SDINBDG4-32G
SDINBDG4-32G
    SANDISK(闪迪)
    BGA153_11.5X13MM
    EMMC 32G
SDINBDG4-32G 数据手册
Data Sheet - Confidential DOC 56-34-01508 • Rev 1.4 • Aug 2017 iNAND® 7250 e.MMC 5.1 with HS400 Interface Confidential, subject to all applicable non-disclosure agreements www.SanDisk.com SanDisk® iNAND 7250 e.MMC 5.1+ HS400 I/F data sheet Confidential REVISION HISTORY Doc. No Revision Date Description DOC-56-34-01508 1.0 March 2017 DOC-56-34-01508 1.1 June 2017 Updated performance target and ext_CSD SKU_ID DOC-56-34-01508 1.2 July 2017 Updated MAX_ENH_SIZE_MULT DOC-56-34-01508 1.3 July 2017 Updated features description of unified boot and Hardware Pin Secure Boot DOC-56-34-01508 1.4 August 2017 Released version Updated marking drawing SanDisk® provides this information, and any related samples, products, and documentation (collectively the “Materials”) solely for the selection and use of SanDisk® products. To the maximum extent permitted by applicable law: (1) Materials are made available “AS IS” and with all faults, SanDisk hereby DISCLAIMS ALL WARRANTIES AND CONDITIONS, EXPRESS, IMPLIED, STATUTORY, OR OTHERWISE, INCLUDING BUT NOT LIMITED TO WARRANTIES OF MERCHANTABILITY, NON-INFRINGEMENT, OR FITNESS FOR ANY PARTICULAR PURPOSE; and (2) SanDisk shall not be liable (whether in contract or tort, including negligence, or under any other theory of liability) for any loss or damage of any kind or nature related to, arising under, or in connection with, the Materials (including your use of the Materials), including for any direct, indirect, special, incidental, or consequential loss or damage (including loss of data, profits, goodwill, or any type of loss or damage suffered as a result of any action brought by a third party) even if such damage or loss was reasonably foreseeable or SanDisk® had been advised of the possibility of the same. You are responsible for obtaining any rights required in connection with your use of the Materials. The Materials are subject to change without further notice. SanDisk® assumes no obligation to correct errors or to notify you of updates to the Materials or to product specifications. You may not reverse engineer, reproduce, modify, distribute, or publicly display the Materials without prior written consent of SanDisk. SanDisk products are not designed or intended to be fail-safe or for use in any application requiring fail-safe performance. You assume sole risk and liability for use of SanDisk products in critical applications. © 2017 Western Digital Corporation or its affiliates. All rights reserved. Specifications are subject to change. SanDisk® is a trademark of Western Digital Corporation or its affiliates, registered in the United States and other countries. microSDHC is a trademark of SD-3C, LLC. Other brand names mentioned herein are for identification purposes only and may be the trademarks of their respective holder(s). © 2017 SanDisk – a Western Digital brand -2- DOC-56-34-01508 Confidential SanDisk iNAND 7250 e.MMC 5.1 HS400 I/F data sheet TABLE OF CONTENTS 1. Introduction ......................................................................................................................... 5 1.1. General Description ...................................................................................................... 5 1.2. Plug-and-Play Integration ............................................................................................. 6 1.3. Feature Overview ......................................................................................................... 7 1.4. MMC bus and Power Lines ........................................................................................... 8 1.4.1. Bus operating conditions ................................................................................................. 8 2. e.MMC Selected Features Overview ................................................................................ 10 2.1. HS400 Interface.......................................................................................................... 11 2.2. Enhanced User Data Area (EUDA) ............................................................................. 11 2.3. Field Firmware Upgrade (FFU) ................................................................................... 11 2.4. Cache ......................................................................................................................... 11 2.5. Discard ....................................................................................................................... 11 2.6. Power off Notifications ................................................................................................ 12 2.7. Packed Commands .................................................................................................... 12 2.8. Boot Partition .............................................................................................................. 12 2.9. RPMB Partition ........................................................................................................... 12 2.10. Automatic Sleep Mode................................................................................................ 12 2.11. Sleep (CMD5) ............................................................................................................. 12 2.12. Enhanced Reliable Write ............................................................................................ 12 2.13. Sanitize ...................................................................................................................... 13 2.14. Secure Erase .............................................................................................................. 13 2.15. Secure Trim ................................................................................................................ 13 2.16. Partition Management................................................................................................. 13 2.17. Device Health ............................................................................................................. 14 2.18. EOL Status ................................................................................................................. 14 2.19. Enhanced Write Protection ......................................................................................... 14 2.20. High Priority Interrupt (HPI)......................................................................................... 14 2.21. H/W Reset .................................................................................................................. 14 2.22. Host-Device Synchronization Flow (Enhanced STROBE) ........................................... 15 2.23. Command-Queue ....................................................................................................... 15 3. Product Specifications ..................................................................................................... 16 3.1. Typical Power Measurements..................................................................................... 16 3.2. Operating Conditions .................................................................................................. 17 © 2017 SanDisk – a Western Digital brand -3- DOC - 56-34-01508 Confidential SanDisk iNAND 7250 e.MMC 5.1 HS400 I/F data sheet 3.2.1. Operating and Storage Temperature Specifications ..................................................... 17 3.2.2. Moisture Sensitivity ........................................................................................................ 17 3.3. Reliability .................................................................................................................... 18 3.4 Typical System Performance ...................................................................................... 19 4. Physical Specifications .................................................................................................... 20 5. Interface Description......................................................................................................... 22 5.1. MMC I/F Ball Array ..................................................................................................... 22 5.2. Pins and Signal Description ........................................................................................ 23 5.3. Registers value ........................................................................................................... 24 5.3.1. OCR Register................................................................................................................. 24 5.3.2. CID Register .................................................................................................................. 24 5.3.3. DSR Register ................................................................................................................. 24 5.3.4. CSD Register ................................................................................................................. 25 5.3.5. EXT_CSD Register ........................................................................................................ 26 5.3.6. User Density .................................................................................................................. 32 6. HW Application Guidelines ............................................................................................... 33 6.1. Design Guidelines ...................................................................................................... 33 6.2. Capacitor Selection & Layout Guidelines .................................................................... 34 6.3. Reference Schematics................................................................................................ 36 7. Propriety iNAND 7250 feature overview .......................................................................... 37 7.1. Device Report ............................................................................................................. 37 7.1.1. Device Report fields ....................................................................................................... 37 7.2. Power-Loss indications ............................................................................................... 38 7.2.1. Unstable Power-Supply indications ............................................................................... 38 7.3. Unified Boot ................................................................................................................ 39 7.3.1. Unified Boot Support Indication ..................................................................................... 39 7.3.2. Enable Unified Boot ....................................................................................................... 39 7.3.3. Important Considerations ............................................................................................... 39 7.4. Hardware Pin Secure Boot ......................................................................................... 40 7.4.1. Requirements................................................................................................................. 41 7.4.2. Physical Proof Protocol Support Indication ................................................................... 41 7.4.3. Enable Physical Proof Protocol ..................................................................................... 41 7.4.4. Configuration Process ................................................................................................... 41 7.4.5. Authentication Process .................................................................................................. 41 8. Marking .............................................................................................................................. 42 9. Ordering Information ........................................................................................................ 43 How to Contact Us .................................................................................................................. 44 © 2017 SanDisk – a Western Digital brand -4- DOC - 56-34-01508 Confidential SanDisk iNAND 7250 e.MMC 5.1 HS400 I/F data sheet 1. INTRODUCTION 1.1. General Description Overview SanDisk iNAND 7250 is an Embedded Flash Drive (EFD) designed for write intensive applications in a wide range of home entertainment and security applications, such as Set-TopBox (STB), Over The Top (OTT), Home Gateways, Smart TV, Smart Security Cameras and more. The iNAND 7250 utilizes an LDPC ECC machine and MLC memory to provide a robust, high performance, high quality and high endurance product. The LDPC engine significantly improves error correction enabling longer device lifetime and an increased ability to handle operation at high temperature. The iNAND 7250 provides 8GB to 64GB of capacity and supports e.MMC 5.1. The iNAND 7250 is the ideal choice to deliver high reliability and high performance for storage applications like imaging, video, music, GPS, gaming, email, office and other new applications such as NOR replacement for embedded systems or other devices. The design of the iNAND 7250 is based on a JEDEC compatible form factor measuring 11.5x13mm (153 balls) for all capacities to lower integration costs and accelerate time-tomarket. Architecture iNAND 7250 combines an embedded thin flash controller with advanced Multilevel Cell (MLC) NAND flash technology enhanced by SanDisk’s embedded flash management software running as firmware on the flash controller. iNAND 7250 employs an industrystandard eMMC 5.11 interface featuring Command-Queue, HS400 interface, FFU, as well as legacy eMMC 4.51 features such as EUDA, Power Off Notifications, Packed commands, Cache, Boot / RPMB partitions, HPI, and HW Reset, making it an optimal device for both reliable code and data storage. Like our other iNAND products, iNAND 7250 offers plug-and-play integration and support for multiple NAND technology transitions, as well as features such as an advanced power management scheme. iNAND 7250 architecture and embedded firmware fully emulates a hard disk to the host processor, enabling read/write operations that are identical to a standard, sector-based hard drive. In addition, SanDisk firmware employs patented methods, such as virtual mapping, dynamic and static wear-leveling, and automatic block management to ensure high data reliability and maximizing flash life expectancy. iNAND 7250 also includes an intelligent controller, which manages interface protocols, data storage and retrieval, error correction code (ECC) algorithms, defect handling and diagnostics, power management and clock control. Combining high performance with features for easy integration and exceptional reliability, iNAND 7250 is an EFD designed to exceed the demands of both manufacturers and their customers. 1 Compatible to JESD84-B51 © 2017 SanDisk – a Western Digital brand -5- DOC-56-34-01508 Confidential SanDisk iNAND 7250 e.MMC 5.1 HS400 I/F data sheet 1.2. Plug-and-Play Integration iNAND’s optimized architecture eliminates the need for complicated software integration and testing processes thereby enabling plug-and-play integration into the host system. The replacement of one iNAND device with another of a newer generation requires virtually no changes to the host. This allows manufacturers to adopt advanced NAND Flash technologies and update product lines with minimal integration or qualification efforts. iNAND 7250 features a MMC interface allows for easy integration regardless of the host (chipset) type used. All device and interface configuration data (such as maximum frequency and device identification) are stored on the device. Figure 1 shows a block diagram of the SanDisk iNAND 7250 with MMC Interface. SanDisk iNAND MMC Bus Interface Single Chip controller Data In/Out Flash Memory Control Figure 1 - iNAND 7250 with MMC Interface Block Diagram © 2017 SanDisk – a Western Digital brand -6- DOC - 56-34-01508 Confidential SanDisk iNAND 7250 e.MMC 5.1 HS400 I/F data sheet 1.3. Feature Overview SanDisk iNAND 7250, with MMC interface, includes the following features:  Memory controller and NAND flash  Mechanical design that complies with JEDEC Specifications with specific optimizations for automotive applications  Offered in three TFBGA packages of e.MMC 5.1 o 11.5mm x 13mm x 0.8mm (8GB-16GB) o 11.5mm x 13mm x 1.0mm (32GB) o 11.5mm x 13mm x 1.2mm (64GB)  Operating temperature range: –25C° to +85C°  Dual power system  Core voltage (VCC) 2.7-3.6 V  I/O (VCCQ) voltage, either: 1.7-1.95V or 2.7-3.6V  8GB - 64GB of data storage  Supports three data bus widths: 1bit (default), 4bit, 8bit  Complies with e.MMC Specification Ver. 5.1 HS400  Variable clock frequencies of 0-20 MHz, 0-26 MHz (default), 0-52 MHz (high-speed), 0-200 MHz SDR (HS200), 0-200 MHz DDR (HS400)  Up to 300 MB/sec bus transfer rate, using 8 parallel data lines at 200 MHz, HS400 Mode  High data integrity with MLC memory, advanced LDPC ECC engine, automatic refresh, advanced power protection  Flexible EUDA, Fast boot  Up to 3K P/E cycles on MLC and 30K on SLC with 1 year data retention @ 55°C and at least 10 year data retention @ 55°C for fresh devices © 2017 SanDisk – a Western Digital brand -7- DOC - 56-34-01508 Confidential SanDisk iNAND 7250 e.MMC 5.1 HS400 I/F data sheet 1.4. MMC bus and Power Lines SanDisk iNAND 7250 supports the MMC interface protocol. For more details regarding these buses refer to JEDEC standard No. JESD84-B51. The iNAND bus has the following communication and power lines:  CMD: Command is a bidirectional signal. The host and iNAND operate in two modes, open drain and push-pull.  DAT0-7: Data lines are bidirectional signals. Host and iNAND operate in push-pull mode.  CLK: Clock input.  RST_n: Hardware Reset Input.  VCCQ: Power supply line for host interface.  VCC: Power supply line for internal flash memory.  VDDi: iNAND’s internal power node, not the power supply. Connect 0.1uF capacitor from VDDi to ground.  VSS, VSSQ: Ground lines.  RCLK: Data strobe.  VSF: Vendor specific functions used for debugging purposes. 1.4.1. Bus operating conditions Table 1 - Bus operating conditions Parameter Min Max Unit Peak voltage on all lines -0.5 VCCQ+0.5 V Input Leakage Current (before initializing and/or connecting the internal pull-up resistors) -100 100 µA Input Leakage Current (after changing the bus width and disconnecting the internal pull-up resistors) -2 2 µA Output Leakage Current (before initializing and/or connecting the internal pull-up resistors) -100 100 µA -2 2 µA Output Leakage Current (after changing the bus width and disconnecting the internal pull-up resistors) © 2017 SanDisk – a Western Digital brand -8- DOC - 56-34-01508 Confidential SanDisk iNAND 7250 e.MMC 5.1 HS400 I/F data sheet Table 2 – Power supply voltage Parameter Supply Voltage © 2017 SanDisk – a Western Digital brand Symbol Min Max Unit VCCQ (Low) 1.7 1.95 V VCCQ (High) 2.7 3.6 V VCC 2.7 3.6 V VSS-VSSQ -0.3 0.3 V -9- DOC - 56-34-01508 Confidential SanDisk iNAND 7250 e.MMC 5.1 HS400 I/F data sheet 2. E.MMC SELECTED FEATURES OVERVIEW iNAND 7250 supported features list: Table 3 – Proprietary Features list e.MMC N/A N/A 4.41 Device Features INTERFACE BUS SPEED EUDA 4.41 4.41 4.41 4.41 4.41 4.41 4.41 4.41 4.5 SECURE ERASE/TRIM BOOT AND MASS STORAGE PARTITIONING & PROTECTION BACKGROUND OPERATIONS POWER OFF NOTIFICATION HARDWARE RESET HPI RPMB EXTENDED PARTITION ATTRIBUTE LARGE SECTOR SIZE SANITIZE (4.51) PACKED COMMANDS DISCARD DATA TAG CONTEXT MANAGEMENT CACHE SECURED FIELD FIRMWARE UPGRADE (sFFU) PRODUCTION STATE AWARENESS DEVICE HEALTH ENHANCE STROBE COMMAND QUEUE RPMB THROUGHPUT CACHE FLUSH AND BARRIER BKOPS CONTROLLER SECURE WP PRE EOL 4.5 4.5 4.5 4.5 4.5 4.5 4.5 5.0 5.0 5.0 5.1 5.1 5.1 5.1 5.1 5.1 5.1 Proprietary Proprietary Proprietary Proprietary Proprietary VSF PNM DEVICE REPORT UNIFIED BOOT HARDWARE PIN SECURE BOOT © 2017 SanDisk – a Western Digital brand Benefit Speed Max theoretical Speed Enhanced User Data Area for higher endurance “True Wipe” One storage device (reduced BOM) Flexibility Better User Experience (low latency) Faster Boot; Responsiveness Robust System Design Control Long Reads/Writes Secure Folders Flexibility Support HS400 Up to 400MB/s Yes Potential performance “True Wipe” Reduce Host Overhead Improved Performance on Full Media Performance and/or Reliability Performance and/or Reliability Better Sequential & Random Writes Enables feature enhancements in the field No Yes Yes Yes Yes (API only) Yes (API only) Yes Yes Different operation during production Yes Vital NAND info Sync between Device and Host in HS400 Responsiveness Faster RPMB write throughput Ordered Cache flushing Host control on BKOPs Secure Write Protect Pre End Of Life notification Enable on-board debugging Special product name Device Firmware status Reports both boot partitions Enable Hardware pin secure write protect Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes (only on CS2.2) Yes (only on CS2.2) - 10 - Yes Yes Yes Yes Yes Yes Yes Yes Yes DOC - 56-34-01508 Confidential SanDisk iNAND 7250 e.MMC 5.1 HS400 I/F data sheet 2.1. HS400 Interface SanDisk 7250 supports HS400 signaling to achieve a bus speed of 400 MB/s via a 200MHz dual data rate clock frequency. HS400 mode supports 4 or 8 bit bus width and the 1.7 – 1.95 VCCQ option. Due to the speed, the host may need to have an adjustable sampling point to reliably receive the incoming data. For additional information please refer to JESD84-B51 standard. 2.2. Enhanced User Data Area (EUDA) For write intensive applications, there is a need for an area of higher endurance or performance. To address this, SanDisk 7250 allows for the definition of an enhanced user data area as specified in the JESD84-B51 standard. This area is a true SLC partition. The EUDA is a designated area of the general User Data Area. The configuration is one-time programmable. 2.3. Field Firmware Upgrade (FFU) Field Firmware Updates (FFU) enables features enhancement in the field. Using this mechanism, the host downloads a new version of the firmware to the e.MMC device and instructs the e.MMC device to install the new downloaded firmware into the device. The entire FFU process occurs in the background without affecting the user/OS data. During the FFU process, the host can replace firmware files or single/all file systems. The secure FFU (sFFU) usage model for firmware upgrades is as follows: 1. sFFU files are generated and signed at the SanDisk lab 2. The sFFU files are handed to SanDisk’s customer 3. SanDisk’s customer can push the firmware updates to their end-users in a transparent way Note 1: The sFFU process and sFFU files are protected against leakage to unauthorized entities. Note 2: During the sFFU process the Host may retrieve the exact status of the process using the smart report feature. For additional information please refer to JESD84-B51 standard and the SanDisk application note on this subject. 2.4. Cache The eMMC cache is dedicated volatile memory at the size of 512KB. Caching enables to improve iNAND performance for both sequential and random access. For additional information please refer to JESD84-B51 standard. 2.5. Discard iNAND supports discard command as defined in e.MMC 5.1 spec. This command allows the host to identify data which is not needed, without requiring the device to remove the data from the Media. It is highly recommended for use to guarantee optimal performance of iNAND and reduce amount of housekeeping operation. © 2017 SanDisk – a Western Digital brand - 11 - DOC - 56-34-01508 Confidential SanDisk iNAND 7250 e.MMC 5.1 HS400 I/F data sheet 2.6. Power off Notifications iNAND supports power off notifications as defined in e.MMC 5.1 spec. The usage of power off notifications allows the device to prepare itself to power off, and improve user experience during power-on. Note that the device may be set into sleep mode while power off notification is enabled. Power off notification long allows the device to shutdown properly and save important data for fast boot time on the next power cycle. 2.7. Packed Commands To enable optimal system performance, iNAND supports packed commands as defined in e.MMC 5.1 spec. It allows the host to pack Read or Write commands into groups (of single type of operation) and transfer these to the device in a single transfer on the bus. Thus, it allows reducing overall bus overheads. 2.8. Boot Partition iNAND supports e.MMC 5.1 boot operation mode: factory configuration supplies two boot partitions each 4MB in size for 8GB-64GB. 2.9. RPMB Partition iNAND supports e.MMC 5.1 RPMB operation mode: factory configuration supplies one RPMB partition 4MB in size for 8GB-64GB. 2.10. Automatic Sleep Mode A unique feature of iNAND is automatic entrance and exit from sleep mode. Upon completion of an operation, iNAND enters sleep mode to conserve power if no further commands are received. The host does not have to take any action for this to occur, however, in order to achieve the lowest sleep current, the host needs to shut down its clock to the memory device. In most systems, embedded devices are in sleep mode except when accessed by the host, thus conserving power. When the host is ready to access a memory device in sleep mode, any command issued to it will cause it to exit sleep and respond immediately. 2.11. Sleep (CMD5) An iNAND 7250 device may be switched between a Sleep and a Standby state using the SLEEP/AWAKE (CMD5). In the Sleep state the power consumption of the memory device is minimized and the memory device reacts only to the commands RESET (CMD0) and SLEEP/AWAKE (CMD5). All the other commands are ignored by the memory device. The VCC power supply may be switched off in Sleep state to enable even further system power consumption saving. For additional information please refer to JESD84-B51. 2.12. Enhanced Reliable Write iNAND 7250 supports enhanced reliable write as defined in e.MMC 5.1 spec. © 2017 SanDisk – a Western Digital brand - 12 - DOC - 56-34-01508 Confidential SanDisk iNAND 7250 e.MMC 5.1 HS400 I/F data sheet Enhanced reliable write is a special write mode in which the old data pointed to by a logical address must remain unchanged until the new data written to same logical address has been successfully programmed. This is to ensure that the target address updated by the reliable write transaction never contains undefined data. When writing in reliable write, data will remain valid even if a sudden power loss occurs during programming. 2.13. Sanitize The Sanitize operation is used to remove data from the device. The use of the Sanitize operation requires the device to physically remove data from the unmapped user address space. The device will continue the sanitize operation, with busy asserted, until one of the following events occurs:  Sanitize operation is complete  HPI is used to abort the operation  Power failure  Hardware reset After the sanitize operation is complete no data should exist in the unmapped host address space. 2.14. Secure Erase For backward compatibility reasons, in addition to the standard erase command the iNAND 7250 supports the optional Secure Erase command. This command allows the host to erase the provided range of LBAs and ensure no older copies of this data exist in the flash. 2.15. Secure Trim For backward compatibility reasons, iNAND 7250 support Secure Trim command. The Secure Trim5 command is similar to the Secure Erase command but performs a secure purge operation on write blocks instead of erase groups. The secure trim command is performed in two steps: 1) Mark the LBA range as candidate for erase. 2) Erase the marked address range and ensure no old copies are left. 2.16. Partition Management iNAND 7250 offers the possibility for the host to configure additional split local memory partitions with independent addressable space starting from logical address 0x00000000 for different usage models. Therefore memory block area scan be classified as follows Factory configuration supplies two boot partitions (refer to section 2.9) implemented as enhanced storage media and one RPMB partitioning of 4MB in size (refer to section 2.10). Up to four General Purpose Area Partitions can be configured to store user data or sensitive data, or for other host usage models. The size of these partitions is a multiple of the write protect group. Size can be programmed once in device life-cycle (one-time programmable). © 2017 SanDisk – a Western Digital brand - 13 - DOC - 56-34-01508 Confidential SanDisk iNAND 7250 e.MMC 5.1 HS400 I/F data sheet 2.17. Device Health Device Health is similar to SMART features of modern hard disks, it provides only vital NAND flash program/erase cycles information in percentage of useful flash life span. The host can query Device Health information utilizing standard MMC command, to get the extended CSD structure:  DEVICE_LIFE_TIME_EST_TYP_A[268], the host may use it to query SLC device health information  DEVICE_LIFE_TIME_EST_TYP_B[269], the host may use it to query MLC device health information The device health feature will provide a % of the wear of the device in 10% fragments. 2.18. EOL Status EOL status is implemented according to the eMMC 5.1 spec. One additional state (state 4) was added to INAND 7250 which indicates that the device is in EOL mode. 2.19. Enhanced Write Protection To allow the host to protect data against erase or write iNAND 7250 supports two levels of write protect command. The entire iNAND 7250 (including the Boot Area Partitions, General Purpose Area Partition, and User Area Partition) may be write-protected by setting the permanent or temporary write protect bits in the CSD Specific segments of iNAND 7250 may be permanently, power-on or temporarily write protected. Segment size can be programmed via the EXT_CSD register. For additional information please refer to the JESD84-B51 standard. 2.20. High Priority Interrupt (HPI) The operating system usually uses demand-paging to launch a process requested by the user. If the host needs to fetch pages while in a middle of a write operation the request will be delayed until the completion of the write command. The high priority interrupt (HPI) as defined in JESD84-B51 enables low read latency operation by suspending a lower priority operation before it is actually completed. For additional information on the HPI function, refer to JESD84-B51. 2.21. H/W Reset Hardware reset may be used by host to reset the device, moving the device to a Pre-idle state and disabling the power-on period write protect on blocks that were power-on write protected before the reset was asserted. For more information, refer to JESD84-B51 standard. © 2017 SanDisk – a Western Digital brand - 14 - DOC - 56-34-01508 Confidential SanDisk iNAND 7250 e.MMC 5.1 HS400 I/F data sheet 2.22. Host-Device Synchronization Flow (Enhanced STROBE) The Enhanced STROBE feature as implemented in iNAND 7250 allows utilizing STROBE to synchronize also the CMD response:     CMD clocking stays SDR (similar to legacy DDR52) Host commands are clocked out with the rising edge of the host clock (as done in legacy eMMC devices) iNAND 7250 will provide STROBE signaling synced with the CMD response in addition to DATA Out Host may use the STROBE signaling for DAT and CMD-Response capturing eliminating the need for a tuning mechanism This feature requires support by the host to enable faster and more reliable operation. 2.23. Command-Queue e.MMC Command Queue enables device visibility of next commands and allows performance improvement. The protocol allows the host to queue up to 32 data-transfer commands in the device by implementing 5 new commands. The benefits of command queuing are:     Random Read performance improvement (higher IOPs) Reducing protocol overhead Command issuance allowed while data transfer is on-going Device order the tasks according to best access to/from flash © 2017 SanDisk – a Western Digital brand - 15 - DOC - 56-34-01508 Confidential SanDisk iNAND 7250 e.MMC 5.1 HS400 I/F data sheet 3. PRODUCT SPECIFICATIONS 3.1. Typical Power Measurements Table 4 – iNAND 7250 Power Consumption Sleep (Ta=25°C@1.8V/3.3V) 8GB 16GB 32GB 64GB Units HS400 Sleep (CMD5 – VCCQ, VCC off) 150 150 150 150 uA HS200 Sleep (CMD5 – VCCQ, VCC off) 150 150 150 150 uA DDR52 Sleep (CMD5 – VCCQ, VCC off) 150 150 150 150 uA Table 5 – iNAND 7250, Power Consumption Peak VCC / VCCQ (Ta=25°C@1.8V/3.3V) Peak [2µs window] VCC 8GB 16GB 32GB 64GB Units 150 230 400 400 mA 295 295 325 365 mA Active HS400 Peak [2µs window] VCCQ Active Peak [2µs window] VCC 150 230 400 400 mA HS200 Peak [2µs window] VCCQ 210 210 240 260 mA Active Peak [2µs window] VCC 150 230 400 400 mA DDR52 2 Peak [2µs window] VCCQ 3 3 200/165 3 200/175 230/195 3 mA 250/200 Table 6 - iNAND 7250, Power Consumption RMS VCC / VCCQ (Ta=25°C@1.8V/3.3V) Read Active HS400 Write Read Active HS200 Write Read Active DDR52 Write 8GB 16GB 32GB 64GB Units RMS [100ms window] VCC 60 60 60 60 mA RMS [100ms window] VCCQ 245 245 275 300 mA RMS [100ms window] VCC 45 85 150 160 mA RMS [100ms window] VCCQ 135 155 195 220 mA RMS [100ms window] VCC 50 50 50 50 mA RMS [100ms window] VCCQ 145 145 165 180 mA RMS [100ms window] VCC 50 75 130 140 mA RMS [100ms window] VCCQ 105 110 130 140 mA RMS [100ms window] VCC 40 40 3 40 3 40 3 mA 3 RMS [100ms window] VCCQ 110/140 110/140 115/150 130/160 mA RMS [100ms window] VCC 45 45 60 70 mA RMS [100ms window] VCCQ 3 95/100 2 The regulator must be able to supply the current as the peak value can last for up to 1ms 3 1.8V/3.3V © 2017 SanDisk – a Western Digital brand - 16 - 3 95/110 3 115/125 3 120/140 mA DOC - 56-34-01508 Confidential 3.2. SanDisk iNAND 7250 e.MMC 5.1 HS400 I/F data sheet Operating Conditions 3.2.1. Operating and Storage Temperature Specifications Table 5 - Operating and Storage Temperatures Condition Ambient Temperature (Ta) Operating -25° C to 85° C Storage -40° C to 85° C 4 3.2.2. Moisture Sensitivity The moisture sensitivity level for iNAND 7250 is MSL = 3. 4 This operating temperature should be maintained on the package case in order to achieve optimized power/performance © 2017 SanDisk – a Western Digital brand - 17 - DOC - 56-34-01508 Confidential 3.3. SanDisk iNAND 7250 e.MMC 5.1 HS400 I/F data sheet Reliability SanDisk iNAND 7250 product meets or exceeds NAND type of products Endurance and Data Retention requirements as per evaluated representative usage models for designed market and relevant sections of JESD47I standard. Table 6 - Critical Reliability Characteristics Reliability Characteristics Uncorrectable Bit Error Rate (UBER) Description Value Uncorrectable bit error rate will not exceed one sector in the specified number of bits read. In such rare events data can be lost. 1 sector in 𝟏𝟎𝟏𝟓 bits read Write Endurance Specification (TBW) Write endurance is commonly classified in Total Terabytes Written (TBW) to a device. This is the total amount of data that can be written to the device over its useful life time and depends on workload. Total Terabytes Written [TBW] Per representative Android workload: TBW is characterized based on a representative mobile workload as described below:   70% Sequential write, 30% Random Write. Distribution of IO Transaction Sizes: o 128KB: 1.5-4%  Cache On, Packed Off Host data is 4K aligned Data Retention Specification (Years) 8GB: 20 TBW 16GB: 40 TBW 32GB: 80 TBW 64GB: 160 TBW Fresh or Early Life Device 10 years of Data Retention @ 55°C (A device whose total write cycles to the flash is less than 10% of the maximum endurance specification) Cycled Device 1 year of Data Retention @ 55°C (Any device whose total write cycles are between 10% of the maximum write endurance specification and equal to or exceed the maximum write endurance specification) © 2017 SanDisk – a Western Digital brand - 18 - DOC - 56-34-01508 Confidential SanDisk iNAND 7250 e.MMC 5.1 HS400 I/F data sheet 3.4 Typical System Performance5 Table 7 – Sequential Performance HS400 Write (MB/s) 40 80 160 160 8GB 16GB 32GB 64GB 67 HS200 Read (MB/s) 300 300 300 300 Write (MB/s) 40 80 125 125 DDR52 Read (MB/s) 170 170 170 170 Table 8 – Sequential Performance – EUDA HS400 Write (MB/s) 60 120 240 240 8GB 16GB 32GB 64GB Read (MB/s) 300 300 300 300 Write (MB/s) 60 120 140 140 HS400 8GB 16GB 32GB 64GB DDR52 Read (MB/s) 170 170 170 170 Write (MB/s) 60 75 75 75 Write (IOPs) Read (MB/s) 90 90 90 90 89 HS200 Read (IOPs) Read (MB/s) 90 90 90 90 12 13 HS200 Table 9 – Random Performance Write (IOPs) Write (MB/s) 40 75 75 75 DDR52 Read (IOPs) Write (IOPs) Read (IOPs) Cache ON QD=8 QD=1 Cache ON QD=8 QD=1 Cache ON QD=8 QD=1 8k 14k 14k 14k 17k 22k 22k 22k 7.8k 7.8k 7.8k 7.8k 6k 6k 6k 6k 10k 10k 10k 10k 4.5k 4.5k 4.5k 4.5k 5.5k 5.5k 5.5k 5.5k 10k 10k 10k 10k 3.5k 3.5k 3.5k 3.5k 5 All performance is measured using SanDisk proprietary test environment, without file system overhead and host turn-around time (HTAT). 6 Sequential Read/Write performance is measured under HS400 mode with a bus width of 8 bit at 200 MHz DDR mode, chunk size of 512KB, and data transfer of 1GB. 7 Sequential Write performance is measured for 100MB host payloads 8 Random performance is measured with a chunk size of 4KB and address range of 1GB 9 Random Write IOPs shown are with cache on © 2017 SanDisk – a Western Digital brand - 19 - DOC - 56-34-01508 Confidential SanDisk iNAND 7250 e.MMC 5.1 HS400 I/F data sheet 4. PHYSICAL SPECIFICATIONS The SanDisk iNAND 7250 is a 153-pin, thin fine-pitched ball grid array (BGA). See Figure 2 and Table 12 for physical specifications and dimensions. Figure 2 - INAND 7250 Package Outline Drawing Table 10 – Package Specification © 2017 SanDisk – a Western Digital brand - 20 - DOC - 56-34-01508 Confidential SanDisk iNAND 7250 e.MMC 5.1 HS400 I/F data sheet 8GB-16GB 32GB 64GB Nom Max Min Nom Max Min Nom Max [mm] [mm] [mm] [mm] [mm] [mm] [mm] [mm] 0.6 0.7 0.8 0.8 0.9 1 1 1.1 1.2 A1 0.17 0.22 0.27 0.17 0.22 0.27 0.17 0.22 0.27 D 11.4 11.5 11.6 11.4 11.5 11.6 11.4 11.5 11.6 E 12.9 13 13.1 12.9 13 13.1 12.9 13 13.1 D1 - 6.5 - - 6.5 - - 6.5 - E1 - 6.5 - - 6.5 - - 6.5 - e - 0.5 - - 0.5 - - 0.5 - b 0.25 0.3 0.35 0.25 0.3 0.35 0.25 0.3 0.35 Symbol Min [mm] A aaa 0.1 0.1 bbb 0.1 0.1 0.1 ddd 0.08 0.08 0.08 eee 0.15 0.15 0.15 fff 0.05 0.05 0.05 MD/ME 14/14 14/14 14/14 © 2017 SanDisk – a Western Digital brand - 21 - 0.1 DOC - 56-34-01508 Confidential SanDisk iNAND 7250 e.MMC 5.1 HS400 I/F data sheet 5. INTERFACE DESCRIPTION 5.1. MMC I/F Ball Array 11 22 33 44 55 66 77 88 99 10 10 11 11 12 12 13 13 14 14 AA NC NC DAT0 DAT1 DAT2 VSS NC NC NC NC NC NC NC NC BB NC DAT3 DAT4 DAT5 DAT6 DAT7 NC NC NC NC NC NC NC NC CC NC Vddi NC VssQ NC VccQ NC NC NC NC NC NC NC NC DD NC NC NC NC NC NC NC VSF2 NC NC NC Index Index NC NC NC NC FF NC NC NC VCC VSF3 NC NC NC GG NC NC NC VSS NC NC NC NC HH NC NC NC RCLK VSS NC NC NC JJ NC NC NC VSS VCC NC NC NC KK NC NC NC RESET VSF4 NC NC NC LL NC NC NC NC NC NC M M NC NC NC VccQ CMD CLK NC NC NC NC NC NC NC NC NN NC VssQ NC VccQ VssQ NC NC NC NC NC NC NC NC NC PP NC NC VccQ VssQ VccQ VssQ NC NC NC NC NC NC NC NC VCC NC VSS NC NC VSF1 EE VSS VCC Figure 3 - 153 balls - Ball Array (Top View) © 2017 SanDisk – a Western Digital brand - 22 - DOC - 56-34-01508 Confidential SanDisk iNAND 7250 e.MMC 5.1 HS400 I/F data sheet 5.2. Pins and Signal Description Table 13 contains the SanDisk iNAND 7250, with MMC interface (153 balls), functional pin assignment. Table 11 – Functional Pin Assignment, 153 balls Ball No. Ball Signal A3 DAT0 A4 DAT1 A5 DAT2 B2 DAT3 B3 DAT4 B4 DAT5 B5 DAT6 B6 DAT7 M5 CMD M6 CLK K5 RST_n H5 RCLK E6 VCC F5 VCC J10 VCC K9 VCC C6 VCCQ M4 VCCQ N4 VCCQ P3 VCCQ P5 VCCQ E7 VSS G5 VSS H10 VSS K8 VSS A6 VSS J5 VSS C4 VSSQ N2 VSSQ N5 VSSQ P4 VSSQ P6 VSSQ C2 VDDi E9 VSF1 E10 VSF2 F10 VSF3 K10 VSF4 Type Description I/O Data I/O: Bidirectional channel used for data transfer I/O Command: A bidirectional channel used for device initialization and command transfers. Input Clock: Each cycle directs a 1-bit transfer on the command and DAT lines Hardware Reset Output Data Strobe Supply Flash I/O and memory power supply Supply Memory controller core and MMC I/F I/O power supply Supply Flash I/O and memory ground connection Supply Memory controller core and MMC I/F ground connection Internal power node. Connect 0.1uF capacitor from VDDi to ground VSF Vendor Specific Function balls for test/debug. VSF balls should be floating and be brought out to test pads. Note: All other pins are not connected [NC] and can be connected to GND or left floating © 2017 SanDisk – a Western Digital brand - 23 - DOC - 56-34-01508 Confidential SanDisk iNAND 7250 e.MMC 5.1 HS400 I/F data sheet 5.3. Registers value 5.3.1. OCR Register Parameter DSR slice Description Value Width Access Mode [30:29] Access mode 2h 2 [23:15] VDD: 2.7 - 3.6 range 1FFh 9 [14:8] VDD: 2.0 - 2.6 range 00h 7 [7] VDD: 1.7 - 1.95 range 1h 1 Note: Bit 30 is set because the device is High Capacity; bit 31 will be set only when the device is ready. 5.3.2. CID Register Parameter DSR slice Description Value Width MMC MID [127:120] Manufacturer ID 45h 8 CBX [113:112] Card BGA 01h 2 OID [111:104] OEM/Application ID 00h 8 48 PNM [103:56] Product name 8GB – DG4008 16GB – DG4016 32GB – DG4032 64GB – DG4064 PRV [55:48] Product revision 01h 8 PSN [47:16] Product serial number Random by Production 32 MDT [15:8] Manufacturing date month, year 8 CRC [7:1] Calculated CRC CRC7 Generator 7 Note: Please refer to the definition of the MDT field as defined in e.MMC Spec version 5.0. 5.3.3. DSR Register Parameter DSR slice Description Value Width RSRVD [15:8] Reserved 04h 8 RSRVD [7:0] Reserved 04h 8 Note: DSR is not implemented; in case of read, a value of 0x0404 will be returned. © 2017 SanDisk – a Western Digital brand - 24 - DOC - 56-34-01508 Confidential SanDisk iNAND 7250 e.MMC 5.1 HS400 I/F data sheet 5.3.4. CSD Register Parameter CSD Slice Description Value Width CSD_STRUCTURE [127:126] CSD structure 3h 3 SPEC_VERS [125:122] System specification version 4h 4 TAAC [119:112] Data read access-time 1 0Fh 8 NSAC [111:104] Data read access-time 2 in CLK cycles (NSAC*100) 00h 8 TRAN_SPEED [103:96] Max. bus clock frequency 32h 8 CCC [95:84] Card command classes 8F5h 12 READ_BL_LEN [83:80] Max. read data block length 9h 4 READ_BL_PARTIAL [79:79] Partial blocks for read allowed 0h 1 WRITE_BLK_MISALIGN [78:78] Write block misalignment 0h 1 READ_BLK_MISALIGN [77:77] Read block misalignment 0h 1 DSR_IMP [76:76] DSR implemented 0h 1 *C_SIZE [73:62] Device size FFFh 12 VDD_R_CURR_MIN [61:59] Max. read current @ VDD min 7h 3 VDD_R_CURR_MAX [58:56] Max. read current @ VDD max 7h 3 VDD_W_CURR_MIN [55:53] Max. write current @ VDD min 7h 3 VDD_W_CURR_MAX [52:50] Max. write current @ VDD max 7h 3 C_SIZE_MULT [49:47] Device size multiplier 7h 3 ERASE_GRP_SIZE [46:42] Erase group size 1Fh 5 ERASE_GRP_MULT [41:37] Erase group size multiplier 1Fh 5 WP_GRP_SIZE [36:32] Write protect group size 0Fh 5 WP_GRP_ENABLE [31:31] Write protect group enable 1h 1 DEFAULT_ECC [30:29] Manufacturer default 0h 2 R2W_FACTOR [28:26] Write speed factor 2h 3 WRITE_BL_LEN [25:22] Max. write data block length 9h 4 WRITE_BL_PARTIAL [21:21] Partial blocks for write allowed 0h 1 CONTENT_PROT_APP [16:16] Content protection application 0h 1 FILE_FORMAT_GRP [15:15] File format group 0h 1 COPY [14:14] Copy flag (OTP) 1h 1 PERM_WRITE_PROTECT [13:13] Permanent write protection 0h 1 TMP_WRITE_PROTECT [12:12] Temporary write protection 0h 1 FILE_FORMAT [11:10] File format 0h 2 ECC [9:8] ECC code 0h 2 CRC [7:1] Calculated CRC CRC7 Generator 7 © 2017 SanDisk – a Western Digital brand - 25 - DOC - 56-34-01508 Confidential SanDisk iNAND 7250 e.MMC 5.1 HS400 I/F data sheet 5.3.5. EXT_CSD Register Parameter ECSD slice Description Value S_CMD_SET [504] Supported Command Sets 1h HPI_FEATURES [503] HPI Features 1h BKOPS_SUPPORT [502] Background operations support 1h Max packed read commands 3Fh Max packed write commands 3Fh MAX_PACKED_READS MAX_PACKED_WRITES [501] [500] DATA_TAG_SUPPORT [499] Data Tag Support 1h TAG_UNIT_SIZE [498] Tag Unit Size 3h TAG_RES_SIZE [497] Tag Resources Size 3h CONTEXT_CAPABILITIES [496] Context management capabilities 5h LARGE_UNIT_SIZE_M1 [495] Large Unit size 0h EXT_SUPPORT [494] Extended partitions attribute support 3h SUPPORTED_MODES [493] FFU supported modes 3h FFU_FEATURES [492] FFU features 0h OPERATION_CODES_TIMEOUT [491] Operation codes timeout 10h FFU_ARG [490:487] FFU Argument 0h BARRIER_SUPPORT [486] Cache barrier support 1h CMDQ_SUPPORT [308] Command queue support 1h CMDQ_DEPTH [307] Command queue depth 1Fh NUMBER_OF_FW_SECTORS_CORRECTLY_PROGRAMMED [305:302] Number of FW sectors correctly programmed 0h Vendor proprietary health report 0h Device life time estimation type B (MLC) 1h Device life time estimation type A (SLC) 1h VENDOR_PROPRIETARY_HEALTH_REPORT DEVICE_LIFE_TIME_EST_TYP_B DEVICE_LIFE_TIME_EST_TYP_A [301:270] [269] [268] PRE_EOL_INFO [267] Pre EOL information 1h OPTIMAL_READ_SIZE [266] Optimal read size 8h OPTIMAL_WRITE_SIZE [265] Optimal write size 8h OPTIMAL_TRIM_UNIT_SIZE [264] Optimal trim unit size 8h DEVICE_VERSION [263:262] Device version 5025h FIRMWARE_VERSION [261:254] Firmware version FW Version PWR_CL_DDR_200_360 [253] Power class for 200MHz, DDR at VCC= 3.6V DDh © 2017 SanDisk – a Western Digital brand - 26 - DOC - 56-34-01508 Confidential SanDisk iNAND 7250 e.MMC 5.1 HS400 I/F data sheet Parameter ECSD slice Description Value CACHE_SIZE [252:249] Cache size 1000h GENERIC_CMD6_TIME [248] Generic CMD6 timeout 19h POWER_OFF_LONG_TIME [247] Power off notification(long) timeout 19h Background operations status Default = 0h Number of correctly programmed sectors Default = 0h 1st Initialization time after partitioning 5Ah BKOPS_STATUS CORRECTLY_PRG_SECTORS_NUM INI_TIMEOUT_AP [246] [245:242] [241] CACHE_FLUSH_POLICY [240] Cache Flush Policy 1h PWR_CL_DDR_52_360 [239] Power class for 52MHz, DDR at VCC = 3.6V 0h Power class for 52MHz, DDR at VCC = 1.95V DDh Power class for 200MHz at VCCQ =1.95V, VCC = 3.6V DDh Power class for 200MHz, at VCCQ =1.3V, VCC = 3.6V 0h Minimum Write Performance for 8bit at 52MHz in DDR mode 0h Minimum Read Performance for 8bit at 52MHz in DDR mode 0h PWR_CL_DDR_52_195 PWR_CL_200_195 PWR_CL_200_130 MIN_PERF_DDR_W_8_52 MIN_PERF_DDR_R_8_52 [238] [237] [236] [235] [234] TRIM _MULT [232] TRIM Multiplier 3h SEC_FEATURE_SUPPORT [231] Secure Feature support 55h SEC_ERASE_MULT [230] Secure Erase Multiplier A6h SEC_TRIM_MULT [229] Secure TRIM Multiplier A6h BOOT_INFO [228] Boot Information 7h BOOT_SIZE_MULT [226] Boot partition size 20h ACCESS_SIZE [225] Access size 8h HC_ERASE_GROUP_SIZE [224] High Capacity Erase unit size 1h (see WP group size table below) ERASE_TIMEOUT_MULT [223] High capacity erase time out 3h REL_WR_SEC_C [222] Reliable write sector count 1h HC_WP_GRP_SIZE [221] High capacity write protect group size 10h (see WP group size table below) S_C_VCC [220] Sleep current [VCC] 8GB – 5h 16GB – 6h 32GB – 7h © 2017 SanDisk – a Western Digital brand - 27 - DOC - 56-34-01508 Confidential Parameter SanDisk iNAND 7250 e.MMC 5.1 HS400 I/F data sheet ECSD slice Description Value 64GB – 8h S_C_VCCQ [219] Sleep current [VCCQ] 7h PRODUCTION_STATE_AWARENESS_TIMEOUT [218] Production state awareness timeout 17h S_A_TIMEOUT SLEEP_NOTIFICATION_TIME [217] Sleep/Awake time out 12h [216] Sleep notification timeout 17h SEC_COUNT [215:212] Sector count See exported capacity table below SECURE_WP_INFO [211] Secure Write Protect Info 1h MIN_PERF_W_8_52 [210] Minimum Write Performance for 8bit @52MHz Ah Minimum Read Performance for 8bit @52MHz Ah Minimum Write Performance for 4bit @52MHz or 8bit @26MHz Ah Minimum Read Performance for 4bit @52MHz or 8bit @26MHz Ah Minimum Write Performance for 4bit @26MHz Ah Minimum Read Performance for 4bit @26MHz Ah MIN_PERF_R_8_52 MIN_PERF_W_8_26_4_52 MIN_PERF_R_8_26_4_52 MIN_PERF_W_4_26 MIN_PERF_R_4_26 [209] [208] [207] [206] [205] PWR_CL_26_360 [203] Power Class for 26MHz @ 3.6V 0h PWR_CL_52_360 [202] Power Class for 52MHz @ 3.6V 0h PWR_CL_26_195 [201] Power Class for 26MHz @ 1.95V DDh Power Class for 52MHz @ 1.95V DDh PWR_CL_52_195 [200] PARTITION_SWITCH_TIME [199] Partition switching timing 3h OUT_OF_INTERRUPT_TIME [198] Out-of-interrupt busy timing 19h DRIVER_STRENGTH [197] I/O Driver Strength 1Fh CARD_TYPE [196:195] Card Type 57h CSD_STRUCTURE [194] CSD Structure Version 2h EXT_CSD_REV [192] Extended CSD Revision 8h CMD_SET [191] Command Set Default = 0h © 2017 SanDisk – a Western Digital brand - 28 - DOC - 56-34-01508 Confidential Parameter SanDisk iNAND 7250 e.MMC 5.1 HS400 I/F data sheet ECSD slice Description Value Updated in runtime CMD_SET_REV [189] Command Set Revision 0h POWER_CLASS [187] Power Class Dh HS_TIMING [185] High Speed Interface Timing Default = 0h Updated in runtime by the host DATA_STRB_MODE_SUPPORT [184] Data strobe mode support 1h BUS_WIDTH [183] Bus Width Mode Default = 0h Updated in runtime by the host ERASE_MEM_CONT [181] Content of explicit erased memory range 0h PARTITION_CONFIG [179] Partition Configuration Default = 0h Updated in runtime by the host BOOT_CONFIG_PROT [178] Boot config protection Default = 0h Updated in runtime by the host BOOT_BUS_CONDITIONS [177] Boot bus width1 Default = 0h Updated in runtime by the host ERASE_GROUP_DEF BOOT_WP_STATUS BOOT_WP USER_WP [175] [174] [173] [171] High-density erase group definition Default = 0h Boot write protection status registers Default = 0h Updated in runtime by the host Updated in runtime Boot area write protect register 0h User area write protect register 0h FW_CONFIG [169] FW Configuration 0h RPMB_SIZE_MULT [168] RPMB Size 20h WR_REL_SET [167] Write reliability setting register 1Fh WR_REL_PARAM [166] SANITIZE_START [165] Write reliability parameter register Start Sanitize operation 15h Default = 0h Updated in runtime by the host BKOPS_START © 2017 SanDisk – a Western Digital brand [164] - 29 - Manually start background operations Default = 0h Updated in runtime by the host DOC - 56-34-01508 Confidential SanDisk iNAND 7250 e.MMC 5.1 HS400 I/F data sheet Parameter ECSD slice Description Value BKOPS_EN [163] Enable background operations handshake 2h H/W reset function Default = 0h RST_n_FUNCTION [162] Updated by the host HPI_MGMT [161] HPI management Default = 0h Updated by the host PARTITIONING SUPPORT [160] Partitioning support 7h MAX_ENH_SIZE_MULT [159:157] Max Enhanced Area Size 8GB – 1B5h 16GB – 383h 32GB – 6FFh 64GB – E47h PARTITIONS_ATTRIBUTE [156] Partitions Attribute Default = 0h Updated by the host PARTITION_SETTING_ [155] Partitioning Setting COMPLETED GP_SIZE_MULT Default = 0h Updated by the host General Purpose Partition Size (GP4) 0h [151:149] General Purpose Partition Size (GP3) 0h [148:146] General Purpose Partition Size (GP2) 0h GP_SIZE_MULT [145:143] General Purpose Partition Size (GP1) 0h ENH_SIZE_MULT [142:140] Enhanced User Data Area Size 0h Enhanced User Data Start Address 0h Bad Block Management mode 0h Production state awareness 0h Package Case Temperature is controlled 0h GP_SIZE_MULT GP_SIZE_MULT ENH_START_ADDR SEC_BAD_BLK_MGMNT PRODUCTION_STATE_AWARENESS TCASE_SUPPORT [154:143] [139:136] [134] [133] [132] PERIODIC_WAKEUP [131] Periodic Wake-up 0h PROGRAM_CID_CSD_DDR_SUPPORT [130] Program CID/CSD in DDR mode support 1h VENDOR_SPECIFIC_FIELD [127:87] Vendor Specific Fields Reserved PWR_CL_DDR_266 [86] 0h CARD_TYPE_2ND_INDEX [84] Maximum power class for HS533 Device HS533 support SKU_FEATURES_ID [80] 7250 SKU identification 0h VENDOR_SPECIFIC_FIELD [82:64] Vendor Specific Fields Reserved © 2017 SanDisk – a Western Digital brand - 30 - 0h DOC - 56-34-01508 Confidential SanDisk iNAND 7250 e.MMC 5.1 HS400 I/F data sheet Parameter ECSD slice Description Value NATIVE_SECTOR_SIZE [63] Native sector size 0h USE_NATIVE_SECTOR [62] Sector size emulation 0h DATA_SECTOR_SIZE [61] Sector size 0h INI_TIMEOUT_EMU [60] 1st initialization after disabling sector size emulation Ah CLASS_6_CTRL [59] Class 6 commands control 0h DYNCAP_NEEDED [58] Number of addressed group to be Released 0h EXCEPTION_EVENTS_CTRL [57:56] Exception events control 0h EXCEPTION_EVENTS_STATUS [55:54] Exception events status 0h EXT_PARTITIONS_ATTRIBUTE [53:52] Extended Partitions Attribute 0h CONTEXT_CONF [51:37] Context configuration Default = 0h PACKED_COMMAND_STATUS [36] Packed command status Default = 0h Updated in runtime PACKED_FAILURE_INDEX POWER_OFF_NOTIFICATION [35] [34] Packed command failure index Default = 0h Power Off Notification Default = 0h Updated in runtime Updated in runtime by the host CACHE_CTRL [33] Control to turn the Cache ON/OFF 0h FLUSH_CACHE [32] Flushing of the cache 0h BARRIER_CTRL [31] Cache barrier 0h MODE_CONFIG [30] Mode config 0h MODE_OPERATION_CODES [29] Mode operation codes 0h FFU_STATUS [26] FFU status 0h PRE_LOADING_DATA_SIZE [25:22] Pre loading data size 0h MAX_PRE_LOADING_DATA_SIZE [21:18] Max pre loading data size See Max Preloading size table below PRODUCT_STATE_AWARENESS_ENABLEMENT [17] Product state awareness enablement 3h AUTO_PRE_SOLDERING SECURE_REMOVAL_TYPE [16] Secure Removal Type 8h CMDQ_MODE_EN [15] Command queue 0h © 2017 SanDisk – a Western Digital brand - 31 - DOC - 56-34-01508 Confidential SanDisk iNAND 7250 e.MMC 5.1 HS400 I/F data sheet 5.3.6. User Density The following table shows the capacity available for user data for the different device sizes: Table 12 – Exported capacity for user data Capacity LBA [Hex] 8GB 0xE90E80 16GB 0x1D5A000 32GB 0x3A3E000 64GB 0x7670000 Table 13 - Write protect group size Capacity HC_ERASE_GROUP_SIZE HC_WP_GRP_SIZE Erase Unit Size [MB] Write Protect Group Size [MB] 8GB 0x1 0x10 0.5MB 8MB 16GB 0x1 0x10 0.5MB 8MB 32GB 0x1 0x10 0.5MB 8MB 64GB 0x1 0x10 0.5MB 8MB The max preloading image in iNAND 7250 is up to the exported capacity per table below Table 14 - Max Preloading Data Size Capacity © 2017 SanDisk – a Western Digital brand Max preloading Image size (in LBA HEX) 8GB 0xE90E80 16GB 0x1D5A000 32GB 0x3A3E000 64GB 0x7670000 - 32 - DOC - 56-34-01508 Confidential SanDisk iNAND 7250 e.MMC 5.1 HS400 I/F data sheet 6. HW APPLICATION GUIDELINES 6.1. Design Guidelines          The e.MMC specification enforces single device per host channel; multi-device configuration per a single host channel is not supported. CLK, RCLK(DS), CMD and DATx lines should be connected to respected host signals. The e.MMC specification requires that all signals will be connected point-to-point, i.e. a single e.MMC device per host channel. The e.MMC hardware reset signal (RST_n) is not mandatory and could be connected to the host reset signal or left unconnected (floating) if not used. All power supply and ground pads must be connected. Make sure pull-up resistors are placed on schematic in case these are external. For further details please refer to “Table 16 - Pull-ups Definition” Bypass capacitors shall be placed as close to the e.MMC device as possible; normally it is recommended to have 0.1uF and 4.7uF capacitors per power supply rail, though specific designs may include a different configuration in which there are more than two capacitors: o VCC and VCCQ slew rates shall be minimally affected by any bypass capacitors configuration o It is recommended to verify the bypass capacitors requirement in the product data sheet VDDi bypass capacitor shall be placed on the PCB. The VDDi is an internal power node for the controller and requires capacitor in range 0.1uF – 2.2uF connected between VDDi pad and ground Vendor Specific Function (VSF) pins should be connected to accessible test points on the PCB (TP on schematic below). It’s recommended to have accessible ground (GND) pads near each TP on PCB It is recommended to layout e.MMC signals with controlled impedance of 45-55 Ohm referencing to adjusted ground plane © 2017 SanDisk – a Western Digital brand - 33 - DOC - 56-34-01508 Confidential SanDisk iNAND 7250 e.MMC 5.1 HS400 I/F data sheet 6.2. Capacitor Selection & Layout Guidelines SanDisk iNAND 7250 has three power domains assigned to VCCQ, VCC and VDDi, as shown in Table 17 below. Table 15 - 7250 Power Domains Pin Power Domain Comments VCCQ Host Interface Supported voltage ranges: Low Voltage Region: 1.8V (nominal) VCC Memory Supported voltage range: High Voltage Region: 3.3V (nominal) VDDi Internal VDDi is the internal regulator connection to an external decoupling capacitor. It is recommended that the power domains connectivity will follow figure 4: Top View Capacitor C_3/4:  Capacitor C3 >= 4.7uF  Capacitor C4 =< 0.1uF  X5R or X7R  Voltage > 6.3V Trace Requirements:  Resistance < 0.5[Ω]  Inductance < 3n[Hy] Placement:  Closest to ball F5 C_3 C_4 Capacitor C_5:  Capacitor >= 0.1uF  Capacitor =< 2.2uF  X5R or X7R  Voltage > 6.3V Trace Requirements:  Resistance < 0.5[Ω]  Inductance < 3n[Hy] Placement:  Closest to ball C2 C_5 14 14 NC NC NC NC NC NC NC NC NC NC NC NC NC NC 13 13 NC NC NC NC NC NC NC NC NC NC NC NC NC NC 12 12 NC NC NC NC NC NC NC NC NC NC NC NC NC NC 11 11 NC NC NC NC NC NC 10 10 NC NC NC VSF2 VSF4 NC NC NC 99 NC NC NC VSF1 VCC NC NC NC 88 NC NC NC NC VSS NC NC NC 77 NC NC NC VSS NC NC NC NC 66 VSS DAT7 VccQ VCC NC CLK NC VssQ 55 DAT2 DAT6 NC QRDY RESET CMD VssQ VccQ 44 DAT1 DAT5 VssQ NC VccQ VccQ VssQ 33 DAT0 DAT4 NC NC NC NC NC NC NC NC NC NC NC VccQ 22 NC DAT3 Vddi NC NC NC NC NC NC NC NC NC VssQ NC 11 NC NC NC NC NC NC NC NC NC NC NC NC NC NC AA BB CC DD FF GG HH JJ KK LL VSF3 VCC NC VSS VSS RCLK VCC VSS Capacitor C_1/2:  Capacitor C1 >= 4.7uF  Capacitor C2 =< 0.1uF  X5R or X7R  Voltage > 6.3V Trace Requirements:  Resistance < 0.5[Ω]  Inductance < 3n[Hy] Placement:  Closest to ball P3 C_1 EE M M NN C_2 PP Figure 4 - Recommended Power Domain Connectivity Note: Signal routing in the diagram is for illustration purposes only and the final routing depends final PCB layout. For clarity, the diagram does not include VSS connection. All balls marked VSS shall be connected to a ground (GND) plane. © 2017 SanDisk – a Western Digital brand - 34 - DOC - 56-34-01508 Confidential SanDisk iNAND 7250 e.MMC 5.1 HS400 I/F data sheet It is recommended to use a X5R/X7R SMT-Ceramic capacitors rated for 6.3V/10V with footprint of 0402 or above. When using ceramic capacitor, it should be located as close to the supply ball as possible. This will eliminate mounting inductance effects and give the internal IC rail a cleaner voltage supply Make all of the power (high current) traces as short, direct, and thick as possible. The capacitors should be as close to each other as possible, as it reduces EMI radiated by the power traces due to the high switching currents through them. In addition, it shall also reduce mounting inductance and resistance as well, which in turn reduces noise spikes, ringing, and IR drop which produce voltage errors. The grounds of the IC capacitors should be connected close together directly to a ground plane. It is also recommended to have a ground plane on both sides of the PCB, as it reduces noise by reducing ground loop. The loop inductance per capacitor shall not exceed 3nH (both on VCC/VCCQ & VSS/VSSQ loops). Cin2 shall be placed closer (from both distance & inductance POV) to the iNAND power & ground balls. Multiple via connections are recommended per each capacitor pad. It is recommended to place the power and ground vias of the capacitor as close to each other as possible. On test platforms, where the iNAND socket is in use, the loop inductance per capacitor shall not exceed 5nH (both on VCC/VCCQ & VSS/VSSQ loop). No passives should be placed below the iNAND device (between iNAND & PCB). VSF balls (VSF1/4) should have exposed and floated test pads on the PCB, with near exposed GND for better measurement. Signal Traces:   Data, CMD, CLK & RCLK bus trace length mismatch should be minimal (up to +/-1mm). Traces should be45-55 ohm controlled impedance. © 2017 SanDisk – a Western Digital brand - 35 - DOC - 56-34-01508 Confidential SanDisk iNAND 7250 e.MMC 5.1 HS400 I/F data sheet 6.3. Reference Schematics Figure 5 – e.MMC Reference Schematics Table 16 – Pull-ups Definition Parameter Pull-up resistance for DAT0–7 Pull-up resistance for CMD Symbol RDAT Min 10 RCMD Pull-down resistance for Data Strobe (RCLK) RPD Typ Max 10010 Unit Kohm Remark to prevent bus floating 4.7 100 Kohm to prevent bus floating 10 47 Kohm At HS400 mode Recommended capacitors: CAPACITOR VALUE 4.7uF 0.1uF 2.2uF 10 MANUFACTURER MURATA TAIYO YUDEN MURATA KYOCERA PANASONIC SAMSUNG MANUFACTURER P/N GRM185R60J475ME15D JMK107BJ475MK-T GRM155R71A104KA01D CM05X5R104K06AH ECJ0EB0J225M CL05A225MQ5NSNC Recommended maximum pull-up is 50Kohm for 1.8V interface supply voltages. A 3V part may use the whole range up to 100Kohms © 2017 SanDisk – a Western Digital brand - 36 - DOC - 56-34-01508 Confidential SanDisk iNAND 7250 e.MMC 5.1 HS400 I/F data sheet 7. PROPRIETY INAND 7250 FEATURE OVERVIEW 7.1. Device Report The iNAND 7250 Device Report feature reflects the firmware and device status.    Enabling Device Report Mode: Send CMD62 with argument of 0x96C9D71C - R1b Response will be returned Reading Device Report Data: Once the host enters Device Report mode, CMD63 with argument 0x00000000 will retrieve the report - 512 Bytes will be returned to the host (Note: CMD63 behaves similarly to CMD17) Resume Normal Operation Mode: Once the Device Report read command (CMD63) was completed, the device automatically goes out of Device Report mode, and resumes normal operation mode. 7.1.1. Device Report fields Byte Offset Size (Bytes) Field Comments [3:0] 4 Avg Erase Count System Average erase value across all system blocks [7:4] 4 Reserved [11:8] 4 Avg Erase Count MLC Average erase value across all MLC blocks [15:12] 4 Read Reclaim Count System Number of reads of system data which passed read-scrub thresholds and require reclaim [19:16] 4 Reserved [23:20] 4 Read Reclaim Count MLC Number of MLC reads which passed read-scrub thresholds and require reclaim [27:24] 4 Bad Block Manufacturer Total bad blocks detected during manufacturing process [31:28] 4 Bad Block Runtime System Total bad blocks in system partitions detected during run-time [35:32] 4 Reserved [39:36] 4 Bad Block Runtime MLC Total bad blocks in MLC partition detected during run-time [43:40] 4 Patch Trial Count Number of secure field firmware updates (sFFU) done from the beginning of the device life [55:44] 12 Patch Release Date Current sFFU release date [63:56] 8 Patch Release Time Current sFFU release hour 4 Cumulative Write Data Size In 100MB Total bytes written from the host in multiples of 100 MB [67:64] [71:68] 4 [75:72] 4 [79:76] 4 VCC Voltage Drop Occurrences VCC Voltage Droop Occurrences Failures to Recover New Host Data After Power Loss © 2017 SanDisk – a Western Digital brand Number of ungraceful power downs to the device. Counter may be inaccurate due to uncommitted counter updates during repeated voltage drops . Number of power-droops (slight power-droop below a threshold and for a very short period of time) Counts times new host data is discarded due to power loss - 37 - DOC - 56-34-01508 Confidential SanDisk iNAND 7250 e.MMC 5.1 HS400 I/F data sheet [83:80] 4 Recovery Operations After Voltage Droop [511:84] 428 Reserved Number of recovery operations done by the device while powerdroop detected 7.2. Power-Loss indications iNAND 7250 is also serving the host by notifying him on cases of Power-Loss events and internal handling of those events. A dedicated field in the EXT_CSD register was allocated to indicate the occurrence of Power Loss/Write Abort during the last power down. This field reports if a Power Loss was detected and recovered during the last power-up. In order to retrieve this field, the host should issue CMD8 command – SEND_EXT_CSD. This command returns full EXT_CSD structure – 512 bytes as block of data. Following is the EXT_CSD field details: Name Power Loss indication Field POWER_LOSS_REPORT Size (bytes) 1 Cell Type R Hex Offset 0x79 Dec. Offset 121 POWER_LOSS_REPORT[121] details:  Bit[2]: RECOVERY_SUCCESS 0x1: Recovery passed successfully 0x0: Recovery failed  Bit[1]: RECOVER_OLD_DATA 0x1: Recovery to old copy of data 0x0: No data recovery required  Bit[0]: POWER_LOSS_DETECTED 0x1: Unexpected Power Loss was detected - Detection is done during initialization, immediately after Power-Up Note: In case Power Loss did not occur on last shut down, this register will show 0x00 7.2.1. Unstable Power-Supply indications In case of Flash voltage drop, the iNAND may not be able to recover the data that was already transferred to the iNAND device, but wasn’t committed in the Flash. In this case the iNAND will “abort” the current host write and return back to the host with an error indication. iNAND 7250 will use BIT19 and BIT20 (cc_error) in the command response to indicate VDET error status to the host. the VDET error indication can be seen only if CMD13 was issued, or in the next command response. Examples:  Open Mode (CMD25+CMD12+CMD13): In both cases, where the voltage droop occurs before or after CMD12: CMD12 response will not have BIT19 and BIT20 set. CMD13 will identify the error indication - BIT19 and BIT20 will be set in CMD13 response © 2017 SanDisk – a Western Digital brand - 38 - DOC - 56-34-01508 Confidential   SanDisk iNAND 7250 e.MMC 5.1 HS400 I/F data sheet Note: The host may send many CMD13 and the BIT19 will be set only in first CMD13 after releasing the busy. Close Mode (CMD23+CMD25+CMD13): CMD13 will identify the error indication - BIT19 and BIT20 will be set in CMD13 response Single Block Mode (CMD24+CMD13): CMD13 will identify the error indication - BIT19 and BIT20 will be set in CMD13 response Host shall retry latest command as long as the VDET error indication on CMD13 response (or next command response (BIT19 and BIT20 are set) is still set 7.3. Unified Boot iNAND 7250 Unified Boot is a proprietary feature that allows the host to boot from a secondary boot partition without the need to explicitly switch to the secondary partition. When this feature is enabled, the device will transfer the data from both boot partitions to the host, first from the enabled boot partition followed by the other partition. A typical use case is to guarantee a version of the boot will always be valid in case of Over The Air (OTA) boot update. The host can set one boot partition as permanent write protect (never to be changed) and the other as temporary write protect. The second boot will be used for update. In case OTA is corrupted or fail, host will always be able to boot based on the old version saved in boot one. This feature is only supported on FW version CS2.2. 7.3.1. Unified Boot Support Indication EXT_CSD Field Name UNI_BOOT_PROC_SUPPORT[93] Bit(s) [0] Read Only Value 0x0 0x1 Description Device doesn’t support Unified Boot Device supports Unified Boot Default 0x0 0xF2 Description Unified Boot is disabled Unified Boot is enabled 7.3.2. Enable Unified Boot EXT_CSD Field Name UNI_BOOT_PROC_ENABLE[92] Bit(s) [0-7] R/W 7.3.3. Important Considerations The configuration of unified boot can only be performed once at the beginning of life of a device, before any data is transferred to it. After all of the parameters have been specified and committed to the device, it cannot be changed. © 2017 SanDisk – a Western Digital brand - 39 - DOC - 56-34-01508 Confidential SanDisk iNAND 7250 e.MMC 5.1 HS400 I/F data sheet This functionality is disabled if either of the boot partitions have ever been write protected. The amount of data transferred for each partition is equal to the partition size, regardless of the size of the programmed image. 7.4. Hardware Pin Secure Boot Per JEDEC e.MMC 5.1 definition, e.MMC boot partitions have 3 write protection methods: 1. Permanent Write Protection – once set, boot data cannot be written 2. Power-on Write Protection – once set, boot data cannot be written until a device reset 3. Secure Write Protection – host may set/clear write protection using a secure key iNAND 7250 introduces a fourth method that works in conjunction with a permanently write protected boot partition. 4. Hardware Pin Secure Boot - a physical authentication procedure is required using VSF pin #4 which is verified by the device controller in order to authorize writing to a boot partition. The physical authentication requires the host to keep VSF pin #4 at ground voltage level and restore it to floating state after the device power-up sequence is complete. This procedure would authorize the user to write to the permanently protected boot partition. Upon reset of the device the authorization to update the boot partition would be aborted and permanent write protection is restored. Host can implement this feature by enabling a push button switch on the platform that would generate the signal below. Device FW Allows Writing to Permanent Write Protect area since:  VSF#4 was GND during POR  Currently VSF#4 status is Floating Power-on Reset: Device Update VSF#4 Status Register VSF#4 Floating Floating GND Before Power-on Reset host has to GND VSF#4 Before Writing to Permanent Write Protect host has to Float VSF#4 Figure 6 Power-on Sequence This feature is only supported on FW version CS2.2. © 2017 SanDisk – a Western Digital brand - 40 - DOC - 56-34-01508 Confidential SanDisk iNAND 7250 e.MMC 5.1 HS400 I/F data sheet 7.4.1. Requirements This feature is designed only for the boot partitions. It works only in addition to boot partition permanent write protection. It will not work with power-on write protection of the boot partitions. Also, it will not work with whole device permanent or temporary write protection. 7.4.2. Physical Proof Protocol Support Indication EXT_CSD Field Name PPP_FEATURES_SUPPORT[123] Bit(s) Value 0x0 0x1 [0] Read Only Description Device does not support HW pin Device supports HW pin 7.4.3. Enable Physical Proof Protocol EXT_CSD Field Name PPP_FEATURES_ENABLE[122] Bit(s) Default 0x0 0x1 [0] R/W Description PPP features are disabled PPP features are enabled 7.4.4. Configuration Process NOTE: This feature must be enabled BEFORE setting permanent write protection on the boot partitions. Step 1: Check PPP_FEATURES_SUPPORT bit 0 to determine that this feature is supported. Step 2: Set PPP_FEATURES_ENABLE bit 0 to 1 to indicate PPP features will be used. Step 3: Set permanent write protection of the boot partitions (BOOT_WP[173] = 0x04). 7.4.5. Authentication Process Step 1: Host must set VSF #4 to GND before, during and for at least 2 seconds after POR. Step 2: Host must return VSF #4 to floating state. Step 3: If the device has determined that all the proper authentication criteria have been met, the host may now write to the protected boot partitions. NOTE: Once authenticated, the boot partitions are write enabled until the next POR. © 2017 SanDisk – a Western Digital brand - 41 - DOC - 56-34-01508 Confidential SanDisk iNAND 7250 e.MMC 5.1 HS400 I/F data sheet 8. MARKING First row: Simplified SanDisk Logo Second row: Sales item P/N Third row: Country of origin i.e. ‘TAIWAN’ or ‘CHINA’ * No ES marking for product in mass production. Fourth row: Y- Last digit of year WW- Work week D- A day within the week. MTLLLXXX – Internal use 2D barcode: Store the 12 Digital ID information as reflected in the fourth row. Figure 7 - Product marking 8GB-64GB © 2017 SanDisk – a Western Digital brand - 42 - DOC - 56-34-01508 Confidential SanDisk iNAND 7250 e.MMC 5.1 HS400 I/F data sheet 9. ORDERING INFORMATION Table 17 – Ordering Information (-25°C to +85°C ambient) Capacity Technology Part Number Samples Part Number Package e.MMC 8GB 15nm X2 eMLC SDINBDG4-8G SDINBDG4-8G-Q 11.5x13x0.8mm 5.1 16GB 15nm X2 eMLC SDINBDG4-16G SDINBDG4-16G-Q 11.5x13x0.8mm 5.1 32GB 15nm X2 eMLC SDINBDG4-32G SDINBDG4-32G-Q 11.5x13x1.0mm 5.1 64GB 15nm X2 eMLC SDINBDG4-64G SDINBDG4-64G-Q 11.5x13x1.2mm 5.1 © 2017 SanDisk – a Western Digital brand - 43 - DOC-56-34-01508 Confidential SanDisk iNAND 7250 e.MMC 5.1 HS400 I/F data sheet HOW TO CONTACT US Please refer to contact information: Western Digital Technologies, Inc. 951 SanDisk Dr. Milpitas, CA 95035-7933 Phone: +1-408-801-1000 OEMProducts@SanDisk.com www.sandisk.com © 2017 SanDisk – a Western Digital brand - 44 - SanDisk’s web site for www.sandisk.com DOC-56-34-01508
SDINBDG4-32G 价格&库存
很抱歉,暂时无法提供与“SDINBDG4-32G”相匹配的价格&库存,您可以联系我们找货
SDINBDG4-32G
    • 1+335.58840
    • 30+304.18200
