XL CONNECTOR
5.0mm pitch/Disconnectable Crimp style Wire-to-wire connectors
Specifications –––––––––––––––––––
• Current rating: 10A AC, DC max.
• Voltage rating: 300V AC, DC max.
• Temperature range: -25˚C to +90˚C
(including temperature rise in applying
electrical current)
• Contact resistance: Initial value/7m Ω max.
After environmental testing/10m Ω max.
• Insulation resistance:
1,000M Ω min.
• Withstanding voltage: 1,500V AC/minute
• Applicable wire: AWG #26 to #16
0.13 to 1.25mm2
• Applicable panel thickness: 0.7 to 2.4mm
* Compliant with RoHS.
* Refer to "General Instruction and Notice when using
Terminals and Connectors" at the end of this catalog.
* Contact JST for details.
Note: The current rating varies depending on the number of circuits and the
wire size used in each connector.
The table below lists the current rating as a function of the number of
circuits and wire size.
Current unit: A
Wire size (AWG)
Circuits
XL connectors are reliable wire-to-wire
connectors, used for such electrical and
electronic equipment as home appliances,
vending machines, and office machines.
#16
#18
#20
#22
#24
#26
2
10
6
5
4
3
3
4
9
5
4
3
3
2
8
6
4
3
3
2
2
12
6
4
3
3
2
2
16
5
3
2
2
1
1
Standards ––––––––––––––––––––––
• Reliable housing construction
• Easy contact insertion
• Box-shaped contact
• Two kinds of connections
Recognized E60389
1 Certified LR20812
2 R75052
Panel layout and Assembly layout
17.7
30.9
Shape I
Shape II
6.5
B
B
Circuits
2
D
C
D
C
7.8
4
8
2.7
12
A
A
16
Receptacle
housing
Panel Panel hole dimensions (mm) General tolerance ±0.13
Applicable panel
hole
thickness (mm)
A
B
C
D
shape
XLR-02V
XLR-04V
XLR-08V
XLR-12V
XLR-16V
1
11.5
4.4
13.95
13.2
2
16.5
5.2
13.95
13.2
2
26.5
5.2
13.95
13.2
2
36.5
5.2
13.95
13.2
2
46.5
5.2
13.95
13.2
0.7∼2.4
Note: 1. Punch holes in the panel according to the figures and table shown above. Burrs must be removed.
2. The strength of the panel must be considered when punching two or more holes.
3. The connector must be inserted from the same side as the hole is punched.
1
XL CONNECTOR
Contact
Applicable wire
Model No.
Pin contact
1.85
Pin contact
AWG #
SYM-01T-P0.7 SXF-01T-P0.7 0.13∼0.5
SYM-41T-P0.7 SXF-41T-P0.7
18.4
1.2 2.5
26∼20
0.5 ∼1.25
20∼16
0.3+0.3∼
0.5+0.5
22+22∼
20+20
Insulation O.D. Q'ty / reel
(mm)
Pin contact
SYM-01T-P0.7
:6,000
SYM-41T-P0.7
1.9∼3.1
:4,000
Socket
1.7+1.7∼ contact:
2.0+2.0 :3,000
1.3∼2.7
Material and Finish
0.65
1.1
mm2
Socket contact
Phosphor bronze, tin-plated (reflow treatment)
RoHS compliance
Note: 1. Contact JST for special products.
2. Contact JST for brass products.
Socket contact
3.0
SYM-01T-P0.7
12.0
4.0
2.5 1.2
SXF-01T-P0.7
1.1
AP-K2N
SYM-41T-P0.7
3.35
Applicator
Dies
Crimp applicator with dies
MKS-L
MK/SYM-01-07
APLMK SYM01-07
MKS-L
MK/SXF-01-07
APLMK SXF01-07
Crimping
machine Crimp applicator
Contact
SXF-41T-P0.7
MKS-L
MK/SYM-41-07
APLMK SYM41-07
MKS-L
MK/SXF-41-07
APLMK SXF41-07
Contact position location numbers
Contact position numbers are stamped
Receptacle housing
Plug housing
Receptacle housing
Plug housing
8
16
8
16
14
6
12
11
10
10
2
11
3
12
JST
4
4
JST
13
2 4
1 3
13
1
3
JST
2
1
JST
14
1
1 2
5
4
2
7
15
JST
3
1
4 2
3 1
15
2
4
JST 2
2 1
6
9
7
1
11
10
8
7
9
2
3
JST
8
7
6
5
1
6
5
4
3
2
1
4
8
7
4
3
8
7
6
5
4
3
2
1
2
JST
8
1
16
15
14
13
12
11
10
9
1
3
9
JST
5
6
5
4
3
2
1
JST
10
2
6
2
12
11
10
9
8
7
5
1
11
7
4
3
2
1
9
12
1
6
12
4
8
8
7
6
5
6
5
4
3
2
1
12
11
10
9
8
7
8
7
6
5
4
3
2
1
16
15
14
13
12
11
10
9
XL CONNECTOR
Housing
Material: PA 66, UL94V-0, white
Circuits
Voltage
rating
Current
rating
Receptacle housing(for pin contact)
XLR-02V
XLP-02V
Q'ty /
bag
10A
6.2
300V
Q'ty /
bag
6.2
2
Plug housing(for socket contact)
500
25.4
XLR-04V
9A
XLP-04V
Q'ty /
bag
11.2
300V
18.7
11.2
4
Q'ty /
bag
500
25.4
Q'ty /
bag
500
18.7
XLP-08V
Q'ty /
bag
21.2
6A
12.35
21.2
300V
5.5
12.9
XLR-08V
8
500
5.5
12.35
12.9
500
500
5.5
25.4
XLR-12V
6A
XLP-12V
Q'ty /
bag
31.2
300V
Q'ty /
bag
18.7
31.2
12
12.35
12.9
200
200
5.5
25.4
12.9
XLR-16V
5A
XLP-16V
Q'ty /
bag
41.2
300V
Q'ty /
bag
18.7
41.2
16
12.35
100
200
5.5
25.4
12.9
12.35
18.7
RoHS compliance
Note: 1. XL connectors with any number of circuits can be used either panel mounted or free hanging. See "Panel layout" for the hole dimensions.
2. Contact JST for special products.
3
很抱歉,暂时无法提供与“SYM-01T-P0.7”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 500+0.12440
- 1000+0.12200
- 国内价格
- 20+0.25672
- 200+0.20207
- 1200+0.17162
- 国内价格 香港价格
- 6000+0.279236000+0.03629
