7 mA (3) IB = 10.4 mA (4) IB = 9.1 mA (5) IB = 7.8 mA (6) IB = 6.5 mA (7) IB = 5.2 mA (8) IB = 3.9 mA (9) IB = 2.6 mA (10) IB = 1.3 mA Fig. 10. BC817-25: Collector-emitter saturation voltage as a function of collector current; typical values Fig. 11. BC817-25: Collector current as a function of collector-emitter voltage; typical values BC817_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 1 July 2022 © Nexperia B.V. 2022. All rights reserved 7 / 13 BC817 series Nexperia 45 V, 500 mA NPN general-purpose transistors 006aaa133 800 006aaa136 10 hFE 600 (1) VBEsat (V) 400 (2) 1 (1) (2) (3) 200 0 10- 1 1 (3) 102 10 I C (mA) 103 10- 1 10- 1 VCE = 1 V (1) Tamb = 150 °C (2) Tamb = 25 °C (3) Tamb = -55 °C 1 102 10 I C (mA) 103 IC/IB = 10 (1) Tamb = -55 °C (2) Tamb = 25 °C (3) Tamb = 150 °C Fig. 12. BC817-40: DC current gain as a function of collector current; typical values 006aaa139 1 Fig. 13. BC817-40: Base-emitter saturation voltage as a function of collector current; typical values 006aaa142 1.2 VCEsat (V) (6) IC (A) 10- 1 (5) (4) (3) (2) 0.8 (1) (7) (8) (9) (1) (2) 10- 2 10- 3 10- 1 0.4 (3) 1 10 102 I C (mA) 103 0 IC/IB = 10 (1) Tamb = 150 °C (2) Tamb = 25 °C (3) Tamb = -55 °C (10) 0 1 2 3 4 VCE (V) 5 Tamb = 25 °C (1) IB = 12.0 mA (2) IB = 10.8 mA (3) IB = 9.6 mA (4) IB = 8.4 mA (5) IB = 7.2 mA (6) IB = 6.0 mA (7) IB = 4.8 mA (8) IB = 3.6 mA (9) IB = 2.4 mA (10) IB = 1.2 mA Fig. 14. BC817-40: Collector-emitter saturation voltage as a function of collector current; typical values Fig. 15. BC817-40: Collector current as a function of collector-emitter voltage; typical values BC817_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 1 July 2022 © Nexperia B.V. 2022. All rights reserved 8 / 13 BC817 series Nexperia 45 V, 500 mA NPN general-purpose transistors 11. Package outline 3.0 2.8 1.1 0.9 3 0.45 0.15 2.5 1.4 2.1 1.2 1 2 1.9 0.48 0.38 Dimensions in mm 0.15 0.09 18-03-12 Fig. 16. Package outline SOT23 (TO-236AB) BC817_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 1 July 2022 © Nexperia B.V. 2022. All rights reserved 9 / 13 BC817 series Nexperia 45 V, 500 mA NPN general-purpose transistors 12. Soldering 3.3 2.9 1.9 solder lands 3 solder resist 2 1.7 solder paste occupied area 0.6 (3×) 0.7 (3×) Dimensions in mm 0.5 (3×) 0.6 (3×) 1 sot23_fr Fig. 17. Reflow soldering footprint for SOT23 (TO-236AB) 2.2 1.2 (2×) 1.4 (2×) solder lands 4.6 solder resist 2.6 occupied area Dimensions in mm 1.4 preferred transport direction during soldering 2.8 4.5 sot23_fw Fig. 18. Wave soldering footprint for SOT23 (TO-236AB) BC817_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 1 July 2022 © Nexperia B.V. 2022. All rights reserved 10 / 13 BC817 series Nexperia 45 V, 500 mA NPN general-purpose transistors 13. Revision history Table 9. Revision history Data sheet ID Release date Data sheet status Change notice Supersedes BC817_SER v.8 20220701 Product data sheet - BC817_SER v.7 Modifications: • BC817_SER v.7 20180615 Product data sheet - BC817_BC817W_BC327 v.6 BC817_BC817W_BC337 v.6 20091117 Product data sheet - BC817_BC817W_BC337 v.5 BC817_BC817W_BC337 v.5 20050221 Product data sheet CPCN200302007F CPCN200405006F BC817 v.4 BC817W v.4 BC337 v.3 BC817 v.4 20040116 Product Specification - BC817 v.3 BC817W_SER v.4 19990518 Product Specification - BC817W_SER v.3 BC337 v.3 19990415 Product Specification - BC337_338_CNV v.2 BC817_SER Product data sheet Product(s) changed to non-automotive qualification. Please refer to nexperia.com for automotive (-Q) product alternative(s). All information provided in this document is subject to legal disclaimers. Rev. 8 — 1 July 2022 © Nexperia B.V. 2022. All rights reserved 11 / 13 BC817 series Nexperia 45 V, 500 mA NPN general-purpose transistors 14. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal BC817_SER Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 8 — 1 July 2022 © Nexperia B.V. 2022. All rights reserved 12 / 13 BC817 series Nexperia 45 V, 500 mA NPN general-purpose transistors Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Quick reference data....................................................1 5. Pinning information......................................................2 6. Ordering information....................................................2 7. Marking.......................................................................... 2 8. Limiting values............................................................. 3 9. Thermal characteristics............................................... 4 10. Characteristics............................................................ 5 11. Package outline.......................................................... 9 12. Soldering................................................................... 10 13. Revision history........................................................11 14. Legal information......................................................12 © Nexperia B.V. 2022. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 1 July 2022 BC817_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 1 July 2022 © Nexperia B.V. 2022. All rights reserved 13 / 13
BC817-40/SNR 价格&库存
很抱歉,暂时无法提供与“BC817-40/SNR”相匹配的价格&库存,您可以联系我们找货
BC817-40/SNR
  • 1000+0.16082
  • 10000+0.16082
  • 100000+0.16082
